[GRASS-SVN] r47596 - grass/trunk/general/g.parser
svn_grass at osgeo.org
Fri Aug 12 05:10:03 EDT 2011
Author: neteler
Date: 2011-08-12 02:10:03 -0700 (Fri, 12 Aug 2011)
New Revision: 47596
grass/trunk/general/g.parser/g.parser.html
grass/trunk/general/g.parser/parse.c
grass/trunk/general/g.parser/translate.c
support {NULL} to predefined description or label
Modified: grass/trunk/general/g.parser/g.parser.html
--- grass/trunk/general/g.parser/g.parser.html 2011-08-12 08:49:58 UTC (rev 47595)
+++ grass/trunk/general/g.parser/g.parser.html 2011-08-12 09:10:03 UTC (rev 47596)
@@ -62,21 +62,23 @@
<div class="code"><pre>
#%module
-#% description: g.parser test script
+#% description: g.parser test script
#%end
#%flag
-#% key: f
-#% description: A flag
+#% key: f
+#% description: A flag
#%end
#%option
-#% key: raster
-#% type: string
-#% gisprompt: old,cell,raster
-#% description: Raster input map
-#% required : yes
+#% key: raster
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: Raster input map
+#% required : yes
#%end
</pre></div>
+With <tt>{NULL}</tt> it is possible to suppress a predefined <tt>description</tt>
+or <tt>label</tt>.
<h2>NOTES</h2>
Modified: grass/trunk/general/g.parser/parse.c
--- grass/trunk/general/g.parser/parse.c 2011-08-12 08:49:58 UTC (rev 47595)
+++ grass/trunk/general/g.parser/parse.c 2011-08-12 09:10:03 UTC (rev 47596)
@@ -5,6 +5,13 @@
#include <grass/glocale.h>
+static char *xstrdup(const char *arg)
+ G_debug(0,"arg: %s", arg);
+ return (G_strcasecmp(arg, "{NULL}") == 0)
+ ? NULL : strdup(arg);
int parse_boolean(struct context *ctx, const char *arg)
if (G_strcasecmp(arg, "yes") == 0)
@@ -59,23 +66,22 @@
fprintf(stderr, _("Unknown command \"%s\" at line %d\n"), cmd, ctx->line);
-void parse_module(struct context *ctx, const char *cmd,
- const char *arg)
+void parse_module(struct context *ctx, const char *cmd, const char *arg)
/* Label and description can be internationalized */
if (G_strcasecmp(cmd, "label") == 0) {
- ctx->module->label = translate(strdup(arg));
+ ctx->module->label = translate(xstrdup(arg));
return;
if (G_strcasecmp(cmd, "description") == 0) {
- ctx->module->description = translate(strdup(arg));
+ ctx->module->description = translate(xstrdup(arg));
return;
if (G_strcasecmp(cmd, "keywords") == 0) {
- G_add_keyword(translate(strdup(arg)));
+ G_add_keyword(translate(xstrdup(arg)));
return;
@@ -107,17 +113,17 @@
/* Label, description, and guisection can all be internationalized */
- ctx->flag->label = translate(strdup(arg));
+ ctx->flag->label = translate(xstrdup(arg));
return;
- ctx->flag->description = translate(strdup(arg));
+ ctx->flag->description = translate(xstrdup(arg));
return;
if (G_strcasecmp(cmd, "guisection") == 0) {
- ctx->flag->guisection = translate(strdup(arg));
+ ctx->flag->guisection = translate(xstrdup(arg));
return;
@@ -146,11 +152,10 @@
return TYPE_STRING;
-void parse_option(struct context *ctx, const char *cmd,
- const char *arg)
+void parse_option(struct context *ctx, const char *cmd, const char *arg)
if (G_strcasecmp(cmd, "key") == 0) {
- ctx->option->key = strdup(arg);
+ ctx->option->key = xstrdup(arg);
return;
@@ -170,48 +175,48 @@
if (G_strcasecmp(cmd, "options") == 0) {
- ctx->option->options = strdup(arg);
+ ctx->option->options = xstrdup(arg);
return;
if (G_strcasecmp(cmd, "key_desc") == 0) {
- ctx->option->key_desc = strdup(arg);
+ ctx->option->key_desc = xstrdup(arg);
return;
/* Label, description, descriptions, and guisection can all be internationalized */
- ctx->option->label = translate(strdup(arg));
+ ctx->option->label = translate(xstrdup(arg));
return;
- ctx->option->description = translate(strdup(arg));
+ ctx->option->description = translate(xstrdup(arg));
return;
if (G_strcasecmp(cmd, "descriptions") == 0) {
- ctx->option->descriptions = translate(strdup(arg));
+ ctx->option->descriptions = translate(xstrdup(arg));
return;
if (G_strcasecmp(cmd, "answer") == 0) {
- ctx->option->answer = strdup(arg);
+ ctx->option->answer = xstrdup(arg);
return;
if (G_strcasecmp(cmd, "gisprompt") == 0) {
- ctx->option->gisprompt = strdup(arg);
+ ctx->option->gisprompt = xstrdup(arg);
return;
- ctx->option->guisection = translate(strdup(arg));
+ ctx->option->guisection = translate(xstrdup(arg));
return;
if (G_strcasecmp(cmd, "guidependency") == 0) {
- ctx->option->guidependency = translate(strdup(arg));
+ ctx->option->guidependency = translate(xstrdup(arg));
return;
Modified: grass/trunk/general/g.parser/translate.c
--- grass/trunk/general/g.parser/translate.c 2011-08-12 08:49:58 UTC (rev 47595)
+++ grass/trunk/general/g.parser/translate.c 2011-08-12 09:10:03 UTC (rev 47596)
@@ -10,6 +10,8 @@
static const char *domain;
+ if (arg == NULL)
+ return arg;
if (*arg && translate_output) {
fputs(arg, stdout);
fputs("\n", stdout);
