[GRASS-SVN] r47704 - grass/branches/releasebranch_6_4/locale/po
svn_grass at osgeo.org
Wed Aug 17 09:18:31 EDT 2011
Author: neteler
Date: 2011-08-17 06:18:30 -0700 (Wed, 17 Aug 2011)
New Revision: 47704
grass/branches/releasebranch_6_4/locale/po/grassmods_ar.po
grass/branches/releasebranch_6_4/locale/po/grassmods_cs.po
grass/branches/releasebranch_6_4/locale/po/grassmods_de.po
grass/branches/releasebranch_6_4/locale/po/grassmods_el.po
grass/branches/releasebranch_6_4/locale/po/grassmods_es.po
grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po
grass/branches/releasebranch_6_4/locale/po/grassmods_hi.po
grass/branches/releasebranch_6_4/locale/po/grassmods_it.po
grass/branches/releasebranch_6_4/locale/po/grassmods_ja.po
grass/branches/releasebranch_6_4/locale/po/grassmods_ko.po
grass/branches/releasebranch_6_4/locale/po/grassmods_lv.po
grass/branches/releasebranch_6_4/locale/po/grassmods_mr.po
grass/branches/releasebranch_6_4/locale/po/grassmods_pl.po
grass/branches/releasebranch_6_4/locale/po/grassmods_pt.po
grass/branches/releasebranch_6_4/locale/po/grassmods_pt_br.po
grass/branches/releasebranch_6_4/locale/po/grassmods_ru.po
grass/branches/releasebranch_6_4/locale/po/grassmods_sl.po
grass/branches/releasebranch_6_4/locale/po/grassmods_th.po
grass/branches/releasebranch_6_4/locale/po/grassmods_tr.po
grass/branches/releasebranch_6_4/locale/po/grassmods_vi.po
grass/branches/releasebranch_6_4/locale/po/grassmods_zh.po
grass/branches/releasebranch_6_4/locale/po/grasswxpy_zh.po
fix typo
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_ar.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_ar.po 2011-08-17 13:17:00 UTC (rev 47703)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_ar.po 2011-08-17 13:18:30 UTC (rev 47704)
@@ -8689,7 +8689,7 @@
msgstr "اسÙ
اÙÙ
ÙÙ Ø§ÙØ±Ø§Ø³ØªØ±Ù اÙÙ
ÙØ¬Ùد"
#: ../raster/r.out.arc/main.c:78
-msgid "Name of an output ARC-GID map (use out=- for stdout)"
+msgid "Name of an output ARC-GRID map (use out=- for stdout)"
msgstr "اسÙ
اÙÙ
ÙÙ Ø§ÙØ±Ø§Ø³ØªØ±Ù Ø§ÙØ¬Ø¯Ùد"
#: ../raster/r.out.arc/main.c:85
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_cs.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_cs.po 2011-08-17 13:17:00 UTC (rev 47703)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_cs.po 2011-08-17 13:18:30 UTC (rev 47704)
@@ -8701,7 +8701,7 @@
msgstr "Název existujícího rastru"
msgstr ""
"Název výstupního ARC-GRID souboru (pro standardní výstup pou¾ijte out=-)"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_de.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_de.po 2011-08-17 13:17:00 UTC (rev 47703)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_de.po 2011-08-17 13:18:30 UTC (rev 47704)
@@ -8796,7 +8796,7 @@
msgstr "Name einer existierenden Rasterkarte."
msgstr "Name der Ausgabe ARCGRID-Datei (verwende out=- für stdout)"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_el.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_el.po 2011-08-17 13:17:00 UTC (rev 47703)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_el.po 2011-08-17 13:18:30 UTC (rev 47704)
@@ -8274,7 +8274,7 @@
msgstr ""
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_es.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_es.po 2011-08-17 13:17:00 UTC (rev 47703)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_es.po 2011-08-17 13:18:30 UTC (rev 47704)
@@ -8813,8 +8813,8 @@
msgstr "Nombre de una capa de mapa ráster existente"
-msgstr "Nombre de un mapa ARC-GID de salida (usar out=- para stdout)"
+msgstr "Nombre de un mapa ARC-GRID de salida (usar out=- para stdout)"
msgid "Number of decimal places"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po 2011-08-17 13:17:00 UTC (rev 47703)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po 2011-08-17 13:18:30 UTC (rev 47704)
@@ -9370,7 +9370,7 @@
msgstr "Nom de la couche raster existante"
msgstr "Nom de la couche ARC-GRID à créer (utiliser out=- pour stdout)"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_hi.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_hi.po 2011-08-17 13:17:00 UTC (rev 47703)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_hi.po 2011-08-17 13:18:30 UTC (rev 47704)
@@ -8965,7 +8965,7 @@
#, fuzzy
msgstr "à¤à¤¾ à¤à¥ लिà¤"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_it.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_it.po 2011-08-17 13:17:00 UTC (rev 47703)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_it.po 2011-08-17 13:18:30 UTC (rev 47704)
@@ -9318,8 +9318,8 @@
msgstr "Nome di una mappa raster esistente"
-msgstr "Nome di output di una mappa ARC-GID (usa out=- per lo standard output)"
+msgstr "Nome di output di una mappa ARC-GRID (usa out=- per lo standard output)"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_ja.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_ja.po 2011-08-17 13:17:00 UTC (rev 47703)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_ja.po 2011-08-17 13:18:30 UTC (rev 47704)
@@ -8490,8 +8490,8 @@
msgstr "æ¢åã®ã©ã¹ã¿ã¼ããã ã¬ã¤ã¤ã¼å"
-msgstr "åºåãã ARC-GID ãããå ï¼æ¨æºåºåã«ã¯ out= - ã使ç¨ããï¼"
+msgstr "åºåãã ARC-GRID ãããå ï¼æ¨æºåºåã«ã¯ out= - ã使ç¨ããï¼"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_ko.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_ko.po 2011-08-17 13:17:00 UTC (rev 47703)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_ko.po 2011-08-17 13:18:30 UTC (rev 47704)
@@ -8356,7 +8356,7 @@
msgstr ""
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_lv.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_lv.po 2011-08-17 13:17:00 UTC (rev 47703)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_lv.po 2011-08-17 13:18:30 UTC (rev 47704)
@@ -8552,7 +8552,7 @@
msgstr ""
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_mr.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_mr.po 2011-08-17 13:17:00 UTC (rev 47703)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_mr.po 2011-08-17 13:18:30 UTC (rev 47704)
@@ -8401,7 +8401,7 @@
msgstr ""
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_pl.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_pl.po 2011-08-17 13:17:00 UTC (rev 47703)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_pl.po 2011-08-17 13:18:30 UTC (rev 47704)
@@ -8628,8 +8628,8 @@
msgstr "Nazwa istniejÄ
cej warstwy mapy rastrowej"
-msgstr "Nazwa wyjÅciowej mapy ARC-GID (use out=- for stdout)"
+msgstr "Nazwa wyjÅciowej mapy ARC-GRID (use out=- for stdout)"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_pt.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_pt.po 2011-08-17 13:17:00 UTC (rev 47703)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_pt.po 2011-08-17 13:18:30 UTC (rev 47704)
@@ -9059,8 +9059,8 @@
msgstr "Nome da camada raster existente"
-msgstr "Nome do mapa ARC-GID de saída (use 'out=-' para saída padrão)"
+msgstr "Nome do mapa ARC-GRID de saída (use 'out=-' para saída padrão)"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_pt_br.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_pt_br.po 2011-08-17 13:17:00 UTC (rev 47703)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_pt_br.po 2011-08-17 13:18:30 UTC (rev 47704)
@@ -8398,8 +8398,8 @@
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_ru.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_ru.po 2011-08-17 13:17:00 UTC (rev 47703)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_ru.po 2011-08-17 13:18:30 UTC (rev 47704)
@@ -8753,9 +8753,9 @@
msgstr "ÐÐ¼Ñ ÑÑÑеÑÑвÑÑÑего ÑаÑÑÑового ÑлоÑ"
msgstr ""
-"ÐÐ¼Ñ Ð²ÑÑ
одного ÑÐ»Ð¾Ñ ARC-GID (иÑполÑзÑйÑе out=- Ð´Ð»Ñ stdout (ÑÑандаÑÑного "
+"ÐÐ¼Ñ Ð²ÑÑ
одного ÑÐ»Ð¾Ñ ARC-GRID (иÑполÑзÑйÑе out=- Ð´Ð»Ñ stdout (ÑÑандаÑÑного "
"вÑвода))"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_sl.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_sl.po 2011-08-17 13:17:00 UTC (rev 47703)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_sl.po 2011-08-17 13:18:30 UTC (rev 47704)
@@ -8818,7 +8818,7 @@
msgstr "Ime obstojeèega rastrskega sloja"
msgstr ""
"Ime izhodne ARC-GRID datoteke (uporabi out=- za standardni izhod (stdout))"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_th.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_th.po 2011-08-17 13:17:00 UTC (rev 47703)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_th.po 2011-08-17 13:18:30 UTC (rev 47704)
@@ -8604,8 +8604,8 @@
msgstr "à¸à¸·à¹à¸à¸à¸à¸ à¸à¸±à¹à¸à¸à¹à¸à¸¡à¸¹à¸¥à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภà¸à¸µà¹à¸¡à¸µà¸à¸¢à¸¹à¹"
-msgstr "à¸à¸·à¹à¸à¸à¸à¸ à¹à¸à¸à¸à¸µà¹à¸à¸¥à¸¥à¸±à¸à¸à¹ ARC-GID (à¹à¸à¹ out=- สำหรัภstdout)"
+msgstr "à¸à¸·à¹à¸à¸à¸à¸ à¹à¸à¸à¸à¸µà¹à¸à¸¥à¸¥à¸±à¸à¸à¹ ARC-GRID (à¹à¸à¹ out=- สำหรัภstdout)"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_tr.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_tr.po 2011-08-17 13:17:00 UTC (rev 47703)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_tr.po 2011-08-17 13:18:30 UTC (rev 47704)
@@ -8357,7 +8357,7 @@
msgstr "Mevcut bir raster harita katmanı adı"
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_vi.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_vi.po 2011-08-17 13:17:00 UTC (rev 47703)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_vi.po 2011-08-17 13:18:30 UTC (rev 47704)
@@ -8713,8 +8713,8 @@
msgstr "Tên lá»p bản Äá» raster hiá»n có"
-msgstr "Tên bản Äá» ARC-GID Äầu ra (dùng out=- cho Äầu ra tiêu chuẩn)"
+msgstr "Tên bản Äá» ARC-GRID Äầu ra (dùng out=- cho Äầu ra tiêu chuẩn)"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_zh.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_zh.po 2011-08-17 13:17:00 UTC (rev 47703)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_zh.po 2011-08-17 13:18:30 UTC (rev 47704)
@@ -8691,7 +8691,7 @@
msgstr "å·²ææ
æ ¼å¾å±çåç§°"
msgstr "è¾åºçGRIDçåç§°(out=-ç¨äºæ åè¾åº)"
Modified: grass/branches/releasebranch_6_4/locale/po/grasswxpy_zh.po
--- grass/branches/releasebranch_6_4/locale/po/grasswxpy_zh.po 2011-08-17 13:17:00 UTC (rev 47703)
+++ grass/branches/releasebranch_6_4/locale/po/grasswxpy_zh.po 2011-08-17 13:18:30 UTC (rev 47704)
@@ -15901,7 +15901,7 @@
#~ msgid "Name of an existing raster map layer"
#~ msgstr "å·²ææ
æ ¼å¾å±çåç§°"
-#~ msgid "Name of an output ARC-GID map (use out=- for stdout)"
+#~ msgid "Name of an output ARC-GRID map (use out=- for stdout)"
#~ msgstr "è¾åºçGRIDçåç§°(out=-ç¨äºæ åè¾åº)"
#~ msgid "Number of decimal places"
