[GRASS-SVN] r47737 - grass/branches/develbranch_6/raster3d/r3.out.v5d
Wed Aug 17 18:28:48 EDT 2011
Author: neteler
Date: 2011-08-17 15:28:48 -0700 (Wed, 17 Aug 2011)
New Revision: 47737
   grass/branches/develbranch_6/raster3d/r3.out.v5d/description.html
   grass/branches/develbranch_6/raster3d/r3.out.v5d/main.c
Milena Nowotarska: i18n cleanup; HTML cleanup
Modified: grass/branches/develbranch_6/raster3d/r3.out.v5d/description.html
--- grass/branches/develbranch_6/raster3d/r3.out.v5d/description.html	2011-08-17 22:27:44 UTC (rev 47736)
+++ grass/branches/develbranch_6/raster3d/r3.out.v5d/description.html	2011-08-17 22:28:48 UTC (rev 47737)
@@ -1,4 +1,4 @@
-<H2>DESCRIPTION</H2>
+<h2>DESCRIPTION</h2>
 Exports 3D raster maps to V5D format. The <em>map</em> parameter is a valid
 3D raster map in the current mapset search path. The <em>output</em> parameter is the name
Modified: grass/branches/develbranch_6/raster3d/r3.out.v5d/main.c
--- grass/branches/develbranch_6/raster3d/r3.out.v5d/main.c	2011-08-17 22:27:44 UTC (rev 47736)
+++ grass/branches/develbranch_6/raster3d/r3.out.v5d/main.c	2011-08-17 22:28:48 UTC (rev 47737)
@@ -51,7 +51,7 @@
     if (map != NULL) {
 	/* should unopen map here! */
 	if (!G3d_closeCell(map))
-	    fatalError("Unable to close 3D raster map");
+	    fatalError(_("Unable to close 3D raster map"));
     G3d_fatalError(errorMsg);
