[GRASS-SVN] r47644 - grass-addons/grass7/gui/wxpython/wx.stream/gui_modules
Mon Aug 15 10:26:29 EDT 2011
Author: madi
Date: 2011-08-15 07:26:28 -0700 (Mon, 15 Aug 2011)
New Revision: 47644
   grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream_panelOne.py
elevation map added on canvas - working copy
Modified: grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream_panelOne.py
--- grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream_panelOne.py	2011-08-15 13:56:55 UTC (rev 47643)
+++ grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream_panelOne.py	2011-08-15 14:26:28 UTC (rev 47644)
@@ -38,14 +38,17 @@
 import menuform
 # First panel # Network extraction
 class TabPanelOne(wx.Panel):
-    def __init__(self, parent, layerManager):
+    def __init__(self, parent, layerManager, MapFrame):
         wx.Panel.__init__(self, parent, id = wx.ID_ANY)
         self.layerManager = layerManager
+        self.mapdisp = MapFrame
         self.parent = parent
         self.thre = 0
         self.r_elev = 'r_elev'
@@ -56,6 +59,7 @@
         self.panel = wx.Panel(self)
         self._layout()
     def _layout(self):
@@ -305,16 +309,23 @@
         info_region = grass.read_command('g.region', flags = 'p')
         # message box
-        self.msg = wx.MessageDialog(parent = self.panel, message = "Please select the center of preview window on the map",
-                                    caption = "Preview utility", style = wx.OK | wx.CANCEL, pos = wx.DefaultPosition)
+        self.msg = wx.MessageDialog(parent = self.panel,
+                                    message = "Please select the center of preview window on the map",
+                                    caption = "Preview utility",
+                                    style = wx.OK | wx.CANCEL,
+                                    pos = wx.DefaultPosition)
         self.retCode = self.msg.ShowModal()
         if self.retCode == wx.ID_OK:
             print "OK"
             # get current Map Display
-            mapdisp = self.layerManager.GetLayerTree().GetMapDisplay()
-            mapdisp.Raise()
-            #grass.run_command('d.rast', map = self.r_elev)
+            self.mapdisp = self.layerManager.GetLayerTree().GetMapDisplay()
+            self.mapdisp.Raise()
+            self.mapdisp.Map.AddLayer(type = 'raster',
+                                 command = ['d.rast', 'map=%s' % self.r_elev])
+            self.mapdisp.OnRender(None)
             # Get position by panel on mouse click
@@ -338,16 +349,27 @@
         # MFD
         if radioval2 == 'True':
             grass.message('Creating flow accumulation map with MFD algorithm..')
-            grass.run_command('r.watershed', elevation = self.r_elev , accumulation = self.r_acc , convergence = 5 , flags = 'a', overwrite = True )
+            grass.run_command('r.watershed', elevation = self.r_elev ,
+                              accumulation = self.r_acc ,
+                              convergence = 5 ,
+                              flags = 'a', overwrite = True )
         # SFD
         if radioval3 == 'True':
             grass.message('Creating flow accumulation map with SFD algorithm..')
-            grass.run_command('r.watershed', elevation = self.r_elev , accumulation = self.r_acc , drainage = self.r_drain , convergence = 5 , flags = 'sa', overwrite = True)
+                              drainage = self.r_drain ,
+                              convergence = 5 ,
+                              flags = 'sa', overwrite = True)
         grass.message('Network extraction..')
-        grass.run_command('r.stream.extract', elevation = self.r_elev , accumulation = self.r_acc , threshold = self.thre,
-                        stream_rast = self.r_stre, stream_vect = self.v_net, direction = self.r_drain, overwrite = True)
+        grass.run_command('r.stream.extract', elevation = self.r_elev ,
+                          threshold = self.thre,
+                          stream_rast = self.r_stre,
+                          stream_vect = self.v_net,
+                          direction = self.r_drain, overwrite = True)
         # Debug
