[GRASS-SVN] r47714 - in grass/trunk/gui/wxpython: . gui_modules
svn_grass at osgeo.org
Wed Aug 17 15:31:48 EDT 2011
Author: annakrat
Date: 2011-08-17 12:31:48 -0700 (Wed, 17 Aug 2011)
New Revision: 47714
grass/trunk/gui/wxpython/gui_modules/colorrules.py
grass/trunk/gui/wxpython/gui_modules/gselect.py
grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
grass/trunk/gui/wxpython/gui_modules/workspace.py
grass/trunk/gui/wxpython/gui_modules/wxnviz.py
grass/trunk/gui/wxpython/wxgui.py
wxGUI/wxNviz: color rules dialog changed to support both v.colors and attribute columns
Modified: grass/trunk/gui/wxpython/gui_modules/colorrules.py
--- grass/trunk/gui/wxpython/gui_modules/colorrules.py 2011-08-17 18:38:59 UTC (rev 47713)
+++ grass/trunk/gui/wxpython/gui_modules/colorrules.py 2011-08-17 19:31:48 UTC (rev 47714)
@@ -46,17 +46,17 @@
class RulesPanel:
- def __init__(self, parent, mapType, columnType, properties, panelWidth = 180):
+ def __init__(self, parent, mapType, attributeType, properties, panelWidth = 180):
"""!Create rules panel
@param mapType raster/vector
- @param columnType color/size for choosing widget type
- @param properties properties of classes derived from ColorTabel
+ @param attributeType color/size for choosing widget type
+ @param properties properties of classes derived from ColorTable
@param panelWidth width of scroll panel"""
self.ruleslines = {}
self.mapType = mapType
- self.columnType = columnType
+ self.attributeType = attributeType
self.properties = properties
self.parent = parent
@@ -72,14 +72,6 @@
self.mainPanel.SetSizer(self.mainSizer)
self.mainPanel.SetAutoLayout(True)
- if self.mapType == 'vector' and self.columnType == 'color':
- self.label = wx.StaticText(parent, id = wx.ID_ANY, label = _("Set color for attribute values:"))
- elif self.mapType == 'vector' and self.columnType == 'size':
- if self.parent.GetParent().vectorType == 'points':
- label = label = _("Set size for attribute values:")
- else:
- label = label = _("Set width for attribute values:")
- self.label = wx.StaticText(parent, id = wx.ID_ANY, label = label)
# (un)check all
self.checkAll = wx.CheckBox(parent, id = wx.ID_ANY, label = _("Check all"))
self.checkAll.SetValue(True)
@@ -138,11 +130,10 @@
size = (80, -1),
style = wx.TE_NOHIDESEL)
if self.mapType == 'vector':
- txt_ctrl.SetToolTipString(_("Enter vector attribute values (e.g. 5) "
- "or ranges (e.g. 5 to 10)"))
+ txt_ctrl.SetToolTipString(_("Enter vector attribute values"))
txt_ctrl.Bind(wx.EVT_TEXT, self.OnRuleValue)
txt_ctrl.SetName('source')
- if self.columnType == 'color':
+ if self.attributeType == 'color':
# color
columnCtrl = csel.ColourSelect(self.mainPanel, id = 2000 + num,
size = globalvar.DIALOG_COLOR_SIZE)
@@ -151,16 +142,20 @@
if not start:
self.ruleslines[enable.GetId()] = { 'value' : '',
'color': "0:0:0" }
- if self.columnType == 'size':
- # size
+ else:
+ # size or width
+ init = 2
+ if self.attributeType == 'size':
+ init = 100
columnCtrl = wx.SpinCtrl(self.mainPanel, id = 2000 + num,
- size = (50, -1), min = 1, max = 1e3,
- initial = 5)
+ size = (50, -1), min = 1, max = 1e4,
+ initial = init)
columnCtrl.Bind(wx.EVT_SPINCTRL, self.OnRuleSize)
+ columnCtrl.Bind(wx.EVT_TEXT, self.OnRuleSize)
columnCtrl.SetName('target')
if not start:
- 'size': 100 }
+ self.attributeType: init }
self.mainSizer.Add(item = enable, proportion = 0,
flag = wx.ALIGN_CENTER_VERTICAL)
@@ -180,13 +175,19 @@
if event.IsChecked():
self.mainPanel.FindWindowById(id + 1000).Enable()
self.mainPanel.FindWindowById(id + 2000).Enable()
- if self.mapType == 'vector':
- value = self.SQLConvert(self.mainPanel.FindWindowById(id + 1000).GetValue(), self.columnType)
+ if self.mapType == 'vector' and not self.parent.GetParent().colorTable:
+ vals = []
+ vals.append(self.mainPanel.FindWindowById(id + 1000).GetValue())
+ try:
+ vals.append(self.mainPanel.FindWindowById(id + 1 + 1000).GetValue())
+ except AttributeError:
+ vals.append(None)
+ value = self.SQLConvert(vals)
else:
value = self.mainPanel.FindWindowById(id + 1000).GetValue()
color = self.mainPanel.FindWindowById(id + 2000).GetValue()
# color
color_str = str(color[0]) + ':' \
+ str(color[1]) + ':' \
@@ -195,9 +196,9 @@
'color' : color_str }
else:
- # size
+ # size or width
self.ruleslines[id] = {'value' : value,
- 'size' : float(color) }
+ self.attributeType : float(color) }
else:
self.mainPanel.FindWindowById(id + 1000).Disable()
@@ -221,50 +222,56 @@
num = event.GetId()
size = event.GetInt()
- self.ruleslines[num - 2000]['size'] = size
+ self.ruleslines[num - 2000][self.attributeType] = size
def OnRuleValue(self, event):
"""!Rule value changed"""
num = event.GetId()
- vals = event.GetString().strip()
+ val = event.GetString().strip()
- if vals == '':
+ if val == '':
return
- self.SetVectorRule(num, vals)
+ try:
+ table = self.parent.colorTable
+ # due to scrollpanel in vector dialog
+ table = self.parent.GetParent().colorTable
+ if table:
+ self.SetRasterRule(num, val)
else:
- self.SetRasterRule(num, vals)
+ self.SetVectorRule(num, val)
- def SetRasterRule(self, num, vals):
+ def SetRasterRule(self, num, val):
"""!Set raster rule"""
- self.ruleslines[num-1000]['value'] = vals
+ self.ruleslines[num - 1000]['value'] = val
- def SetVectorRule(self, num, vals):
+ def SetVectorRule(self, num, val):
"""!Set vector rule"""
- tc = self.mainPanel.FindWindowById(num)
- source, target = 'source_rgb', 'rgb'
- else:
- source, target = 'source_size', 'size'
- if self.properties[source] == '' or self.properties[target] == '':
- tc.SetValue('')
- gcmd.GMessage(parent = self,
- message = _("Please select attribute column "
- "and RGB color column first"))
- else:
- try:
- self.ruleslines[num-1000]['value'] = self.SQLConvert(vals, self.columnType)
- except ValueError:
- tc.SetValue('')
- self.ruleslines[num-1000]['value'] = ''
- return
+## tc = self.mainPanel.FindWindowById(num)
+## source, target = 'sourceColumn', 'storeColumn'
+## if self.properties[source] == '' or self.properties[target] == '':
+## tc.SetValue('')
+## gcmd.GMessage(parent = self.parent,
+## message = _("Please select attribute column "
+## "and RGB color column first"))
+## else:
+ vals = []
+ vals.append(val)
+ try:
+ vals.append(self.mainPanel.FindWindowById(num + 1).GetValue())
+ vals.append(None)
+ self.ruleslines[num - 1000]['value'] = self.SQLConvert(vals)
+## except ValueError:
+## tc.SetValue('')
+## self.ruleslines[num - 1000]['value'] = ''
def Enable(self, enable = True):
"""!Enable/Disable all widgets"""
for child in self.mainPanel.GetChildren():
child.Enable(enable)
+ sql = True
+ self.LoadRulesline(sql)# todo
self.btnAdd.Enable(enable)
self.numRules.Enable(enable)
self.checkAll.Enable(enable)
@@ -272,48 +279,42 @@
def LoadRules(self):
- """!Fill rule widgets from ruleslines"""
message = ""
for item in range(len(self.ruleslines)):
self.mainPanel.FindWindowById(item + 1000).SetValue(self.ruleslines[item]['value'])
r, g, b = (0, 0, 0) # default
- if self.ruleslines[item][self.columnType] == '':
- self.ruleslines[item][self.columnType] = '%d:%d:%d' % (r, g, b)
- elif self.columnType == 'size':
- self.ruleslines[item][self.columnType] = 100
+ if not self.ruleslines[item][self.attributeType]:
+ self.ruleslines[item][self.attributeType] = '%d:%d:%d' % (r, g, b)
+ elif self.attributeType == 'size':
+ self.ruleslines[item][self.attributeType] = 100
+ elif self.attributeType == 'width':
+ self.ruleslines[item][self.attributeType] = 2
try:
- r, g, b = map(int, self.ruleslines[item][self.columnType].split(':'))
+ r, g, b = map(int, self.ruleslines[item][self.attributeType].split(':'))
except ValueError, e:
message = _("Bad color format. Use color format '0:0:0'")
self.mainPanel.FindWindowById(item + 2000).SetValue((r, g, b))
else:
- value = float(self.ruleslines[item][self.columnType])
+ value = float(self.ruleslines[item][self.attributeType])
self.mainPanel.FindWindowById(item + 2000).SetValue(value)
if message:
gcmd.GMessage(parent = self.parent, message = message)
return False
- return True
- def SQLConvert(self, vals, type = 'color'):
+ return True
+ def SQLConvert(self, vals):
"""!Prepare value for SQL query"""
- if type == 'color':
- source = 'source_rgb'
- elif type == 'size':
- source = 'source_size'
- valslist = []
- valslist = vals.split('to')
- if len(valslist) == 1:
- sqlrule = '%s=%s' % (self.properties[source], valslist[0])
- elif len(valslist) > 1:
- sqlrule = '%s>=%s AND %s<=%s' % (self.properties[source], valslist[0],
- self.properties[source], valslist[1])
+ if vals[0].isdigit():
+ sqlrule = '%s>=%s' % (self.properties['sourceColumn'], vals[0])
+ if vals[1]:
+ sqlrule += ' AND %s<%s' % (self.properties['sourceColumn'], vals[1])
else:
- return None
+ sqlrule = '%s=%s' % (self.properties['sourceColumn'], vals[0])
return sqlrule
@@ -339,8 +340,7 @@
# input map to change
self.inmap = ''
# reference to layer with preview
- self.layer = None
+ self.layer = None
# layout
self._doLayout()
@@ -360,10 +360,10 @@
# if not the right type, than select another
try:
sel = self.parent.curr_page.maptree.layer_selected
- if sel and self.parent.curr_page.maptree.GetPyData(sel)[0]['type'] == self.type:
+ if sel and self.parent.curr_page.maptree.GetPyData(sel)[0]['type'] == self.mapType:
layer = sel
else:
- layer = self.parent.curr_page.maptree.FindItemByData(key = 'type', value = self.type)
+ layer = self.parent.curr_page.maptree.FindItemByData(key = 'type', value = self.mapType)
except:
layer = None
if layer:
@@ -418,17 +418,13 @@
row += 1
# color table
- self.colorRulesPanel = RulesPanel(parent = parent, mapType = self.type,
- columnType = 'color', properties = self.properties)
- if self.type == 'vector':
- bodySizer.Add(item = self.colorRulesPanel.label, pos = (row, 0), span = (1, 2),
- flag = wx.ALL, border = 5)
- row += 1
+ self.rulesPanel = RulesPanel(parent = parent, mapType = self.mapType,
+ attributeType = self.attributeType, properties = self.properties)
- bodySizer.Add(item = self.colorRulesPanel.mainPanel, pos = (row, 0), span = (1, 2),
+ bodySizer.Add(item = self.rulesPanel.mainPanel, pos = (row, 0), span = (1, 2),
# add two rules as default
- self.colorRulesPanel.AddRules(2)
+ self.rulesPanel.AddRules(2)
# preview window
self._createPreview(parent = parent)
@@ -436,9 +432,9 @@
flag = wx.EXPAND | wx.LEFT | wx.RIGHT, border = 5)
row += 1
# add ckeck all and clear all
- bodySizer.Add(item = self.colorRulesPanel.checkAll, flag = wx.ALIGN_CENTER_VERTICAL,
+ bodySizer.Add(item = self.rulesPanel.checkAll, flag = wx.ALIGN_CENTER_VERTICAL,
pos = (row, 0))
- bodySizer.Add(item = self.colorRulesPanel.clearAll, pos = (row, 1))
+ bodySizer.Add(item = self.rulesPanel.clearAll, pos = (row, 1))
# preview button
self.btnPreview = wx.Button(parent, id = wx.ID_ANY,
@@ -450,9 +446,9 @@
"(current Map Display extent is used)."))
row +=1
# add rules button and spin to sizer
- bodySizer.Add(item = self.colorRulesPanel.numRules, pos = (row, 0),
+ bodySizer.Add(item = self.rulesPanel.numRules, pos = (row, 0),
- bodySizer.Add(item = self.colorRulesPanel.btnAdd, pos = (row, 1))
+ bodySizer.Add(item = self.rulesPanel.btnAdd, pos = (row, 1))
@@ -479,12 +475,14 @@
@return True on success otherwise False
- ret = self.CreateColorTable()
+ ret = self.CreateColorTable(mapType = self.mapType)
+ if not self.colorTable:
+ self.UseAttrColumn()
if ret:
display = self.parent.GetLayerTree().GetMapDisplay()
if display and display.IsAutoRendered():
display.GetWindow().UpdateMap(render = True)
return ret
def OnOK(self, event):
@@ -495,7 +493,105 @@
def OnCancel(self, event):
"""!Do not apply any changes and close the dialog"""
self.Destroy()
+ def LoadTable(self, mapType = 'raster'):
+ """!Load current color table (using `r.colors.out`)"""
+ self.rulesPanel.Clear()
+ if mapType == 'raster':
+ cmd = ['r.colors.out',
+ 'read=True',
+ 'map=%s' % self.inmap,
+ 'rules=-']
+ else:
+ cmd = ['v.colors.out',
+ 'read=True',
+ 'rules=-']
+ if self.properties['sourceColumn'] != 'cat':
+ cmd.append('column=%s' % self.properties['sourceColumn'])
+ cmd = utils.CmdToTuple(cmd)
+ if self.inmap:
+ ctable = gcmd.RunCommand(cmd[0], **cmd[1])
+ else:
+ self.OnPreview()
+ return
+ rulesNumber = len(ctable.splitlines())
+ self.rulesPanel.AddRules(rulesNumber)
+ count = 0
+ for line in ctable.splitlines():
+ value, color = map(lambda x: x.strip(), line.split(' '))
+ self.rulesPanel.ruleslines[count]['value'] = value
+ self.rulesPanel.ruleslines[count]['color'] = color
+ self.rulesPanel.mainPanel.FindWindowById(count + 1000).SetValue(value)
+ rgb = list()
+ for c in color.split(':'):
+ rgb.append(int(c))
+ self.rulesPanel.mainPanel.FindWindowById(count + 2000).SetColour(rgb)
+ count += 1
+ self.OnPreview(tmp = True)
+ def CreateColorTable(self, force = False, mapType = 'raster'):
+ """!Creates color table
+ @return True on success
+ @return False on failure
+ rulestxt = ''
+ for rule in self.rulesPanel.ruleslines.itervalues():
+ if not rule['value']: # skip empty rules
+ continue
+ if rule['value'] not in ('nv', 'default') and \
+ rule['value'][-1] != '%' and \
+ not self._IsNumber(rule['value']):
+ gcmd.GError(_("Invalid rule value '%s'. Unable to apply color table.") % rule['value'],
+ parent = self)
+ return False
+ rulestxt += rule['value'] + ' ' + rule['color'] + '\n'
+ if not rulestxt:
+ gcmd.GMessage(parent = self, message = _("No color rules given."))
+ return False
+ gtemp = utils.GetTempfile()
+ output = open(gtemp, "w")
+ try:
+ output.write(rulestxt)
+ finally:
+ output.close()
+ flags = ''
+ if not force and not self.ovrwrtcheck.IsChecked():
+ flags = 'w'
+ cmd = ['%s.colors' % mapType[0],#r.colors/v.colors
+ 'flags=%s' % flags,
+ 'rules=%s' % gtemp]
+ if mapType == 'vector' and self.properties['sourceColumn']:
+ ret = gcmd.RunCommand(cmd[0], **cmd[1])
+ if ret != 0 and mapType == 'raster':
+ gcmd.GMessage(_("Color table already exists. "
+ "Check out 'replace existing color table' to "
+ "overwrite it."),
+ parent = self)
+ return False
+ return True
def DoPreview(self, ltype, cmdlist):
"""!Update preview (based on computational region)"""
@@ -507,7 +603,7 @@
self.layer.SetCmd(cmdlist)
# apply new color table and display preview
- self.CreateColorTable(force = True)
+ self.CreateColorTable(force = True, mapType = self.mapType)
self.preview.UpdatePreview()
def RunHelp(self, cmd):
@@ -530,8 +626,9 @@
def __init__(self, parent, **kwargs):
"""!Dialog for interactively entering color rules for raster maps"""
- self.type = 'raster'
+ self.mapType = 'raster'
+ self.attributeType = 'color'
+ self.colorTable = True
# raster properties
self.properties = {
# min cat in raster map
@@ -630,7 +727,7 @@
self.btnPreview.Enable(False)
self.btnOK.Enable(False)
self.btnApply.Enable(False)
- self.OnLoadTable(event)
+ self.LoadTable()
return
info = grass.raster_info(map = self.inmap)
@@ -638,7 +735,7 @@
if info:
self.properties['min'] = info['min']
self.properties['max'] = info['max']
+ self.LoadTable()
else:
self.inmap = ''
self.properties['min'] = self.properties['max'] = None
@@ -661,41 +758,9 @@
self.btnPreview.Enable()
self.btnOK.Enable()
self.btnApply.Enable()
- def OnLoadTable(self, event):
- """!Load current color table (using `r.colors.out`)"""
- self.colorRulesPanel.Clear()
- if self.inmap:
- ctable = gcmd.RunCommand('r.colors.out',
- parent = self,
- read = True,
- map = self.inmap,
- rules = '-')
- else:
- self.OnPreview(event)
- return
- rulesNumber = len(ctable.splitlines())
- self.colorRulesPanel.AddRules(rulesNumber)
- count = 0
- for line in ctable.splitlines():
- value, color = map(lambda x: x.strip(), line.split(' '))
- self.colorRulesPanel.ruleslines[count]['value'] = value
- self.colorRulesPanel.ruleslines[count]['color'] = color
- self.colorRulesPanel.mainPanel.FindWindowById(count + 1000).SetValue(value)
- rgb = list()
- for c in color.split(':'):
- rgb.append(int(c))
- self.colorRulesPanel.mainPanel.FindWindowById(count + 2000).SetColour(rgb)
- count += 1
- self.OnPreview(tmp = False)
- def OnPreview(self, event = None, tmp = True):
+ def OnPreview(self, tmp = True):
if not self.inmap:
self.preview.EraseMap()
@@ -739,7 +804,7 @@
def OnSaveTable(self, event):
"""!Save color table to file"""
rulestxt = ''
- for rule in self.ruleslines.itervalues():
continue
@@ -763,97 +828,50 @@
cmd = 'r.colors'
ColorTable.RunHelp(self, cmd = cmd)
- def CreateColorTable(self, force = False):
- """!Creates color table
- @return True on success
- @return False on failure
- rulestxt = ''
- for rule in self.colorRulesPanel.ruleslines.itervalues():
- if not rule['value']: # skip empty rules
- continue
- if rule['value'] not in ('nv', 'default') and \
- rule['value'][-1] != '%' and \
- not self._IsNumber(rule['value']):
- gcmd.GError(_("Invalid rule value '%s'. Unable to apply color table.") % rule['value'],
- parent = self)
- return False
- rulestxt += rule['value'] + ' ' + rule['color'] + '\n'
- if not rulestxt:
- gcmd.GMessage(parent = self, message = _("No color rules given."))
- return False
- gtemp = utils.GetTempfile()
- output = open(gtemp, "w")
- try:
- output.write(rulestxt)
- finally:
- output.close()
- if not force and not self.ovrwrtcheck.IsChecked():
- flags = 'w'
- else:
- flags = ''
- ret = gcmd.RunCommand('r.colors',
- flags = flags,
- map = self.inmap,
- rules = gtemp)
- if ret != 0:
- gcmd.GMessage(_("Color table already exists. "
- "Check out 'replace existing color table' to "
- "overwrite it."),
- parent = self)
- return False
- return True
class VectorColorTable(ColorTable):
- def __init__(self, parent, **kwargs):
+ def __init__(self, parent, attributeType, **kwargs):
"""!Dialog for interactively entering color rules for vector maps"""
- self.type = 'vector'
+ # dialog attributes
+ self.mapType = 'vector'
+ self.attributeType = attributeType # color, size, width
+ # in version 7 v.colors used, otherwise color column only
+ self.version7 = int(grass.version()['version'].split('.')[0]) >= 7
+ self.colorTable = False
# vector properties
self.properties = {
- # list of database layers for vector (minimum of 1)
- 'layers' : [],
- # list of database columns for vector
- 'columns' : [],
# vector layer for attribute table to use for setting color
'layer' : 1,
# vector attribute table used for setting color
'table' : '',
# vector attribute column for assigning colors
- 'source_rgb' : '',
+ 'sourceColumn' : '',
+ # vector attribute column to use for loading colors
+ 'loadColumn' : '',
# vector attribute column to use for storing colors
- 'rgb' : '',
+ 'storeColumn' : '',
# vector attribute column for temporary storing colors
- 'tmp_rgb' : '',
- # vector attribute column for temporary storing size
- 'tmp_size' : '',
- # vector attribute column for assigning size
- 'source_size' : '',
- # vector attribute column to use for storing size
- 'size' : '',
+ 'tmpColumn' : ''
+ self.columnsProp = {'color': {'name': 'GRASSRGB', 'type1': 'varchar(11)', 'type2': ['character']},
+ 'size' : {'name': 'GRASSSIZE', 'type1': 'integer', 'type2': ['integer']},
+ 'width': {'name': 'GRASSWIDTH', 'type1': 'integer', 'type2': ['integer']}}
ColorTable.__init__(self, parent = parent,
- title = _('Create new color table for vector map'), **kwargs)
+ title = _('Create new color rules for vector map'), **kwargs)
# additional bindings for vector color management
- self.Bind(wx.EVT_COMBOBOX, self.OnLayerSelection, self.cb_vlayer)
- self.Bind(wx.EVT_COMBOBOX, self.OnColumnSelection, self.cb_color_att)
- self.Bind(wx.EVT_COMBOBOX, self.OnRGBColSelection, self.cb_rgb_col)
- self.Bind(wx.EVT_BUTTON, self.OnAddColumn, self.btn_add_RGB)
+ self.Bind(wx.EVT_COMBOBOX, self.OnLayerSelection, self.layerSelect)
+ self.Bind(wx.EVT_COMBOBOX, self.OnSourceColumnSelection, self.sourceColumn)
+ self.Bind(wx.EVT_COMBOBOX, self.OnFromColSelection, self.fromColumn)
+ self.Bind(wx.EVT_COMBOBOX, self.OnToColSelection, self.toColumn)
+ self.Bind(wx.EVT_BUTTON, self.OnAddColumn, self.addColumn)
self._initLayer()
- self.cr_label.SetLabel(_("Enter vector attribute values (e.g. 5) "
+ if self.colorTable:
+ self.cr_label.SetLabel(_("Enter vector attribute values or percents:"))
+ else:
+ self.cr_label.SetLabel(_("Enter vector attribute values:"))
self.SetMinSize(self.GetSize())
self.CentreOnScreen()
self.Show()
@@ -869,11 +887,9 @@
self.selectionInput = gselect.Select(parent, id = wx.ID_ANY,
size = globalvar.DIALOG_GSELECT_SIZE,
type = 'vector')
- # layout
inputSizer.Add(item = self.selectionInput, proportion = 1,
flag = wx.ALIGN_CENTER_VERTICAL | wx.ALL | wx.EXPAND, border = 5)
return inputSizer
def _createVectorAttrb(self, parent):
@@ -884,38 +900,68 @@
label = _('Layer:'))
cb_vc_label = wx.StaticText(parent, id = wx.ID_ANY,
label = _('Attribute column:'))
- cb_vrgb_label = wx.StaticText(parent, id = wx.ID_ANY,
- label = _('RGB color column:'))
+ labels = [_("Load color from column:"), _("Save color to column:")]
+ labels = [_("Load size from column:"), _("Save size to column:")]
+ labels = [_("Load width from column:"), _("Save width to column:")]
+ if self.version7 and self.attributeType == 'color':
+ self.useColumn = wx.CheckBox(parent, id = wx.ID_ANY,
+ label = _("Use color column instead of color table:"))
+ self.useColumn.Bind(wx.EVT_CHECKBOX, self.OnCheckColumn)
+ fromColumnLabel = wx.StaticText(parent, id = wx.ID_ANY,
+ label = labels[0])
+ toColumnLabel = wx.StaticText(parent, id = wx.ID_ANY,
+ label = labels[1])
self.rgb_range_label = wx.StaticText(parent, id = wx.ID_ANY)
- self.cb_vlayer = gselect.LayerSelect(parent)
- self.cb_color_att = gselect.ColumnSelect(parent)
- self.cb_rgb_col = gselect.ColumnSelect(parent)
- self.btn_add_RGB = wx.Button(parent, id = wx.ID_ANY,
+ self.layerSelect = gselect.LayerSelect(parent)
+ self.sourceColumn = gselect.ColumnSelect(parent)
+ self.fromColumn = gselect.ColumnSelect(parent)
+ self.toColumn = gselect.ColumnSelect(parent)
+ self.addColumn = wx.Button(parent, id = wx.ID_ANY,
label = _('Add column'))
- self.btn_add_RGB.SetToolTipString(_("Add GRASSRGB column to current attribute table."))
+ self.addColumn.SetToolTipString(_("Add GRASSRGB column to current attribute table."))
# layout
inputSizer = wx.StaticBoxSizer(inputBox, wx.VERTICAL)
vSizer = wx.GridBagSizer(hgap = 5, vgap = 5)
- vSizer.Add(cb_vl_label, pos = (0, 0),
+ row = 0
+ vSizer.Add(cb_vl_label, pos = (row, 0),
- vSizer.Add(self.cb_vlayer, pos = (0, 1),
+ vSizer.Add(self.layerSelect, pos = (row, 1),
- vSizer.Add(cb_vc_label, pos = (1, 0),
+ row += 1
+ vSizer.Add(cb_vc_label, pos = (row, 0),
- vSizer.Add(self.cb_color_att, pos = (1, 1),
+ vSizer.Add(self.sourceColumn, pos = (row, 1),
- vSizer.Add(self.rgb_range_label, pos = (1, 2),
+ vSizer.Add(self.rgb_range_label, pos = (row, 2),
- vSizer.Add(cb_vrgb_label, pos = (2, 0),
+ row += 1
+ vSizer.Add(self.useColumn, pos = (row, 0), span = (1, 2),
+ flag = wx.ALIGN_CENTER_VERTICAL)
+ row += 1
+ vSizer.Add(fromColumnLabel, pos = (row, 0),
- vSizer.Add(self.cb_rgb_col, pos = (2, 1),
+ vSizer.Add(self.fromColumn, pos = (row, 1),
- vSizer.Add(self.btn_add_RGB, pos = (2, 2),
+ row += 1
+ vSizer.Add(toColumnLabel, pos = (row, 0),
+ vSizer.Add(self.toColumn, pos = (row, 1),
+ vSizer.Add(self.addColumn, pos = (row, 2),
inputSizer.Add(item = vSizer,
+ self.colorColumnSizer = vSizer
return inputSizer
def _doLayout(self):
@@ -982,10 +1028,47 @@
if dlg.ShowModal() == wx.ID_YES:
dlg.Destroy()
menuform.GUI(parent = self).ParseCommand(['v.db.addtable', 'map=' + self.inmap],
- completed = (self.CreateTable, self.inmap, ''))
+ completed = (self.CreateAttrTable, self.inmap, ''))
else:
dlg.Destroy()
+ def OnCheckColumn(self, event):
+ """!Use color column instead of color table"""
+ if self.useColumn.GetValue():
+ self.properties['loadColumn'] = self.fromColumn.GetStringSelection()
+ self.properties['storeColumn'] = self.toColumn.GetStringSelection()
+ self.fromColumn.Enable(True)
+ self.toColumn.Enable(True)
+ if self.properties['loadColumn']:
+ self.LoadTable()
+ else:
+ else:
+ self.properties['loadColumn'] = ''
+ self.properties['storeColumn'] = ''
+ self.fromColumn.Enable(False)
+ self.toColumn.Enable(False)
+ self.LoadTable()
+ def EnableVectorAttributes(self, enable):
+ """!Enable/disable part of dialog connected with db"""
+ for child in self.colorColumnSizer.GetChildren():
+ child.GetWindow().Enable(enable)
+ def DisableClearAll(self):
+ """!Enable, disable the whole dialog"""
+ self.EnableVectorAttributes(False)
+ self.btnPreview.Enable(False)
+ self.btnOK.Enable(False)
+ self.btnApply.Enable(False)
+ self.preview.EraseMap()
def OnSelectionInput(self, event):
"""!Vector map selected"""
if event:
@@ -998,51 +1081,60 @@
self.UpdateDialog()
def UpdateDialog(self):
- """!Update dialog after map selection"""
+ """!Update dialog after map selection"""
if not self.inmap:
- self.btnPreview.Enable(False)
- self.btnOK.Enable(False)
- self.btnApply.Enable(False)
- self.preview.EraseMap()
+ self.DisableClearAll()
return
+ if self.inmap and not self.CheckMapset():
+ # currently v.colors need the map to be in current mapset
+ message = _("Selected map <%s> is not in current mapset <%s>. "
+ "Color rules cannot be edited.") % \
+ (self.inmap, grass.gisenv()['MAPSET'])
+ else:
+ "Attribute table cannot be edited.") % \
+ wx.CallAfter(gcmd.GMessage, parent = self, message = message)
+ return
# check for db connection
self.dbInfo = gselect.VectorDBInfo(self.inmap)
- if not len(self.dbInfo.layers):
- wx.CallAfter(self.NoConnection, self.inmap)
- for combo in (self.cb_vlayer, self.cb_color_att, self.cb_rgb_col):
+ enable = True
+ if not len(self.dbInfo.layers): # no connection
+ if not (self.version7 and self.attributeType == 'color'): # otherwise it doesn't matter
+ wx.CallAfter(self.NoConnection, self.inmap)
+ enable = False
+ for combo in (self.layerSelect, self.sourceColumn, self.fromColumn, self.toColumn):
combo.SetValue("")
- combo.Disable()
combo.Clear()
- enable = False
- else:
+ else: # db connection exist
# initialize layer selection combobox
- combo.Enable()
- self.cb_vlayer.InsertLayers(self.inmap)
+ self.EnableVectorAttributes(True)
+ self.layerSelect.InsertLayers(self.inmap)
# initialize attribute table for layer=1
- self.properties['layer'] = self.cb_vlayer.GetString(0)
- self.cb_vlayer.SetStringSelection(self.properties['layer'])
+ self.properties['layer'] = self.layerSelect.GetString(0)
+ self.layerSelect.SetStringSelection(self.properties['layer'])
layer = int(self.properties['layer'])
self.properties['table'] = self.dbInfo.layers[layer]['table']
- if self.CheckMapset():
- enable = True
- self.btn_add_RGB.Enable(True)
- self.AddTemporaryColumn(name = 'tmp_rgb', type = 'varchar(20)')
+ self.AddTemporaryColumn(name = 'tmpColumn', type = 'varchar(20)')
else:
- enable = False
- wx.CallAfter(gcmd.GMessage, parent = self,
- message = _("Selected map <%s> is not in current mapset <%s>. "
- "Attribute table cannot be edited. "
- "Color rules will not be saved.") %
- (self.inmap, grass.gisenv()['MAPSET']))
- self.btn_add_RGB.Enable(False)
+ self.AddTemporaryColumn(name = 'tmpColumn', type = 'integer')
# initialize column selection comboboxes
self.OnLayerSelection(event = None)
+ self.useColumn.SetValue(False)
+ self.OnCheckColumn(event = None)
+ self.LoadTable()
self.btnPreview.Enable(enable)
self.btnOK.Enable(enable)
@@ -1054,7 +1146,7 @@
ret = gcmd.RunCommand('v.db.addcolumn',
map = self.inmap,
layer = self.properties['layer'],
- columns = '%s %s' % (name, type))
+ column = '%s %s' % (name, type))
self.properties[name] = name
def DeleteTemporaryColumn(self, name):
@@ -1066,47 +1158,61 @@
def OnLayerSelection(self, event):
# reset choices in column selection comboboxes if layer changes
- vlayer = int(self.cb_vlayer.GetStringSelection())
- self.cb_color_att.InsertColumns(vector = self.inmap, layer = vlayer, dbInfo = self.dbInfo)
- self.cb_color_att.SetSelection(0)
- self.properties['source_rgb'] = self.cb_color_att.GetString(0)
- self.cb_rgb_col.InsertColumns(vector = self.inmap, layer = vlayer, type = ["character"], dbInfo = self.dbInfo)
-# self.cb_rgb_col.Delete(self.cb_rgb_col.FindString(self.properties['source_rgb']))
- found = self.cb_rgb_col.FindString('GRASSRGB')
+ vlayer = int(self.layerSelect.GetStringSelection())
+ self.sourceColumn.InsertColumns(vector = self.inmap, layer = vlayer,
+ type = ['integer', 'double precision'], dbInfo = self.dbInfo,
+ excludeCols = ['tmpColumn'])
+ self.sourceColumn.SetStringSelection('cat')
+ self.properties['sourceColumn'] = self.sourceColumn.GetString(0)
+ type = ['character']
+ else:
+ type = ['integer']
+ self.fromColumn.InsertColumns(vector = self.inmap, layer = vlayer, type = type,
+ dbInfo = self.dbInfo, excludeCols = ['tmpColumn'])
+ self.toColumn.InsertColumns(vector = self.inmap, layer = vlayer, type = type,
+ found = self.fromColumn.FindString(self.columnsProp[self.attributeType]['name'])
if found != wx.NOT_FOUND:
- self.cb_rgb_col.SetSelection(found)
- self.properties['rgb'] = self.cb_rgb_col.GetString(found)
+ self.fromColumn.SetSelection(found)
+ self.toColumn.SetSelection(found)
+ self.properties['loadColumn'] = self.fromColumn.GetString(found)
+ self.properties['storeColumn'] = self.toColumn.GetString(found)
else:
- self.properties['rgb'] = ''
- self.LoadTable(attColumn = self.properties['source_rgb'],
- rgbColumn = self.properties['rgb'], rulesPanel = self.colorRulesPanel)
+ if event:
+ self.LoadTable()
self.Update()
- def OnColumnSelection(self, event):
- self.properties['source_rgb'] = event.GetString()
+ def OnSourceColumnSelection(self, event):
+ self.properties['sourceColumn'] = event.GetString()
+ self.LoadTable()
def OnAddColumn(self, event):
- """!Add GRASSRGB column if it doesn't exist"""
- if 'GRASSRGB' not in self.cb_rgb_col.GetItems():
+ """!Add GRASS(RGB,SIZE,WIDTH) column if it doesn't exist"""
+ if self.columnsProp[self.attributeType]['name'] not in self.fromColumn.GetItems():
- map = self.inmap,
+ map = self.inmap,
- columns = 'GRASSRGB varchar(20)')
- self.cb_rgb_col.InsertColumns(self.inmap, self.properties['layer'], type = ["character"])
- self.cb_rgb_col.SetStringSelection('GRASSRGB')
- self.properties['rgb'] = self.cb_rgb_col.GetStringSelection()
+ columns = '%s %s' % (self.columnsProp[self.attributeType]['name'],
+ self.columnsProp[self.attributeType]['type1']))
+ self.toColumn.InsertColumns(self.inmap, self.properties['layer'],
+ type = self.columnsProp[self.attributeType]['type2'])
+ self.toColumn.SetStringSelection(self.columnsProp[self.attributeType]['name'])
- self.LoadTable(attColumn = self.properties['source_rgb'], rgbColumn = self.properties['rgb'],
- rulesPanel = self.colorRulesPanel, type = 'color')
+ self.LoadTable()
else:
- message = _("GRASSRGB column already exists."))
+ message = _("%s column already exists.") % \
+ self.columnsProp[self.attributeType]['name'])
- def CreateTable(self, dcmd, layer, params, propwin):
+ def CreateAttrTable(self, dcmd, layer, params, propwin):
"""!Create attribute table"""
if dcmd:
cmd = utils.CmdToTuple(dcmd)
@@ -1115,63 +1221,79 @@
self.OnSelectionInput(None)
return True
combo.SetValue("")
combo.Disable()
return False
- def LoadTable(self, attColumn, rgbColumn, rulesPanel, type = 'color'):
+ def LoadTable(self):
+ """!Load table"""
+ ColorTable.LoadTable(self, mapType = 'vector')
+ else:
+ self.LoadRulesFromColumn(sourceColumn = self.properties['sourceColumn'],
+ loadColumn = self.properties['loadColumn'],
+ rulesPanel = self.rulesPanel,
+ type = self.attributeType)
+ def LoadRulesFromColumn(self, sourceColumn, loadColumn, rulesPanel, type):
"""!Load current column (GRASSRGB, size column)"""
rulesPanel.Clear()
- if not attColumn or not rgbColumn:
+ if not sourceColumn:
return
busy = wx.BusyInfo(message = _("Please wait, loading data from attribute table..."),
parent = self)
wx.Yield()
+ columns = sourceColumn
+ if loadColumn:
+ columns += ',' + loadColumn
if self.inmap:
- outFile = tempfile.NamedTemporaryFile(mode='w+b')
+ outFile = tempfile.NamedTemporaryFile(mode = 'w+b')
sep = '|'
ret = gcmd.RunCommand('v.db.select',
- quiet = True,
- flags = 'c',
- map = self.inmap,
- layer = self.properties['layer'],
- columns = attColumn + ',' + rgbColumn,
- fs = sep,
- stdout = outFile)
+ quiet = True,
+ flags = 'c',
+ map = self.inmap,
+ layer = self.properties['layer'],
+ columns = columns,
+ fs = sep,
+ stdout = outFile)
else:
busy.Destroy()
return
- ctype = self.dbInfo.GetTableDesc(self.properties['table'])\
- [self.properties['source_rgb']]['ctype']
- [self.properties['source_size']]['ctype']
+## if type == 'color':
+## ctype = self.dbInfo.GetTableDesc(self.properties['table'])\
+## [sourceColumn]['ctype']
outFile.seek(0)
i = 0
minim = maxim = 0.0
while True:
# os.linesep doesn't work here (MSYS)
record = outFile.readline().replace('\n', '')
if not record:
break
rulesPanel.ruleslines[i] = {}
- col1, col2 = record.split(sep)
- if ctype not in (int, float):
- col1 = "'" + col1 + "'"
+ if not loadColumn:
+ col1 = record
+ col2 = None
else:
- if float(col1) < minim:
- minim = float(col1)
- if float(col1) > maxim:
- maxim = float(col1)
+ col1, col2 = record.split(sep)
+## if ctype not in (int, float):
+## col1 = "'" + col1 + "'"
+## else:
+ if float(col1) < minim:
+ minim = float(col1)
+ if float(col1) > maxim:
+ maxim = float(col1)
rulesPanel.ruleslines[i]['value'] = col1
rulesPanel.ruleslines[i][type] = col2
@@ -1179,10 +1301,10 @@
rulesPanel.AddRules(i, start = True)
ret = rulesPanel.LoadRules()
- self.SetRangeLabel(type, ctype, minim, maxim)
+## self.SetRangeLabel(type, ctype, minim, maxim)
if ret:
- self.OnPreview()
+ self.OnPreview()
else:
rulesPanel.Clear()
@@ -1207,24 +1329,72 @@
else:
self.size_range_label.SetLabel('')
- def OnRGBColSelection(self, event):
- self.properties['rgb'] = event.GetString()
+ def OnFromColSelection(self, event):
+ """!Selection in combobox (for loading values) changed"""
+ self.properties['loadColumn'] = event.GetString()
+ self.LoadTable()
+ def OnToColSelection(self, event):
+ """!Selection in combobox (for storing values) changed"""
+ self.properties['storeColumn'] = event.GetString()
+ def OnPreview(self, event = None, tmp = True):
+ """!Update preview (based on computational region)"""
+ self.OnTablePreview(tmp)
+ else:
+ self.OnColumnPreview()
+ def OnTablePreview(self, tmp):
+ if not self.inmap:
+ return
+ ltype = 'vector'
+ cmdlist = ['d.vect',
+ 'map=%s' % self.inmap]
+ # find existing color table and copy to temp file
+ old_colrtable = None
+ path = grass.find_file(name = self.inmap, element = 'vector')['file']
+ if os.path.exists(os.path.join(path, 'colr')):
+ old_colrtable = os.path.join(path, 'colr')
+ colrtemp = utils.GetTempfile()
+ shutil.copyfile(old_colrtable, colrtemp)
- def OnPreview(self, event = None):
+ ColorTable.DoPreview(self, ltype, cmdlist)
+ # restore previous color table
+ if tmp:
+ if old_colrtable:
+ shutil.copyfile(colrtemp, old_colrtable)
+ os.remove(colrtemp)
+ else:
+ gcmd.RunCommand('v.colors',
+ parent = self,
+ flags = 'r',
+ map = self.inmap)
+ def OnColumnPreview(self):
- if not self.inmap or not self.properties["rgb"] or not self.properties["tmp_rgb"]:
+ if not self.inmap or not self.properties['tmpColumn']:
return
'-a',
- 'rgb_column=%s' % self.properties['tmp_rgb'],
'type=point,line,boundary,area']
+ cmdlist.append('rgb_column=%s' % self.properties['tmpColumn'])
+ cmdlist.append('size_column=%s' % self.properties['tmpColumn'])
+ cmdlist.append('width_column=%s' % self.properties['tmpColumn'])
ltype = 'vector'
@@ -1234,7 +1404,38 @@
cmd = 'v.colors'
+ def UseAttrColumn(self, useAttrColumn = True):
+ """!Use attribute column to render map"""
+ # TODO switch back to table, not only selected map
+ layer = self.parent.curr_page.maptree.layer_selected
+ if layer and self.parent.curr_page.maptree.GetPyData(layer)[0]['maplayer'].GetName() == self.inmap:
+## cmd = self.parent.curr_page.maptree.GetPyData(layer)[0]['maplayer'].GetCmd()
+## if useAttrColumn:
+## cmd[1].update({'flags': 'a', })
+ '-a',
+ 'type=point,line,boundary,area']
+ cmdlist.append('rgb_column=%s' % self.properties['storeColumn'])
+ cmdlist.append('size_column=%s' % self.properties['storeColumn'])
+ cmdlist.append('width_column=%s' % self.properties['storeColumn'])
+ self.parent.curr_page.maptree.GetPyData(layer)[0]['maplayer'].SetCmd(cmdlist)
+ def CreateColorTable(self, force = False, mapType = 'vector'):
+ """!Create color rules (color table or color column)"""
+ ret = ColorTable.CreateColorTable(self, force, mapType)
+ else:
+ ret = self.UpdateColorColumn(force)
+ return ret
+ def UpdateColorColumn(self, force):
@@ -1242,17 +1443,19 @@
rulestxt = ''
continue
if force:
- rgb_col = self.properties['tmp_rgb']
+ rgb_col = self.properties['tmpColumn']
else:
- rgb_col = self.properties['rgb']
+ rgb_col = self.properties['storeColumn']
+ if not self.properties['storeColumn']:
+ gcmd.GMessage(self.parent, message = _("Please select column to save values to."))
rulestxt += "UPDATE %s SET %s='%s' WHERE %s ;\n" % (self.properties['table'],
rgb_col,
- rule['color'],
+ rule[self.attributeType],
rule['value'])
if not rulestxt:
return False
@@ -1274,12 +1477,12 @@
and delete temporary column"""
if self.OnApply(event):
self.Destroy()
- self.DeleteTemporaryColumn(name = self.properties['tmp_rgb'])
+ self.DeleteTemporaryColumn(name = self.properties['tmpColumn'])
self.Destroy()
class ThematicVectorTable(VectorColorTable):
def __init__(self, parent, vectorType, **kwargs):
@@ -1288,70 +1491,9 @@
self.vectorType = vectorType
VectorColorTable.__init__(self, parent = parent, **kwargs)
- # additional bingings
- self.Bind(wx.EVT_COMBOBOX, self.OnSizeSourceSelection, self.cb_size_att)
- self.Bind(wx.EVT_COMBOBOX, self.OnSizeSelection, self.cb_size_col)
- self.Bind(wx.EVT_BUTTON, self.OnAddSizeColumn, self.btn_add_size)
- self.Bind(wx.EVT_CHECKBOX, self.OnColorChecked, self.rgb_check)
- self.Bind(wx.EVT_CHECKBOX, self.OnSizeChecked, self.size_check)
self.SetTitle(_("Thematic mapping for vector map in 3D view"))
- def UpdateDialog(self):
- """!Update dialog according to selected map"""
- VectorColorTable.UpdateDialog(self)
- if not self.inmap:
- self.sizeRulesPanel.Clear()
- for combo in (self.cb_size_att, self.cb_size_col):
- combo.SetValue("")
- combo.Disable()
- combo.Clear()
- enable = False
- else:
- # initialize layer selection combobox
- for combo in (self.cb_vlayer, self.cb_size_att, self.cb_size_col):
- combo.Enable()
- self.btn_add_size.Enable(True)
- self.AddTemporaryColumn(name = 'tmp_size', type = 'integer')
- else:
- def OnLayerSelection(self, event):
- VectorColorTable.OnLayerSelection(self, event)
- # reset choices in column selection comboboxes if layer changes
- self.cb_size_att.InsertColumns(vector = self.inmap, layer = vlayer, dbInfo = self.dbInfo)
- self.cb_size_att.SetSelection(0)
- self.properties['source_size'] = self.cb_size_att.GetString(0)
- self.cb_size_col.InsertColumns(vector = self.inmap, layer = vlayer,
- type = ["integer", "double precision"], dbInfo = self.dbInfo)
- for item in self.cb_size_col.GetItems():
- if item.lower().find('size') >= 0:
- self.cb_size_col.SetStringSelection(item)
- self.properties['size'] = item
- else:
- self.properties['size'] = ''
- self.LoadTable(attColumn = self.properties['source_size'], rgbColumn = self.properties['size'],
- rulesPanel = self.sizeRulesPanel, type = 'size')
- self.Update()
- def OnSizeSelection(self, event):
- self.properties['size'] = event.GetString()
- def OnSizeSourceSelection(self, event):
- self.properties['source_size'] = event.GetString()
def _initLayer(self):
"""!Set initial layer when opening dialog"""
@@ -1359,292 +1501,33 @@
self.selectionInput.SetValue(self.inmap)
self.selectionInput.Disable()
- def _doLayout(self):
- """!Do main layout"""
- mainsizer = wx.BoxSizer(wx.VERTICAL)
- # ? size (-1, ...) doesn't work
- scrollPanel = scrolled.ScrolledPanel(self, id = wx.ID_ANY, size = (870, 600),
- style = wx.TAB_TRAVERSAL)
- scrollPanel.SetupScrolling()
- sizer = wx.BoxSizer(wx.VERTICAL)
- # map selection
- mapSelection = self._createMapSelection(parent = scrollPanel)
- sizer.Add(item = mapSelection, proportion = 0,
- flag = wx.ALL | wx.EXPAND, border = 5)
- # set vector attributes
- vectorAttrb = self._createVectorAttrb(parent = scrollPanel)
- sizer.Add(item = vectorAttrb, proportion = 0,
- # body & preview
- bodySizer = self._createBody(parent = scrollPanel)
- sizer.Add(item = bodySizer, proportion = 1,
- scrollPanel.SetSizer(sizer)
- scrollPanel.Fit()
- mainsizer.Add(scrollPanel, proportion = 1, flag = wx.EXPAND | wx.ALL, border = 5)
- # buttons
- btnSizer = self._createButtons()
- mainsizer.Add(item = wx.StaticLine(parent = self, id = wx.ID_ANY,
- style = wx.LI_HORIZONTAL), proportion = 0,
- flag = wx.EXPAND | wx.ALL, border = 5)
- mainsizer.Add(item = btnSizer, proportion = 0,
- flag = wx.ALL | wx.ALIGN_RIGHT, border = 5)
- self.SetSizer(mainsizer)
- mainsizer.Layout()
- mainsizer.Fit(self)
- def _createBody(self, parent):
- """!Create dialog body consisting of rules and preview"""
- bodySizer = wx.GridBagSizer(hgap = 5, vgap = 5)
- row = 0
- # label with instructions - don't want it now
- self.cr_label = wx.StaticText(parent, id = wx.ID_ANY)
- self.cr_label.Hide()
- # color table
- columnType = 'color', properties = self.properties,
- panelWidth = 200)
- # size table
- self.sizeRulesPanel = RulesPanel(parent = parent, mapType = self.type,
- columnType = 'size', properties = self.properties,
- panelWidth = 200)
- bodySizer.Add(item = self.colorRulesPanel.label, pos = (row, 0), span = (1, 2))
- bodySizer.Add(item = self.sizeRulesPanel.label, pos = (row, 2), span = (1, 2))
- row += 1
- bodySizer.Add(item = self.colorRulesPanel.mainPanel, pos = (row, 0), span = (1, 2))
- # add two rules as default
- bodySizer.Add(item = self.sizeRulesPanel.mainPanel, pos = (row, 2), span = (1, 2))
- self.sizeRulesPanel.AddRules(2)
- # preview window
- self._createPreview(parent = parent)
- bodySizer.Add(item = self.preview, pos = (row, 4),
- flag = wx.EXPAND | wx.LEFT | wx.RIGHT, border = 10)
- row += 1
- # add ckeck all and clear all
- pos = (row, 0))
- bodySizer.Add(item = self.sizeRulesPanel.checkAll, flag = wx.ALIGN_CENTER_VERTICAL,
- pos = (row, 2))
- bodySizer.Add(item = self.sizeRulesPanel.clearAll, pos = (row, 3))
- # preview button
- self.btnPreview = wx.Button(parent, id = wx.ID_ANY,
- label = _("Preview"))
- bodySizer.Add(item = self.btnPreview, pos = (row, 4),
- flag = wx.ALIGN_RIGHT)
- self.btnPreview.SetToolTipString(_("Show preview of map "
- "(current Map Display extent is used)."))
- row += 1
- # add rules button and spin to sizer
- flag = wx.ALIGN_CENTER_VERTICAL)
- bodySizer.Add(item = self.sizeRulesPanel.numRules, pos = (row, 2),
- bodySizer.Add(item = self.sizeRulesPanel.btnAdd, pos = (row, 3),
- flag = wx.ALIGN_LEFT)
- return bodySizer
- def _createVectorAttrb(self, parent):
- """!Create part of dialog with layer/column selection"""
- inputBox = wx.StaticBox(parent = parent, id = wx.ID_ANY,
- label = " %s " % _("Select vector columns"))
- layer_label = wx.StaticText(parent, id = wx.ID_ANY, label = _('Layer:'))
- self.rgb_check = wx.CheckBox(parent, id = wx.ID_ANY, label = _('Use color for thematic mapping:'))
- if self.vectorType == 'points':
- label = _('Use symbol size for thematic mapping:')
- else:
- label = _('Use line width for thematic mapping:')
- self.size_check = wx.CheckBox(parent, id = wx.ID_ANY, label = label)
- self.rgb_check.SetValue(True)
- self.size_check.SetValue(True)
- color_att_label = wx.StaticText(parent, id = wx.ID_ANY,
- label = _('Attribute column:'))
- size_att_label = wx.StaticText(parent, id = wx.ID_ANY,
- rgb_col_label = wx.StaticText(parent, id = wx.ID_ANY,
- label = _('Symbol size column:')
- else:
- label = _('Line with column:')
- size_col_label = wx.StaticText(parent, id = wx.ID_ANY, label = label)
- self.rgb_range_label = wx.StaticText(parent, id = wx.ID_ANY)
- self.size_range_label = wx.StaticText(parent, id = wx.ID_ANY)
- cb_size = (150, -1)
- self.cb_vlayer = gselect.LayerSelect(parent, size = cb_size)
- self.cb_color_att = gselect.ColumnSelect(parent, size = cb_size)
- self.cb_size_att = gselect.ColumnSelect(parent, size = cb_size)
- self.cb_rgb_col = gselect.ColumnSelect(parent, size = cb_size)
- self.cb_size_col = gselect.ColumnSelect(parent, size = cb_size)
- label = _('Add column'))
- self.btn_add_size = wx.Button(parent, id = wx.ID_ANY,
- label = _("Add size column to current attribute table.")
- else:
- label = _("Add width column to current attribute table.")
- self.btn_add_size.SetToolTipString(label)
- # layout
- inputSizer = wx.StaticBoxSizer(inputBox, wx.VERTICAL)
- vSizer = wx.GridBagSizer(hgap = 5, vgap = 5)
- vSizer.AddGrowableCol(2)
- vSizer.Add(layer_label, pos = (0, 0),
- vSizer.Add(self.rgb_check, pos = (1, 0), span = (1, 3),
- vSizer.Add(self.size_check, pos = (1, 3), span = (1, 3),
- vSizer.Add(color_att_label, pos = (2, 0),
- vSizer.Add(size_att_label, pos = (2, 3),
- vSizer.Add(rgb_col_label, pos = (4, 0),
- vSizer.Add(size_col_label, pos = (4, 3),
- vSizer.Add(self.cb_color_att, pos = (2, 1),
- vSizer.Add(self.cb_size_att, pos = (2, 4),
- vSizer.Add(self.rgb_range_label, pos = (3, 1),
- vSizer.Add(self.size_range_label, pos = (3, 4),
- vSizer.Add(self.cb_rgb_col, pos = (4, 1),
- vSizer.Add(self.cb_size_col, pos = (4, 4),
- vSizer.Add(self.btn_add_RGB, pos = (4, 2),
- vSizer.Add(self.btn_add_size, pos = (4, 5),
- inputSizer.Add(item = vSizer,
- flag = wx.ALIGN_CENTER_VERTICAL | wx.ALL | wx.EXPAND, border = 5)
- return inputSizer
- def OnAddSizeColumn(self, event):
- """!Add size column if it doesn't exist"""
- name = 'GRASSSIZE'
- else:
- name = 'GRASSWIDTH'
- ret = gcmd.RunCommand('v.db.addcolumn',
- map = self.inmap,
- columns = '%s integer' % name)
- self.cb_size_col.InsertColumns(self.inmap, self.properties['layer'], type = ["integer"])
- self.cb_size_col.SetStringSelection(name)
- self.properties['size'] = name
- def OnColorChecked(self, event):
- """!Use color for thematic mapping"""
- if self.rgb_check.IsChecked():
- self.colorRulesPanel.Enable(True)
- else:
- self.colorRulesPanel.Enable(False)
- def OnSizeChecked(self, event):
- """!Use size for thematic mapping"""
- if self.size_check.IsChecked():
- self.sizeRulesPanel.Enable(True)
- else:
- self.sizeRulesPanel.Enable(False)
- """!Update preview (based on computational region)"""
- if not self.inmap or not self.properties['size'] or not self.properties['tmp_size']:
- return
- cmdlist = ['d.vect',
- '-a',
- 'map=%s' % self.inmap,
- 'type=point,line,boundary,area']
- if self.size_check.IsChecked()\
- and self.properties["size"] and self.properties["tmp_size"]:
- cmdlist.append('size_column=%s' % self.properties['tmp_size'])
- else:
- cmdlist.append('width_column=%s' % self.properties['tmp_size'])
- if self.rgb_check.IsChecked()\
- and self.properties["rgb"] and self.properties['tmp_rgb']:
- cmdlist.append('rgb_column=%s' % self.properties['tmp_rgb'])
- ltype = 'vector'
- ColorTable.DoPreview(self, ltype, cmdlist)
def OnApply(self, event):
"""!Apply selected color table
- ret = VectorColorTable.CreateColorTable(self)
+ ret = self.CreateColorTable()
if not ret:
- ret = self.CreateSizeTable()
- if not ret:
- gcmd.GMessage(parent = self, message = _("No size rules given."))
+ gcmd.GMessage(parent = self, message = _("No rules given."))
data = self.parent.GetLayerData(nvizType = 'vector')
data['vector']['points']['thematic']['layer'] = int(self.properties['layer'])
- if self.size_check.IsChecked() and self.properties['size']:
- data['vector'][self.vectorType]['thematic']['sizecolumn'] = self.properties['size']
- else:
- data['vector'][self.vectorType]['thematic']['sizecolumn'] = None
+ value = None
+ if self.properties['storeColumn']:
+ value = self.properties['storeColumn']
- if self.rgb_check.IsChecked() and self.properties['rgb']:
- data['vector'][self.vectorType]['thematic']['rgbcolumn'] = self.properties['rgb']
+ data['vector'][self.vectorType]['thematic']['rgbcolumn'] = value
+ else:
+ data['vector'][self.vectorType]['thematic']['sizecolumn'] = value
else:
- data['vector'][self.vectorType]['thematic']['rgbcolumn'] = None
+ data['vector'][self.vectorType]['thematic']['rgbcolumn'] = None
+ else:
+ data['vector'][self.vectorType]['thematic']['sizecolumn'] = None
data['vector'][self.vectorType]['thematic']['update'] = None
@@ -1653,61 +1536,6 @@
self.parent.mapWindow.Refresh(False)
return ret
- """!Creates color and size table"""
- VectorColorTable.CreateColorTable(self, force = True)
- self.CreateSizeTable(force = True)
- def CreateSizeTable(self, force = False):
- """!Creates size table
- VectorColorTable.CreateColorTable(self)
- rulestxt = ''
- for rule in self.sizeRulesPanel.ruleslines.itervalues():
- continue
- if force:
- size_col = self.properties['tmp_size']
- else:
- size_col = self.properties['size']
- rulestxt += "UPDATE %s SET %s='%s' WHERE %s ;\n" % (self.properties['table'],
- size_col,
- rule['size'],
- rule['value'])
- if not rulestxt:
- return False
- try:
- finally:
- output.close()
- gcmd.RunCommand('db.execute',
- parent = self,
- input = gtemp)
- return True
- def OnOK(self, event):
- """!Apply selected color table, close the dialog
- and delete temporary column"""
- if self.OnApply(event):
- self.Destroy()
- self.DeleteTemporaryColumn(name = 'tmp_size')
- self.DeleteTemporaryColumn(name = 'tmp_rgb')
- def OnCancel(self, event):
- """!Do not apply any changes and close the dialog"""
- self.Destroy()
class BufferedWindow(wx.Window):
"""!A Buffered window class"""
Modified: grass/trunk/gui/wxpython/gui_modules/gselect.py
--- grass/trunk/gui/wxpython/gui_modules/gselect.py 2011-08-17 18:38:59 UTC (rev 47713)
+++ grass/trunk/gui/wxpython/gui_modules/gselect.py 2011-08-17 19:31:48 UTC (rev 47714)
@@ -800,12 +800,13 @@
if vector:
self.InsertColumns(vector, layer)
- def InsertColumns(self, vector, layer, excludeKey = False, type = None, dbInfo = None):
+ def InsertColumns(self, vector, layer, excludeKey = False, excludeCols = None, type = None, dbInfo = None):
"""!Insert columns for a vector attribute table into the columns combobox
@param vector vector name
@param layer vector layer number
@param excludeKey exclude key column from the list?
+ @param excludeCols list of columns to be removed from the list
@param type only columns of given type (given as list)
if not dbInfo:
@@ -820,13 +821,20 @@
columns[val['index']] = key
if excludeKey: # exclude key column
columns.remove(keyColumn)
+ if excludeCols: # exclude key column
+ for key in columnchoices.iterkeys():
+ if key in excludeCols:
+ columns.remove(key)
if type: # only selected column types
for key, value in columnchoices.iteritems():
if value['type'] not in type:
- columns.remove(key)
+ try:
+ except ValueError:
+ pass
except (KeyError, ValueError):
columns = list()
self.SetItems(columns)
self.SetValue(self.defaultValue)
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py 2011-08-17 18:38:59 UTC (rev 47713)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py 2011-08-17 19:31:48 UTC (rev 47714)
@@ -1543,10 +1543,18 @@
# thematic
if 'update' in data['thematic']:
- if data['thematic']['use']:
+ color = width = None
+ colorTable = False
+ if data['thematic']['usecolor'] or data['thematic']['usewidth']:
+ if data['thematic']['usecolor']:
+ color = data['thematic']['rgbcolumn']
+ colorTable = True
+ if data['thematic']['usewidth']:
+ width = data['thematic']['sizecolumn']
self._display.SetLinesStyleThematic(id = id, layer = data['thematic']['layer'],
- color = data['thematic']['rgbcolumn'],
- width = data['thematic']['sizecolumn'])
+ color = color,
+ colorTable = colorTable,
+ width = width)
else:
self._display.UnsetLinesStyleThematic(id = id)
data['thematic'].pop('update')
@@ -1598,10 +1606,18 @@
# thematic
+ color = size = None
+ if data['thematic']['usecolor'] or data['thematic']['usesize']:
+ colorTable = True
+ if data['thematic']['usesize']:
+ size = data['thematic']['sizecolumn']
self._display.SetPointsStyleThematic(id = id, layer = data['thematic']['layer'],
- size = data['thematic']['sizecolumn'])
+ color = color,
+ size = size)
else:
self._display.UnsetPointsStyleThematic(id = id)
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_tools.py 2011-08-17 18:38:59 UTC (rev 47713)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_tools.py 2011-08-17 19:31:48 UTC (rev 47714)
@@ -1147,25 +1147,43 @@
# thematic mapping
self.win['vector']['lines']['thematic'] = {}
- checkThematic = wx.CheckBox(parent = panel, id = wx.ID_ANY,
- label = _("use thematic mapping for vector lines"))
- self.win['vector']['lines']['thematic']['check'] = checkThematic.GetId()
- checkThematic.Bind(wx.EVT_CHECKBOX, self.OnCheckThematic)
- checkThematic.SetValue(False)
+ checkThematicColor = wx.CheckBox(parent = panel, id = wx.ID_ANY,
+ label = _("use color for thematic mapping"))
+ checkThematicWidth = wx.CheckBox(parent = panel, id = wx.ID_ANY,
+ label = _("use width for thematic mapping"))
+ self.win['vector']['lines']['thematic']['checkcolor'] = checkThematicColor.GetId()
+ self.win['vector']['lines']['thematic']['checkwidth'] = checkThematicWidth.GetId()
+ checkThematicColor.Bind(wx.EVT_CHECKBOX, self.OnCheckThematic)
+ checkThematicWidth.Bind(wx.EVT_CHECKBOX, self.OnCheckThematic)
+ checkThematicColor.SetValue(False)
+ checkThematicWidth.SetValue(False)
+ vSizer = wx.BoxSizer(wx.VERTICAL)
hSizer = wx.BoxSizer(wx.HORIZONTAL)
- hSizer.Add(item = checkThematic, flag = wx.ALIGN_CENTER_VERTICAL,
+ hSizer.Add(item = checkThematicColor, flag = wx.ALIGN_CENTER_VERTICAL,
border = 5)
setThematic = wx.Button(parent = panel, id = wx.ID_ANY,
label = _("Set options..."))
- self.win['vector']['lines']['thematic']['button'] = setThematic.GetId()
+ self.win['vector']['lines']['thematic']['buttoncolor'] = setThematic.GetId()
setThematic.Bind(wx.EVT_BUTTON, self.OnSetThematic)
hSizer.Add(item = wx.Size(-1, -1), proportion = 1)
hSizer.Add(item = setThematic, flag = wx.ALIGN_CENTER_VERTICAL|wx.LEFT,
border = 5, proportion = 0)
+ vSizer.Add(hSizer, flag = wx.EXPAND)
+ hSizer = wx.BoxSizer(wx.HORIZONTAL)
+ hSizer.Add(item = checkThematicWidth, flag = wx.ALIGN_CENTER_VERTICAL,
+ border = 5)
+ setThematic = wx.Button(parent = panel, id = wx.ID_ANY,
+ label = _("Set options..."))
+ self.win['vector']['lines']['thematic']['buttonwidth'] = setThematic.GetId()
+ setThematic.Bind(wx.EVT_BUTTON, self.OnSetThematic)
+ hSizer.Add(item = wx.Size(-1, -1), proportion = 1)
+ hSizer.Add(item = setThematic, flag = wx.ALIGN_CENTER_VERTICAL|wx.LEFT,
+ border = 5, proportion = 0)
- gridSizer.Add(item = hSizer, flag = wx.ALIGN_CENTER_VERTICAL | wx.EXPAND,
+ gridSizer.Add(item = vSizer, flag = wx.ALIGN_CENTER_VERTICAL | wx.EXPAND,
pos = (1, 1), span = (1, 5))
# display
@@ -1305,21 +1323,34 @@
pos = (0, 6))
# thematic mapping
self.win['vector']['points']['thematic'] = {}
- label = _("use thematic mapping for vector points"))
- self.win['vector']['points']['thematic']['check'] = checkThematic.GetId()
+ checkThematicSize = wx.CheckBox(parent = panel, id = wx.ID_ANY,
+ label = _("use size for thematic mapping"))
+ self.win['vector']['points']['thematic']['checkcolor'] = checkThematicColor.GetId()
+ self.win['vector']['points']['thematic']['checksize'] = checkThematicSize.GetId()
+ checkThematicSize.Bind(wx.EVT_CHECKBOX, self.OnCheckThematic)
+ checkThematicSize.SetValue(False)
- gridSizer.Add(item = checkThematic, flag = wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_LEFT,
+ gridSizer.Add(item = checkThematicColor, flag = wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_LEFT,
- self.win['vector']['points']['thematic']['button'] = setThematic.GetId()
+ self.win['vector']['points']['thematic']['buttoncolor'] = setThematic.GetId()
gridSizer.Add(item = setThematic, flag = wx.ALIGN_CENTER_VERTICAL,
pos = (1, 6))
+ gridSizer.Add(item = checkThematicSize, flag = wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_LEFT,
+ pos = (2, 1), span = (1, 5))
+ self.win['vector']['points']['thematic']['buttonsize'] = setThematic.GetId()
+ gridSizer.Add(item = setThematic, flag = wx.ALIGN_CENTER_VERTICAL,
+ pos = (2, 6))
vertSizer.Add(gridSizer, proportion = 0, flag = wx.EXPAND, border = 0)
# high
gridSizer = wx.GridBagSizer(vgap = 5, hgap = 5)
@@ -3211,17 +3242,28 @@
"""!Switch on/off thematic mapping"""
# can be called with no event to enable/disable button
if not event:
- ids = (self.win['vector']['points']['thematic']['check'],
- self.win['vector']['lines']['thematic']['check'])
+ ids = (self.win['vector']['points']['thematic']['checkcolor'],
+ self.win['vector']['lines']['thematic']['checkcolor'],
+ self.win['vector']['points']['thematic']['checksize'],
+ self.win['vector']['lines']['thematic']['checkwidth'])
else:
ids = (event.GetId(),)
for id in ids:
- if id == self.win['vector']['points']['thematic']['check']:
- type = 'points'
+ if id in self.win['vector']['points']['thematic'].values():
+ vtype = 'points'
+ if id == self.win['vector'][vtype]['thematic']['checkcolor']:
+ attrType = 'color'
+ else:
+ attrType = 'size'
else:
- type = 'lines'
- check = self.win['vector'][type]['thematic']['check']
- button = self.win['vector'][type]['thematic']['button']
+ vtype = 'lines'
+ else:
+ attrType = 'width'
+ check = self.win['vector'][vtype]['thematic']['check' + attrType]
+ button = self.win['vector'][vtype]['thematic']['button' + attrType]
if self.FindWindowById(check).GetValue():
checked = True
else:
@@ -3229,8 +3271,8 @@
self.FindWindowById(button).Enable(checked)
data = self.GetLayerData('vector')
- data['vector'][type]['thematic']['use'] = checked
- data['vector'][type]['thematic']['update'] = None
+ data['vector'][vtype]['thematic']['use' + attrType] = checked
+ data['vector'][vtype]['thematic']['update'] = None
# update properties
event = wxUpdateProperties(data = data)
@@ -3241,11 +3283,17 @@
def OnSetThematic(self, event):
"""!Set options for thematic points"""
- if event.GetId() == self.win['vector']['points']['thematic']['button']:
- vectorType = 'points'
+ if event.GetId() in self.win['vector']['points']['thematic'].values():
+ vtype = 'points'
else:
- vectorType = 'lines'
- ctable = colorrules.ThematicVectorTable(self, vectorType)
+ vtype = 'lines'
+ if event.GetId() == self.win['vector'][vtype]['thematic']['buttoncolor']:
+ elif vtype == 'points':
+ attrType = 'size'
+ else:
+ ctable = colorrules.ThematicVectorTable(self, vtype, attributeType = attrType)
ctable.CentreOnScreen()
ctable.Show()
@@ -4269,6 +4317,16 @@
self.FindWindowById(self.win['vector'][v]['height']['slider']).Enable(enable)
self.FindWindowById(self.win['vector'][v]['height']['text']).Enable(enable)
+ if data[v]['thematic']['usecolor']:
+ check = self.FindWindowById(self.win['vector'][v]['thematic']['checkcolor'])
+ check.SetValue(data[v]['thematic']['usecolor'])
+ if 'usesize' in data[v]['thematic'] and data[v]['thematic']['usesize']:
+ check = self.FindWindowById(self.win['vector'][v]['thematic']['checksize'])
+ check.SetValue(data[v]['thematic']['usesize'])
+ elif 'usewidth' in data[v]['thematic'] and data[v]['thematic']['usewidth']:
+ check = self.FindWindowById(self.win['vector'][v]['thematic']['checkwidth'])
+ check.SetValue(data[v]['thematic']['usewidth'])
+ self.OnCheckThematic(None)
# lines
@@ -4342,7 +4400,7 @@
win.SetValue(color)
else:
win.SetValue(data['points'][prop]['value'])
- self.OnCheckThematic(None)
+## self.OnCheckThematic(None)
# height
for type in ('slider', 'text'):
win = self.FindWindowById(self.win['vector']['points']['height'][type])
Modified: grass/trunk/gui/wxpython/gui_modules/workspace.py
--- grass/trunk/gui/wxpython/gui_modules/workspace.py 2011-08-17 18:38:59 UTC (rev 47713)
+++ grass/trunk/gui/wxpython/gui_modules/workspace.py 2011-08-17 19:31:48 UTC (rev 47714)
@@ -387,7 +387,20 @@
# height
self.__processLayerNvizNode(node_vpoints, 'size', int,
nviz['vector']['points'])
+ # thematic
+ node_thematic = node_vpoints.find('thematic')
+ thematic = nviz['vector']['points']['thematic'] = {}
+ thematic['rgbcolumn'] = self.__processLayerNvizNode(node_thematic, 'rgbcolumn', str)
+ thematic['sizecolumn'] = self.__processLayerNvizNode(node_thematic, 'sizecolumn', str)
+ for col in ('rgbcolumn', 'sizecolumn'):
+ if thematic[col] == 'None':
+ thematic[col] = None
+ thematic['layer'] = self.__processLayerNvizNode(node_thematic, 'layer', int)
+ for use in ('usecolor', 'usesize', 'usewidth'):
+ if node_thematic.get(use, ''):
+ thematic[use] = int(node_thematic.get(use, '0'))
# vlines
node_vlines = node_nviz.find('vlines')
if node_vlines is not None:
@@ -417,6 +430,19 @@
# height
self.__processLayerNvizNode(node_vlines, 'height', int,
nviz['vector']['lines'])
+ # thematic
+ node_thematic = node_vlines.find('thematic')
+ thematic = nviz['vector']['lines']['thematic'] = {}
return nviz
@@ -711,7 +737,8 @@
'sizecolumn' : UserSettings.Get(group='nviz', key='vector',
subkey=['lines', 'sizecolumn']),
'layer': 1,
- 'use' : False}
+ 'usecolor' : False,
+ 'usewidth' : False}
if 'object' in data:
for attrb in ('color', 'width', 'mode', 'height'):
data[attrb]['update'] = None
@@ -749,7 +776,8 @@
subkey=['points', 'sizecolumn']),
'layer': 1,
- 'use' : False}
+ 'usesize' : False}
for attrb in ('size', 'width', 'marker',
'color', 'surface', 'height', 'thematic'):
@@ -1123,7 +1151,7 @@
marker))
self.indent += 4
for name in data[attrb].iterkeys():
- if name in ('object', 'marker', 'thematic'):
+ if name in ('object', 'marker'):
continue
if name == 'mode':
self.file.write('%s<%s type="%s">\n' % (' ' * self.indent, name,
@@ -1140,6 +1168,21 @@
self.file.write('%s</map>\n' % (' ' * self.indent))
self.indent -= 4
self.file.write('%s</%s>\n' % ((' ' * self.indent, name)))
+ elif name == 'thematic':
+ self.file.write('%s<%s ' % (' ' * self.indent, name))
+ for key in data[attrb][name].iterkeys():
+ if key.startswith('use'):
+ self.file.write('%s="%s" ' % (key, int(data[attrb][name][key])))
+ self.file.write('>\n')
+ self.indent += 4
+ for key, value in data[attrb][name].iteritems():
+ continue
+ if value is None:
+ value = ''
+ self.file.write('%s<%s>%s</%s>\n' % (' ' * self.indent, key, value, key))
+ self.indent -= 4
+ self.file.write('%s</%s>\n' % (' ' * self.indent, name))
else:
self.file.write('%s<%s>\n' % (' ' * self.indent, name))
self.indent += 4
@@ -1219,7 +1262,7 @@
self.indent -= 4
self.file.write('%s</focus>\n' % (' ' * self.indent))
# background
- self.__writeTagWithValue('background_color', view['background']['color'], format = 'd:%d:%d')
+ self.__writeTagWithValue('background_color', view['background']['color'][:3], format = 'd:%d:%d')
self.indent -= 4
self.file.write('%s</view>\n' % (' ' * self.indent))
Modified: grass/trunk/gui/wxpython/gui_modules/wxnviz.py
--- grass/trunk/gui/wxpython/gui_modules/wxnviz.py 2011-08-17 18:38:59 UTC (rev 47713)
+++ grass/trunk/gui/wxpython/gui_modules/wxnviz.py 2011-08-17 19:31:48 UTC (rev 47714)
@@ -29,6 +29,7 @@
try:
from grass.lib.gis import *
from grass.lib.raster3d import *
+ from grass.lib.vector import *
from grass.lib.ogsf import *
from grass.lib.nviz import *
from grass.lib.raster import *
@@ -84,6 +85,9 @@
self.data_obj = nv_data()
self.data = pointer(self.data_obj)
+ self.color_obj = Colors()
+ self.color = pointer(self.color_obj)
self.width = self.height = -1
self.showLight = False
@@ -943,21 +947,74 @@
return 1
- def SetPointsStyleThematic(self, id, layer, color = None, width = None, size = None, symbol = None):
- """!Set thematic style for vector points"""
- GP_set_style_thematic(id, layer, color, width, size, symbol)
+ def ReadVectorColors(self, name, mapset):
+ """!Read vector colors
+ @param name vector map name
+ @mapset mapset name ("" for search path)
+ @return -1 on error
+ @return 0 if color table missing
+ @return 1 on success (color table found)
+ return Vect_read_colors(name, mapset, self.color)
+ def SetPointsStyleThematic(self, id, layer, color = None, colorTable = False,
+ width = None, size = None, symbol = None):
+ """!Set thematic style for vector points
+ @param id vector set id
+ @param layer layer number for thematic mapping
+ @param colorTable use color table
+ @param color color column name
+ @param width width column name
+ @param size size column name
+ @param symbol symbol column name
+ file = c_char_p()
+ ret = GP_get_sitename(id, byref(file))
+ if ret < 0:
+ return -1
+ ret = self.ReadVectorColors(file, "")
+ if ret < 0:
+ return -1
+ if colorTable:
+ GP_set_style_thematic(id, layer, color, width, size, symbol, self.color)
+ else:
+ GP_set_style_thematic(id, layer, color, width, size, symbol, None)
- def SetLinesStyleThematic(self, id, layer, color = None, width = None):
- """!Set thematic style for vector lines"""
- GV_set_style_thematic(id, layer, color, width)
+ def SetLinesStyleThematic(self, id, layer, color = None, colorTable = False, width = None):
+ """!Set thematic style for vector lines
+ file = c_char_p()
+ ret = GV_get_vectname(id, byref(file))
+ if ret < 0:
+ return -1
+ if ret < 0:
+ return -1
+ if colorTable:
+ GV_set_style_thematic(id, layer, color, width, self.color)
+ else:
+ GV_set_style_thematic(id, layer, color, width, None)
def UnsetLinesStyleThematic(self, id):
"""!Unset thematic style for vector points"""
- GP_unset_style_thematic(id)
+ GV_unset_style_thematic(id)
def UnsetPointsStyleThematic(self, id):
"""!Unset thematic style for vector lines"""
- GV_unset_style_thematic(id)
+ GP_unset_style_thematic(id)
def UnsetVectorPointSurface(self, id, surf_id):
"""!Unset reference surface of vector set (points)
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2011-08-17 18:38:59 UTC (rev 47713)
+++ grass/trunk/gui/wxpython/wxgui.py 2011-08-17 19:31:48 UTC (rev 47714)
@@ -1041,7 +1041,7 @@
if cmd[0] == 'r.colors':
ctable = colorrules.RasterColorTable(self)
else:
- ctable = colorrules.VectorColorTable(self)
+ ctable = colorrules.VectorColorTable(self, attributeType = 'color')
ctable.Show()
