[GRASS-SVN] r47476 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sun Aug 7 09:07:55 EDT 2011
Author: martinl
Date: 2011-08-07 06:07:55 -0700 (Sun, 07 Aug 2011)
New Revision: 47476
grass/trunk/gui/wxpython/gui_modules/dbm.py
wxGUI/dbm: fix OnCloseWindow
standardize names of hidden methods
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py 2011-08-07 12:55:41 UTC (rev 47475)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py 2011-08-07 13:07:55 UTC (rev 47476)
@@ -636,9 +636,9 @@
if not self.editable:
self.notebook.GetPage(self.notebook.GetPageCount()-1).Enable(False)
- self.__createBrowsePage()
- self.__createManageTablePage()
- self.__createManageLayerPage()
+ self._createBrowsePage()
+ self._createManageTablePage()
+ self._createManageLayerPage()
if selection:
wx.CallAfter(self.notebook.SetSelectionByName, selection) # select browse tab
@@ -655,15 +655,16 @@
self.notebook.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CHANGED, self.OnPageChanged)
self.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CHANGED, self.OnLayerPageChanged, self.browsePage)
self.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CHANGED, self.OnLayerPageChanged, self.manageTablePage)
+ self.Bind(wx.EVT_CLOSE, self.OnCloseWindow)
# do layout
- self.__layout()
+ self._layout()
# self.SetMinSize(self.GetBestSize())
self.SetSize((680, 550)) # FIXME hard-coded size
self.SetMinSize(self.GetSize())
- def __createBrowsePage(self, onlyLayer=-1):
+ def _createBrowsePage(self, onlyLayer=-1):
"""!Create browse tab page"""
for layer in self.mapDBInfo.layers.keys():
if onlyLayer > 0 and layer != onlyLayer:
@@ -810,7 +811,7 @@
except (IndexError, KeyError):
self.layer = None
- def __createManageTablePage(self, onlyLayer=-1):
+ def _createManageTablePage(self, onlyLayer=-1):
"""!Create manage page (create/link and alter tables)"""
@@ -848,7 +849,7 @@
tableSizer = wx.StaticBoxSizer(tableBox, wx.VERTICAL)
- list = self.__createTableDesc(panel, table)
+ list = self._createTableDesc(panel, table)
list.Bind(wx.EVT_COMMAND_RIGHT_CLICK, self.OnTableRightUp) #wxMSW
list.Bind(wx.EVT_RIGHT_UP, self.OnTableRightUp) #wxGTK
self.layerPage[layer]['tableData'] = list.GetId()
@@ -980,7 +981,7 @@
except IndexError:
self.layer = None
- def __createTableDesc(self, parent, table):
+ def _createTableDesc(self, parent, table):
"""!Create list with table description"""
list = TableListCtrl(parent=parent, id=wx.ID_ANY,
table=self.mapDBInfo.tables[table],
@@ -992,7 +993,7 @@
return list
- def __createManageLayerPage(self):
+ def _createManageLayerPage(self):
"""!Create manage page"""
splitterWin = wx.SplitterWindow(parent=self.manageLayerPage, id=wx.ID_ANY)
splitterWin.SetMinimumPaneSize(100)
@@ -1010,7 +1011,7 @@
label=" %s " % _("List of layers"))
layerSizer = wx.StaticBoxSizer(layerBox, wx.VERTICAL)
- self.layerList = self.__createLayerDesc(panelList)
+ self.layerList = self._createLayerDesc(panelList)
self.layerList.Bind(wx.EVT_COMMAND_RIGHT_CLICK, self.OnLayerRightUp) #wxMSW
self.layerList.Bind(wx.EVT_RIGHT_UP, self.OnLayerRightUp) #wxGTK
@@ -1045,7 +1046,7 @@
splitterWin.SplitHorizontally(panelList, panelManage, 100)
splitterWin.Fit()
- def __createLayerDesc(self, parent):
+ def _createLayerDesc(self, parent):
"""!Create list of linked layers"""
list = LayerListCtrl(parent=parent, id=wx.ID_ANY,
layers=self.mapDBInfo.layers)
@@ -1057,7 +1058,7 @@
return list
- def __layout(self):
+ def _layout(self):
"""!Do layout"""
# frame body
mainSizer = wx.BoxSizer(wx.VERTICAL)
@@ -1999,10 +2000,12 @@
def OnCloseWindow(self, event):
"""!Cancel button pressed"""
- self.Close()
if self.parent and self.parent.GetName() == 'LayerManager':
# deregister ATM
self.parent.dialogs['atm'].remove(self)
+ if not isinstance(event, wx.CloseEvent):
+ self.Destroy()
event.Skip()
@@ -2136,9 +2139,9 @@
if layer in self.mapDBInfo.layers.keys():
# 'browse data' page
- self.__createBrowsePage(layer)
+ self._createBrowsePage(layer)
# 'manage tables' page
- self.__createManageTablePage(layer)
+ self._createManageTablePage(layer)
# set current page selection
self.notebook.SetSelectionByName('layers')
@@ -2349,20 +2352,20 @@
caption=_("Warning"),
style=wx.OK | wx.ICON_WARNING | wx.CENTRE)
- self.defaultTables = self.__getTables(self.defaultConnect['driver'],
+ self.defaultTables = self._getTables(self.defaultConnect['driver'],
self.defaultConnect['database'])
try:
- self.defaultColumns = self.__getColumns(self.defaultConnect['driver'],
+ self.defaultColumns = self._getColumns(self.defaultConnect['driver'],
self.defaultConnect['database'],
self.defaultTables[0])
except IndexError:
self.defaultColumns = []
- self.__createAddPage()
- self.__createDeletePage()
- self.__createModifyPage()
+ self._createAddPage()
+ self._createDeletePage()
+ self._createModifyPage()
- def __createAddPage(self):
+ def _createAddPage(self):
"""!Add new layer"""
self.addPanel = wx.Panel(parent=self, id=wx.ID_ANY)
self.AddPage(page=self.addPanel, text=_("Add layer"))
@@ -2553,7 +2556,7 @@
self.addPanel.SetSizer(pageSizer)
pageSizer.Fit(self.addPanel)
- def __createDeletePage(self):
+ def _createDeletePage(self):
"""!Delete layer"""
self.deletePanel = wx.Panel(parent=self, id=wx.ID_ANY)
self.AddPage(page=self.deletePanel, text=_("Remove layer"))
@@ -2621,7 +2624,7 @@
self.deletePanel.SetSizer(pageSizer)
- def __createModifyPage(self):
+ def _createModifyPage(self):
"""!Modify layer"""
self.modifyPanel = wx.Panel(parent=self, id=wx.ID_ANY)
self.AddPage(page=self.modifyPanel, text=_("Modify layer"))
@@ -2676,7 +2679,7 @@
database = self.mapDBInfo.layers[layer]['database']
table = self.mapDBInfo.layers[layer]['table']
- listOfColumns = self.__getColumns(driver, database, table)
+ listOfColumns = self._getColumns(driver, database, table)
self.modifyLayerWidgets['driver'][1].SetStringSelection(driver)
self.modifyLayerWidgets['database'][1].SetValue(database)
if table in self.modifyLayerWidgets['table'][1].GetItems():
@@ -2731,7 +2734,7 @@
self.modifyPanel.SetSizer(pageSizer)
- def __getTables(self, driver, database):
+ def _getTables(self, driver, database):
"""!Get list of tables for given driver and database"""
tables = []
@@ -2755,7 +2758,7 @@
return tables
- def __getColumns(self, driver, database, table):
+ def _getColumns(self, driver, database, table):
"""!Get list of column of given table"""
columns = []
@@ -2782,7 +2785,7 @@
winTable = self.addLayerWidgets['table'][1]
winKey = self.addLayerWidgets['key'][1]
- tables = self.__getTables(driver, database)
+ tables = self._getTables(driver, database)
winTable.SetItems(tables)
winTable.SetSelection(0)
@@ -2803,7 +2806,7 @@
table = event.GetString()
win = self.addLayerWidgets['key'][1]
- cols = self.__getColumns(driver, database, table)
+ cols = self._getColumns(driver, database, table)
win.SetItems(cols)
win.SetSelection(0)
@@ -2818,14 +2821,14 @@
driver.SetStringSelection(self.defaultConnect['driver'])
database.SetValue(self.defaultConnect['database'])
- tables = self.__getTables(self.defaultConnect['driver'],
+ tables = self._getTables(self.defaultConnect['driver'],
table.SetItems(tables)
table.SetSelection(0)
if len(tables) == 0:
key.SetItems([])
else:
- cols = self.__getColumns(self.defaultConnect['driver'],
+ cols = self._getColumns(self.defaultConnect['driver'],
tables[0])
key.SetItems(cols)
@@ -2867,12 +2870,12 @@
# update list of tables
tableList = self.addLayerWidgets['table'][1]
- tableList.SetItems(self.__getTables(driver, database))
+ tableList.SetItems(self._getTables(driver, database))
tableList.SetStringSelection(table)
# update key column selection
keyList = self.addLayerWidgets['key'][1]
- keyList.SetItems(self.__getColumns(driver, database, table))
+ keyList.SetItems(self._getColumns(driver, database, table))
keyList.SetStringSelection(key)
event.Skip()
@@ -2960,7 +2963,7 @@
# update dialog
@@ -2991,7 +2994,7 @@
driver = self.mapDBInfo.layers[layer]['driver']
self.modifyLayerWidgets['table'][1].SetStringSelection(table)
