[GRASS-SVN] r47515 - grass/branches/develbranch_6/raster3d/base
    svn_grass at osgeo.org
    Tue Aug  9 17:53:44 EDT 2011
Author: neteler
Date: 2011-08-09 14:53:44 -0700 (Tue, 09 Aug 2011)
New Revision: 47515
   grass/branches/develbranch_6/raster3d/base/r3.null.main.c
Milena Nowotarska: message standardization
Modified: grass/branches/develbranch_6/raster3d/base/r3.null.main.c
--- grass/branches/develbranch_6/raster3d/base/r3.null.main.c	2011-08-09 21:53:39 UTC (rev 47514)
+++ grass/branches/develbranch_6/raster3d/base/r3.null.main.c	2011-08-09 21:53:44 UTC (rev 47515)
@@ -103,14 +103,14 @@
     cacheSize = G3d_cacheSizeEncode(G3D_USE_CACHE_XY, 1);
     if (NULL == G_find_grid3(name, ""))
-	G3d_fatalError(_("Requested 3d raster map not found"));
+	G3d_fatalError(_("3D raster map <%s> not found"), name);
     fprintf(stderr, "name %s Mapset %s \n", name, G_mapset());
     map = G3d_openCellOld(name, G_mapset(), G3D_DEFAULT_WINDOW,
 			  DCELL_TYPE, cacheSize);
     if (map == NULL)
-	G3d_fatalError(_("modifyNull: error opening map"));
+	G3d_fatalError(_("Unable to open 3D raster map <%s>"), name);
     G3d_getRegionStructMap(map, ®ion);
     G3d_getTileDimensionsMap(map, &tileX, &tileY, &tileZ);
@@ -185,9 +185,9 @@
     G3d_unlockAll(mapOut);
     if (!G3d_closeCell(map))
-	G3d_fatalError(_("modifyNull: error closing map"));
+	G3d_fatalError(_("Unable to close raster map"));
     if (!G3d_closeCell(mapOut))
-	G3d_fatalError(_("modifyNull: error closing tmp file"));
+	G3d_fatalError(_("modifyNull: Unable to close tmp file"));
