[GRASS-SVN] r47681 - grass/trunk/vector/v.colors.out
svn_grass at osgeo.org
Tue Aug 16 14:22:25 EDT 2011
Author: martinl
Date: 2011-08-16 11:22:25 -0700 (Tue, 16 Aug 2011)
New Revision: 47681
Added:
grass/trunk/vector/v.colors.out/make_colors.c
grass/trunk/vector/v.colors.out/Makefile
grass/trunk/vector/v.colors.out/local_proto.h
grass/trunk/vector/v.colors.out/main.c
grass/trunk/vector/v.colors.out/scan_cats.c
v.colors.out: optionally refer color table to the given attribute column
Modified: grass/trunk/vector/v.colors.out/Makefile
--- grass/trunk/vector/v.colors.out/Makefile 2011-08-16 16:58:53 UTC (rev 47680)
+++ grass/trunk/vector/v.colors.out/Makefile 2011-08-16 18:22:25 UTC (rev 47681)
@@ -2,8 +2,8 @@
PGM = v.colors.out
-LIBES = $(VECTORLIB) $(GISLIB) $(RASTERLIB)
-DEPENDENCIES = $(VECTORDEP) $(GISDEP) $(RASTERDEP)
+LIBES = $(VECTORLIB) $(GISLIB) $(RASTERLIB) $(DBMILIB)
+DEPENDENCIES = $(VECTORDEP) $(GISDEP) $(RASTERDEP) $(DBMIDEP)
EXTRA_INC = $(VECT_INC)
EXTRA_CFLAGS = $(VECT_CFLAGS)
Modified: grass/trunk/vector/v.colors.out/local_proto.h
--- grass/trunk/vector/v.colors.out/local_proto.h 2011-08-16 16:58:53 UTC (rev 47680)
+++ grass/trunk/vector/v.colors.out/local_proto.h 2011-08-16 18:22:25 UTC (rev 47681)
@@ -1,2 +1,6 @@
+/* make_colors */
+struct Colors *make_colors(const char *, const char *, const char *,
+ struct Colors *);
/* scan_cats.c */
void scan_cats(const char *, const char *, int *, int *);
Modified: grass/trunk/vector/v.colors.out/main.c
--- grass/trunk/vector/v.colors.out/main.c 2011-08-16 16:58:53 UTC (rev 47680)
+++ grass/trunk/vector/v.colors.out/main.c 2011-08-16 18:22:25 UTC (rev 47681)
@@ -29,16 +29,16 @@
struct GModule *module;
struct
- struct Option *map, *field, *file;
+ struct Option *map, *field, *file, *col;
} opt;
struct
struct Flag *p;
} flag;
- struct Colors colors;
+ struct Colors cat_colors, *colors;
int min, max;
- const char *file, *name, *layer;
+ const char *file, *name, *layer, *column;
FILE *fp;
G_gisinit(argv[0]);
@@ -60,9 +60,15 @@
opt.file->description = _("\"-\" to write to stdout");
opt.file->answer = "-";
+ opt.col = G_define_standard_option(G_OPT_DB_COLUMN);
+ opt.col->label = _("Name of attribute (numeric) column to which refer color rules");
+ opt.col->description = _("If not given color rules are refered to categories");
+ opt.col->guisection = _("Settings");
flag.p = G_define_flag();
flag.p->key = 'p';
flag.p->description = _("Output values as percentages");
+ flag.p->guisection = _("Settings");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -70,8 +76,9 @@
name = opt.map->answer;
layer = opt.field->answer;
file = opt.file->answer;
+ column = opt.col->answer;
- if (Vect_read_colors(name, "", &colors) < 0)
+ if (Vect_read_colors(name, "", &cat_colors) < 0)
G_fatal_error(_("Unable to read color table for vector map <%s>"),
opt.map->answer);
@@ -87,8 +94,13 @@
if (!fp)
G_fatal_error(_("Unable to open output file <%s>"), file);
+ if (column)
+ colors = make_colors(name, layer, column, &cat_colors);
+ else
+ colors = &cat_colors;
- Rast_print_colors(&colors, (DCELL) min, (DCELL) max, fp,
+ Rast_print_colors(colors, (DCELL) min, (DCELL) max, fp,
flag.p->answer ? 1 : 0);
exit(EXIT_SUCCESS);
Added: grass/trunk/vector/v.colors.out/make_colors.c
--- grass/trunk/vector/v.colors.out/make_colors.c (rev 0)
+++ grass/trunk/vector/v.colors.out/make_colors.c 2011-08-16 18:22:25 UTC (rev 47681)
@@ -0,0 +1,78 @@
+#include <grass/gis.h>
+#include <grass/vector.h>
+#include <grass/raster.h>
+#include <grass/dbmi.h>
+#include <grass/glocale.h>
+struct Colors *make_colors(const char *name, const char *layer,
+ const char *column, struct Colors *cat_colors)
+ int field, is_fp, ctype, nrec, cat, i;
+ int red, grn, blu;
+ struct Map_info Map;
+ struct field_info *fi;
+ struct Colors *colors;
+ dbDriver *driver;
+ dbCatValArray cvarr;
+ dbCatVal *cv;
+ Vect_set_open_level(1); /* no topology required */
+ Vect_open_old2(&Map, name, "", layer);
+ field = Vect_get_field_number(&Map, layer);
+ if (field < 1)
+ G_fatal_error(_("Layer <%s> not found"), layer);
+ fi = Vect_get_field(&Map, field);
+ if (!fi)
+ G_fatal_error(_("Database connection not defined for layer <%s>"),
+ layer);
+ driver = db_start_driver_open_database(fi->driver, fi->database);
+ if (!driver)
+ G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+ fi->database, fi->driver);
+ ctype = db_column_Ctype(driver, fi->table, column);
+ if (ctype == -1)
+ G_fatal_error(_("Column <%s> not found in table <%s>"),
+ column, fi->table);
+ if (ctype != DB_C_TYPE_INT && ctype != DB_C_TYPE_DOUBLE)
+ G_fatal_error(_("Column <%s> is not numeric"), column);
+ is_fp = ctype == DB_C_TYPE_DOUBLE;
+ nrec = db_select_CatValArray(driver, fi->table, fi->key, column,
+ NULL, &cvarr);
+ if (nrec < 1) {
+ G_important_message(_("No data selected"));
+ return 0;
+ colors = (struct Colors *) G_malloc(sizeof(struct Colors));
+ Rast_init_colors(colors);
+ for (i = 0; i < cvarr.n_values; i++) {
+ cv = &(cvarr.value[i]);
+ cat = cv->cat;
+ if (Rast_get_c_color((const CELL *) &cat, &red, &grn, &blu,
+ cat_colors) == 0)
+ continue;
+ if (is_fp)
+ Rast_add_d_color_rule((const DCELL*) &(cv->val.d), red, grn, blu,
+ (const DCELL*) &(cv->val.d), red, grn, blu,
+ colors);
+ else
+ Rast_add_c_color_rule((const CELL*) &(cv->val.i), red, grn, blu,
+ (const CELL*) &(cv->val.i), red, grn, blu,
+ colors);
+ Vect_close(&Map);
+ return colors;
Property changes on: grass/trunk/vector/v.colors.out/make_colors.c
___________________________________________________________________
Added: svn:mime-type
+ text/x-csrc
Added: svn:eol-style
+ native
Modified: grass/trunk/vector/v.colors.out/scan_cats.c
--- grass/trunk/vector/v.colors.out/scan_cats.c 2011-08-16 16:58:53 UTC (rev 47680)
+++ grass/trunk/vector/v.colors.out/scan_cats.c 2011-08-16 18:22:25 UTC (rev 47681)
@@ -15,6 +15,7 @@
*cmin = *cmax = -1;
ilayer = Vect_get_field_number(&Map, layer);
if (ilayer < 1)
@@ -39,6 +40,8 @@
Vect_destroy_cats_struct(Cats);
+ Vect_close(&Map);
void scan_layer(int field, const struct line_cats *Cats, int *cmin, int *cmax)
