[GRASS-SVN] r47563 - grass/trunk/vector/v.colors
svn_grass at osgeo.org
Thu Aug 11 16:57:51 EDT 2011
Author: martinl
Date: 2011-08-11 13:57:51 -0700 (Thu, 11 Aug 2011)
New Revision: 47563
Added:
grass/trunk/vector/v.colors/Makefile
grass/trunk/vector/v.colors/local_proto.h
grass/trunk/vector/v.colors/main.c
grass/trunk/vector/v.colors/scan_cats.c
grass/trunk/vector/v.colors/v.colors.html
v.colors (C program) added
Property changes on: grass/trunk/vector/v.colors
___________________________________________________________________
Added: svn:ignore
+ OBJ.*
Added: grass/trunk/vector/v.colors/Makefile
--- grass/trunk/vector/v.colors/Makefile (rev 0)
+++ grass/trunk/vector/v.colors/Makefile 2011-08-11 20:57:51 UTC (rev 47563)
@@ -0,0 +1,12 @@
+MODULE_TOPDIR = ../..
+PGM = v.colors
+LIBES = $(VECTORLIB) $(DBMILIB) $(GISLIB) $(RASTERLIB) $(RASTER3DLIB)
+DEPENDENCIES = $(VECTORDEP) $(DBMIDEP) $(GISDEP) $(RASTERDEP) $(RASTER3DDEP)
+EXTRA_INC = $(VECT_INC)
+EXTRA_CFLAGS = $(VECT_CFLAGS)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Property changes on: grass/trunk/vector/v.colors/Makefile
Added: svn:mime-type
+ text/x-makefile
Added: svn:eol-style
+ native
Added: grass/trunk/vector/v.colors/local_proto.h
--- grass/trunk/vector/v.colors/local_proto.h (rev 0)
+++ grass/trunk/vector/v.colors/local_proto.h 2011-08-11 20:57:51 UTC (rev 47563)
@@ -0,0 +1 @@
+void scan_cats(const struct Map_info *, int, int *, int*);
Property changes on: grass/trunk/vector/v.colors/local_proto.h
+ text/x-chdr
+ native
Added: grass/trunk/vector/v.colors/main.c
--- grass/trunk/vector/v.colors/main.c (rev 0)
+++ grass/trunk/vector/v.colors/main.c 2011-08-11 20:57:51 UTC (rev 47563)
@@ -0,0 +1,279 @@
+ * MODULE: v.colors
+ * AUTHOR(S): Martin Landa <landa.martin gmail.com>
+ * PURPOSE: Manage color tables for vector maps
+ * COPYRIGHT: (C) 2011 by the GRASS Development Team
+ * This program is free software under the GNU General
+ * Public License (>=v2). Read the file COPYING that
+ * comes with GRASS for details.
+#include <string.h>
+#include <stdlib.h>
+#include <grass/gis.h>
+#include <grass/raster.h>
+#include <grass/raster3d.h>
+#include <grass/vector.h>
+#include <grass/glocale.h>
+#include "local_proto.h"
+int main(int argc, char *argv[])
+ struct GModule *module;
+ struct {
+ struct Flag *r, *w, *l, *g, *a, *n, *e;
+ } flag;
+ struct {
+ struct Option *map, *field, *colr, *rast, *volume, *rules;
+ } opt;
+ int min, max, layer;
+ int have_stats;
+ int overwrite, remove, is_from_stdin, stat, have_colors;
+ const char *mapset, *cmapset;
+ const char *name, *style, *rules, *cmap;
+ struct Map_info Map;
+ struct Colors colors, colors_tmp;
+ /* struct Cell_stats statf; */
+ G_gisinit(argv[0]);
+ module = G_define_module();
+ G_add_keyword(_("vector"));
+ G_add_keyword(_("color table"));
+ module->description =
+ _("Creates/modifies the color table associated with a vector map.");
+ opt.map = G_define_standard_option(G_OPT_V_MAP);
+ opt.field = G_define_standard_option(G_OPT_V_FIELD);
+ opt.colr = G_define_standard_option(G_OPT_M_COLR);
+ opt.rast = G_define_standard_option(G_OPT_R_INPUT);
+ opt.rast->key = "raster";
+ opt.rast->required = NO;
+ opt.rast->description =
+ _("Raster map from which to copy color table");
+ opt.rast->guisection = _("Define");
+ opt.volume = G_define_standard_option(G_OPT_R3_INPUT);
+ opt.volume->key = "volume";
+ opt.volume->required = NO;
+ opt.volume->description =
+ _("3D raster map from which to copy color table");
+ opt.volume->guisection = _("Define");
+ opt.rules = G_define_standard_option(G_OPT_F_INPUT);
+ opt.rules->key = "rules";
+ opt.rules->required = NO;
+ opt.rules->label = _("Path to rules file");
+ opt.rules->description = _("\"-\" to read rules from stdin");
+ opt.rules->guisection = _("Define");
+ flag.r = G_define_flag();
+ flag.r->key = 'r';
+ flag.r->description = _("Remove existing color table");
+ flag.r->guisection = _("Remove");
+ flag.w = G_define_flag();
+ flag.w->key = 'w';
+ flag.w->description =
+ _("Only write new color table if one doesn't already exist");
+ flag.l = G_define_flag();
+ flag.l->key = 'l';
+ flag.l->description = _("List available rules then exit");
+ flag.l->suppress_required = YES;
+ flag.l->guisection = _("Print");
+ flag.n = G_define_flag();
+ flag.n->key = 'n';
+ flag.n->description = _("Invert colors");
+ flag.n->guisection = _("Define");
+ flag.g = G_define_flag();
+ flag.g->key = 'g';
+ flag.g->description = _("Logarithmic scaling");
+ flag.g->guisection = _("Define");
+ flag.a = G_define_flag();
+ flag.a->key = 'a';
+ flag.a->description = _("Logarithmic-absolute scaling");
+ flag.a->guisection = _("Define");
+ flag.e = G_define_flag();
+ flag.e->key = 'e';
+ flag.e->description = _("Histogram equalization");
+ flag.e->guisection = _("Define");
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
+ if (flag.l->answer) {
+ G_list_color_rules(stdout);
+ return EXIT_SUCCESS;
+ overwrite = !flag.w->answer;
+ remove = flag.r->answer;
+ name = opt.map->answer;
+ style = opt.colr->answer;
+ rules = opt.rules->answer;
+ have_stats = FALSE;
+ if (!name)
+ G_fatal_error(_("No vector map specified"));
+ if (opt.rast->answer && opt.volume->answer)
+ G_fatal_error(_("Options <%s> and <%s> are mutually exclusive"),
+ opt.rast->key, opt.volume->key);
+ cmap = NULL;
+ if (opt.rast->answer)
+ cmap = opt.rast->answer;
+ if (opt.volume->answer)
+ cmap = opt.volume->answer;
+ if (!cmap && !style && !rules && !remove)
+ G_fatal_error(_("One of -%c or options <%s>, <%s> or <%s> "
+ "must be specified"), flag.r->key, opt.colr->key,
+ opt.rast->key, opt.rules->key);
+ if (!!style + !!cmap + !!rules > 1)
+ G_fatal_error(_("Options <%s>, <%s>, and <%s> are mutually "
+ "exclusive"), opt.colr->key, opt.rules->key,
+ opt.rast->key);
+ if (flag.g->answer && flag.a->answer)
+ G_fatal_error(_("Flags -%c and -%c flags are mutually exclusive"),
+ flag.g->key, flag.a->key);
+ is_from_stdin = rules && strcmp(rules, "-") == 0;
+ if (is_from_stdin)
+ rules = NULL;
+ /* open map and get min/max values */
+ Vect_open_old2(&Map, name, "", opt.field->answer);
+ name = Vect_get_name(&Map);
+ mapset = Vect_get_mapset(&Map);
+ stat = -1;
+ if (remove) {
+ stat = Vect_remove_colors(name, mapset);
+ if (stat < 0)
+ G_fatal_error(_("Unable to remove color table of vector map <%s>"), name);
+ if (stat == 0)
+ G_warning(_("Color table of vector map <%s> not found"), name);
+ G_suppress_warnings(TRUE);
+ have_colors = Vect_read_colors(name, mapset, &colors);
+ if (have_colors > 0 && !overwrite) {
+ G_fatal_error(_("Color table exists. Exiting."));
+ G_suppress_warnings(FALSE);
+ layer = Vect_get_field_number(&Map, opt.field->answer);
+ if (layer < 1)
+ G_fatal_error(_("Layer <%s> not found"), opt.field->answer);
+ scan_cats(&Map, layer, &min, &max);
+ if (is_from_stdin) {
+ if (!read_color_rules(stdin, &colors, min, max, fp))
+ } else if (style) {
+ if (strcmp(style, "random") == 0) {
+ Rast_make_random_colors(&colors, (CELL) min, (CELL) max);
+ } else if (strcmp(style, "grey.eq") == 0) {
+ G_fatal_error(_("Color table <%s> not supported"), "grey.eq");
+ if (!have_stats)
+ have_stats = get_stats(name, mapset, &statf);
+ Rast_make_histogram_eq_colors(&colors, &statf);
+ } else if (strcmp(style, "grey.log") == 0) {
+ G_fatal_error(_("Color table <%s> not supported"), "grey.log");
+ if (!have_stats)
+ Rast_make_histogram_log_colors(&colors, &statf, (CELL) min,
+ (CELL) max);
+ } else if (G_find_color_rule(style))
+ Rast_make_colors(&colors, style, (CELL) min, (CELL) max);
+ else
+ G_fatal_error(_("Unknown color request '%s'"), style);
+ else if (rules) {
+ if (!Rast_load_fp_colors(&colors, rules, min, max))
+ G_fatal_error(_("Unable to load rules file <%s>"), rules);
+ else {
+ /* use color from another map (cmap) */
+ if (opt.rast->answer) {
+ cmapset = G_find_raster2(cmap, "");
+ if (!cmapset)
+ G_fatal_error(_("Raster map <%s> not found"), cmap);
+ if (Rast_read_colors(cmap, cmapset, &colors) < 0)
+ G_fatal_error(_("Unable to read color table for raster map <%s>"), cmap);
+ } else {
+ cmapset = G_find_grid3(cmap, "");
+ if (!cmapset)
+ G_fatal_error(_("3D raster map <%s> not found"), cmap);
+ if (Rast3d_readColors(cmap, cmapset, &colors) < 0)
+ G_fatal_error(_("Unable to read color table for 3D raster map <%s>"), cmap);
+ if (flag.n->answer)
+ Rast_invert_colors(&colors);
+ if (flag.e->answer) {
+ G_fatal_error(_("Flag -%c needs to be implemeneted"));
+ if (!have_stats)
+ Rast_histogram_eq_colors(&colors_tmp, &colors, &statf);
+ colors = colors_tmp;
+ if (flag.g->answer) {
+ Rast_log_colors(&colors_tmp, &colors, 100);
+ if (flag.a->answer) {
+ Rast_abs_log_colors(&colors_tmp, &colors, 100);
+ Vect_write_colors(name, mapset, &colors);
+ G_message(_("Color table for vector map <%s> set to '%s'"),
+ G_fully_qualified_name(name, mapset),
+ is_from_stdin ? "rules" : style ? style : rules ? rules :
+ cmap);
+ exit(EXIT_SUCCESS);
Property changes on: grass/trunk/vector/v.colors/main.c
+ text/x-csrc
+ native
Added: grass/trunk/vector/v.colors/scan_cats.c
--- grass/trunk/vector/v.colors/scan_cats.c (rev 0)
+++ grass/trunk/vector/v.colors/scan_cats.c 2011-08-11 20:57:51 UTC (rev 47563)
@@ -0,0 +1,49 @@
+static void scan_layer(int, const struct line_cats *, int *, int *);
+void scan_cats(const struct Map_info *Map, int field, int *min, int* max)
+ int ltype, cmin, cmax;
+ struct line_cats *Cats;
+ *min = *max = -1;
+ Cats = Vect_new_cats_struct();
+ while(TRUE) {
+ ltype = Vect_read_next_line(Map, NULL, Cats);
+ if (ltype == -1)
+ G_fatal_error(_("Unable to read vector map"));
+ if (ltype == -2)
+ break; /* EOF */
+ scan_layer(field, Cats, &cmin, &cmax);
+ if (*min == -1 || cmin <= *min)
+ *min = cmin;
+ if (*max == -1 || cmax >= *max)
+ *max = cmax;
+ Vect_destroy_cats_struct(Cats);
+void scan_layer(int field, const struct line_cats *Cats, int *cmin, int *cmax)
+ int n, cat;
+ *cmin = *cmax = -1;
+ for (n = 0; n < Cats->n_cats; n++) {
+ if (Cats->field[n] == field) {
+ cat = Cats->cat[n];
+ if (*cmin == -1 || cat <= *cmin)
+ *cmin = cat;
+ if (*cmax == -1 || cat >= *cmax)
+ *cmax = cat;
Property changes on: grass/trunk/vector/v.colors/scan_cats.c
+ text/x-csrc
+ native
Added: grass/trunk/vector/v.colors/v.colors.html
--- grass/trunk/vector/v.colors/v.colors.html (rev 0)
+++ grass/trunk/vector/v.colors/v.colors.html 2011-08-11 20:57:51 UTC (rev 47563)
@@ -0,0 +1,69 @@
+<h2>DESCRIPTION</h2>
+<em>v.colors</em> allows the user to create and/or modify the color
+table for a vector map. The vector map (specified on the command line
+by <b>map=</b>) must exist in the user's current mapset search path.
+<p>
+The <b>rast</b> option allows user to specify a raster map <i>name</i>
+from which to copy the color map.
+<p>
+The <b>volume</b> option allows user to specify a volume (3D raster)
+map <i>name</i> from which to copy the color map.
+<p>
+If the user specifies the <b>-w</b> flag, the current color table file
+for the input map will not be overwritten. This means that the color
+table is created only if the <i>map</i> does not already have a color
+table. If this option is not specified, the color table will be
+created if one does not exist, or modified if it does.
+<p>
+In general, tables which associate colors with percentages (aspect,
+bcyr, byg, byr, elevation, grey, gyr, rainbow, ramp, ryb, ryg and
+wave) can be applied to any data, while those which use absolute
+values (aspectcolr, curvature, etopo2, evi, ndvi, population, slope,
+srtm, and terrain) only make sense for data with certain ranges.
+One can get a rough idea of the applicability of a colour table by
+reading the corresponding rules file
+(<tt>$GISBASE/etc/colors/<name></tt>). For example
+the <em>ryg</em> rule is defined as:
+<div class="code"><pre>
+0% red
+50% yellow
+100% green
+</pre></div>
+<p>
+The <b>rules</b> color table type will cause <em>r.colors</em> to read
+color table specifications from standard input and will build
+the color table accordingly.
+<p>
+For details see <em><a href="r.colors.html">r.colors</a></em> manual page.
+<h2>EXAMPLES</h2>
+<h2>SEE ALSO</h2>
+<em>
+ <a href="d.vect.html">d.vect</a>,
+ <a href="r.colors.html">r.colors</a>,
+ <a href="r3.colors.html">r3.colors</a>,
+</em>
+<p>
+See also wiki
+page <a href="http://grass.osgeo.org/wiki/Color_tables">Color
+tables</a> (from GRASS User Wiki)
+<h2>AUTHORS</h2>
+Adopted <a href="r.colors.html">r.colors</a> by Martin Landa, Czech
+Technical University in Prague, Czech Republic
+<p>
+<i>Last changed: $Date$</i>
Property changes on: grass/trunk/vector/v.colors/v.colors.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
