[GRASS-SVN] r47495 - grass/trunk/display/d.vect
svn_grass at osgeo.org
Sun Aug 7 15:59:22 EDT 2011
Author: martinl
Date: 2011-08-07 12:59:22 -0700 (Sun, 07 Aug 2011)
New Revision: 47495
grass/trunk/display/d.vect/lines.c
d.vect: don't call Vect_get_map_box() for every feature in the loop
Modified: grass/trunk/display/d.vect/lines.c
--- grass/trunk/display/d.vect/lines.c 2011-08-07 19:53:42 UTC (rev 47494)
+++ grass/trunk/display/d.vect/lines.c 2011-08-07 19:59:22 UTC (rev 47495)
@@ -65,7 +65,9 @@
int width;
SYMBOL *Symb;
double var_size, rotation;
+ struct bound_box box;
+ struct Colors colors;
Symb = NULL;
custom_rgb = FALSE;
cv_rgb = cv_width = cv_size = cv_rot = NULL;
@@ -78,11 +80,17 @@
"v.build or v.build.all."));
- if (z_color_flag && !Vect_is_3d(Map)) {
- G_warning(_("Vector map is not 3D. Unable to colorize features based on z-coordinates."));
- z_color_flag = 0;
+ if (z_color_flag) {
+ if (!Vect_is_3d(Map)) {
+ G_warning(_("Vector map is not 3D. Unable to colorize features based on z-coordinates."));
+ z_color_flag = 0;
+ else {
+ Vect_get_map_box(Map, &box);
+ Rast_make_fp_colors(&colors, z_style, box.B, box.T);
var_size = size;
rotation = 0.0;
nerror_rgb = 0;
@@ -196,20 +204,11 @@
/* z height colors */
if (z_color_flag) {
- struct bound_box box;
- double zval;
- struct Colors colors;
- Vect_get_map_box(Map, &box);
- zval = Points->z[0];
- G_debug(3, "display line %d, cat %d, x: %f, y: %f, z: %f", line,
- cat, Points->x[0], Points->y[0], Points->z[0]);
custom_rgb = TRUE;
- Rast_make_fp_colors(&colors, z_style, box.B, box.T);
- Rast_get_color(&zval, &red, &grn, &blu, &colors, DCELL_TYPE);
- G_debug(3, "b %d, g: %d, r %d", blu, grn, red);
+ Rast_get_color(&Points->z[0], &red, &grn, &blu, &colors, DCELL_TYPE);
+ G_debug(3, "\tb: %d, g: %d, r: %d", blu, grn, red);
if (table_colors_flag) {
/* only first category */
Vect_cat_get(Cats,
