[GRASS-SVN] r47610 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat Aug 13 16:51:05 EDT 2011
Author: annakrat
Date: 2011-08-13 13:51:05 -0700 (Sat, 13 Aug 2011)
New Revision: 47610
grass/trunk/gui/wxpython/gui_modules/colorrules.py
wxNviz: make Cancel button work in thematic mapping dialog
Modified: grass/trunk/gui/wxpython/gui_modules/colorrules.py
--- grass/trunk/gui/wxpython/gui_modules/colorrules.py 2011-08-13 17:51:42 UTC (rev 47609)
+++ grass/trunk/gui/wxpython/gui_modules/colorrules.py 2011-08-13 20:51:05 UTC (rev 47610)
@@ -831,7 +831,11 @@
# vector attribute column for assigning colors
'source_rgb' : '',
# vector attribute column to use for storing colors
- 'rgb' : '',
+ 'rgb' : '',
+ # vector attribute column for temporary storing colors
+ 'tmp_rgb' : '',
+ # vector attribute column for temporary storing size
+ 'tmp_size' : '',
# vector attribute column for assigning size
'source_size' : '',
# vector attribute column to use for storing size
@@ -996,7 +1000,7 @@
def UpdateDialog(self):
"""!Update dialog after map selection"""
if not self.inmap:
- self.colorRulesPanel.ruleslines.Clear()
+ self.colorRulesPanel.Clear()
self.btnPreview.Enable(False)
self.btnOK.Enable(False)
self.btnApply.Enable(False)
@@ -1023,12 +1027,10 @@
layer = int(self.properties['layer'])
self.properties['table'] = self.dbInfo.layers[layer]['table']
- # initialize column selection comboboxes
- self.OnLayerSelection(event = None)
if self.CheckMapset():
enable = True
self.btn_add_RGB.Enable(True)
+ self.AddTemporaryColumn(name = 'tmp_rgb', type = 'varchar(20)')
else:
enable = False
wx.CallAfter(gcmd.GMessage, parent = self,
@@ -1039,10 +1041,29 @@
self.btn_add_RGB.Enable(False)
+ # initialize column selection comboboxes
+ self.OnLayerSelection(event = None)
self.btnPreview.Enable(enable)
self.btnOK.Enable(enable)
self.btnApply.Enable(enable)
+ def AddTemporaryColumn(self, name, type):
+ """!Add temporary column to not overwrite the original values,
+ need to be deleted when closing dialog"""
+ ret = gcmd.RunCommand('v.db.addcolumn',
+ map = self.inmap,
+ layer = self.properties['layer'],
+ columns = '%s %s' % (name, type))
+ self.properties[name] = name
+ def DeleteTemporaryColumn(self, name):
+ """!Delete temporary column"""
+ ret = gcmd.RunCommand('v.db.dropcolumn',
+ map = self.inmap,
+ column = name)
def OnLayerSelection(self, event):
# reset choices in column selection comboboxes if layer changes
vlayer = int(self.cb_vlayer.GetStringSelection())
@@ -1195,14 +1216,14 @@
def OnPreview(self, event = None):
"""!Update preview (based on computational region)"""
- if not self.inmap or not self.properties["rgb"]:
+ if not self.inmap or not self.properties["rgb"] or not self.properties["tmp_rgb"]:
self.preview.EraseMap()
return
cmdlist = ['d.vect',
'-a',
'map=%s' % self.inmap,
- 'rgb_column=%s' % self.properties["rgb"],
+ 'rgb_column=%s' % self.properties['tmp_rgb'],
'type=point,line,boundary,area']
ltype = 'vector'
@@ -1225,8 +1246,12 @@
if not rule['value']: # skip empty rules
continue
+ if force:
+ rgb_col = self.properties['tmp_rgb']
+ else:
+ rgb_col = self.properties['rgb']
rulestxt += "UPDATE %s SET %s='%s' WHERE %s ;\n" % (self.properties['table'],
- self.properties['rgb'],
+ rgb_col,
rule['color'],
rule['value'])
if not rulestxt:
@@ -1244,6 +1269,17 @@
input = gtemp)
return True
+ def OnOK(self, event):
+ """!Apply selected color table, close the dialog
+ and delete temporary column"""
+ if self.OnApply(event):
+ self.Destroy()
+ self.DeleteTemporaryColumn(name = self.properties['tmp_rgb'])
+ def OnCancel(self, event):
+ """!Do not apply any changes and close the dialog"""
+ self.Destroy()
class ThematicVectorTable(VectorColorTable):
def __init__(self, parent, vectorType, **kwargs):
@@ -1265,7 +1301,8 @@
"""!Update dialog according to selected map"""
VectorColorTable.UpdateDialog(self)
+ if not self.inmap:
+ self.sizeRulesPanel.Clear()
if not len(self.dbInfo.layers):
for combo in (self.cb_size_att, self.cb_size_col):
combo.SetValue("")
@@ -1279,6 +1316,7 @@
self.btn_add_size.Enable(True)
+ self.AddTemporaryColumn(name = 'tmp_size', type = 'integer')
else:
@@ -1561,7 +1599,7 @@
- if not self.inmap:
+ if not self.inmap or not self.properties['size'] or not self.properties['tmp_size']:
return
@@ -1570,14 +1608,16 @@
- if self.size_check.IsChecked() and self.properties["size"]:
+ if self.size_check.IsChecked()\
+ and self.properties["size"] and self.properties["tmp_size"]:
if self.vectorType == 'points':
- cmdlist.append('size_column=%s' % self.properties["size"])
+ cmdlist.append('size_column=%s' % self.properties['tmp_size'])
else:
- cmdlist.append('width_column=%s' % self.properties["size"])
+ cmdlist.append('width_column=%s' % self.properties['tmp_size'])
- if self.rgb_check.IsChecked() and self.properties["rgb"]:
- cmdlist.append('rgb_column=%s' % self.properties["rgb"])
+ if self.rgb_check.IsChecked()\
+ and self.properties["rgb"] and self.properties['tmp_rgb']:
+ cmdlist.append('rgb_column=%s' % self.properties['tmp_rgb'])
ltype = 'vector'
ColorTable.DoPreview(self, ltype, cmdlist)
@@ -1614,6 +1654,11 @@
return ret
+ def CreateColorTable(self, force = False):
+ """!Creates color and size table"""
+ VectorColorTable.CreateColorTable(self, force = True)
+ self.CreateSizeTable(force = True)
def CreateSizeTable(self, force = False):
"""!Creates size table
@@ -1627,8 +1672,12 @@
continue
+ if force:
+ size_col = self.properties['tmp_size']
+ else:
+ size_col = self.properties['size']
- self.properties['size'],
+ size_col,
rule['size'],
rule['value'])
if not rulestxt:
@@ -1645,7 +1694,21 @@
parent = self,
input = gtemp)
return True
+ self.Destroy()
+ self.DeleteTemporaryColumn(name = 'tmp_size')
+ self.DeleteTemporaryColumn(name = 'tmp_rgb')
+ self.Destroy()
class BufferedWindow(wx.Window):
"""!A Buffered window class"""
def __init__(self, parent, id,
