[GRASS-SVN] r47489 - grass/trunk/display/d.vect
svn_grass at osgeo.org
Sun Aug 7 14:54:30 EDT 2011
Author: martinl
Date: 2011-08-07 11:54:29 -0700 (Sun, 07 Aug 2011)
New Revision: 47489
grass/trunk/display/d.vect/main.c
d.vect: standardize options
wcolumn -> width_column
wscale -> width_scale
rot_column -> rotation_column
Modified: grass/trunk/display/d.vect/main.c
--- grass/trunk/display/d.vect/main.c 2011-08-07 18:29:41 UTC (rev 47488)
+++ grass/trunk/display/d.vect/main.c 2011-08-07 18:54:29 UTC (rev 47489)
@@ -192,13 +192,13 @@
width_opt->description = _("Line width");
wcolumn_opt = G_define_standard_option(G_OPT_DB_COLUMN);
- wcolumn_opt->key = "wcolumn";
+ wcolumn_opt->key = "width_column";
wcolumn_opt->guisection = _("Lines");
wcolumn_opt->description =
_("Name of column for line widths (these values will be scaled by wscale)");
wscale_opt = G_define_option();
- wscale_opt->key = "wscale";
+ wscale_opt->key = "width_scale";
wscale_opt->type = TYPE_DOUBLE;
wscale_opt->answer = "1";
wscale_opt->guisection = _("Lines");
@@ -232,7 +232,7 @@
_("Name of numeric column containing symbol size");
rotcolumn_opt = G_define_standard_option(G_OPT_DB_COLUMN);
- rotcolumn_opt->key = "rot_column";
+ rotcolumn_opt->key = "rotation_column";
rotcolumn_opt->guisection = _("Symbols");
rotcolumn_opt->label =
_("Name of numeric column containing symbol rotation angle");
