[GRASS-SVN] r47780 - grass/trunk/lib/db/dbmi_base
svn_grass at osgeo.org
Fri Aug 19 12:12:12 EDT 2011
Author: martinl
Date: 2011-08-19 09:12:12 -0700 (Fri, 19 Aug 2011)
New Revision: 47780
grass/trunk/lib/db/dbmi_base/handle.c
dbmi: update dox strings for db_set_handle
Modified: grass/trunk/lib/db/dbmi_base/handle.c
--- grass/trunk/lib/db/dbmi_base/handle.c 2011-08-19 16:11:17 UTC (rev 47779)
+++ grass/trunk/lib/db/dbmi_base/handle.c 2011-08-19 16:12:12 UTC (rev 47780)
@@ -27,14 +27,14 @@
- \brief Set handle
+ \brief Set handle (database and schema name)
\param handle pointer to dbHandle
\param dbName database name
\param dbSchema schema name
\return DB_OK on success
- \return error code on failure
+ \return DB_FAILED on failure
int db_set_handle(dbHandle * handle, const char *dbName, const char *dbSchema)
