[GRASS-SVN] r47579 - in grass/branches/releasebranch_6_4: . lib/cairodriver
Thu Aug 11 18:00:45 EDT 2011
Author: neteler
Date: 2011-08-11 15:00:45 -0700 (Thu, 11 Aug 2011)
New Revision: 47579
   grass/branches/releasebranch_6_4/configure
   grass/branches/releasebranch_6_4/configure.in
   grass/branches/releasebranch_6_4/lib/cairodriver/Graph.c
backport of r47311
Modified: grass/branches/releasebranch_6_4/configure
--- grass/branches/releasebranch_6_4/configure	2011-08-11 21:43:13 UTC (rev 47578)
+++ grass/branches/releasebranch_6_4/configure	2011-08-11 22:00:45 UTC (rev 47579)
@@ -14466,10 +14466,16 @@
 if test -n "$USE_CAIRO"; then
-cairo="cairo cairo-ft"
+cairo="cairo"
+pkgs="cairo-ft cairo-fc"
 if test -n "$USE_X11"; then
-	cairo="$cairo cairo-xlib-xrender"
+	pkgs="$pkgs cairo-xlib-xrender"
 fi
+for pkg in $pkgs ; do
+    if pkg-config --exists $pkg ; then
+        cairo="$cairo $pkg"
+    fi
+done
 # With Cairo includes directory
 #FIXME: somehow quote dirs with spaces in $cairo ?
@@ -14477,7 +14483,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:14481: checking for location of cairo includes" >&5
+echo "configure:14487: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -14503,15 +14509,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:14507: checking for $ac_hdr" >&5
+echo "configure:14513: checking for $ac_hdr" >&5
 cat > conftest.$ac_ext <<EOF
-#line 14510 "configure"
+#line 14516 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:14515: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14521: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -14547,7 +14553,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:14551: checking for location of cairo library" >&5
+echo "configure:14557: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -14567,7 +14573,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:14571: checking for cairo linking flags" >&5
+echo "configure:14577: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -14583,10 +14589,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:14587: checking for cairo_create" >&5
+echo "configure:14593: checking for cairo_create" >&5
-#line 14590 "configure"
+#line 14596 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char cairo_create(); below.  */
@@ -14609,7 +14615,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14613: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14619: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -14643,10 +14649,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:14647: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:14653: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 14650 "configure"
+#line 14656 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -14669,7 +14675,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14673: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14679: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -14697,6 +14703,65 @@
+ac_save_libs="$LIBS"
+ac_save_ldflags="$LDFLAGS"
+LIBS=" $CAIROLIB $LIBS"
+LDFLAGS=" $LDFLAGS"
+echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
+echo "configure:14712: checking for cairo_xlib_surface_get_xrender_format" >&5
+cat > conftest.$ac_ext <<EOF
+#line 14715 "configure"
+#include "confdefs.h"
+/* System header to define __stub macros and hopefully few prototypes,
+    which can conflict with char cairo_xlib_surface_get_xrender_format(); below.  */
+#include <assert.h>
+/* Override any gcc2 internal prototype to avoid an error.  */
+/* We use char because int might match the return type of a gcc2
+    builtin and then its argument prototype would still apply.  */
+char cairo_xlib_surface_get_xrender_format();
+int main() {
+/* The GNU C library defines this for functions which it implements
+    to always fail with ENOSYS.  Some functions are actually named
+    something starting with __ and the normal name is an alias.  */
+#if defined (__stub_cairo_xlib_surface_get_xrender_format) || defined (__stub___cairo_xlib_surface_get_xrender_format)
+choke me
+#else
+cairo_xlib_surface_get_xrender_format();
+#endif
+; return 0; }
+EOF
+if { (eval echo configure:14738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+  eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
+else
+  echo "configure: failed program was:" >&5
+  cat conftest.$ac_ext >&5
+  rm -rf conftest*
+  eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=no"
+fi
+rm -f conftest*
+if eval "test \"`echo '$ac_cv_func_'cairo_xlib_surface_get_xrender_format`\" = yes"; then
+  echo "$ac_t""yes" 1>&6
+CAIRO_HAS_XRENDER_SURFACE=1
+else
+  echo "$ac_t""no" 1>&6
+fi
+LIBS=${ac_save_libs}
+LDFLAGS=${ac_save_ldflags}
 CAIROLIB="$CAIROLIB $CAIROLDFLAGS"
 fi # $USE_CAIRO
@@ -14711,7 +14776,7 @@
 echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:14715: checking whether to use GLw" >&5
+echo "configure:14780: checking whether to use GLw" >&5
 echo "$ac_t"""$with_glw"" 1>&6
 case "$with_glw" in
 	"no")	USE_GLW=	;;
@@ -14730,7 +14795,7 @@
 echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:14734: checking for location of GLw includes" >&5
+echo "configure:14799: checking for location of GLw includes" >&5
 case "$with_glw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -14756,15 +14821,15 @@
 do
-echo "configure:14760: checking for $ac_hdr" >&5
+echo "configure:14825: checking for $ac_hdr" >&5
-#line 14763 "configure"
+#line 14828 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14768: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14833: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14792,15 +14857,15 @@
 do
-echo "configure:14796: checking for $ac_hdr" >&5
+echo "configure:14861: checking for $ac_hdr" >&5
-#line 14799 "configure"
+#line 14864 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14804: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14869: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14840,7 +14905,7 @@
 echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:14844: checking for location of GLw library" >&5
+echo "configure:14909: checking for location of GLw library" >&5
 case "$with_glw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -14865,13 +14930,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14869: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:14934: checking for GLwCreateMDrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14875 "configure"
+#line 14940 "configure"
@@ -14882,7 +14947,7 @@
 GLwCreateMDrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14886: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -14907,13 +14972,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14911: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:14976: checking for GLwCreateM1DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14917 "configure"
+#line 14982 "configure"
@@ -14924,7 +14989,7 @@
 GLwCreateM1DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14928: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14993: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14949,13 +15014,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14953: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:15018: checking for GLwCreateM2DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14959 "configure"
+#line 15024 "configure"
@@ -14966,7 +15031,7 @@
 GLwCreateM2DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15035: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14991,13 +15056,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14995: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:15060: checking for GLwCreateMDrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 15001 "configure"
+#line 15066 "configure"
@@ -15008,7 +15073,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15012: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15077: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15033,13 +15098,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:15037: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:15102: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 15043 "configure"
+#line 15108 "configure"
@@ -15050,7 +15115,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15054: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15119: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15075,13 +15140,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:15079: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:15144: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 15085 "configure"
+#line 15150 "configure"
@@ -15092,7 +15157,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15096: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15161: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15119,13 +15184,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:15123: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:15188: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 15129 "configure"
+#line 15194 "configure"
@@ -15136,7 +15201,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15140: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15205: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15155,13 +15220,13 @@
-echo "configure:15159: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:15224: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 15165 "configure"
+#line 15230 "configure"
@@ -15172,7 +15237,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15241: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15199,13 +15264,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:15203: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15268: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 15209 "configure"
+#line 15274 "configure"
@@ -15216,7 +15281,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15220: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15285: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15235,13 +15300,13 @@
-echo "configure:15239: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15304: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 15245 "configure"
+#line 15310 "configure"
@@ -15252,7 +15317,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15256: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15321: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15365,7 +15430,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:15369: checking whether to use FreeType" >&5
+echo "configure:15434: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -15384,7 +15449,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:15388: checking for location of FreeType includes" >&5
+echo "configure:15453: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -15410,15 +15475,15 @@
 do
-echo "configure:15414: checking for $ac_hdr" >&5
+echo "configure:15479: checking for $ac_hdr" >&5
-#line 15417 "configure"
+#line 15482 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15422: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15487: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15452,7 +15517,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:15456: checking for location of FreeType library" >&5
+echo "configure:15521: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -15477,13 +15542,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:15481: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:15546: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 15487 "configure"
+#line 15552 "configure"
@@ -15494,7 +15559,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:15498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15563: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15535,7 +15600,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:15539: checking whether to use NLS" >&5
+echo "configure:15604: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -15555,10 +15620,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:15559: checking for gettext" >&5
+echo "configure:15624: checking for gettext" >&5
-#line 15562 "configure"
+#line 15627 "configure"
     which can conflict with char gettext(); below.  */
@@ -15581,7 +15646,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15585: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15650: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -15599,13 +15664,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:15603: checking for gettext in -lintl" >&5
+echo "configure:15668: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 15609 "configure"
+#line 15674 "configure"
@@ -15616,7 +15681,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:15620: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15651,7 +15716,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:15655: checking whether to use C++" >&5
+echo "configure:15720: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -15667,7 +15732,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:15671: checking for $ac_word" >&5
+echo "configure:15736: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -15696,7 +15761,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:15700: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:15765: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -15707,12 +15772,12 @@
 cat > conftest.$ac_ext << EOF
-#line 15711 "configure"
+#line 15776 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:15716: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15781: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -15738,19 +15803,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:15742: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:15807: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:15747: checking whether we are using GNU C++" >&5
+echo "configure:15812: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15754: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15819: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -15768,7 +15833,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:15772: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:15837: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -15809,7 +15874,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:15813: checking whether to use openDWG" >&5
+echo "configure:15878: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -15829,7 +15894,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:15833: checking for location of openDGW includes" >&5
+echo "configure:15898: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -15855,15 +15920,15 @@
 do
-echo "configure:15859: checking for $ac_hdr" >&5
+echo "configure:15924: checking for $ac_hdr" >&5
-#line 15862 "configure"
+#line 15927 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15867: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15932: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15897,7 +15962,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:15901: checking for location of openDWG library" >&5
+echo "configure:15966: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -15944,7 +16009,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:15948: checking for special C compiler options needed for large files" >&5
+echo "configure:16013: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -15952,7 +16017,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 15956 "configure"
+#line 16021 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -15968,7 +16033,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15972: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16037: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -15977,7 +16042,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 15981 "configure"
+#line 16046 "configure"
@@ -15993,7 +16058,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15997: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16062: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -16013,11 +16078,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:16017: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:16082: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 16021 "configure"
+#line 16086 "configure"
@@ -16033,14 +16098,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:16037: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16102: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 16044 "configure"
+#line 16109 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -16058,7 +16123,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:16062: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16127: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -16077,11 +16142,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:16081: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:16146: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 16085 "configure"
+#line 16150 "configure"
@@ -16097,14 +16162,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:16101: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16166: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 16108 "configure"
+#line 16173 "configure"
 #define _LARGE_FILES 1
@@ -16122,7 +16187,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:16126: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16191: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -16141,25 +16206,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:16145: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:16210: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 16149 "configure"
+#line 16214 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:16156: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16221: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 16163 "configure"
+#line 16228 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -16168,7 +16233,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:16172: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16237: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -16189,10 +16254,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:16193: checking if system supports Large Files at all" >&5
+echo "configure:16258: checking if system supports Large Files at all" >&5
-#line 16196 "configure"
+#line 16261 "configure"
 #include <stdio.h>
@@ -16224,7 +16289,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:16228: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16293: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -16253,7 +16318,7 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:16257: checking whether to use Python" >&5
+echo "configure:16322: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
@@ -16273,7 +16338,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
-echo "configure:16277: checking for $ac_word" >&5
+echo "configure:16342: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -16315,15 +16380,15 @@
 do
-echo "configure:16319: checking for $ac_hdr" >&5
+echo "configure:16384: checking for $ac_hdr" >&5
-#line 16322 "configure"
+#line 16387 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:16327: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16392: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -16393,7 +16458,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:16397: checking whether to use wxWidgets" >&5
+echo "configure:16462: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -16414,7 +16479,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:16418: checking for $ac_word" >&5
+echo "configure:16483: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -16462,7 +16527,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:16466: checking wxWidgets version" >&5
+echo "configure:16531: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -16485,15 +16550,15 @@
 do
-echo "configure:16489: checking for $ac_hdr" >&5
+echo "configure:16554: checking for $ac_hdr" >&5
-#line 16492 "configure"
+#line 16557 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:16497: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16562: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -16820,6 +16885,7 @@
 s%@XMINC@%$XMINC%g
 s%@XMLIB@%$XMLIB%g
 s%@CAIRO_HAS_XRENDER@%$CAIRO_HAS_XRENDER%g
+s%@CAIRO_HAS_XRENDER_SURFACE@%$CAIRO_HAS_XRENDER_SURFACE%g
 s%@CAIROINC@%$CAIROINC%g
 s%@CAIROLIB@%$CAIROLIB%g
 s%@USE_CAIRO@%$USE_CAIRO%g
Modified: grass/branches/releasebranch_6_4/configure.in
--- grass/branches/releasebranch_6_4/configure.in	2011-08-11 21:43:13 UTC (rev 47578)
+++ grass/branches/releasebranch_6_4/configure.in	2011-08-11 22:00:45 UTC (rev 47579)
@@ -1639,10 +1639,16 @@
+cairo="cairo"
 fi
+    fi
+done
@@ -1663,6 +1669,9 @@
 LOC_CHECK_FUNC(cairo_xlib_surface_create_with_xrender_format,,,,,$CAIROLIB,
 [CAIRO_HAS_XRENDER=1],[CAIRO_HAS_XRENDER=0])
 AC_SUBST(CAIRO_HAS_XRENDER)
+LOC_CHECK_FUNC(cairo_xlib_surface_get_xrender_format,,,,,$CAIROLIB,
+[CAIRO_HAS_XRENDER_SURFACE=1],[CAIRO_HAS_XRENDER_SURFACE=])
+AC_SUBST(CAIRO_HAS_XRENDER_SURFACE)
Modified: grass/branches/releasebranch_6_4/lib/cairodriver/Graph.c
--- grass/branches/releasebranch_6_4/lib/cairodriver/Graph.c	2011-08-11 21:43:13 UTC (rev 47578)
+++ grass/branches/releasebranch_6_4/lib/cairodriver/Graph.c	2011-08-11 22:00:45 UTC (rev 47579)
@@ -1,9 +1,31 @@
+  \file lib/cairodriver/Graph.c
+  \brief GRASS cairo display driver - driver settings
+  (C) 2007-2008, 2011 by Lars Ahlzen and the GRASS Development Team
+  This program is free software under the GNU General Public License
+  (>=v2). Read the file COPYING that comes with GRASS for details.
+  \author Lars Ahlzen <lars ahlzen.com> (original contibutor)
+  \author Glynn Clements
 #include "cairodriver.h"
+#if CAIRO_HAS_PS_SURFACE
 #include <cairo-ps.h>
+#endif
+#if CAIRO_HAS_PDF_SURFACE
 #include <cairo-pdf.h>
+#endif
+#if CAIRO_HAS_SVG_SURFACE
 #include <cairo-svg.h>
-#if defined(USE_X11) && CAIRO_HAS_XLIB_SURFACE
+#endif
+#if CAIRO_HAS_XLIB_XRENDER_SURFACE
 #include <cairo-xlib.h>
+#include <cairo-xlib-xrender.h>
 #endif
 #include <unistd.h>
