[GRASS-SVN] r47608 - grass/trunk/vector/v.colors
svn_grass at osgeo.org
Sat Aug 13 12:46:49 EDT 2011
Author: martinl
Date: 2011-08-13 09:46:48 -0700 (Sat, 13 Aug 2011)
New Revision: 47608
grass/trunk/vector/v.colors/main.c
grass/trunk/vector/v.colors/v.colors.html
v.colors: manual updated
Modified: grass/trunk/vector/v.colors/main.c
--- grass/trunk/vector/v.colors/main.c 2011-08-13 13:51:12 UTC (rev 47607)
+++ grass/trunk/vector/v.colors/main.c 2011-08-13 16:46:48 UTC (rev 47608)
@@ -61,13 +61,14 @@
opt.field = G_define_standard_option(G_OPT_V_FIELD);
opt.attrcol = G_define_standard_option(G_OPT_DB_COLUMN);
- opt.attrcol->description = _("Name of column containing numeric data");
+ opt.attrcol->label = _("Name of column containing numeric data");
+ opt.attrcol->description = _("If not given categories are used");
opt.colr = G_define_standard_option(G_OPT_M_COLR);
opt.rgbcol = G_define_standard_option(G_OPT_DB_COLUMN);
opt.rgbcol->key = "rgb_column";
opt.rgbcol->label = _("Name of color column to populate RGB values");
- opt.rgbcol->description = _("If no column given, write color table instead");
+ opt.rgbcol->description = _("If not given writes color table");
opt.rast = G_define_standard_option(G_OPT_R_INPUT);
opt.rast->key = "raster";
Modified: grass/trunk/vector/v.colors/v.colors.html
--- grass/trunk/vector/v.colors/v.colors.html 2011-08-13 13:51:12 UTC (rev 47607)
+++ grass/trunk/vector/v.colors/v.colors.html 2011-08-13 16:46:48 UTC (rev 47608)
@@ -2,7 +2,7 @@
<em>v.colors</em> allows the user to create and/or modify the color
table for a vector map. The vector map (specified on the command line
-by <b>map=</b>) must exist in the user's current mapset search path.
+by <b>map</b>) must exist in the user's current mapset search path.
<p>
The <b>rast</b> option allows user to specify a raster map <i>name</i>
@@ -47,6 +47,28 @@
<h2>EXAMPLES</h2>
+Define color table <tt>wave</tt> based on categories from layer 1
+<div class="code"><pre>
+v.colors map=soils_general layer=1 color=wave
+</pre></div>
+Define color table <tt>ryg</tt> based on values from attribute
+column <tt>AREA</tt>. Attribute table is linked to layer 1.
+v.to.db map=soils_general layer=1 option=area column=AREA
+v.colors map=soils_general layer=1 color=wave column=AREA
+</pre></div>
+Write color values to the attribute table (column <tt>GRASSRGB</tt>)
+instead of creating color table.
+v.db.addcolumn map=soils_general column="GRASSRGB varchar(12)"
+v.colors map=soils_general layer=1 color=wave column=AREA rgb_column=GRASSRGB
+</pre></div>
<h2>SEE ALSO</h2>
<em>
@@ -62,8 +84,7 @@
<h2>AUTHORS</h2>
-Adopted <a href="r.colors.html">r.colors</a> by Martin Landa, Czech
-Technical University in Prague, Czech Republic
+Martin Landa, Czech Technical University in Prague, Czech Republic
<p>
<i>Last changed: $Date$</i>
