[GRASS-SVN] r47533 - grass/trunk/include
Wed Aug 10 12:49:20 EDT 2011
Author: martinl
Date: 2011-08-10 09:49:20 -0700 (Wed, 10 Aug 2011)
New Revision: 47533
Added:
   grass/trunk/include/raster3d.h
   grass/trunk/include/raster3ddefs.h
Removed:
   grass/trunk/include/G3d.h
G3d.h renamed to raster3d.h
function moved to raster3ddefs.h
Deleted: grass/trunk/include/G3d.h
--- grass/trunk/include/G3d.h	2011-08-10 16:45:08 UTC (rev 47532)
+++ grass/trunk/include/G3d.h	2011-08-10 16:49:20 UTC (rev 47533)
@@ -1,614 +0,0 @@
-#ifndef GRASS_G3D_H
-#define GRASS_G3D_H
-#include <grass/gis.h>
-#include <grass/raster.h>
-#define G3D_TILE_SAME_AS_FILE 2
-#define G3D_NO_COMPRESSION 0
-#define G3D_COMPRESSION 1
-#define G3D_USE_LZW 1
-#define G3D_NO_LZW 0
-#define G3D_USE_RLE 1
-#define G3D_NO_RLE 0
-#define G3D_MAX_PRECISION -1
-#define G3D_NO_CACHE 0
-#define G3D_USE_CACHE_DEFAULT -1
-#define G3D_USE_CACHE_X -2
-#define G3D_USE_CACHE_Y -3
-#define G3D_USE_CACHE_Z -4
-#define G3D_USE_CACHE_XY -5
-#define G3D_USE_CACHE_XZ -6
-#define G3D_USE_CACHE_YZ -7
-#define G3D_USE_CACHE_XYZ -8
-#define G3D_DEFAULT_WINDOW NULL
-#define G3D_DIRECTORY      "grid3"
-#define G3D_CELL_ELEMENT   "cell"
-#define G3D_CATS_ELEMENT   "cats"
-#define G3D_RANGE_ELEMENT  "range"
-#define G3D_HEADER_ELEMENT "cellhd"
-#define G3D_HISTORY_ELEMENT "hist"
-#define G3D_COLOR_ELEMENT  "color"
-#define G3D_COLOR2_DIRECTORY  "colr2"
-#define G3D_MASK_MAP       "G3D_MASK"
-#define G3D_WINDOW_ELEMENT   "WIND3"
-#define G3D_DEFAULT_WINDOW_ELEMENT   "DEFAULT_WIND3"
-#define G3D_WINDOW_DATABASE "windows3d"
-#define G3D_PERMANENT_MAPSET "PERMANENT"
-typedef struct
-    double north, south;
-    double east, west;
-    double top, bottom;
-    /* dimension of data in "cells"; rows == #x; cols == #y; depths == #z */
-    int rows, cols, depths;
-    double ns_res, ew_res, tb_res;
-    int proj;			/* Projection (see gis.h) */
-    int zone;			/* Projection zone (see gis.h) */
-} G3D_Region;
-struct G3D_Map;
-typedef void resample_fn(struct G3D_Map *, int, int, int, void *, int);
-typedef struct G3D_Map
-    char *fileName;
-    char *tempName;
-    char *mapset;
-    /* operation performed on map */
-    int operation;		/* G3D_WRITE_DATA or G3D_READ_DATA */
-    /* region */
-    G3D_Region region;
-    /* window for map */
-    G3D_Region window;
-    /* resmapling function used for map. default is nearest neighbor */
-    resample_fn *resampleFun;
-    /* units */
-    char *unit;
-    /* dimension of a single tile in "cells" */
-    int tileX, tileY, tileZ;
-    /* # of tiles in x, y, and z direction */
-    int nx, ny, nz;
-    /* data file specific information */
-    /* file descriptor */
-    int data_fd;		/* file descriptor */
-    /* type in which data is stored on file */
-    int type;			/* DCELL_TYPE or FCELL_TYPE */
-    /* data concering the compression */
-    int precision;		/* G3D_MAX_PRECISION or, 0 .. 23 for float,
-				   0 .. 52 for double */
-    int compression;		/* G3D_NO_COMPRESSION or G3D_USE_COMPRESSION */
-    int useLzw;			/* G3D_USE_LZW or G3D_NO_LZW */
-    int useRle;			/* G3D_USE_RLE or G3D_NO_RLE */
-    int useXdr;			/* G3D_USE_XDR or G3D_NO_XDR */
-    /* pointer to first tile in file */
-    int offset;
-    /* pointer to the first index entry in file */
-    long indexOffset;
-    /* sizeof (long) of the system on which the file is/was written */
-    int indexLongNbytes;
-    /* max # bytes used in the representation of indices; this is equal to */
-    /* # bytes used in the representation of "indexOffset" */
-    int indexNbytesUsed;
-    /* pointer to the last entry in the file */
-    int fileEndPtr;
-    /* indicates if index is stored in file; used for G3D_READ_DATA only */
-    int hasIndex;		/* G3D_HAS_INDEX or G3D_NO_INDEX */
-    /* information concerning internal storage of data */
-    /* index specific information */
-    /* index[i] == the offset of tile "i" in the data file */
-    long *index;
-    /* tileLength[i] == # bytes used to store tile "i" */
-    int *tileLength;
-    /* tile specific information */
-    /* type in which data is stored in memory */
-    int typeIntern;		/* DCELL_TYPE or FCELL_TYPE */
-    /* in non-cache mode the "data" array is used to store one tile */
-    char *data;
-    /* index of tile currently stored in "data"; -1 if none */
-    int currentIndex;
-    /* cache related variables */
-    int useCache;		/* 1 if cache is used */
-    void *cache;		/* pointer to cache structure */
-    int cacheFD;		/* file discriptor of cache file -- write mode only */
-    char *cacheFileName;	/* filename of cache file -- write mode only */
-    long cachePosLast;		/* position of last entry in cache file -- write */
-    /* mode only */
-    /* range info */
-    struct FPRange range;
-    /* some constants stored for efficiency */
-    /* number of bytes required to store a single value of "type" */
-    int numLengthExtern;
-    /* number of bytes required to store a single value of "typeIntern" */
-    int numLengthIntern;
-    /* see header.c for details */
-    int clipX, clipY, clipZ;
-    int tileXY, tileSize;
-    int nxy, nTiles;
-    /* mask related information */
-    int useMask;		/* 1 if mask is used; 0 otherwise */
-} G3D_Map;
-typedef struct
-    char *elts;			/* ptr to array of elts */
-    int nofElts;		/* size of "elts" */
-    int eltSize;		/* size of elt in "elts" */
-    int *names;			/* name[i] is the name of elts[i] */
-    char *locks;		/* lock[i] == 1 iff elts[i] is locked
-				   lock[i] == 0 iff elts[i] is unlocked but active
-				   lock[i] == 2 iff elts[i] doesn't contain valid data */
-    int autoLock;		/* 1 if auto locking is turned on */
-    int nofUnlocked;		/* nof tiles which are unlocked */
-    int minUnlocked;		/* min nof elts which have to remain unlocked. min = 1 */
-    int *next, *prev;		/* prev/next pointers for fifo */
-    int first, last;		/* index (into next) of first and last elt in fifo */
-    /* first == -1 iff fifo is empty */
-    int (*eltRemoveFun) ();	/* callback activated if the contents of an
-				   elt needs to be removed */
-    void *eltRemoveFunData;	/* pointer to user data passed along with
-				   eltRemoveFun */
-    int (*eltLoadFun) ();	/* callback activated to load contents of an elt */
-    void *eltLoadFunData;	/* pointer to user data passed along with
-				   eltLoadFun */
-    void *hash;			/* ptr to hashTable used to relate external names to
-				   internal indices (elts) */
-} G3D_cache;
-typedef struct
-    int nofNames;
-    int *index;
-    char *active;
-    int lastName;
-    int lastIndex;
-    int lastIndexActive;
-} G3d_cache_hash;
-/*Structures */
-typedef struct _d_interval
-    double low, high;
-    int inf;
-    struct _d_interval *next;
-} d_Interval;
-typedef struct _d_mask
-    d_Interval *list;
-} d_Mask;
-typedef int write_fn(int, const void *, void *);
-typedef int read_fn(int, void *, void *);
-/* cache.c */
-void G3d_cache_reset(G3D_cache *);
-void G3d_cache_dispose(G3D_cache *);
-void *G3d_cache_new(int, int, int, write_fn *, void *, read_fn *, void *);
-void G3d_cache_set_removeFun(G3D_cache *, write_fn *, void *);
-void G3d_cache_set_loadFun(G3D_cache *, read_fn *, void *);
-void *G3d_cache_new_read(int, int, int, read_fn *, void *);
-int G3d_cache_lock(G3D_cache *, int);
-void G3d_cache_lock_intern(G3D_cache *, int);
-int G3d_cache_unlock(G3D_cache *, int);
-int G3d_cache_unlock_all(G3D_cache *);
-int G3d_cache_lock_all(G3D_cache *);
-void G3d_cache_autolock_on(G3D_cache *);
-void G3d_cache_autolock_off(G3D_cache *);
-void G3d_cache_set_minUnlock(G3D_cache *, int);
-int G3d_cache_remove_elt(G3D_cache *, int);
-int G3d_cache_flush(G3D_cache *, int);
-int G3d_cache_remove_all(G3D_cache *);
-int G3d_cache_flush_all(G3D_cache *);
-void *G3d_cache_elt_ptr(G3D_cache *, int);
-int G3d_cache_load(G3D_cache *, int);
-int G3d_cache_get_elt(G3D_cache *, int, void *);
-int G3d_cache_put_elt(G3D_cache *, int, const void *);
-/* cachehash.c */
-void G3d_cache_hash_reset(G3d_cache_hash *);
-void G3d_cache_hash_dispose(G3d_cache_hash *);
-void *G3d_cache_hash_new(int);
-void G3d_cache_hash_remove_name(G3d_cache_hash *, int);
-void G3d_cache_hash_load_name(G3d_cache_hash *, int, int);
-int G3d_cache_hash_name2index(G3d_cache_hash *, int);
-/* changeprecision.c */
-void G3d_changePrecision(void *, int, const char *);
-/* changetype.c */
-void G3d_changeType(void *, const char *);
-/* filecompare.c */
-void G3d_compareFiles(const char *, const char *, const char *, const char *);
-/* filename.c */
-void G3d_filename(char *, const char *, const char *, const char *);
-/* find_grid3.c */
-char *G_find_grid3(const char *, const char *);
-/* fpcompress.c */
-void G_fpcompress_printBinary(char *, int);
-void G_fpcompress_dissectXdrDouble(unsigned char *);
-int G_fpcompress_writeXdrNums(int, char *, int, int, char *, int, int, int);
-int G_fpcompress_writeXdrFloats(int, char *, int, int, char *, int, int);
-int G_fpcompress_writeXdrDouble(int, char *, int, int, char *, int, int);
-int G_fpcompress_readXdrNums(int, char *, int, int, int, char *, int);
-int G_fpcompress_readXdrFloats(int, char *, int, int, int, char *);
-int G_fpcompress_readXdrDoubles(int, char *, int, int, int, char *);
-/* g3dalloc.c */
-void *G3d_malloc(int);
-void *G3d_realloc(void *, int);
-void G3d_free(void *);
-/* g3dcache.c */
-int G3d_initCache(G3D_Map *, int);
-int G3d_disposeCache(G3D_Map *);
-int G3d_flushAllTiles(G3D_Map *);
-/* g3dcats.c */
-int G3d_writeCats(const char *, struct Categories *);
-int G3d_readCats(const char *, const char *, struct Categories *);
-/* g3dclose.c */
-int G3d_closeCell(G3D_Map *);
-/* g3dcolor.c */
-int G3d_removeColor(const char *);
-int G3d_readColors(const char *, const char *, struct Colors *);
-int G3d_writeColors(const char *, const char *, struct Colors *);
-/* g3ddefaults.c */
-void G3d_setCompressionMode(int, int, int, int);
-void G3d_getCompressionMode(int *, int *, int *, int *);
-void G3d_setCacheSize(int);
-int G3d_getCacheSize(void);
-void G3d_setCacheLimit(int);
-int G3d_getCacheLimit(void);
-void G3d_setFileType(int);
-int G3d_getFileType(void);
-void G3d_setTileDimension(int, int, int);
-void G3d_getTileDimension(int *, int *, int *);
-void G3d_setErrorFun(void (*)(const char *));
-void G3d_setUnit(const char *);
-void G3d_initDefaults(void);
-/* g3ddoubleio.c */
-int G3d_writeDoubles(int, int, const double *, int);
-int G3d_readDoubles(int, int, double *, int);
-/* g3derror.c */
-void G3d_skipError(const char *);
-void G3d_printError(const char *);
-void G3d_fatalError(const char *, ...) __attribute__ ((format(printf, 1, 2)))
-    __attribute__ ((noreturn));
-void G3d_fatalError_noargs(const char *) __attribute__ ((noreturn));
-void G3d_error(const char *, ...) __attribute__ ((format(printf, 1, 2)));
-/* g3dfpxdr.c */
-int G3d_isXdrNullNum(const void *, int);
-int G3d_isXdrNullFloat(const float *);
-int G3d_isXdrNullDouble(const double *);
-void G3d_setXdrNullNum(void *, int);
-void G3d_setXdrNullDouble(double *);
-void G3d_setXdrNullFloat(float *);
-int G3d_initFpXdr(G3D_Map *, int);
-int G3d_initCopyToXdr(G3D_Map *, int);
-int G3d_copyToXdr(const void *, int);
-int G3d_initCopyFromXdr(G3D_Map *, int);
-int G3d_copyFromXdr(int, void *);
-/* g3dhistory.c */
-int G3d_writeHistory(const char *, struct History *);
-int G3d_readHistory(const char *, const char *, struct History *);
-/* g3dintio.c */
-int G3d_writeInts(int, int, const int *, int);
-int G3d_readInts(int, int, int *, int);
-/* g3dkeys.c */
-int G3d_keyGetInt(struct Key_Value *, const char *, int *);
-int G3d_keyGetDouble(struct Key_Value *, const char *, double *);
-int G3d_keyGetString(struct Key_Value *, const char *, char **);
-int G3d_keyGetValue(struct Key_Value *, const char *, char *, char *, int,
-		    int, int *);
-int G3d_keySetInt(struct Key_Value *, const char *, const int *);
-int G3d_keySetDouble(struct Key_Value *, const char *, const double *);
-int G3d_keySetString(struct Key_Value *, const char *, char *const *);
-int G3d_keySetValue(struct Key_Value *, const char *, const char *,
-		    const char *, int, int, const int *);
-/* g3dlong.c */
-int G3d_longEncode(long *, unsigned char *, int);
-void G3d_longDecode(unsigned char *, long *, int, int);
-/* g3dmapset.c */
-void G3d_makeMapsetMapDirectory(const char *);
-/* g3dmask.c */
-int G3d_maskClose(void);
-int G3d_maskFileExists(void);
-int G3d_maskOpenOld(void);
-int G3d_maskReopen(int);
-int G3d_isMasked(G3D_Map *, int, int, int);
-void G3d_maskNum(G3D_Map *, int, int, int, void *, int);
-void G3d_maskFloat(G3D_Map *, int, int, int, float *);
-void G3d_maskDouble(G3D_Map *, int, int, int, double *);
-void G3d_maskTile(G3D_Map *, int, void *, int);
-void G3d_maskOn(G3D_Map *);
-void G3d_maskOff(G3D_Map *);
-int G3d_maskIsOn(G3D_Map *);
-int G3d_maskIsOff(G3D_Map *);
-const char *G3d_maskFile(void);
-int G3d_maskMapExists(void);
-/* maskfn.c */
-int G3d_mask_d_select(DCELL *, d_Mask *);
-DCELL G3d_mask_match_d_interval(DCELL, d_Interval *);
-void G3d_parse_vallist(char **, d_Mask **);
-/* g3dmisc.c */
-int G3d_g3dType2cellType(int);
-void G3d_copyFloat2Double(const float *, int, double *, int, int);
-void G3d_copyDouble2Float(const double *, int, float *, int, int);
-void G3d_copyValues(const void *, int, int, void *, int, int, int);
-int G3d_length(int);
-int G3d_externLength(int);
-/* g3dnull.c */
-int G3d_isNullValueNum(const void *, int);
-void G3d_setNullValue(void *, int, int);
-/* g3dopen2.c */
-void *G3d_openNewParam(const char *, int , int, G3D_Region *, int, int, int, int, int, int, int);
-/* g3dopen.c */
-void *G3d_openCellOldNoHeader(const char *, const char *);
-void *G3d_openCellOld(const char *, const char *, G3D_Region *, int, int);
-void *G3d_openCellNew(const char *, int, int, G3D_Region *);
-void *G3d_openNewOptTileSize(const char *, int , G3D_Region * , int , int );
-/* g3dparam.c */
-void G3d_setStandard3dInputParams(void);
-int G3d_getStandard3dParams(int *, int *, int *, int *, int *, int *, int *,
-			    int *, int *, int *, int *, int *);
-void G3d_setWindowParams(void);
-char *G3d_getWindowParams(void);
-/* g3drange.c */
-void G3d_range_updateFromTile(G3D_Map *, const void *, int, int, int, int,
-			      int, int, int, int);
-int G3d_readRange(const char *, const char *, struct FPRange *);
-int G3d_range_load(G3D_Map *);
-void G3d_range_min_max(G3D_Map *, double *, double *);
-int G3d_range_write(G3D_Map *);
-int G3d_range_init(G3D_Map *);
-/* g3dregion.c */
-void G3d_getRegionValue(G3D_Map *, double, double, double, void *, int);
-void G3d_adjustRegion(G3D_Region *);
-void G3d_regionCopy(G3D_Region *, G3D_Region *);
-void G3d_incorporate2dRegion(struct Cell_head *, G3D_Region *);
-void G3d_regionFromToCellHead(struct Cell_head *, G3D_Region *);
-void G3d_adjustRegionRes(G3D_Region *);
-void G3d_extract2dRegion(G3D_Region *, struct Cell_head *);
-void G3d_regionToCellHead(G3D_Region *, struct Cell_head *);
-int G3d_readRegionMap(const char *, const char *, G3D_Region *);
-int G3d_isValidLocation(G3D_Region *, double, double, double);
-void G3d_location2coord(G3D_Region *, double, double, double, int *, int *, int *);
-void G3d_location2coord2(G3D_Region *, double, double, double, int *, int *, int *);
-void G3d_coord2location(G3D_Region *, double, double, double, double *, double *, double *);
-/* g3dresample.c */
-void G3d_nearestNeighbor(G3D_Map *, int, int, int, void *, int);
-void G3d_setResamplingFun(G3D_Map *, void (*)());
-void G3d_getResamplingFun(G3D_Map *, void (**)());
-void G3d_getNearestNeighborFunPtr(void (**)());
-/* g3dvolume.c */
-void G3d_getVolumeA(void *, double[2][2][2][3], int, int, int, void *, int);
-void G3d_getVolume(void *, double, double, double, double, double, double,
-		   double, double, double, double, double, double, int, int,
-		   int, void *, int);
-void G3d_getAlignedVolume(void *, double, double, double, double, double,
-			  double, int, int, int, void *, int);
-void G3d_makeAlignedVolumeFile(void *, const char *, double, double, double,
-			       double, double, double, int, int, int);
-/* g3dwindow.c */
-void G3d_getValue(G3D_Map *, int, int, int, void *, int);
-float G3d_getFloat(G3D_Map *, int, int, int);
-double G3d_getDouble(G3D_Map *, int, int, int);
-void G3d_getWindowValue(G3D_Map *, double, double, double, void *, int);
-G3D_Region *G3d_windowPtr(void);
-void G3d_setWindow(G3D_Region *);
-void G3d_setWindowMap(G3D_Map *, G3D_Region *);
-void G3d_getWindow(G3D_Region *);
-/* g3dwindowio.c */
-void G3d_useWindowParams(void);
-int G3d_readWindow(G3D_Region *, const char *);
-/* int G3d_writeWindow (G3D_Region *, char *); */
-/* getblock.c */
-void G3d_getBlockNocache(G3D_Map *, int, int, int, int, int, int, void *,
-			 int);
-void G3d_getBlock(G3D_Map *, int, int, int, int, int, int, void *, int);
-/* header.c */
-int G3d_readHeader(G3D_Map *, int *, int *, double *, double *, double *,
-		   double *, double *, double *, int *, int *, int *,
-		   double *, double *, double *, int *, int *, int *, int *,
-		   int *, int *, int *, int *, int *, int *, int *, char **);
-int G3d_writeHeader(G3D_Map *, int, int, double, double, double, double,
-		    double, double, int, int, int, double, double, double,
-		    int, int, int, int, int, int, int, int, int, int, int,
-		    char *);
-int G3d_cacheSizeEncode(int, int);
-int G3d__computeCacheSize(G3D_Map *, int);
-int G3d_fillHeader(G3D_Map *, int, int, int, int, int, int, int, int, int,
-		   int, int, int, int, int, int, int, double, double, double,
-		   double, double, double, int, int, int, double, double,
-		   double, char *);
-/* headerinfo.c */
-void G3d_getCoordsMap(G3D_Map *, int *, int *, int *);
-void G3d_getCoordsMapWindow(G3D_Map *, int *, int *, int *);
-void G3d_getNofTilesMap(G3D_Map *, int *, int *, int *);
-void G3d_getRegionMap(G3D_Map *, double *, double *, double *, double *,
-		      double *, double *);
-void G3d_getWindowMap(G3D_Map *, double *, double *, double *, double *,
-void G3d_getTileDimensionsMap(G3D_Map *, int *, int *, int *);
-int G3d_tileTypeMap(G3D_Map *);
-int G3d_fileTypeMap(G3D_Map *);
-int G3d_tilePrecisionMap(G3D_Map *);
-int G3d_tileUseCacheMap(G3D_Map *);
-void G3d_printHeader(G3D_Map *);
-void G3d_getRegionStructMap(G3D_Map *, G3D_Region *);
-/* index.c */
-int G3d_flushIndex(G3D_Map *);
-int G3d_initIndex(G3D_Map *, int);
-/* retile.c */
-void G3d_retile(void *, const char *, int, int, int);
-/* rle.c */
-int G_rle_count_only(char *, int, int);
-void G_rle_encode(char *, char *, int, int);
-void G_rle_decode(char *, char *, int, int, int *, int *);
-/* tilealloc.c */
-void *G3d_allocTilesType(G3D_Map *, int, int);
-void *G3d_allocTiles(G3D_Map *, int);
-void G3d_freeTiles(void *);
-/* tileio.c */
-void *G3d_getTilePtr(G3D_Map *, int);
-int G3d_tileLoad(G3D_Map *, int);
-int G3d__removeTile(G3D_Map *, int);
-float G3d_getFloatRegion(G3D_Map *, int, int, int);
-double G3d_getDoubleRegion(G3D_Map *, int, int, int);
-void G3d_getValueRegion(G3D_Map *, int, int, int, void *, int);
-/* tilemath.c */
-void G3d_computeOptimalTileDimension(G3D_Region *, int, int *, int *, int *, int);
-void G3d_tileIndex2tile(G3D_Map *, int, int *, int *, int *);
-int G3d_tile2tileIndex(G3D_Map *, int, int, int);
-void G3d_tileCoordOrigin(G3D_Map *, int, int, int, int *, int *, int *);
-void G3d_tileIndexOrigin(G3D_Map *, int, int *, int *, int *);
-void G3d_coord2tileCoord(G3D_Map *, int, int, int, int *, int *, int *, int *,
-			 int *, int *);
-void G3d_coord2tileIndex(G3D_Map *, int, int, int, int *, int *);
-int G3d_coordInRange(G3D_Map *, int, int, int);
-int G3d_tileIndexInRange(G3D_Map *, int);
-int G3d_tileInRange(G3D_Map *, int, int, int);
-int G3d_computeClippedTileDimensions(G3D_Map *, int, int *, int *, int *,
-				     int *, int *, int *);
-/* tilenull.c */
-void G3d_setNullTileType(G3D_Map *, void *, int);
-void G3d_setNullTile(G3D_Map *, void *);
-/* tileread.c */
-int G3d_readTile(G3D_Map *, int, void *, int);
-int G3d_readTileFloat(G3D_Map *, int, void *);
-int G3d_readTileDouble(G3D_Map *, int, void *);
-int G3d_lockTile(G3D_Map *, int);
-int G3d_unlockTile(G3D_Map *, int);
-int G3d_unlockAll(G3D_Map *);
-void G3d_autolockOn(G3D_Map *);
-void G3d_autolockOff(G3D_Map *);
-void G3d_minUnlocked(G3D_Map *, int);
-int G3d_beginCycle(G3D_Map *);
-int G3d_endCycle(G3D_Map *);
-/* tilewrite.c */
-int G3d_writeTile(G3D_Map *, int, const void *, int);
-int G3d_writeTileFloat(G3D_Map *, int, const void *);
-int G3d_writeTileDouble(G3D_Map *, int, const void *);
-int G3d_flushTile(G3D_Map *, int);
-int G3d_flushTileCube(G3D_Map *, int, int, int, int, int, int);
-int G3d_flushTilesInCube(G3D_Map *, int, int, int, int, int, int);
-int G3d_putFloat(G3D_Map *, int, int, int, float);
-int G3d_putDouble(G3D_Map *, int, int, int, double);
-int G3d_putValue(G3D_Map *, int, int, int, const void *, int);
-/* writeascii.c */
-void G3d_writeAscii(void *, const char *);
-#endif /* #ifndef GRASS_G3D_H */
Copied: grass/trunk/include/raster3d.h (from rev 47529, grass/trunk/include/G3d.h)
--- grass/trunk/include/raster3d.h	                        (rev 0)
+++ grass/trunk/include/raster3d.h	2011-08-10 16:49:20 UTC (rev 47533)
@@ -0,0 +1,262 @@
+#ifndef GRASS_RASTER3D_H
+#define GRASS_RASTER3D_H
+#include <grass/gis.h>
+#include <grass/raster.h>
+#define G3D_TILE_SAME_AS_FILE 2
+#define G3D_NO_COMPRESSION 0
+#define G3D_COMPRESSION 1
+#define G3D_USE_LZW 1
+#define G3D_NO_LZW 0
+#define G3D_USE_RLE 1
+#define G3D_NO_RLE 0
+#define G3D_MAX_PRECISION -1
+#define G3D_NO_CACHE 0
+#define G3D_USE_CACHE_DEFAULT -1
+#define G3D_USE_CACHE_X -2
+#define G3D_USE_CACHE_Y -3
+#define G3D_USE_CACHE_Z -4
+#define G3D_USE_CACHE_XY -5
+#define G3D_USE_CACHE_XZ -6
+#define G3D_USE_CACHE_YZ -7
+#define G3D_USE_CACHE_XYZ -8
+#define G3D_DEFAULT_WINDOW NULL
+#define G3D_DIRECTORY      "grid3"
+#define G3D_CELL_ELEMENT   "cell"
+#define G3D_CATS_ELEMENT   "cats"
+#define G3D_RANGE_ELEMENT  "range"
+#define G3D_HEADER_ELEMENT "cellhd"
+#define G3D_HISTORY_ELEMENT "hist"
+#define G3D_COLOR_ELEMENT  "color"
+#define G3D_COLOR2_DIRECTORY  "colr2"
+#define G3D_MASK_MAP       "G3D_MASK"
+#define G3D_WINDOW_ELEMENT   "WIND3"
+#define G3D_DEFAULT_WINDOW_ELEMENT   "DEFAULT_WIND3"
+#define G3D_WINDOW_DATABASE "windows3d"
+#define G3D_PERMANENT_MAPSET "PERMANENT"
+typedef struct
+    double north, south;
+    double east, west;
+    double top, bottom;
+    /* dimension of data in "cells"; rows == #x; cols == #y; depths == #z */
+    int rows, cols, depths;
+    double ns_res, ew_res, tb_res;
+    int proj;			/* Projection (see gis.h) */
+    int zone;			/* Projection zone (see gis.h) */
+} G3D_Region;
+struct G3D_Map;
+typedef void resample_fn(struct G3D_Map *, int, int, int, void *, int);
+typedef struct G3D_Map
+    char *fileName;
+    char *tempName;
+    char *mapset;
+    /* operation performed on map */
+    int operation;		/* G3D_WRITE_DATA or G3D_READ_DATA */
+    /* region */
+    G3D_Region region;
+    /* window for map */
+    G3D_Region window;
+    /* resmapling function used for map. default is nearest neighbor */
+    resample_fn *resampleFun;
+    /* units */
+    char *unit;
+    /* dimension of a single tile in "cells" */
+    int tileX, tileY, tileZ;
+    /* # of tiles in x, y, and z direction */
+    int nx, ny, nz;
+    /* data file specific information */
+    /* file descriptor */
+    int data_fd;		/* file descriptor */
+    /* type in which data is stored on file */
+    int type;			/* DCELL_TYPE or FCELL_TYPE */
+    /* data concering the compression */
+    int precision;		/* G3D_MAX_PRECISION or, 0 .. 23 for float,
+				   0 .. 52 for double */
+    int compression;		/* G3D_NO_COMPRESSION or G3D_USE_COMPRESSION */
+    int useLzw;			/* G3D_USE_LZW or G3D_NO_LZW */
+    int useRle;			/* G3D_USE_RLE or G3D_NO_RLE */
+    int useXdr;			/* G3D_USE_XDR or G3D_NO_XDR */
+    /* pointer to first tile in file */
+    int offset;
+    /* pointer to the first index entry in file */
+    long indexOffset;
+    /* sizeof (long) of the system on which the file is/was written */
+    int indexLongNbytes;
+    /* max # bytes used in the representation of indices; this is equal to */
+    /* # bytes used in the representation of "indexOffset" */
+    int indexNbytesUsed;
+    /* pointer to the last entry in the file */
+    int fileEndPtr;
+    /* indicates if index is stored in file; used for G3D_READ_DATA only */
+    int hasIndex;		/* G3D_HAS_INDEX or G3D_NO_INDEX */
+    /* information concerning internal storage of data */
+    /* index specific information */
+    /* index[i] == the offset of tile "i" in the data file */
+    long *index;
+    /* tileLength[i] == # bytes used to store tile "i" */
+    int *tileLength;
+    /* tile specific information */
+    /* type in which data is stored in memory */
+    int typeIntern;		/* DCELL_TYPE or FCELL_TYPE */
+    /* in non-cache mode the "data" array is used to store one tile */
+    char *data;
+    /* index of tile currently stored in "data"; -1 if none */
+    int currentIndex;
+    /* cache related variables */
+    int useCache;		/* 1 if cache is used */
+    void *cache;		/* pointer to cache structure */
+    int cacheFD;		/* file discriptor of cache file -- write mode only */
+    char *cacheFileName;	/* filename of cache file -- write mode only */
+    long cachePosLast;		/* position of last entry in cache file -- write */
+    /* mode only */
+    /* range info */
+    struct FPRange range;
+    /* some constants stored for efficiency */
+    /* number of bytes required to store a single value of "type" */
+    int numLengthExtern;
+    /* number of bytes required to store a single value of "typeIntern" */
+    int numLengthIntern;
+    /* see header.c for details */
+    int clipX, clipY, clipZ;
+    int tileXY, tileSize;
+    int nxy, nTiles;
+    /* mask related information */
+    int useMask;		/* 1 if mask is used; 0 otherwise */
+} G3D_Map;
+typedef struct
+    char *elts;			/* ptr to array of elts */
+    int nofElts;		/* size of "elts" */
+    int eltSize;		/* size of elt in "elts" */
+    int *names;			/* name[i] is the name of elts[i] */
+    char *locks;		/* lock[i] == 1 iff elts[i] is locked
+				   lock[i] == 0 iff elts[i] is unlocked but active
+				   lock[i] == 2 iff elts[i] doesn't contain valid data */
+    int autoLock;		/* 1 if auto locking is turned on */
+    int nofUnlocked;		/* nof tiles which are unlocked */
+    int minUnlocked;		/* min nof elts which have to remain unlocked. min = 1 */
+    int *next, *prev;		/* prev/next pointers for fifo */
+    int first, last;		/* index (into next) of first and last elt in fifo */
+    /* first == -1 iff fifo is empty */
+    int (*eltRemoveFun) ();	/* callback activated if the contents of an
+				   elt needs to be removed */
+    void *eltRemoveFunData;	/* pointer to user data passed along with
+				   eltRemoveFun */
+    int (*eltLoadFun) ();	/* callback activated to load contents of an elt */
+    void *eltLoadFunData;	/* pointer to user data passed along with
+				   eltLoadFun */
+    void *hash;			/* ptr to hashTable used to relate external names to
+				   internal indices (elts) */
+} G3D_cache;
+typedef struct
+    int nofNames;
+    int *index;
+    char *active;
+    int lastName;
+    int lastIndex;
+    int lastIndexActive;
+} G3d_cache_hash;
+/*Structures */
+typedef struct _d_interval
+    double low, high;
+    int inf;
+    struct _d_interval *next;
+} d_Interval;
+typedef struct _d_mask
+    d_Interval *list;
+} d_Mask;
+typedef int write_fn(int, const void *, void *);
+typedef int read_fn(int, void *, void *);
+/*============================== Prototypes ================================*/
+#include <grass/raster3ddefs.h>
+#endif /* #ifndef GRASS_RASTER3D_H */
Added: grass/trunk/include/raster3ddefs.h
--- grass/trunk/include/raster3ddefs.h	                        (rev 0)
+++ grass/trunk/include/raster3ddefs.h	2011-08-10 16:49:20 UTC (rev 47533)
@@ -0,0 +1,360 @@
+#ifndef GRASS_RASTER3DDEFS_H
+#define GRASS_RASTER3DDEFS_H
+/* cache.c */
+void G3d_cache_reset(G3D_cache *);
+void G3d_cache_dispose(G3D_cache *);
+void *G3d_cache_new(int, int, int, write_fn *, void *, read_fn *, void *);
+void G3d_cache_set_removeFun(G3D_cache *, write_fn *, void *);
+void G3d_cache_set_loadFun(G3D_cache *, read_fn *, void *);
+void *G3d_cache_new_read(int, int, int, read_fn *, void *);
+int G3d_cache_lock(G3D_cache *, int);
+void G3d_cache_lock_intern(G3D_cache *, int);
+int G3d_cache_unlock(G3D_cache *, int);
+int G3d_cache_unlock_all(G3D_cache *);
+int G3d_cache_lock_all(G3D_cache *);
+void G3d_cache_autolock_on(G3D_cache *);
+void G3d_cache_autolock_off(G3D_cache *);
+void G3d_cache_set_minUnlock(G3D_cache *, int);
+int G3d_cache_remove_elt(G3D_cache *, int);
+int G3d_cache_flush(G3D_cache *, int);
+int G3d_cache_remove_all(G3D_cache *);
+int G3d_cache_flush_all(G3D_cache *);
+void *G3d_cache_elt_ptr(G3D_cache *, int);
+int G3d_cache_load(G3D_cache *, int);
+int G3d_cache_get_elt(G3D_cache *, int, void *);
+int G3d_cache_put_elt(G3D_cache *, int, const void *);
+/* cachehash.c */
+void G3d_cache_hash_reset(G3d_cache_hash *);
+void G3d_cache_hash_dispose(G3d_cache_hash *);
+void *G3d_cache_hash_new(int);
+void G3d_cache_hash_remove_name(G3d_cache_hash *, int);
+void G3d_cache_hash_load_name(G3d_cache_hash *, int, int);
+int G3d_cache_hash_name2index(G3d_cache_hash *, int);
+/* changeprecision.c */
+void G3d_changePrecision(void *, int, const char *);
+/* changetype.c */
+void G3d_changeType(void *, const char *);
+/* filecompare.c */
+void G3d_compareFiles(const char *, const char *, const char *, const char *);
+/* filename.c */
+void G3d_filename(char *, const char *, const char *, const char *);
+/* find_grid3.c */
+char *G_find_grid3(const char *, const char *);
+/* fpcompress.c */
+void G_fpcompress_printBinary(char *, int);
+void G_fpcompress_dissectXdrDouble(unsigned char *);
+int G_fpcompress_writeXdrNums(int, char *, int, int, char *, int, int, int);
+int G_fpcompress_writeXdrFloats(int, char *, int, int, char *, int, int);
+int G_fpcompress_writeXdrDouble(int, char *, int, int, char *, int, int);
+int G_fpcompress_readXdrNums(int, char *, int, int, int, char *, int);
+int G_fpcompress_readXdrFloats(int, char *, int, int, int, char *);
+int G_fpcompress_readXdrDoubles(int, char *, int, int, int, char *);
+/* g3dalloc.c */
+void *G3d_malloc(int);
+void *G3d_realloc(void *, int);
+void G3d_free(void *);
+/* g3dcache.c */
+int G3d_initCache(G3D_Map *, int);
+int G3d_disposeCache(G3D_Map *);
+int G3d_flushAllTiles(G3D_Map *);
+/* g3dcats.c */
+int G3d_writeCats(const char *, struct Categories *);
+int G3d_readCats(const char *, const char *, struct Categories *);
+/* g3dclose.c */
+int G3d_closeCell(G3D_Map *);
+/* g3dcolor.c */
+int G3d_removeColor(const char *);
+int G3d_readColors(const char *, const char *, struct Colors *);
+int G3d_writeColors(const char *, const char *, struct Colors *);
+/* g3ddefaults.c */
+void G3d_setCompressionMode(int, int, int, int);
+void G3d_getCompressionMode(int *, int *, int *, int *);
+void G3d_setCacheSize(int);
+int G3d_getCacheSize(void);
+void G3d_setCacheLimit(int);
+int G3d_getCacheLimit(void);
+void G3d_setFileType(int);
+int G3d_getFileType(void);
+void G3d_setTileDimension(int, int, int);
+void G3d_getTileDimension(int *, int *, int *);
+void G3d_setErrorFun(void (*)(const char *));
+void G3d_setUnit(const char *);
+void G3d_initDefaults(void);
+/* g3ddoubleio.c */
+int G3d_writeDoubles(int, int, const double *, int);
+int G3d_readDoubles(int, int, double *, int);
+/* g3derror.c */
+void G3d_skipError(const char *);
+void G3d_printError(const char *);
+void G3d_fatalError(const char *, ...) __attribute__ ((format(printf, 1, 2)))
+    __attribute__ ((noreturn));
+void G3d_fatalError_noargs(const char *) __attribute__ ((noreturn));
+void G3d_error(const char *, ...) __attribute__ ((format(printf, 1, 2)));
+/* g3dfpxdr.c */
+int G3d_isXdrNullNum(const void *, int);
+int G3d_isXdrNullFloat(const float *);
+int G3d_isXdrNullDouble(const double *);
+void G3d_setXdrNullNum(void *, int);
+void G3d_setXdrNullDouble(double *);
+void G3d_setXdrNullFloat(float *);
+int G3d_initFpXdr(G3D_Map *, int);
+int G3d_initCopyToXdr(G3D_Map *, int);
+int G3d_copyToXdr(const void *, int);
+int G3d_initCopyFromXdr(G3D_Map *, int);
+int G3d_copyFromXdr(int, void *);
+/* g3dhistory.c */
+int G3d_writeHistory(const char *, struct History *);
+int G3d_readHistory(const char *, const char *, struct History *);
+/* g3dintio.c */
+int G3d_writeInts(int, int, const int *, int);
+int G3d_readInts(int, int, int *, int);
+/* g3dkeys.c */
+int G3d_keyGetInt(struct Key_Value *, const char *, int *);
+int G3d_keyGetDouble(struct Key_Value *, const char *, double *);
+int G3d_keyGetString(struct Key_Value *, const char *, char **);
+int G3d_keyGetValue(struct Key_Value *, const char *, char *, char *, int,
+		    int, int *);
+int G3d_keySetInt(struct Key_Value *, const char *, const int *);
+int G3d_keySetDouble(struct Key_Value *, const char *, const double *);
+int G3d_keySetString(struct Key_Value *, const char *, char *const *);
+int G3d_keySetValue(struct Key_Value *, const char *, const char *,
+		    const char *, int, int, const int *);
+/* g3dlong.c */
+int G3d_longEncode(long *, unsigned char *, int);
+void G3d_longDecode(unsigned char *, long *, int, int);
+/* g3dmapset.c */
+void G3d_makeMapsetMapDirectory(const char *);
+/* g3dmask.c */
+int G3d_maskClose(void);
+int G3d_maskFileExists(void);
+int G3d_maskOpenOld(void);
+int G3d_maskReopen(int);
+int G3d_isMasked(G3D_Map *, int, int, int);
+void G3d_maskNum(G3D_Map *, int, int, int, void *, int);
+void G3d_maskFloat(G3D_Map *, int, int, int, float *);
+void G3d_maskDouble(G3D_Map *, int, int, int, double *);
+void G3d_maskTile(G3D_Map *, int, void *, int);
+void G3d_maskOn(G3D_Map *);
+void G3d_maskOff(G3D_Map *);
+int G3d_maskIsOn(G3D_Map *);
+int G3d_maskIsOff(G3D_Map *);
+const char *G3d_maskFile(void);
+int G3d_maskMapExists(void);
+/* maskfn.c */
+int G3d_mask_d_select(DCELL *, d_Mask *);
+DCELL G3d_mask_match_d_interval(DCELL, d_Interval *);
+void G3d_parse_vallist(char **, d_Mask **);
+/* g3dmisc.c */
+int G3d_g3dType2cellType(int);
+void G3d_copyFloat2Double(const float *, int, double *, int, int);
+void G3d_copyDouble2Float(const double *, int, float *, int, int);
+void G3d_copyValues(const void *, int, int, void *, int, int, int);
+int G3d_length(int);
+int G3d_externLength(int);
+/* g3dnull.c */
+int G3d_isNullValueNum(const void *, int);
+void G3d_setNullValue(void *, int, int);
+/* g3dopen2.c */
+void *G3d_openNewParam(const char *, int , int, G3D_Region *, int, int, int, int, int, int, int);
+/* g3dopen.c */
+void *G3d_openCellOldNoHeader(const char *, const char *);
+void *G3d_openCellOld(const char *, const char *, G3D_Region *, int, int);
+void *G3d_openCellNew(const char *, int, int, G3D_Region *);
+void *G3d_openNewOptTileSize(const char *, int , G3D_Region * , int , int );
+/* g3dparam.c */
+void G3d_setStandard3dInputParams(void);
+int G3d_getStandard3dParams(int *, int *, int *, int *, int *, int *, int *,
+			    int *, int *, int *, int *, int *);
+void G3d_setWindowParams(void);
+char *G3d_getWindowParams(void);
+/* g3drange.c */
+void G3d_range_updateFromTile(G3D_Map *, const void *, int, int, int, int,
+			      int, int, int, int);
+int G3d_readRange(const char *, const char *, struct FPRange *);
+int G3d_range_load(G3D_Map *);
+void G3d_range_min_max(G3D_Map *, double *, double *);
+int G3d_range_write(G3D_Map *);
+int G3d_range_init(G3D_Map *);
+/* g3dregion.c */
+void G3d_getRegionValue(G3D_Map *, double, double, double, void *, int);
+void G3d_adjustRegion(G3D_Region *);
+void G3d_regionCopy(G3D_Region *, G3D_Region *);
+void G3d_incorporate2dRegion(struct Cell_head *, G3D_Region *);
+void G3d_regionFromToCellHead(struct Cell_head *, G3D_Region *);
+void G3d_adjustRegionRes(G3D_Region *);
+void G3d_extract2dRegion(G3D_Region *, struct Cell_head *);
+void G3d_regionToCellHead(G3D_Region *, struct Cell_head *);
+int G3d_readRegionMap(const char *, const char *, G3D_Region *);
+int G3d_isValidLocation(G3D_Region *, double, double, double);
+void G3d_location2coord(G3D_Region *, double, double, double, int *, int *, int *);
+void G3d_location2coord2(G3D_Region *, double, double, double, int *, int *, int *);
+void G3d_coord2location(G3D_Region *, double, double, double, double *, double *, double *);
+/* g3dresample.c */
+void G3d_nearestNeighbor(G3D_Map *, int, int, int, void *, int);
+void G3d_setResamplingFun(G3D_Map *, void (*)());
+void G3d_getResamplingFun(G3D_Map *, void (**)());
+void G3d_getNearestNeighborFunPtr(void (**)());
+/* g3dvolume.c */
+void G3d_getVolumeA(void *, double[2][2][2][3], int, int, int, void *, int);
+void G3d_getVolume(void *, double, double, double, double, double, double,
+		   double, double, double, double, double, double, int, int,
+		   int, void *, int);
+void G3d_getAlignedVolume(void *, double, double, double, double, double,
+			  double, int, int, int, void *, int);
+void G3d_makeAlignedVolumeFile(void *, const char *, double, double, double,
+			       double, double, double, int, int, int);
+/* g3dwindow.c */
+void G3d_getValue(G3D_Map *, int, int, int, void *, int);
+float G3d_getFloat(G3D_Map *, int, int, int);
+double G3d_getDouble(G3D_Map *, int, int, int);
+void G3d_getWindowValue(G3D_Map *, double, double, double, void *, int);
+G3D_Region *G3d_windowPtr(void);
+void G3d_setWindow(G3D_Region *);
+void G3d_setWindowMap(G3D_Map *, G3D_Region *);
+void G3d_getWindow(G3D_Region *);
+/* g3dwindowio.c */
+void G3d_useWindowParams(void);
+int G3d_readWindow(G3D_Region *, const char *);
+/* int G3d_writeWindow (G3D_Region *, char *); */
+/* getblock.c */
+void G3d_getBlockNocache(G3D_Map *, int, int, int, int, int, int, void *,
+			 int);
+void G3d_getBlock(G3D_Map *, int, int, int, int, int, int, void *, int);
+/* header.c */
+int G3d_readHeader(G3D_Map *, int *, int *, double *, double *, double *,
+		   double *, double *, double *, int *, int *, int *,
+		   double *, double *, double *, int *, int *, int *, int *,
+		   int *, int *, int *, int *, int *, int *, int *, char **);
+int G3d_writeHeader(G3D_Map *, int, int, double, double, double, double,
+		    double, double, int, int, int, double, double, double,
+		    int, int, int, int, int, int, int, int, int, int, int,
+		    char *);
+int G3d_cacheSizeEncode(int, int);
+int G3d__computeCacheSize(G3D_Map *, int);
+int G3d_fillHeader(G3D_Map *, int, int, int, int, int, int, int, int, int,
+		   int, int, int, int, int, int, int, double, double, double,
+		   double, double, double, int, int, int, double, double,
+		   double, char *);
+/* headerinfo.c */
+void G3d_getCoordsMap(G3D_Map *, int *, int *, int *);
+void G3d_getCoordsMapWindow(G3D_Map *, int *, int *, int *);
+void G3d_getNofTilesMap(G3D_Map *, int *, int *, int *);
+void G3d_getRegionMap(G3D_Map *, double *, double *, double *, double *,
+		      double *, double *);
+void G3d_getWindowMap(G3D_Map *, double *, double *, double *, double *,
+void G3d_getTileDimensionsMap(G3D_Map *, int *, int *, int *);
+int G3d_tileTypeMap(G3D_Map *);
+int G3d_fileTypeMap(G3D_Map *);
+int G3d_tilePrecisionMap(G3D_Map *);
+int G3d_tileUseCacheMap(G3D_Map *);
+void G3d_printHeader(G3D_Map *);
+void G3d_getRegionStructMap(G3D_Map *, G3D_Region *);
+/* index.c */
+int G3d_flushIndex(G3D_Map *);
+int G3d_initIndex(G3D_Map *, int);
+/* retile.c */
+void G3d_retile(void *, const char *, int, int, int);
+/* rle.c */
+int G_rle_count_only(char *, int, int);
+void G_rle_encode(char *, char *, int, int);
+void G_rle_decode(char *, char *, int, int, int *, int *);
+/* tilealloc.c */
+void *G3d_allocTilesType(G3D_Map *, int, int);
+void *G3d_allocTiles(G3D_Map *, int);
+void G3d_freeTiles(void *);
+/* tileio.c */
+void *G3d_getTilePtr(G3D_Map *, int);
+int G3d_tileLoad(G3D_Map *, int);
+int G3d__removeTile(G3D_Map *, int);
+float G3d_getFloatRegion(G3D_Map *, int, int, int);
+double G3d_getDoubleRegion(G3D_Map *, int, int, int);
+void G3d_getValueRegion(G3D_Map *, int, int, int, void *, int);
+/* tilemath.c */
+void G3d_computeOptimalTileDimension(G3D_Region *, int, int *, int *, int *, int);
+void G3d_tileIndex2tile(G3D_Map *, int, int *, int *, int *);
+int G3d_tile2tileIndex(G3D_Map *, int, int, int);
+void G3d_tileCoordOrigin(G3D_Map *, int, int, int, int *, int *, int *);
+void G3d_tileIndexOrigin(G3D_Map *, int, int *, int *, int *);
+void G3d_coord2tileCoord(G3D_Map *, int, int, int, int *, int *, int *, int *,
+			 int *, int *);
+void G3d_coord2tileIndex(G3D_Map *, int, int, int, int *, int *);
+int G3d_coordInRange(G3D_Map *, int, int, int);
+int G3d_tileIndexInRange(G3D_Map *, int);
+int G3d_tileInRange(G3D_Map *, int, int, int);
+int G3d_computeClippedTileDimensions(G3D_Map *, int, int *, int *, int *,
+				     int *, int *, int *);
+/* tilenull.c */
+void G3d_setNullTileType(G3D_Map *, void *, int);
+void G3d_setNullTile(G3D_Map *, void *);
+/* tileread.c */
+int G3d_readTile(G3D_Map *, int, void *, int);
+int G3d_readTileFloat(G3D_Map *, int, void *);
+int G3d_readTileDouble(G3D_Map *, int, void *);
+int G3d_lockTile(G3D_Map *, int);
+int G3d_unlockTile(G3D_Map *, int);
+int G3d_unlockAll(G3D_Map *);
+void G3d_autolockOn(G3D_Map *);
+void G3d_autolockOff(G3D_Map *);
+void G3d_minUnlocked(G3D_Map *, int);
+int G3d_beginCycle(G3D_Map *);
+int G3d_endCycle(G3D_Map *);
+/* tilewrite.c */
+int G3d_writeTile(G3D_Map *, int, const void *, int);
+int G3d_writeTileFloat(G3D_Map *, int, const void *);
+int G3d_writeTileDouble(G3D_Map *, int, const void *);
+int G3d_flushTile(G3D_Map *, int);
+int G3d_flushTileCube(G3D_Map *, int, int, int, int, int, int);
+int G3d_flushTilesInCube(G3D_Map *, int, int, int, int, int, int);
+int G3d_putFloat(G3D_Map *, int, int, int, float);
+int G3d_putDouble(G3D_Map *, int, int, int, double);
+int G3d_putValue(G3D_Map *, int, int, int, const void *, int);
+/* writeascii.c */
+void G3d_writeAscii(void *, const char *);
+#endif /* RASTER3DDEFS */
Property changes on: grass/trunk/include/raster3ddefs.h
___________________________________________________________________
Added: svn:mime-type
   + text/x-chdr
Added: svn:eol-style
   + native
