[GRASS-SVN] r47528 - in grass/trunk/raster3d: . r3.mask r3.null
Wed Aug 10 06:58:01 EDT 2011
Author: martinl
Date: 2011-08-10 03:58:01 -0700 (Wed, 10 Aug 2011)
New Revision: 47528
Added:
   grass/trunk/raster3d/r3.mask/
   grass/trunk/raster3d/r3.mask/Makefile
   grass/trunk/raster3d/r3.mask/main.c
   grass/trunk/raster3d/r3.mask/r3.mask.html
   grass/trunk/raster3d/r3.null/
   grass/trunk/raster3d/r3.null/Makefile
   grass/trunk/raster3d/r3.null/main.c
   grass/trunk/raster3d/r3.null/r3.null.html
   grass/trunk/raster3d/r3.null/test.r3.null.sh
   grass/trunk/raster3d/r3.null/test_volume_double_1.ref
   grass/trunk/raster3d/r3.null/test_volume_double_2.ref
   grass/trunk/raster3d/r3.null/test_volume_double_null_1.ref
   grass/trunk/raster3d/r3.null/test_volume_double_null_2.ref
   grass/trunk/raster3d/r3.null/test_volume_float_1.ref
   grass/trunk/raster3d/r3.null/test_volume_float_2.ref
   grass/trunk/raster3d/r3.null/test_volume_float_null_1.ref
   grass/trunk/raster3d/r3.null/test_volume_float_null_2.ref
Removed:
   grass/trunk/raster3d/base/
raster3d: split base into r3.mask and r3.null
Property changes on: grass/trunk/raster3d/r3.mask
___________________________________________________________________
Added: svn:ignore
   + OBJ.*
Added: grass/trunk/raster3d/r3.mask/Makefile
--- grass/trunk/raster3d/r3.mask/Makefile	                        (rev 0)
+++ grass/trunk/raster3d/r3.mask/Makefile	2011-08-10 10:58:01 UTC (rev 47528)
@@ -0,0 +1,10 @@
+MODULE_TOPDIR = ../..
+PGM=r3.mask
+LIBES = $(GPDELIB) $(G3DLIB) $(GISLIB)
+DEPENDENCIES = $(GPDEDEP) $(G3DDEP) $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Property changes on: grass/trunk/raster3d/r3.mask/Makefile
Added: svn:mime-type
   + text/x-makefile
Added: svn:eol-style
   + native
Copied: grass/trunk/raster3d/r3.mask/main.c (from rev 47526, grass/trunk/raster3d/base/r3.mask.main.c)
--- grass/trunk/raster3d/r3.mask/main.c	                        (rev 0)
+++ grass/trunk/raster3d/r3.mask/main.c	2011-08-10 10:58:01 UTC (rev 47528)
@@ -0,0 +1,170 @@
+* MODULE:       r3.mask
+* AUTHOR(S):    Roman Waupotitsch, Michael Shapiro, Helena Mitasova,
+*		Bill Brown, Lubos Mitas, Jaro Hofierka
+* PURPOSE:      Establishes the current working 3D raster mask.
+* COPYRIGHT:    (C) 2005 by the GRASS Development Team
+*               This program is free software under the GNU General Public
+*               License (>=v2). Read the file COPYING that comes with GRASS
+*               for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/G3d.h>
+#include <grass/glocale.h>
+typedef struct
+    struct Option *map, *maskVals;
+} paramType;
+static paramType params;
+void getParams(char **name, d_Mask ** maskRules)
+    *name = params.map->answer;
+    G3d_parse_vallist(params.maskVals->answers, maskRules);
+#define MAX(a,b) (a > b ? a : b)
+static void makeMask(char *name, d_Mask * maskRules)
+    void *map, *mask;
+    G3D_Region region;
+    int tileX, tileY, tileZ, x, y, z, cacheSize;
+    double value;
+    float floatNull;
+    cacheSize = G3d_cacheSizeEncode(G3D_USE_CACHE_XY, 1);
+    if (NULL == G_find_grid3(name, ""))
+	G3d_fatalError(_("3D raster map <%s> not found"), name);
+    map = G3d_openCellOld(name, G_mapset(), G3D_DEFAULT_WINDOW,
+			  DCELL_TYPE, cacheSize);
+    if (map == NULL)
+	G3d_fatalError(_("Unable to open 3D raster map <%s>"), name);
+    G3d_getRegionStructMap(map, &region);
+    G3d_getTileDimensionsMap(map, &tileX, &tileY, &tileZ);
+    mask = G3d_openNewParam(G3d_maskFile(), FCELL_TYPE, cacheSize,
+			    &region, FCELL_TYPE, G3D_NO_LZW, G3D_USE_RLE, 0,
+			    tileX, tileY, tileZ);
+    if (mask == NULL)
+	G3d_fatalError(_("Unable to open 3D raster mask file"));
+    G3d_minUnlocked(map, G3D_USE_CACHE_X);
+    G3d_autolockOn(map);
+    G3d_unlockAll(map);
+    G3d_minUnlocked(mask, G3D_USE_CACHE_X);
+    G3d_autolockOn(mask);
+    G3d_unlockAll(mask);
+    G3d_setNullValue(&floatNull, 1, FCELL_TYPE);
+    for (z = 0; z < region.depths; z++) {
+	if ((z % tileZ) == 0) {
+	for (y = 0; y < region.rows; y++)	/* We count from north to south in the cube coordinate system */
+	    for (x = 0; x < region.cols; x++) {
+		value = G3d_getDoubleRegion(map, x, y, z);
+		if (G3d_mask_d_select((DCELL *) & value, maskRules))
+		    G3d_putFloat(mask, x, y, z, (float)floatNull);	/* mask-out value */
+		else
+		    G3d_putFloat(mask, x, y, z, (float)0.0);	/* not mask-out value */
+	    if (!G3d_flushTilesInCube
+		(mask, 0, 0, MAX(0, z - tileZ), region.rows - 1,
+		 region.cols - 1, z))
+		G3d_fatalError(_("makeMask: error flushing tiles in cube"));
+    if (!G3d_flushAllTiles(mask))
+	G3d_fatalError(_("makeMask: error flushing all tiles"));
+    G3d_autolockOff(map);
+    G3d_autolockOff(mask);
+    if (!G3d_closeCell(mask))
+	G3d_fatalError(_("Unable to close 3D raster mask file"));
+    if (!G3d_closeCell(map))
+	G3d_fatalError(_("Unable to close raster map <%s>"), name);
+int main(int argc, char *argv[])
+    char *name;
+    d_Mask *maskRules;
+    struct GModule *module;
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    G_add_keyword(_("raster3d"));
+    G_add_keyword(_("voxel"));
+    module->description =
+	_("Establishes the current working 3D raster mask.");
+    params.map = G_define_option();
+    params.map->key = "map";
+    params.map->type = TYPE_STRING;
+    params.map->required = YES;
+    params.map->multiple = NO;
+    params.map->gisprompt = "old,grid3,3d-raster";
+    params.map->description = _("3D raster map with reference values");
+    params.maskVals = G_define_option();
+    params.maskVals->key = "maskvalues";
+    params.maskVals->key_desc = "val[-val]";
+    params.maskVals->type = TYPE_STRING;
+    params.maskVals->required = NO;
+    params.maskVals->multiple = YES;
+    params.maskVals->description = _("List of cell values to be masked out");
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    if (G3d_maskFileExists())
+	G_fatal_error(_("Cannot create mask file: G3D_MASK already exists"));
+    getParams(&name, &maskRules);
+    makeMask(name, maskRules);
+    exit(EXIT_SUCCESS);
Copied: grass/trunk/raster3d/r3.mask/r3.mask.html (from rev 47526, grass/trunk/raster3d/base/r3.mask.html)
--- grass/trunk/raster3d/r3.mask/r3.mask.html	                        (rev 0)
+++ grass/trunk/raster3d/r3.mask/r3.mask.html	2011-08-10 10:58:01 UTC (rev 47528)
@@ -0,0 +1,28 @@
+<H2>DESCRIPTION</H2>
+File <EM>map</EM> is used as reference file.
+Cells in the mask are marked as "mask out" if the corresponding cell in
+<EM>map</EM> contains a value in the range specified with <EM>maskvalues</EM>.
+<P>
+Before a new 3D-mask can be created the exisitng mask has to be removed
+with <EM>g.remove</EM>.
+<H3>Parameters:</H3>
+<DL>
+<DT><B>maskvalues</B>
+<DD>Values specified to be masked out
+<DT><B>grid3d</B>
+<DD>Name of G3D-map that is used as the mask reference
+</DL>
+<H2>SEE ALSO</H2>
+<EM><A HREF="g.remove.html">g.remove</A></EM>
+<H2>AUTHORS</H2>
+Roman Waupotitsch, Michael Shapiro,
+Helena Mitasova, Bill Brown, Lubos Mitas,
+Jaro Hofierka
+<p><i>Last changed: $Date$</i>
Property changes on: grass/trunk/raster3d/r3.null
Added: svn:ignore
   + OBJ.*
Added: grass/trunk/raster3d/r3.null/Makefile
--- grass/trunk/raster3d/r3.null/Makefile	                        (rev 0)
+++ grass/trunk/raster3d/r3.null/Makefile	2011-08-10 10:58:01 UTC (rev 47528)
@@ -0,0 +1,10 @@
+PGM=r3.null
+default: cmd
Property changes on: grass/trunk/raster3d/r3.null/Makefile
   + text/x-makefile
   + native
Copied: grass/trunk/raster3d/r3.null/main.c (from rev 47526, grass/trunk/raster3d/base/r3.null.main.c)
--- grass/trunk/raster3d/r3.null/main.c	                        (rev 0)
+++ grass/trunk/raster3d/r3.null/main.c	2011-08-10 10:58:01 UTC (rev 47528)
@@ -0,0 +1,198 @@
+* MODULE:       r3.null
+* PURPOSE:      Explicitly create the 3D NULL-value bitmap file.
+*               for details.
+#include <stdio.h>
+typedef struct
+    struct Option *map, *setNull, *null;
+} paramType;
+/* function prototypes */
+static void setParams(void);
+static void getParams(char **name, d_Mask ** maskRules, int *changeNull,
+		      double *newNullVal);
+static void modifyNull(char *name, d_Mask * maskRules, int changeNull,
+		       double newNullVal);
+	_("3d raster map for which to modify null values");
+    params.setNull = G_define_option();
+    params.setNull->key = "setnull";
+    params.setNull->key_desc = "val[-val]";
+    params.setNull->type = TYPE_STRING;
+    params.setNull->required = NO;
+    params.setNull->multiple = YES;
+    params.setNull->description = _("List of cell values to be set to NULL");
+    params.null = G_define_option();
+    params.null->key = "null";
+    params.null->type = TYPE_DOUBLE;
+    params.null->required = NO;
+    params.null->multiple = NO;
+    params.null->description = _("The value to replace the null value by");
+static void
+getParams(char **name, d_Mask ** maskRules, int *changeNull,
+    G3d_parse_vallist(params.setNull->answers, maskRules);
+    *changeNull = (params.null->answer != NULL);
+    if (*changeNull)
+	if (sscanf(params.null->answer, "%lf", newNullVal) != 1)
+	    G3d_fatalError(_("Illegal value for null"));
+static void
+modifyNull(char *name, d_Mask * maskRules, int changeNull, double newNullVal)
+    void *map, *mapOut;
+    int tileX, tileY, tileZ, x, y, z;
+    double value;
+    int doCompress, doLzw, doRle, precision;
+    int cacheSize;
+    fprintf(stderr, "name %s Mapset %s \n", name, G_mapset());
+    if (map == NULL)
+    G3d_getCompressionMode(&doCompress, &doLzw, &doRle, &precision);
+    mapOut = G3d_openNewParam(name, DCELL_TYPE, G3D_USE_CACHE_XY,
+			      &region, G3d_fileTypeMap(map),
+			      doLzw, doRle, G3d_tilePrecisionMap(map), tileX,
+			      tileY, tileZ);
+    if (mapOut == NULL)
+	G3d_fatalError(_("modifyNull: error opening tmp file"));
+    G3d_minUnlocked(mapOut, G3D_USE_CACHE_X);
+    G3d_autolockOn(mapOut);
+    G3d_unlockAll(mapOut);
+		if (G3d_isNullValueNum(&value, DCELL_TYPE)) {
+		    if (changeNull) {
+			value = newNullVal;
+		else if (G3d_mask_d_select((DCELL *) & value, maskRules)) {
+		    G3d_setNullValue(&value, 1, DCELL_TYPE);
+		G3d_putDouble(mapOut, x, y, z, value);
+		(mapOut, 0, 0, MAX(0, z - tileZ), region.rows - 1,
+		G3d_fatalError(_("modifyNull: error flushing tiles in cube"));
+    if (!G3d_flushAllTiles(mapOut))
+	G3d_fatalError(_("modifyNull: error flushing all tiles"));
+    G3d_autolockOff(mapOut);
+	G3d_fatalError(_("Unable to close raster map"));
+    if (!G3d_closeCell(mapOut))
+	G3d_fatalError(_("modifyNull: Unable to close tmp file"));
+int main(int argc, char **argv)
+    char *name;
+    int changeNull;
+    double newNullVal;
+	_("Explicitly create the 3D NULL-value bitmap file.");
+    setParams();
+    getParams(&name, &maskRules, &changeNull, &newNullVal);
+    modifyNull(name, maskRules, changeNull, newNullVal);
Copied: grass/trunk/raster3d/r3.null/r3.null.html (from rev 47526, grass/trunk/raster3d/base/r3.null.html)
--- grass/trunk/raster3d/r3.null/r3.null.html	                        (rev 0)
+++ grass/trunk/raster3d/r3.null/r3.null.html	2011-08-10 10:58:01 UTC (rev 47528)
@@ -0,0 +1,13 @@
+Modifies the NULL values of <EM>map</EM>.
+<H2>SEE ALSO</H2>
+<EM><A HREF="r.null.html">r.null</A></EM><br>
+<H2>AUTHORS</H2>
+Jaro Hofierka
Copied: grass/trunk/raster3d/r3.null/test.r3.null.sh (from rev 47526, grass/trunk/raster3d/base/test.r3.null.sh)
--- grass/trunk/raster3d/r3.null/test.r3.null.sh	                        (rev 0)
+++ grass/trunk/raster3d/r3.null/test.r3.null.sh	2011-08-10 10:58:01 UTC (rev 47528)
@@ -0,0 +1,41 @@
+# Tests for r3.null
+# We set up a specific region in the
+# @preprocess step of this test. We generate
+# voxel data with r3.mapcalc. The region setting
+# should work for UTM and LL test locations
+g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
+# We create several (float, double, null value) voxel map
+# with value = col + row + depth.
+r3.mapcalc --o expr="test_volume_float_1 = float(col() + row() + depth())"
+r3.mapcalc --o expr="test_volume_float_2 = test_volume_float_1"
+r3.mapcalc --o expr="test_volume_double_1 = double(col() + row() + depth())"
+r3.mapcalc --o expr="test_volume_double_2 = test_volume_double_1"
+# Add null value information
+r3.mapcalc --o expr="test_volume_float_null_1 = if(row() == 1 || row() == 5, null(), test_volume_float_1)"
+r3.mapcalc --o expr="test_volume_float_null_2 = if(row() == 1 || row() == 5, null(), test_volume_float_1)"
+r3.mapcalc --o expr="test_volume_double_null_1 = if(row() == 1 || row() == 5, null(), test_volume_double_1)"
+r3.mapcalc --o expr="test_volume_double_null_2 = if(row() == 1 || row() == 5, null(), test_volume_double_1)"
+# We @test r3.null to set and modify null values.
+# Validation is based on @files with @precision=3
+# First float maps
+r3.null map=test_volume_float_1 setnull=3,4,5
+r3.null map=test_volume_float_2 setnull=7,8,9
+r3.null map=test_volume_float_null_1 null=-1.5
+r3.null map=test_volume_float_null_2 null=-10.5
+# Double maps
+r3.null map=test_volume_double_1 setnull=3,4,5
+r3.null map=test_volume_double_2 setnull=7,8,9
+r3.null map=test_volume_double_null_1 null=-1.5
+r3.null map=test_volume_double_null_2 null=-10.5
+# Commands to export the references
+# r3.out.ascii dp=3 input=test_volume_float_1 output=test_volume_float_1.ref
+# r3.out.ascii dp=3 input=test_volume_float_2 output=test_volume_float_2.ref
+# r3.out.ascii dp=3 input=test_volume_float_null_1 output=test_volume_float_null_1.ref
+# r3.out.ascii dp=3 input=test_volume_float_null_2 output=test_volume_float_null_2.ref
+# r3.out.ascii dp=3 input=test_volume_double_1 output=test_volume_double_1.ref
+# r3.out.ascii dp=3 input=test_volume_double_2 output=test_volume_double_2.ref
+# r3.out.ascii dp=3 input=test_volume_double_null_1 output=test_volume_double_null_1.ref
+# r3.out.ascii dp=3 input=test_volume_double_null_2 output=test_volume_double_null_2.ref
Copied: grass/trunk/raster3d/r3.null/test_volume_double_1.ref (from rev 47526, grass/trunk/raster3d/base/test_volume_double_1.ref)
--- grass/trunk/raster3d/r3.null/test_volume_double_1.ref	                        (rev 0)
+++ grass/trunk/raster3d/r3.null/test_volume_double_1.ref	2011-08-10 10:58:01 UTC (rev 47528)
@@ -0,0 +1,51 @@
+version: grass7
+order: nsbt
+north: 80.000000
+south: 0.000000
+east: 120.000000
+west: 0.000000
+top: 50.000000
+bottom: 0.000000
+rows: 8
+cols: 12
+levels: 5
+* * * 6.000 7.000 8.000 9.000 10.000 11.000 12.000 13.000 14.000
+* * 6.000 7.000 8.000 9.000 10.000 11.000 12.000 13.000 14.000 15.000
+* 6.000 7.000 8.000 9.000 10.000 11.000 12.000 13.000 14.000 15.000 16.000
+6.000 7.000 8.000 9.000 10.000 11.000 12.000 13.000 14.000 15.000 16.000 17.000
+7.000 8.000 9.000 10.000 11.000 12.000 13.000 14.000 15.000 16.000 17.000 18.000
+8.000 9.000 10.000 11.000 12.000 13.000 14.000 15.000 16.000 17.000 18.000 19.000
+9.000 10.000 11.000 12.000 13.000 14.000 15.000 16.000 17.000 18.000 19.000 20.000
+10.000 11.000 12.000 13.000 14.000 15.000 16.000 17.000 18.000 19.000 20.000 21.000
+11.000 12.000 13.000 14.000 15.000 16.000 17.000 18.000 19.000 20.000 21.000 22.000
+12.000 13.000 14.000 15.000 16.000 17.000 18.000 19.000 20.000 21.000 22.000 23.000
+13.000 14.000 15.000 16.000 17.000 18.000 19.000 20.000 21.000 22.000 23.000 24.000
+14.000 15.000 16.000 17.000 18.000 19.000 20.000 21.000 22.000 23.000 24.000 25.000
Copied: grass/trunk/raster3d/r3.null/test_volume_double_2.ref (from rev 47526, grass/trunk/raster3d/base/test_volume_double_2.ref)
--- grass/trunk/raster3d/r3.null/test_volume_double_2.ref	                        (rev 0)
+++ grass/trunk/raster3d/r3.null/test_volume_double_2.ref	2011-08-10 10:58:01 UTC (rev 47528)
@@ -0,0 +1,51 @@
+version: grass7
+order: nsbt
+north: 80.000000
+south: 0.000000
+east: 120.000000
+west: 0.000000
+top: 50.000000
+bottom: 0.000000
+rows: 8
+cols: 12
+levels: 5
+3.000 4.000 5.000 6.000 * * * 10.000 11.000 12.000 13.000 14.000
+4.000 5.000 6.000 * * * 10.000 11.000 12.000 13.000 14.000 15.000
+5.000 6.000 * * * 10.000 11.000 12.000 13.000 14.000 15.000 16.000
+6.000 * * * 10.000 11.000 12.000 13.000 14.000 15.000 16.000 17.000
+* * * 10.000 11.000 12.000 13.000 14.000 15.000 16.000 17.000 18.000
+* * 10.000 11.000 12.000 13.000 14.000 15.000 16.000 17.000 18.000 19.000
+* 10.000 11.000 12.000 13.000 14.000 15.000 16.000 17.000 18.000 19.000 20.000
Copied: grass/trunk/raster3d/r3.null/test_volume_double_null_1.ref (from rev 47526, grass/trunk/raster3d/base/test_volume_double_null_1.ref)
--- grass/trunk/raster3d/r3.null/test_volume_double_null_1.ref	                        (rev 0)
+++ grass/trunk/raster3d/r3.null/test_volume_double_null_1.ref	2011-08-10 10:58:01 UTC (rev 47528)
@@ -0,0 +1,51 @@
+version: grass7
+order: nsbt
+north: 80.000000
+south: 0.000000
+east: 120.000000
+west: 0.000000
+top: 50.000000
+bottom: 0.000000
+rows: 8
+cols: 12
+levels: 5
+-1.500 -1.500 -1.500 -1.500 -1.500 -1.500 -1.500 -1.500 -1.500 -1.500 -1.500 -1.500
+4.000 5.000 6.000 7.000 8.000 9.000 10.000 11.000 12.000 13.000 14.000 15.000
+5.000 6.000 7.000 8.000 9.000 10.000 11.000 12.000 13.000 14.000 15.000 16.000
Copied: grass/trunk/raster3d/r3.null/test_volume_double_null_2.ref (from rev 47526, grass/trunk/raster3d/base/test_volume_double_null_2.ref)
--- grass/trunk/raster3d/r3.null/test_volume_double_null_2.ref	                        (rev 0)
+++ grass/trunk/raster3d/r3.null/test_volume_double_null_2.ref	2011-08-10 10:58:01 UTC (rev 47528)
@@ -0,0 +1,51 @@
+version: grass7
+order: nsbt
+north: 80.000000
+south: 0.000000
+east: 120.000000
+west: 0.000000
+top: 50.000000
+bottom: 0.000000
+rows: 8
+cols: 12
+levels: 5
+-10.500 -10.500 -10.500 -10.500 -10.500 -10.500 -10.500 -10.500 -10.500 -10.500 -10.500 -10.500
Copied: grass/trunk/raster3d/r3.null/test_volume_float_1.ref (from rev 47526, grass/trunk/raster3d/base/test_volume_float_1.ref)
--- grass/trunk/raster3d/r3.null/test_volume_float_1.ref	                        (rev 0)
+++ grass/trunk/raster3d/r3.null/test_volume_float_1.ref	2011-08-10 10:58:01 UTC (rev 47528)
@@ -0,0 +1,51 @@
+version: grass7
+order: nsbt
+north: 80.000000
+south: 0.000000
+east: 120.000000
+west: 0.000000
+top: 50.000000
+bottom: 0.000000
+rows: 8
+cols: 12
+levels: 5
Copied: grass/trunk/raster3d/r3.null/test_volume_float_2.ref (from rev 47526, grass/trunk/raster3d/base/test_volume_float_2.ref)
--- grass/trunk/raster3d/r3.null/test_volume_float_2.ref	                        (rev 0)
+++ grass/trunk/raster3d/r3.null/test_volume_float_2.ref	2011-08-10 10:58:01 UTC (rev 47528)
@@ -0,0 +1,51 @@
+version: grass7
+order: nsbt
+north: 80.000000
+south: 0.000000
+east: 120.000000
+west: 0.000000
+top: 50.000000
+bottom: 0.000000
+rows: 8
+cols: 12
+levels: 5
Copied: grass/trunk/raster3d/r3.null/test_volume_float_null_1.ref (from rev 47526, grass/trunk/raster3d/base/test_volume_float_null_1.ref)
--- grass/trunk/raster3d/r3.null/test_volume_float_null_1.ref	                        (rev 0)
+++ grass/trunk/raster3d/r3.null/test_volume_float_null_1.ref	2011-08-10 10:58:01 UTC (rev 47528)
@@ -0,0 +1,51 @@
+version: grass7
+order: nsbt
+north: 80.000000
+south: 0.000000
+east: 120.000000
+west: 0.000000
+top: 50.000000
+bottom: 0.000000
+rows: 8
+cols: 12
+levels: 5
Copied: grass/trunk/raster3d/r3.null/test_volume_float_null_2.ref (from rev 47526, grass/trunk/raster3d/base/test_volume_float_null_2.ref)
--- grass/trunk/raster3d/r3.null/test_volume_float_null_2.ref	                        (rev 0)
+++ grass/trunk/raster3d/r3.null/test_volume_float_null_2.ref	2011-08-10 10:58:01 UTC (rev 47528)
@@ -0,0 +1,51 @@
+version: grass7
+order: nsbt
+north: 80.000000
+south: 0.000000
+east: 120.000000
+west: 0.000000
+top: 50.000000
+bottom: 0.000000
+rows: 8
+cols: 12
+levels: 5
