[GRASS-SVN] r47683 - grass/trunk/display/d.vect
svn_grass at osgeo.org
Tue Aug 16 14:44:00 EDT 2011
Author: martinl
Date: 2011-08-16 11:44:00 -0700 (Tue, 16 Aug 2011)
New Revision: 47683
grass/trunk/display/d.vect/d.vect.html
d.vect: note v.colors in the manual
Modified: grass/trunk/display/d.vect/d.vect.html
--- grass/trunk/display/d.vect/d.vect.html 2011-08-16 18:32:56 UTC (rev 47682)
+++ grass/trunk/display/d.vect/d.vect.html 2011-08-16 18:44:00 UTC (rev 47683)
@@ -1,17 +1,17 @@
<h2>DESCRIPTION</h2>
-<em>d.vect</em> displays GRASS vector data in the active frame on the graphics
-monitor.
+<em>d.vect</em> displays vector maps in the active frame on the
+graphics monitor.
<h2>NOTES</h2>
<em>d.vect</em> can simply be used typing <tt>d.vect
-map=vector_map</tt>. There are a large variety of optional parameters
+map=vector_map</tt>. There are a large variety of optional parameters
which allow the user to specify vector type, colors, data fields, SQL
queries, label size and justification, etc.
<p>
-By default <em>d.vect</em> fills in holes in polygons (islands). If
+By default <em>d.vect</em> fills in holes in polygons (islands). If
you only want to show active areas limit the features with, e.g.,
<div class="code"><pre>
d.vect map=vector_map cats=1-999999
@@ -22,11 +22,13 @@
specified in addition to the column name (<b>attrcolumn</b> parameter).
<p>
-Colors may be specified in an attribute table column named 'GRASSRGB'
-(which is a <tt>varchar(11)</tt> column
-containing <tt>RRR:GGG:BBB</tt> values), see the flag <b>-a</b>.
+Colors may be specified
+by <em><a href="v.colors.html">v.colors</a></em> as a color table or
+in an attribute table column named 'GRASSRGB' (which is
+a <tt>varchar(11)</tt> column containing <tt>RRR:GGG:BBB</tt> values),
+see the flag <b>-a</b>.
-<P>
+<p>
A table for a vector map might look like this:
@@ -109,19 +111,21 @@
<h2>SEE ALSO</h2>
<em>
-<a HREF="d.erase.html">d.erase</a>,
-<a HREF="d.rast.html">d.rast</a>,
-<a HREF="v.colors.html">v.colors</a>,
-<a HREF="v.db.addcolumn.html">v.db.addcolumn</a>,
-<a HREF="v.db.update.html">v.db.update</a><br>
-<a HREF="sql.html">GRASS SQL interface</a>
+ <a href="v.colors.html">v.colors</a>,
+ <a href="d.erase.html">d.erase</a>,
+ <a href="d.rast.html">d.rast</a>,
+ <a href="v.db.addcolumn.html">v.db.addcolumn</a>,
+ <a href="v.db.update.html">v.db.update</a><br>
+ <a href="sql.html">GRASS SQL interface</a>
</em>
<h2>AUTHORS</h2>
CERL<br>
Radim Blazek, ITC-Irst, Trento, Italy<br>
-other GRASS developers
+Support for color tables by Martin Landa, Czech Technical University in Prague (8/2011)<br>
+and many other GRASS developers
<p>
<i>Last changed: $Date$</i>
