[GRASS-SVN] r47511 - grass/trunk/gui/wxpython/gui_modules
Tue Aug 9 14:07:37 EDT 2011
Author: annakrat
Date: 2011-08-09 11:07:37 -0700 (Tue, 09 Aug 2011)
New Revision: 47511
   grass/trunk/gui/wxpython/gui_modules/colorrules.py
   grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
   grass/trunk/gui/wxpython/gui_modules/preferences.py
   grass/trunk/gui/wxpython/gui_modules/workspace.py
   grass/trunk/gui/wxpython/gui_modules/wxnviz.py
wxNviz: thematic mapping for lines
Modified: grass/trunk/gui/wxpython/gui_modules/colorrules.py
--- grass/trunk/gui/wxpython/gui_modules/colorrules.py	2011-08-09 17:16:13 UTC (rev 47510)
+++ grass/trunk/gui/wxpython/gui_modules/colorrules.py	2011-08-09 18:07:37 UTC (rev 47511)
@@ -75,9 +75,16 @@
         if self.mapType == 'vector' and self.columnType == 'color':
             self.label = wx.StaticText(parent, id = wx.ID_ANY, label =  _("Set color for attribute values:"))
         elif self.mapType == 'vector' and self.columnType == 'size':
-            self.label = wx.StaticText(parent, id = wx.ID_ANY, label = _("Set size for attribute values:"))
+            if self.parent.vectorType == 'points':
+                label = label = _("Set size for attribute values:")
+            else:
+                label = label = _("Set width for attribute values:")
+            self.label = wx.StaticText(parent, id = wx.ID_ANY, label = label)
+        #  determines how many rules should be added
         self.numRules = wx.SpinCtrl(parent, id = wx.ID_ANY,
                                     min = 1, max = 1e6)
+        # add rules
         self.btnAdd = wx.Button(parent, id = wx.ID_ADD)
         self.btnAdd.Bind(wx.EVT_BUTTON, self.OnAddRules)
@@ -212,7 +219,11 @@
     def SetVectorRule(self, num, vals):
         """!Set vector rule"""
         tc = self.mainPanel.FindWindowById(num)
-        if self.properties['source_rgb'] == '' or self.properties['rgb'] == '':
+        if self.columnType == 'color':
+            source, target = 'source_rgb', 'rgb'
+        else:
+            source, target = 'source_size', 'size'
+        if self.properties[source] == '' or self.properties[target] == '':
             tc.SetValue('')
             gcmd.GMessage(parent = self,
                           message = _("Please select attribute column "
@@ -1097,6 +1108,9 @@
             self.preview.EraseMap()
             return
+        busy = wx.BusyInfo(message = _("Please wait, loading data from attribute table..."),
+                           parent = self)
+        wx.Yield()
         if self.inmap:
             outFile = tempfile.NamedTemporaryFile(mode='w+b')
             sep = '|'
@@ -1111,6 +1125,7 @@
         else:
             self.OnPreview(event)
+            busy.Destroy()
             return
         if type == 'color':
             ctype = self.dbInfo.GetTableDesc(self.properties['table'])\
@@ -1150,6 +1165,8 @@
         else:
             rulesPanel.Clear()
+        busy.Destroy()
     def SetRangeLabel(self, type, ctype, minim, maxim):
         """!Set labels with info about attribute column range"""
         if type == 'color':
@@ -1237,9 +1254,10 @@
 ##            return False
 class ThematicVectorTable(VectorColorTable):
-    def __init__(self, parent, **kwargs):
+    def __init__(self, parent, vectorType, **kwargs):
         """!Dialog for interactively entering color/size rules
             for vector maps for thematic mapping in nviz"""
+        self.vectorType = vectorType
         VectorColorTable.__init__(self, parent = parent, **kwargs)
         # additional bingings
@@ -1251,6 +1269,7 @@
         self.SetTitle(_("Thematic mapping for vector map in 3D view"))
     def UpdateDialog(self):
         """!Update dialog according to selected map"""
         VectorColorTable.UpdateDialog(self)
@@ -1410,7 +1429,12 @@
         """!Create part of dialog with layer/column selection"""
         layer_label = wx.StaticText(parent, id = wx.ID_ANY, label = _('Layer:'))
         self.rgb_check = wx.CheckBox(parent, id = wx.ID_ANY, label = _('Use color for thematic mapping:'))
-        self.size_check = wx.CheckBox(parent, id = wx.ID_ANY, label = _('Use size for thematic mapping:'))
+        if self.vectorType == 'points':
+            label = _('Use symbol size for thematic mapping:')
+        else:
+            label = _('Use line width for thematic mapping:')
+        self.size_check = wx.CheckBox(parent, id = wx.ID_ANY, label = label)
         self.rgb_check.SetValue(True)
         self.size_check.SetValue(True)
@@ -1420,8 +1444,12 @@
                                          label = _('Attribute column:'))
         rgb_col_label = wx.StaticText(parent, id = wx.ID_ANY,
                                            label = _('RGB color column:'))
-        size_col_label = wx.StaticText(parent, id = wx.ID_ANY,
-                                           label = _('Size column:'))
+            label = _('Symbol size column:')
+        else:
+            label = _('Line with column:')
+        size_col_label = wx.StaticText(parent, id = wx.ID_ANY, label = label)
         self.rgb_range_label = wx.StaticText(parent, id = wx.ID_ANY)
         self.size_range_label = wx.StaticText(parent, id = wx.ID_ANY)
         cb_size = (150, -1)
@@ -1435,8 +1463,13 @@
         self.btn_add_size = wx.Button(parent, id = wx.ID_ANY,
                                              label = _('Add column'))
         self.btn_add_RGB.SetToolTipString(_("Add GRASSRGB column to current attribute table."))
-        self.btn_add_size.SetToolTipString(_("Add size column to current attribute table."))
+            label = _("Add size column to current attribute table.")
+        else:
+            label = _("Add width column to current attribute table.")
+        self.btn_add_size.SetToolTipString(label)
         # layout
         inputBox = wx.StaticBox(parent = parent, id = wx.ID_ANY,
                                 label = " %s " % _("Select vector columns"))
@@ -1490,7 +1523,11 @@
     def OnAddSizeColumn(self, event):
         """!Add size column if it doesn't exist"""
-        name = 'GRASSSIZE'
+            name = 'GRASSSIZE'
+        else:
+            name = 'GRASSWIDTH'
         ret = gcmd.RunCommand('v.db.addcolumn',
                                map = self.inmap,
                               layer = self.properties['layer'],
@@ -1526,8 +1563,13 @@
                     '-a',
                    'map=%s' % self.inmap,
                    'type=point,line,boundary,area']
         if self.size_check.IsChecked() and self.properties["size"]:
-            cmdlist.append('size_column=%s' % self.properties["size"])
+                cmdlist.append('size_column=%s' % self.properties["size"])
+            else:
+                cmdlist.append('width_column=%s' % self.properties["size"])
         if self.rgb_check.IsChecked() and self.properties["rgb"]:
             cmdlist.append('rgb_column=%s' % self.properties["rgb"])
         ltype = 'vector'
@@ -1544,17 +1586,18 @@
         data = self.parent.GetLayerData(nvizType = 'vector')
         data['vector']['points']['thematic']['layer'] = int(self.properties['layer'])
         if self.size_check.IsChecked() and self.properties['size']:
-            data['vector']['points']['thematic']['sizecolumn'] = self.properties['size']
+            data['vector'][self.vectorType]['thematic']['sizecolumn'] = self.properties['size']
         else:
-            data['vector']['points']['thematic']['sizecolumn'] = None
+            data['vector'][self.vectorType]['thematic']['sizecolumn'] = None
         if self.rgb_check.IsChecked() and self.properties['rgb']:
-            data['vector']['points']['thematic']['rgbcolumn'] = self.properties['rgb']
+            data['vector'][self.vectorType]['thematic']['rgbcolumn'] = self.properties['rgb']
         else:
-            data['vector']['points']['thematic']['rgbcolumn'] = None
+            data['vector'][self.vectorType]['thematic']['rgbcolumn'] = None
-        data['vector']['points']['thematic']['update'] = None
+        data['vector'][self.vectorType]['thematic']['update'] = None
         event = wxUpdateProperties(data = data)
         wx.PostEvent(self.parent.mapWindow, event)
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py	2011-08-09 17:16:13 UTC (rev 47510)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py	2011-08-09 18:07:37 UTC (rev 47511)
@@ -1540,7 +1540,16 @@
             self._display.SetVectorLineHeight(id,
                                               data['height']['value'])
             data['height'].pop('update')
+        # thematic
+        if 'update' in data['thematic']:
+            if data['thematic']['use']:
+                self._display.SetLinesStyleThematic(id = id, layer = data['thematic']['layer'],
+                                               color = data['thematic']['rgbcolumn'],
+                                               width = data['thematic']['sizecolumn'])
+            else:
+                self._display.UnsetLinesStyleThematic(id = id)
+            data['thematic'].pop('update')
         # surface
         if 'surface' in data['mode'] and 'update' in data['mode']:
             for item in range(len(data['mode']['surface']['value'])):
@@ -1590,11 +1599,11 @@
         # thematic
-                self._display.SetStyleThematic(id = id, layer = data['thematic']['layer'],
+                self._display.SetPointsStyleThematic(id = id, layer = data['thematic']['layer'],
                                                size = data['thematic']['sizecolumn'])
             else:
-                self._display.UnsetStyleThematic(id = id)
+                self._display.UnsetPointsStyleThematic(id = id)
         # surface
@@ -1890,7 +1899,7 @@
         subcmd += "height=%d " % (self.iview['height']['value'])
         subcmd += "perspective=%d " % (self.view['persp']['value'])
         subcmd += "twist=%d " % (self.view['twist']['value'])
-        subcmd += "zexag=%d " % (self.view['z-exag']['value'])
+        subcmd += "zexag=%d " % (self.view['z-exag']['value'] * self.iview['z-exag']['original'])
         subcmd += "focus=%d,%d,%d " % (self.iview['focus']['x'],self.iview['focus']['y'],self.iview['focus']['z'])
         cmd += subcmd
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_tools.py	2011-08-09 17:16:13 UTC (rev 47510)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_tools.py	2011-08-09 18:07:37 UTC (rev 47511)
@@ -1145,10 +1145,33 @@
         gridSizer.Add(item = color, pos = (0, 4), flag = wx.ALIGN_CENTER_VERTICAL |
                       wx.ALIGN_LEFT)
+        # thematic mapping
+        self.win['vector']['lines']['thematic'] = {}
+        checkThematic = wx.CheckBox(parent = panel, id = wx.ID_ANY,
+                                         label = _("use thematic mapping for vector lines"))
+        self.win['vector']['lines']['thematic']['check'] = checkThematic.GetId()
+        checkThematic.Bind(wx.EVT_CHECKBOX, self.OnCheckThematic)
+        checkThematic.SetValue(False)
+        hSizer = wx.BoxSizer(wx.HORIZONTAL)
+        hSizer.Add(item = checkThematic, flag = wx.ALIGN_CENTER_VERTICAL,
+                    border = 5)
+        setThematic = wx.Button(parent = panel, id = wx.ID_ANY,
+                                         label = _("Set options..."))
+        self.win['vector']['lines']['thematic']['button'] = setThematic.GetId()
+        setThematic.Bind(wx.EVT_BUTTON, self.OnSetThematic)
+        hSizer.Add(item = wx.Size(-1, -1), proportion = 1)
+        hSizer.Add(item = setThematic, flag = wx.ALIGN_CENTER_VERTICAL|wx.LEFT,
+                    border = 5, proportion = 0)
+        gridSizer.Add(item = hSizer, flag = wx.ALIGN_CENTER_VERTICAL | wx.EXPAND,
+                      pos = (1, 1), span = (1, 5))
         # display
         gridSizer.Add(item = wx.StaticText(parent = panel, id = wx.ID_ANY,
                                          label = _("Display")),
-                      pos = (1, 0), flag = wx.ALIGN_CENTER_VERTICAL |
+                      pos = (2, 0), flag = wx.ALIGN_CENTER_VERTICAL |
                       wx.ALIGN_LEFT)
         display = wx.Choice (parent = panel, id = wx.ID_ANY, size = (-1, -1),
@@ -1158,12 +1181,12 @@
         display.Bind(wx.EVT_CHOICE, self.OnVectorDisplay)
         gridSizer.Add(item = display, flag = wx.ALIGN_CENTER_VERTICAL |
-                      wx.ALIGN_LEFT|wx.EXPAND, pos = (1, 1), span = (1,4))
+                      wx.ALIGN_LEFT|wx.EXPAND, pos = (2, 1), span = (1,4))
         # height
                                          label = _("Height above surface:")),
-                      pos = (2, 5), flag = wx.ALIGN_BOTTOM|wx.EXPAND)
+                      pos = (3, 5), flag = wx.ALIGN_BOTTOM|wx.EXPAND)
         surface = wx.CheckListBox(parent = panel, id = wx.ID_ANY, size = (-1, 60),
                                   choices = [], style = wx.LB_NEEDED_SB)
@@ -1171,7 +1194,7 @@
         self.win['vector']['lines']['surface'] = surface.GetId()
         gridSizer.Add(item = surface,
-                      pos = (2, 0), span = (3, 5),
+                      pos = (3, 0), span = (3, 5),
                       flag = wx.ALIGN_CENTER_VERTICAL|wx.EXPAND)
         self._createControl(panel, data = self.win['vector']['lines'], name = 'height', size = -1,
@@ -1180,9 +1203,9 @@
         self.FindWindowById(self.win['vector']['lines']['height']['slider']).SetValue(0)
         self.FindWindowById(self.win['vector']['lines']['height']['text']).SetValue(0)
         gridSizer.Add(item = self.FindWindowById(self.win['vector']['lines']['height']['slider']),
-                      pos = (3, 5),  flag = wx.EXPAND|wx.ALIGN_RIGHT)
+                      pos = (4, 5),  flag = wx.EXPAND|wx.ALIGN_RIGHT)
         gridSizer.Add(item = self.FindWindowById(self.win['vector']['lines']['height']['text']),
-                      pos = (4, 5),
+                      pos = (5, 5),
                       flag = wx.ALIGN_CENTER)
         boxSizer.Add(item = gridSizer, proportion = 1,
@@ -3186,18 +3209,29 @@
     def OnCheckThematic(self, event):
         """!Switch on/off thematic mapping"""
-        check = self.win['vector']['points']['thematic']['check']
-        button = self.win['vector']['points']['thematic']['button']
-        if self.FindWindowById(check).GetValue():
-            checked = True
+        # can be called with no event to enable/disable button
+        if not event:
+            ids = (self.win['vector']['points']['thematic']['check'],
+                  self.win['vector']['lines']['thematic']['check'])
         else:
-            checked = False
-        self.FindWindowById(button).Enable(checked)
+            ids = (event.GetId(),)
+        for id in ids:
+            if id == self.win['vector']['points']['thematic']['check']:
+                type = 'points'
+            else:
+                type = 'lines'
+            check = self.win['vector'][type]['thematic']['check']
+            button = self.win['vector'][type]['thematic']['button']
+            if self.FindWindowById(check).GetValue():
+                checked = True
+            else:
+                checked = False
+            self.FindWindowById(button).Enable(checked)
+            data = self.GetLayerData('vector')
+            data['vector'][type]['thematic']['use'] = checked
+            data['vector'][type]['thematic']['update'] = None
-        data = self.GetLayerData('vector')
-        data['vector']['points']['thematic']['use'] = checked
         # update properties
         wx.PostEvent(self.mapWindow, event)
@@ -3207,7 +3241,11 @@
     def OnSetThematic(self, event):
         """!Set options for thematic points"""
-        ctable = colorrules.ThematicVectorTable(self)
+        if event.GetId() == self.win['vector']['points']['thematic']['button']:
+            vectorType = 'points'
+        else:
+            vectorType = 'lines'
+        ctable = colorrules.ThematicVectorTable(self, vectorType)
         ctable.CentreOnScreen()
         ctable.Show()
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py	2011-08-09 17:16:13 UTC (rev 47510)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py	2011-08-09 18:07:37 UTC (rev 47511)
@@ -525,6 +525,8 @@
                         'color' : (0, 0, 255, 255), # blue
                         'flat' : False,
                         'height' : 0,
+                        'rgbcolumn': None,
+                        'sizecolumn': None,
                     'points' : {
                         'show' : False,
Modified: grass/trunk/gui/wxpython/gui_modules/workspace.py
--- grass/trunk/gui/wxpython/gui_modules/workspace.py	2011-08-09 17:16:13 UTC (rev 47510)
+++ grass/trunk/gui/wxpython/gui_modules/workspace.py	2011-08-09 18:07:37 UTC (rev 47511)
@@ -705,7 +705,13 @@
         # height
         data['height'] = { 'value' : UserSettings.Get(group='nviz', key='vector',
                                                       subkey=['lines', 'height']) }
+        # thematic
+        data['thematic'] = {'rgbcolumn' : UserSettings.Get(group='nviz', key='vector',
+                                                      subkey=['lines', 'rgbcolumn']),
+                            'sizecolumn' : UserSettings.Get(group='nviz', key='vector',
+                                                      subkey=['lines', 'sizecolumn']),
+                            'layer': 1,
+                            'use' : False}
         if 'object' in data:
             for attrb in ('color', 'width', 'mode', 'height'):
                 data[attrb]['update'] = None
Modified: grass/trunk/gui/wxpython/gui_modules/wxnviz.py
--- grass/trunk/gui/wxpython/gui_modules/wxnviz.py	2011-08-09 17:16:13 UTC (rev 47510)
+++ grass/trunk/gui/wxpython/gui_modules/wxnviz.py	2011-08-09 18:07:37 UTC (rev 47511)
@@ -940,13 +940,21 @@
         return 1
-    def SetStyleThematic(self, id, layer, color = None, width = None, size = None, symbol = None):
+    def SetPointStyleThematic(self, id, layer, color = None, width = None, size = None, symbol = None):
         """!Set thematic style for vector points"""
         GP_set_style_thematic(id, layer, color, width, size, symbol)
+    def SetLinesStyleThematic(self, id, layer, color = None, width = None):
+        """!Set thematic style for vector lines"""
+        GV_set_style_thematic(id, layer, color, width)
-    def UnsetStyleThematic(self, id):
+    def UnsetLinesStyleThematic(self, id):
         """!Unset thematic style for vector points"""
-        GP_unset_style_thematic(id)
+        GP_unset_style_thematic(id)
+    def UnsetPointStyleThematic(self, id):
+        """!Unset thematic style for vector lines"""
+        GV_unset_style_thematic(id)
     def UnsetVectorPointSurface(self, id, surf_id):
         """!Unset reference surface of vector set (points)
