[GRASS-SVN] r47719 - grass/trunk/raster3d/r3.out.ascii
svn_grass at osgeo.org
Wed Aug 17 17:32:48 EDT 2011
Author: neteler
Date: 2011-08-17 14:32:48 -0700 (Wed, 17 Aug 2011)
New Revision: 47719
grass/trunk/raster3d/r3.out.ascii/main.c
grass/trunk/raster3d/r3.out.ascii/r3.out.ascii.html
Milena Nowotarska: i18n cleanup; HTML cleanup
Modified: grass/trunk/raster3d/r3.out.ascii/main.c
--- grass/trunk/raster3d/r3.out.ascii/main.c 2011-08-17 21:21:11 UTC (rev 47718)
+++ grass/trunk/raster3d/r3.out.ascii/main.c 2011-08-17 21:32:48 UTC (rev 47719)
@@ -59,7 +59,7 @@
if (map != NULL) {
/* should unopen map here! */
if (!Rast3d_close(map))
- fatalError(_("Error closing 3d raster map"));
+ fatalError(_("Unable to close 3D raster map"));
@@ -78,7 +78,7 @@
param.input->required = YES;
param.input->gisprompt = "old,grid3,3d-raster";
param.input->multiple = NO;
- param.input->description = _("3d raster map to be converted to ASCII");
+ param.input->description = _("3D raster map to be converted to ASCII");
param.output = G_define_option();
param.output->key = "output";
@@ -121,7 +121,7 @@
param.mask = G_define_flag();
param.mask->key = 'm';
- param.mask->description = _("Use RASTER3D mask (if exists) with input map");
+ param.mask->description = _("Use 3D raster mask (if exists) with input map");
@@ -327,7 +327,7 @@
if (NULL == G_find_raster3d(input, ""))
- Rast3d_fatal_error(_("Requested 3d raster map not found"));
+ Rast3d_fatal_error(_("3D raster map <%s> not found"), input);
/* Initiate the default settings */
Rast3d_init_defaults();
@@ -340,7 +340,7 @@
RASTER3D_TILE_SAME_AS_FILE, RASTER3D_USE_CACHE_DEFAULT);
if (map == NULL)
- Rast3d_fatal_error(_("Error opening 3d raster map"));
+ Rast3d_fatal_error(_("Error opening 3d raster map <%s>"), input);
/* Open the output ascii file */
fp = openAscii(output, region);
@@ -368,11 +368,11 @@
/* Close files and exit */
if (output)
if (fclose(fp))
- fatalError(_("Error closing new ASCII file"));
+ fatalError(_("Unable to close new ASCII file"));
return 0;
Modified: grass/trunk/raster3d/r3.out.ascii/r3.out.ascii.html
--- grass/trunk/raster3d/r3.out.ascii/r3.out.ascii.html 2011-08-17 21:21:11 UTC (rev 47718)
+++ grass/trunk/raster3d/r3.out.ascii/r3.out.ascii.html 2011-08-17 21:32:48 UTC (rev 47719)
@@ -1,21 +1,24 @@
-<H2>DESCRIPTION</H2>
+<h2>DESCRIPTION</h2>
-Outputs <I>RASTER3D</I> maps in <I>ASCII</I> format. <I>map</I> is
-a valid RASTER3D map in the current mapset. <I>output</I> is the name of
-an ASCII file which will be written in the current working directory.
-If <I>output</I> is not specified then <B>stdout</B> is used. The
-<I>-h</I> flag may be used to suppress header information. The module is
-sensitive to region settings (set with g.region). The <em>-c</em> flag will create grass6
-r3.in.ascii compatible output.
+Outputs 3D raster maps in ASCII format. The <em>map</em> parameter is
+a valid 3D raster map in the current mapset search path. The <em>output</em>
+parameter is the name of an ASCII file which will be written in the
+current working directory.
+<p>
+If <em>output</em> is not specified then standard output (stdout) is used. The
+<em>-h</em> flag may be used to suppress header information. The module is
+sensitive to region settings (set with <em>g.region</em>).
+<p>
+The <em>-c</em> flag will create GRASS 6 <em>r3.in.ascii</em> compatible
+output.
-<H2>NOTES</H2>
+<h2>NOTES</h2>
The default format for the ASCII file is equivalent to that required
-by <EM>r3.in.ascii</EM>. In particular, files output by
-<EM>r3.out.ascii</EM> with header information may be converted back to
-RASTER3D maps with <EM>r3.in.ascii</EM>.
+by <em>r3.in.ascii</em>. In particular, files output by
+<em>r3.out.ascii</em> with header information may be converted back to
+3D raster maps with <em>r3.in.ascii</em>.
-<P>
+<p>
The format for the ASCII file is:
<pre>
version: <i>"grass7"</i>
@@ -31,8 +34,8 @@
levels: <i>integer</i>
</pre>
-Ther <B>version</B> and <B>order</B> options are introduced in grass7 June 2011.
-The <B>order</B> option describes the order of rows and depths in the output.
+The <b>version</b> and <b>order</b> options have been introduced in GRASS 7 in June 2011.
+The <b>order</b> option describes the order of rows and depths in the output.
It is possible to create output of different row order using the <em>-r</em> flag
and output of different depths order using the <em>-d</em> flag. The default order is:
<pre>
@@ -51,7 +54,7 @@
<li><b>sntb</b>: south -> north and top -> bottom ordering using <em>-rd</em> flag</li>
</ul>
-The header is followed by cell values in <EM>floating point</EM> format.
+The header is followed by cell values in <em>floating point</em> format.
Cell values are output as a series of horizontal slices in row-major
order. That is in case of the default north -> south and bottom -> top (nsbt) ordering:
@@ -71,18 +74,18 @@
(x, y + rows, z + 1) (x + 1, y + rows, z + 1) ... (x + cols, y + rows, z + 1)
- and so on
+and so on.
</pre>
-The data starts with the upper left corner (NW) at the bottom of the data set.
+The data starts with the upper left corner (NW) at the bottom of the data set.
<P>
-One level maps can be imported with r.in.ascii (Raster 2D) using the default <B>nsbt</B> order
+One level maps can be imported with <em>r.in.ascii</em> (2D raster) using the default <b>nsbt</b> order
and removing the header lines "version", "order", "top", "bottom" and "levels".
-<H2>SEE ALSO</H2>
-<EM><A HREF="r3.in.ascii.html">r3.in.ascii</A></EM><br>
-<EM><A HREF="g.region.html">g.region</A></EM><br>
+<h2>SEE ALSO</h2>
+<em><a href="r3.in.ascii.html">r3.in.ascii</a></em>,
+<em><a href="g.region.html">g.region</a></em>
<H2>AUTHORS</H2>
Roman Waupotitsch, Michael Shapiro,
