[GRASS-SVN] r47777 - grass-addons/grass7/gui/wxpython/wx.wms
svn_grass at osgeo.org
Fri Aug 19 10:00:00 EDT 2011
Author: sudeepsingh
Date: 2011-08-19 07:00:00 -0700 (Fri, 19 Aug 2011)
New Revision: 47777
Removed:
grass-addons/grass7/gui/wxpython/wx.wms/savepopup.py
savepopup.py module no longer required
Deleted: grass-addons/grass7/gui/wxpython/wx.wms/savepopup.py
--- grass-addons/grass7/gui/wxpython/wx.wms/savepopup.py 2011-08-19 13:59:20 UTC (rev 47776)
+++ grass-addons/grass7/gui/wxpython/wx.wms/savepopup.py 2011-08-19 14:00:00 UTC (rev 47777)
@@ -1,86 +0,0 @@
-#!/usr/bin/env python
-# -*- coding: utf-8 -*-
-# generated by wxGlade 0.6.3 on Sat Aug 6 14:09:41 2011
-import wx
-from wx.lib.pubsub import Publisher
-# begin wxGlade: extracode
-# end wxGlade
-class SaveFrame(wx.Frame):
- def __init__(self, *args, **kwds):
- # begin wxGlade: SaveFrame.__init__
- kwds["style"] = wx.DEFAULT_FRAME_STYLE
- wx.Frame.__init__(self, *args, **kwds)
- self.unsaved_label = wx.StaticText(self, -1, " You have unsaved changes \n Do you want to\n")
- self.SaveButton = wx.Button(self, -1, "Save")
- self.DontSaveButton = wx.Button(self, -1, "Don't Save")
- self.button_3 = wx.Button(self, -1, "Cancel")
- self.__set_properties()
- self.__do_layout()
- self.Bind(wx.EVT_BUTTON, self.OnSave, self.SaveButton)
- self.Bind(wx.EVT_BUTTON, self.OnDontSave, self.DontSaveButton)
- self.Bind(wx.EVT_BUTTON, self.OnCancel, self.button_3)
- # end wxGlade
- def __set_properties(self):
- # begin wxGlade: SaveFrame.__set_properties
- self.SetTitle("frame_1")
- # end wxGlade
- def __do_layout(self):
- # begin wxGlade: SaveFrame.__do_layout
- sizer_2 = wx.BoxSizer(wx.VERTICAL)
- sizer_3 = wx.BoxSizer(wx.HORIZONTAL)
- sizer_2.Add(self.unsaved_label, 0, 0, 0)
- sizer_3.Add(self.SaveButton, 0, 0, 0)
- sizer_3.Add(self.DontSaveButton, 0, 0, 0)
- sizer_3.Add(self.button_3, 0, 0, 0)
- sizer_2.Add(sizer_3, 0, wx.EXPAND, 0)
- self.SetSizer(sizer_2)
- sizer_2.Fit(self)
- self.Layout()
- # end wxGlade
- def OnSave(self, event): # wxGlade: SaveFrame.<event_handler>
- print "Event handler `OnSave' not implemented!"
- msg = ''
- Publisher().sendMessage(("PopupSaveRequest"), msg)
- event.Skip()
- self.Destroy()
- def OnDontSave(self, event): # wxGlade: SaveFrame.<event_handler>
- print "Event handler `OnDontSave' not implemented!"
- msg = ''
- Publisher().sendMessage(("PopupNotSaveRequest"), msg)
- event.Skip()
- self.Destroy()
- def OnCancel(self, event): # wxGlade: SaveFrame.<event_handler>
- print "Event handler `OnCancel' not implemented!"
- msg = ''
- Publisher().sendMessage(("PopupCancelRequest"), msg)
- event.Skip()
- self.Destroy()
-# end of class SaveFrame
-def SavePopUp():
- app = wx.PySimpleApp(0)
- wx.InitAllImageHandlers()
- dialog_1 = SaveFrame(None, -1, "")
- app.SetTopWindow(dialog_1)
- dialog_1.Show()
- app.MainLoop()
-if __name__ == "__main__":
- dialog_1.Show()
- app.MainLoop()
\ No newline at end of file
