[GRASS-SVN] r47603 - grass/trunk/vector/v.colors
svn_grass at osgeo.org
Fri Aug 12 16:05:22 EDT 2011
Author: martinl
Date: 2011-08-12 13:05:22 -0700 (Fri, 12 Aug 2011)
New Revision: 47603
Added:
grass/trunk/vector/v.colors/write_rgb.c
grass/trunk/vector/v.colors/local_proto.h
grass/trunk/vector/v.colors/main.c
v.colors: write rgb values if rgbcolumn is defined
Modified: grass/trunk/vector/v.colors/local_proto.h
--- grass/trunk/vector/v.colors/local_proto.h 2011-08-12 19:15:44 UTC (rev 47602)
+++ grass/trunk/vector/v.colors/local_proto.h 2011-08-12 20:05:22 UTC (rev 47603)
@@ -4,3 +4,7 @@
/* scan_cats */
void scan_cats(const struct Map_info *, int, double *, double*);
+/* write_rgb.c */
+void write_rgb_values(const struct Map_info *, int, const char *,
+ struct Colors *);
Modified: grass/trunk/vector/v.colors/main.c
--- grass/trunk/vector/v.colors/main.c 2011-08-12 19:15:44 UTC (rev 47602)
+++ grass/trunk/vector/v.colors/main.c 2011-08-12 20:05:22 UTC (rev 47603)
@@ -42,7 +42,7 @@
int have_stats, is_fp;
int overwrite, remove, is_from_stdin, stat, have_colors;
const char *mapset, *cmapset;
- const char *name, *style, *rules, *cmap, *attrcolumn;
+ const char *name, *style, *rules, *cmap, *attrcolumn, *rgbcolumn;
struct Map_info Map;
struct Colors colors, colors_tmp;
@@ -140,6 +140,7 @@
style = opt.colr->answer;
rules = opt.rules->answer;
attrcolumn = opt.attrcol->answer;
+ rgbcolumn = opt.rgbcol->answer;
have_stats = FALSE;
if (!name)
@@ -294,7 +295,10 @@
colors = colors_tmp;
- Vect_write_colors(name, mapset, &colors);
+ if (rgbcolumn)
+ write_rgb_values(&Map, layer, rgbcolumn, &colors);
+ else
+ Vect_write_colors(name, mapset, &colors);
G_message(_("Color table for vector map <%s> set to '%s'"),
G_fully_qualified_name(name, mapset),
Added: grass/trunk/vector/v.colors/write_rgb.c
--- grass/trunk/vector/v.colors/write_rgb.c (rev 0)
+++ grass/trunk/vector/v.colors/write_rgb.c 2011-08-12 20:05:22 UTC (rev 47603)
@@ -0,0 +1,61 @@
+#include <grass/gis.h>
+#include <grass/vector.h>
+#include <grass/dbmi.h>
+#include <grass/raster.h>
+#include <grass/glocale.h>
+void write_rgb_values(const struct Map_info *Map, int layer, const char *column_name,
+ struct Colors *colors)
+ int ctype, nrec, i;
+ int red, grn, blu;
+ int *pval;
+ char buf[1024];
+ struct field_info *fi;
+ dbDriver *driver;
+ dbString stmt;
+ fi = Vect_get_field(Map, layer);
+ if (!fi)
+ G_fatal_error(_("Database connection not defined for layer %d"),
+ layer);
+ driver = db_start_driver_open_database(fi->driver, fi->database);
+ if (!driver)
+ G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+ fi->database, fi->driver);
+ ctype = db_column_Ctype(driver, fi->table, column_name);
+ if (ctype == -1)
+ G_fatal_error(_("Column <%s> not found in table <%s>"),
+ column_name, fi->table);
+ if (ctype != DB_C_TYPE_STRING)
+ G_fatal_error(_("Data type of column <%s> must be char"), column_name);
+ nrec = db_select_int(driver, fi->table, fi->key, NULL, &pval);
+ if (nrec < 1) {
+ G_warning(_("No categories found"));
+ return;
+ db_init_string(&stmt);
+ db_begin_transaction(driver);
+ for (i = 0; i < nrec; i++) {
+ if (Rast_get_c_color((const CELL *) &(pval[i]), &red, &grn, &blu,
+ colors) == 0)
+ G_warning(_("No color value defined for category %d"), pval[i]);
+ sprintf(buf, "UPDATE %s SET %s='%d:%d:%d' WHERE %s=%d", fi->table,
+ column_name, red, grn, blu, fi->key, pval[i]);
+ G_debug(3, "\tSQL: %s", buf);
+ db_set_string(&stmt, buf);
+ if (db_execute_immediate(driver, &stmt) != DB_OK)
+ G_fatal_error(_("Unable to update RGB values"));
+ db_commit_transaction(driver);
+ db_close_database(driver);
Property changes on: grass/trunk/vector/v.colors/write_rgb.c
___________________________________________________________________
Added: svn:mime-type
+ text/x-csrc
Added: svn:eol-style
+ native
