[GRASS-SVN] r47760 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu Aug 18 16:17:07 EDT 2011
Author: annakrat
Date: 2011-08-18 13:17:07 -0700 (Thu, 18 Aug 2011)
New Revision: 47760
grass/trunk/gui/wxpython/gui_modules/colorrules.py
wxGUI: color rules dialog: add load/save color table, remove checkbox for r.colors -w flag
Modified: grass/trunk/gui/wxpython/gui_modules/colorrules.py
--- grass/trunk/gui/wxpython/gui_modules/colorrules.py 2011-08-18 17:34:51 UTC (rev 47759)
+++ grass/trunk/gui/wxpython/gui_modules/colorrules.py 2011-08-18 20:17:07 UTC (rev 47760)
@@ -30,6 +30,7 @@
import wx
import wx.lib.colourselect as csel
import wx.lib.scrolledpanel as scrolled
+import wx.lib.filebrowsebutton as filebrowse
import grass.script as grass
@@ -247,14 +248,6 @@
def SetVectorRule(self, num, val):
"""!Set vector rule"""
-## tc = self.mainPanel.FindWindowById(num)
-## source, target = 'sourceColumn', 'storeColumn'
-## if self.properties[source] == '' or self.properties[target] == '':
-## tc.SetValue('')
-## gcmd.GMessage(parent = self.parent,
-## message = _("Please select attribute column "
-## "and RGB color column first"))
-## else:
vals = []
vals.append(val)
try:
@@ -262,9 +255,6 @@
except AttributeError:
vals.append(None)
self.ruleslines[num - 1000]['value'] = self.SQLConvert(vals)
-## except ValueError:
-## tc.SetValue('')
-## self.ruleslines[num - 1000]['value'] = ''
def Enable(self, enable = True):
"""!Enable/Disable all widgets"""
@@ -371,7 +361,69 @@
type = mapLayer.GetType()
self.selectionInput.SetValue(name)
self.inmap = name
+ def _createMapSelection(self, parent):
+ """!Create map selection part of dialog"""
+ # top controls
+ if self.mapType == 'raster':
+ maplabel = _('Select raster map:')
+ else:
+ maplabel = _('Select vector map:')
+ inputBox = wx.StaticBox(parent, id = wx.ID_ANY,
+ label = " %s " % maplabel)
+ inputSizer = wx.StaticBoxSizer(inputBox, wx.VERTICAL)
+ self.selectionInput = gselect.Select(parent, id = wx.ID_ANY,
+ size = globalvar.DIALOG_GSELECT_SIZE,
+ type = self.mapType)
+ # layout
+ inputSizer.Add(item = self.selectionInput,
+ flag = wx.ALIGN_CENTER_VERTICAL | wx.ALL | wx.EXPAND, border = 5)
+ return inputSizer
+ def _createFileSelection(self, parent):
+ """!Create file (open/save rules) selection part of dialog"""
+ label = " %s " % _("Import or export color table:"))
+ self.loadRules = filebrowse.FileBrowseButton(parent = parent, id = wx.ID_ANY, fileMask = '*',
+ labelText = _('Load color table from file:'),
+ dialogTitle = _('Choose file to load color table'),
+ buttonText = _('Load'),
+ toolTip = _("Type filename or click to choose "
+ "file and load color table"),
+ startDirectory = os.getcwd(), fileMode = wx.OPEN,
+ changeCallback = self.OnLoadRulesFile)
+ self.saveRules = filebrowse.FileBrowseButton(parent = parent, id = wx.ID_ANY, fileMask = '*',
+ labelText = _('Save color table to file:'),
+ dialogTitle = _('Choose file to save color table'),
+ "file and save color table"),
+ buttonText = _('Save'),
+ startDirectory = os.getcwd(), fileMode = wx.SAVE,
+ changeCallback = self.OnSaveRulesFile)
+ default = wx.Button(parent = parent, id = wx.ID_ANY, label = _("Reload default table"))
+ # layout
+ sizer = wx.BoxSizer(wx.HORIZONTAL)
+ sizer.Add(item = self.loadRules, flag = wx.RIGHT, border = 10)
+ sizer.Add(item = default, flag = wx.ALIGN_CENTER_VERTICAL)
+ inputSizer.Add(item = sizer, flag = wx.TOP|wx.LEFT, border = 5)
+ sizer.Add(item = self.saveRules, flag = wx.ALIGN_CENTER_VERTICAL)
+ inputSizer.Add(item = sizer, flag = wx.ALL, border = 5)
+ default.Bind(wx.EVT_BUTTON, self.OnLoadDefaultTable)
+ if self.mapType == 'vector':
+ # parent is collapsible pane
+ parent.SetSizer(inputSizer)
+ return inputSizer
def _createPreview(self, parent):
"""!Create preview"""
# initialize preview display
@@ -472,7 +524,7 @@
@return True on success otherwise False
- ret = self.CreateColorTable(mapType = self.mapType)
+ ret = self.CreateColorTable()
if not self.colorTable:
self.UseAttrColumn()
if ret:
@@ -493,34 +545,43 @@
self.Map.Clean()
self.Destroy()
- def LoadTable(self, mapType = 'raster'):
- """!Load current color table (using `r(v).colors.out`)
+ def OnSaveRulesFile(self, event):
+ """!Save color table to file"""
+ path = event.GetString()
+ if not os.path.exists(path):
+ return
- @param mapType map type (raster or vector)"""
+ rulestxt = ''
+ for rule in self.rulesPanel.ruleslines.itervalues():
+ if not rule['value']:
+ continue
+ rulestxt += rule['value'] + ' ' + rule['color'] + '\n'
+ if not rulestxt:
+ gcmd.GMessage(message = _("Nothing to save."),
+ parent = self)
+ return
+ fd = open(path, 'w')
+ fd.write(rulestxt)
+ fd.close()
+ def OnLoadRulesFile(self, event):
+ """!Load color table from file"""
+ return
self.rulesPanel.Clear()
- if mapType == 'raster':
- cmd = ['r.colors.out',
- 'read=True',
- 'map=%s' % self.inmap,
- 'rules=-']
- else:
- cmd = ['v.colors.out',
- 'read=True',
- 'rules=-']
- if self.properties['sourceColumn'] and self.properties['sourceColumn'] != 'cat':
- cmd.append('column=%s' % self.properties['sourceColumn'])
- cmd = utils.CmdToTuple(cmd)
- if self.inmap:
- ctable = gcmd.RunCommand(cmd[0], **cmd[1])
- else:
- self.OnPreview()
- return
+ file = open(path, 'r')
+ ctable = file.read()
+ self.ReadColorTable(ctable = ctable)
+ def ReadColorTable(self, ctable):
+ """!Read color table
+ @param table color table in format coming from r.colors.out"""
rulesNumber = len(ctable.splitlines())
self.rulesPanel.AddRules(rulesNumber)
@@ -548,9 +609,44 @@
# raster min, max is known from r.info
self.properties['min'], self.properties['max'] = minim, maxim
self.SetRangeLabel()
- self.OnPreview(tmp = True)
+ self.OnPreview(tmp = True)
+ def OnLoadDefaultTable(self, event):
+ """!Load internal color table"""
+ self.LoadTable()
+ def LoadTable(self, mapType = 'raster'):
+ """!Load current color table (using `r(v).colors.out`)
+ @param mapType map type (raster or vector)"""
+ self.rulesPanel.Clear()
+ if mapType == 'raster':
+ cmd = ['r.colors.out',
+ 'read=True',
+ 'map=%s' % self.inmap,
+ 'rules=-']
+ else:
+ cmd = ['v.colors.out',
+ 'read=True',
+ 'rules=-']
+ if self.properties['sourceColumn'] and self.properties['sourceColumn'] != 'cat':
+ cmd.append('column=%s' % self.properties['sourceColumn'])
+ cmd = utils.CmdToTuple(cmd)
+ if self.inmap:
+ ctable = gcmd.RunCommand(cmd[0], **cmd[1])
+ else:
+ self.OnPreview()
+ return
- def CreateColorTable(self, force = False, mapType = 'raster'):
+ def CreateColorTable(self, tmp = False):
"""!Creates color table
@@ -581,26 +677,16 @@
output.write(rulestxt)
finally:
output.close()
- flags = ''
- if not force and not self.ovrwrtcheck.IsChecked():
- flags = 'w'
- cmd = ['%s.colors' % mapType[0],#r.colors/v.colors
- 'flags=%s' % flags,
+ cmd = ['%s.colors' % self.mapType[0],#r.colors/v.colors
'rules=%s' % gtemp]
- if mapType == 'vector' and self.properties['sourceColumn']:
+ if self.mapType == 'vector' and self.properties['sourceColumn']\
+ and self.properties['sourceColumn'] != 'cat':
- ret = gcmd.RunCommand(cmd[0], **cmd[1])
- if ret != 0 and mapType == 'raster':
- gcmd.GMessage(_("Color table already exists. "
- "Check out 'replace existing color table' to "
- "overwrite it."),
- parent = self)
+ ret = gcmd.RunCommand(cmd[0], **cmd[1])
+ if ret != 0:
return False
return True
@@ -616,7 +702,7 @@
self.layer.SetCmd(cmdlist)
# apply new color table and display preview
- self.CreateColorTable(force = True, mapType = self.mapType)
+ self.CreateColorTable(tmp = True)
self.preview.UpdatePreview()
def RunHelp(self, cmd):
@@ -652,10 +738,6 @@
ColorTable.__init__(self, parent,
title = _('Create new color table for raster map'), **kwargs)
- # additional bindings for raster color management
- self.Bind(wx.EVT_BUTTON, self.OnSaveTable, self.btnSave)
self._initLayer()
@@ -663,39 +745,6 @@
self.CentreOnScreen()
self.Show()
- def _createMapSelection(self, parent):
- """!Create map selection part of dialog"""
- # top controls
- maplabel = _('Select raster map:')
- inputBox = wx.StaticBox(parent, id = wx.ID_ANY,
- label = " %s " % maplabel)
- inputSizer = wx.StaticBoxSizer(inputBox, wx.VERTICAL)
- self.selectionInput = gselect.Select(parent, id = wx.ID_ANY,
- size = globalvar.DIALOG_GSELECT_SIZE,
- type = 'cell')
- self.ovrwrtcheck = wx.CheckBox(parent, id = wx.ID_ANY,
- label = _('replace existing color table'))
- self.ovrwrtcheck.SetValue(UserSettings.Get(group = 'cmd', key = 'overwrite', subkey = 'enabled'))
- self.btnSave = wx.Button(parent, id = wx.ID_SAVE)
- self.btnSave.SetToolTipString(_('Save color table to file'))
- # layout
- inputSizer.Add(item = self.selectionInput,
- flag = wx.ALIGN_CENTER_VERTICAL | wx.ALL | wx.EXPAND, border = 5)
- replaceSizer = wx.BoxSizer(wx.HORIZONTAL)
- replaceSizer.Add(item = self.ovrwrtcheck, proportion = 1,
- flag = wx.ALL | wx.ALIGN_CENTER_VERTICAL, border = 1)
- replaceSizer.Add(item = self.btnSave, proportion = 0,
- flag = wx.ALIGN_RIGHT | wx.ALL, border = 5)
- inputSizer.Add(item = replaceSizer, proportion = 1,
- flag = wx.ALL | wx.EXPAND, border = 0)
- return inputSizer
def _doLayout(self):
"""!Do main layout"""
sizer = wx.BoxSizer(wx.VERTICAL)
@@ -706,6 +755,12 @@
sizer.Add(item = mapSelection, proportion = 0,
flag = wx.ALL | wx.EXPAND, border = 5)
+ # manage extern tables
+ fileSelection = self._createFileSelection(parent = self)
+ sizer.Add(item = fileSelection, proportion = 0,
+ flag = wx.ALL | wx.EXPAND, border = 5)
# body & preview
bodySizer = self._createBody(parent = self)
@@ -731,7 +786,9 @@
"""!Raster map selected"""
if event:
self.inmap = event.GetString()
+ self.loadRules.SetValue('')
+ self.saveRules.SetValue('')
if self.inmap:
if not grass.find_file(name = self.inmap, element = 'cell')['file']:
self.inmap = None
@@ -813,29 +870,7 @@
parent = self,
flags = 'r',
map = self.inmap)
- def OnSaveTable(self, event):
- """!Save color table to file"""
- rulestxt = ''
- for rule in self.rulesPanel.ruleslines.itervalues():
- if not rule['value']:
- continue
- rulestxt += rule['value'] + ' ' + rule['color'] + '\n'
- if not rulestxt:
- gcmd.GMessage(message = _("Nothing to save."),
- parent = self)
- return
- dlg = wx.FileDialog(parent = self,
- message = _("Save color table to file"),
- defaultDir = os.getcwd(), style = wx.SAVE | wx.OVERWRITE_PROMPT)
- if dlg.ShowModal() == wx.ID_OK:
- path = dlg.GetPath()
- fd = open(path, 'w')
- fd.write(rulestxt)
- fd.close()
- dlg.Destroy()
def OnHelp(self, event):
"""!Show GRASS manual page"""
cmd = 'r.colors'
@@ -894,22 +929,6 @@
self.SetSize((-1, 735))
self.Show()
- # top controls
- maplabel = _('Select vector map:')
- type = 'vector')
- inputSizer.Add(item = self.selectionInput, proportion = 1,
- return inputSizer
def _createVectorAttrb(self, parent):
"""!Create part of dialog with layer/column selection"""
@@ -996,6 +1015,18 @@
+ if self.version7 and self.attributeType == 'color':
+ self.cp = wx.CollapsiblePane(scrollPanel, label = _("Import or export color table"),
+ winid = wx.ID_ANY,
+ style = wx.CP_DEFAULT_STYLE|wx.CP_NO_TLW_RESIZE)
+ self.Bind(wx.EVT_COLLAPSIBLEPANE_CHANGED, self.OnPaneChanged, self.cp)
+ self._createFileSelection(parent = self.cp.GetPane())
+ sizer.Add(item = self.cp, proportion = 0,
# set vector attributes
vectorAttrb = self._createVectorAttrb(parent = scrollPanel)
@@ -1027,8 +1058,17 @@
self.SetSizer(mainsizer)
mainsizer.Layout()
- mainsizer.Fit(self)
+ mainsizer.Fit(self)
+ def OnPaneChanged(self, event = None):
+ # redo the layout
+ self.Layout()
+ # and also change the labels
+ if self.cp.IsExpanded():
+ self.cp.SetLabel('')
+ else:
+ self.cp.SetLabel(_("Import or export color table"))
def CheckMapset(self):
"""!Check if current vector is in current mapset"""
if grass.find_file(name = self.inmap,
@@ -1095,7 +1135,11 @@
# switch to another map -> delete temporary column
self.DeleteTemporaryColumn()
if self.inmap:
if not grass.find_file(name = self.inmap, element = 'vector')['file']:
self.inmap = None
@@ -1472,16 +1516,16 @@
self.parent.curr_page.maptree.GetPyData(layer)[0]['maplayer'].SetCmd(cmdlist)
- def CreateColorTable(self, force = False, mapType = 'vector'):
"""!Create color rules (color table or color column)"""
if self.colorTable:
- ret = ColorTable.CreateColorTable(self, force, mapType)
+ ret = ColorTable.CreateColorTable(self)
else:
- ret = self.UpdateColorColumn(force)
+ ret = self.UpdateColorColumn(tmp)
return ret
- def UpdateColorColumn(self, force):
+ def UpdateColorColumn(self, tmp):
@@ -1492,7 +1536,7 @@
if not rule['value']: # skip empty rules
continue
- if force:
+ if tmp:
rgb_col = self.properties['tmpColumn']
else:
rgb_col = self.properties['storeColumn']
