[GRASS-SVN] r47576 - grass/trunk/scripts/g.extension
svn_grass at osgeo.org
Thu Aug 11 17:34:00 EDT 2011
Author: martinl
Date: 2011-08-11 14:34:00 -0700 (Thu, 11 Aug 2011)
New Revision: 47576
grass/trunk/scripts/g.extension/g.extension.py
g.extension: fix `remove` action
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py 2011-08-11 21:28:55 UTC (rev 47575)
+++ grass/trunk/scripts/g.extension/g.extension.py 2011-08-11 21:34:00 UTC (rev 47576)
@@ -392,16 +392,17 @@
def remove_extension():
# is module available?
- if not os.path.exists(os.path.join(options['prefix'], 'bin', options['extension'])):
- grass.fatal(_("Module '%s' not found") % options['extension'])
+ bin_dir = os.path.join(options['prefix'], 'bin', options['extension'])
+ scr_dir = os.path.join(options['prefix'], 'scripts', options['extension'])
+ if not os.path.exists(bin_dir) and not os.path.exists(scr_dir):
+ grass.fatal(_("Module <%s> not found") % options['extension'])
- for file in [os.path.join(options['prefix'], 'bin', options['extension']),
- os.path.join(options['prefix'], 'scripts', options['extension']),
- os.path.join(options['prefix'], 'docs', 'html', options['extension'] + '.html')]:
- if os.path.isfile(file):
- os.remove(file)
- grass.message(_("'%s' successfully uninstalled.") % options['extension'])
+ for f in [bin_dir, scr_dir,
+ os.path.join(options['prefix'], 'docs', 'html', options['extension'] + '.html'),
+ os.path.join(options['prefix'], 'man', 'man1', options['extension'] + '.1')]:
+ grass.try_remove(f)
+ grass.message(_("Module <%s> successfully uninstalled") % options['extension'])
def create_dir(path):
if os.path.isdir(path):
