[GRASS-SVN] r47606 - grass/trunk/lib/raster
svn_grass at osgeo.org
Sat Aug 13 08:58:53 EDT 2011
Author: martinl
Date: 2011-08-13 05:58:53 -0700 (Sat, 13 Aug 2011)
New Revision: 47606
grass/trunk/lib/raster/color_rule.c
rasterlib: update doxygen strings for color_rule.c
Modified: grass/trunk/lib/raster/color_rule.c
--- grass/trunk/lib/raster/color_rule.c 2011-08-13 12:44:00 UTC (rev 47605)
+++ grass/trunk/lib/raster/color_rule.c 2011-08-13 12:58:53 UTC (rev 47606)
@@ -1,15 +1,15 @@
- * \file raster/color_rule.c
- * \brief Raster Library - Color rules.
- * (C) 2001-2009 by the GRASS Development Team
- * This program is free software under the GNU General Public License
- * (>=v2). Read the file COPYING that comes with GRASS for details.
- * \author Original author CERL
+ \file lib/raster/color_rule.c
+ \brief Raster Library - Color rules.
+ (C) 2001-2009 by the GRASS Development Team
+ This program is free software under the GNU General Public License
+ (>=v2). Read the file COPYING that comes with GRASS for details.
+ \author Original author CERL
#include <grass/gis.h>
#include <grass/raster.h>
@@ -21,19 +21,17 @@
struct _Color_Info_ *, int,
DCELL *, DCELL *, RASTER_MAP_TYPE);
- * \brief Adds the floating-point rule (DCELL version)
- * See Rast_add_color_rule() for details.
- * \param v1 cell value
- * \param r1,g1,b1 color value
- * \param v2 cell value
- * \param r2,g2,b2 color value
- * \param[in,out] colors pointer to color table structure
- * \return
+ \brief Adds the floating-point color rule (DCELL version)
+ See Rast_add_color_rule() for details.
+ \param v1 cell value
+ \param r1,g1,b1 color value
+ \param v2 cell value
+ \param r2,g2,b2 color value
+ \param[in,out] colors pointer to color table structure
void Rast_add_d_color_rule(const DCELL * val1, int r1, int g1, int b1,
const DCELL * val2, int r2, int g2, int b2,
struct Colors *colors)
@@ -44,17 +42,16 @@
- * \brief Adds the floating-point rule (FCELL version)
- * \return
+ \brief Adds the floating-point color rule (FCELL version)
void Rast_add_f_color_rule(const FCELL * cat1, int r1, int g1, int b1,
const FCELL * cat2, int r2, int g2, int b2,
@@ -65,17 +62,16 @@
- * \brief Adds the floating-point rule (CCELL version)
- * \return
+ \brief Adds the integer color rule (CELL version)
void Rast_add_c_color_rule(const CELL * cat1, int r1, int g1, int b1,
const CELL * cat2, int r2, int g2, int b2,
@@ -86,27 +82,25 @@
- * Adds the floating-point rule that the range [<em>v1,v2</em>] gets a
- * linear ramp of colors from [<em>r1,g1,b1</em>] to
- * [<em>r2,g2,b2</em>].
- * If either <em>v1</em> or <em>v2</em> is the NULL-value, this call is converted into
- * <tt>Rast_set_null_value_color (r1, g1, b1, colors)</tt>
- * - If <em>map_type</em> is CELL_TYPE, calls Rast_add_c_color_rule()
- * - If <em>map_type</em> is FCELL_TYPE, calls Rast_add_f_color_rule()
- * - If <em>map_type</em> is DCELL_TYPE, calls Rast_add_d_color_rule()
- * \param data_type raster data type (CELL, FCELL, DCELL)
- * \return
+ \brief Adds the color rule
+ Adds the floating-point rule that the range [<em>v1,v2</em>] gets a
+ linear ramp of colors from [<em>r1,g1,b1</em>] to
+ [<em>r2,g2,b2</em>].
+ If either <em>v1</em> or <em>v2</em> is the NULL-value, this call is converted ino
+ <tt>Rast_set_null_value_color (r1, g1, b1, colors)</tt>
+ - If <em>map_type</em> is CELL_TYPE, calls Rast_add_c_color_rule()
+ - If <em>map_type</em> is FCELL_TYPE, calls Rast_add_f_color_rule()
+ - If <em>map_type</em> is DCELL_TYPE, calls Rast_add_d_color_rule()
+ \param data_type raster data type (CELL, FCELL, DCELL)
void Rast_add_color_rule(const void *val1, int r1, int g1, int b1,
const void *val2, int r2, int g2, int b2,
struct Colors *colors, RASTER_MAP_TYPE data_type)
@@ -116,17 +110,17 @@
- * \brief Add modular color rule (DCELL version)
- * \param val1 cell value
- * \param val2 cell value
- * \return -1 on failure
- * \return 1 on success
+ \brief Add modular floating-point color rule (DCELL version)
+ \param val1 cell value
+ \param val2 cell value
+ \return -1 on failure
+ \return 1 on success
int Rast_add_modular_d_color_rule(const DCELL * val1, int r1, int g1, int b1,
@@ -146,17 +140,17 @@
- * \brief Add modular color rule (FCELL version)
+ \brief Add modular floating-point color rule (FCELL version)
int Rast_add_modular_f_color_rule(const FCELL * val1, int r1, int g1, int b1,
const FCELL * val2, int r2, int g2, int b2,
@@ -176,17 +170,17 @@
- * \brief Add modular color rule (CELL version)
+ \brief Add modular integer color rule (CELL version)
int Rast_add_modular_c_color_rule(const CELL * val1, int r1, int g1, int b1,
const CELL * val2, int r2, int g2, int b2,
@@ -206,21 +200,21 @@
- * \todo Question: shouldn't this function call
- * G_add_modular_<data_type>_raster_color_rule() instead?
+ \brief Add modular color rule
+ \todo Question: shouldn't this function call
+ G_add_modular_<data_type>_raster_color_rule() instead?
int Rast_add_modular_color_rule(const void *val1, int r1, int g1, int b1,
