[GRASS-SVN] r47570 - grass/trunk/lib/init
svn_grass at osgeo.org
Thu Aug 11 17:16:47 EDT 2011
Author: martinl
Date: 2011-08-11 14:16:47 -0700 (Thu, 11 Aug 2011)
New Revision: 47570
grass/trunk/lib/init/grass.py
grass.py (r47557):
use sys.stdout.write instead of print
fix indentation
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2011-08-11 21:16:02 UTC (rev 47569)
+++ grass/trunk/lib/init/grass.py 2011-08-11 21:16:47 UTC (rev 47570)
@@ -671,7 +671,7 @@
message(_("Executing '%s' ...") % batch_job)
grass_gui = "text"
shell = batch_job
- bj = Popen(shell,shell=True)
+ bj = Popen(shell, shell=True)
bj.wait()
message(_("Execution of '%s' finished.") % batch_job)
@@ -860,27 +860,32 @@
return [elem for elem in list if expr.match(elem)]
def print_params():
- plat = os.path.join(gisbase,'include','Make','Platform.make')
- fileplat = open(plat)
- linesplat = fileplat.readlines()
- fileplat.close()
- for i in sys.argv[2:]:
- if i == 'path':
- print gisbase
- elif i == 'arch':
- val = grep('ARCH',linesplat)
- print val[0].split('=')[1].strip()
- elif i == 'build':
- build = os.path.join(gisbase,'include','grass','confparms.h')
- filebuild = open(build)
- val = filebuild.readline()
- print val.strip().strip('"').strip()
- elif i == 'compiler':
- val = grep('CC',linesplat)
- else:
- print "Parameter not supported"
+ plat = gfile(gisbase, 'include', 'Make', 'Platform.make')
+ fileplat = open(plat)
+ linesplat = fileplat.readlines()
+ fileplat.close()
+ params = sys.argv[2:]
+ if not params:
+ params = ['arch', 'build', 'compiler', 'path']
+ for arg in params:
+ if arg == 'path':
+ sys.stdout.write("%s\n" % gisbase)
+ elif arg == 'arch':
+ val = grep('ARCH',linesplat)
+ sys.stdout.write("%s\n" % val[0].split('=')[1].strip())
+ elif arg == 'build':
+ build = os.path.join(gisbase,'include','grass','confparms.h')
+ filebuild = open(build)
+ val = filebuild.readline()
+ sys.stdout.write("%s\n" % val.strip().strip('"').strip())
+ elif arg == 'compiler':
+ val = grep('CC',linesplat)
+ else:
+ error(_("Parameter <%s> not supported") % i)
def get_username():
global user
if windows:
