[GRASS-SVN] r47492 - grass/trunk/display/d.vect
Sun Aug 7 15:51:52 EDT 2011
Author: martinl
Date: 2011-08-07 12:51:52 -0700 (Sun, 07 Aug 2011)
New Revision: 47492
   grass/trunk/display/d.vect/lines.c
   grass/trunk/display/d.vect/main.c
d.vect: -z flag works for all vector types
Modified: grass/trunk/display/d.vect/lines.c
--- grass/trunk/display/d.vect/lines.c	2011-08-07 19:23:28 UTC (rev 47491)
+++ grass/trunk/display/d.vect/lines.c	2011-08-07 19:51:52 UTC (rev 47492)
@@ -76,9 +76,13 @@
 	G_warning(_("Unable to display lines by id, topology not available. "
 		    "Please try to rebuild topology using "
 		    "v.build or v.build.all."));
-	return 1;
+    if (z_color_flag && !Vect_is_3d(Map)) {
+	G_warning(_("Vector map is not 3D. Unable to colorize features based on z-coordinates."));
+	z_color_flag = 0;
     var_size = size;
     rotation = 0.0;
     nerror_rgb = 0;
@@ -191,7 +195,7 @@
 	/* z height colors */
-	if (z_color_flag && Vect_is_3d(Map)) {
+	if (z_color_flag) {
 	    struct bound_box box;
 	    double zval;
 	    struct Colors colors;
Modified: grass/trunk/display/d.vect/main.c
--- grass/trunk/display/d.vect/main.c	2011-08-07 19:23:28 UTC (rev 47491)
+++ grass/trunk/display/d.vect/main.c	2011-08-07 19:51:52 UTC (rev 47492)
@@ -355,7 +355,7 @@
     zcol_flag = G_define_flag();
     zcol_flag->key = 'z';
-    zcol_flag->description = _("Colorize polygons according to z height");
+    zcol_flag->description = _("Colorize features according to z-coordinate");
     zcol_flag->guisection = _("Colors");
     sqrt_flag = G_define_flag();
@@ -525,13 +525,14 @@
     D_save_command(G_recreate_command());
     D_close_driver();
-    G_done_msg(" ");
     Vect_close(&Map);
     Vect_destroy_cat_list(Clist);
-    if (stat != 0)
+    if (stat != 0) {
+	G_fatal_error(_("Rendering failed"));
 	exit(EXIT_FAILURE);
+    G_done_msg(" ");
     exit(EXIT_SUCCESS);
