[GRASS-SVN] r47803 - in grass/branches/develbranch_6/raster3d:
r3.out.ascii r3.out.v5d r3.out.vtk r3.to.rast
svn_grass at osgeo.org
Sun Aug 21 17:06:15 EDT 2011
Author: neteler
Date: 2011-08-21 14:06:15 -0700 (Sun, 21 Aug 2011)
New Revision: 47803
grass/branches/develbranch_6/raster3d/r3.out.ascii/description.html
grass/branches/develbranch_6/raster3d/r3.out.v5d/main.c
grass/branches/develbranch_6/raster3d/r3.out.vtk/errorHandling.c
grass/branches/develbranch_6/raster3d/r3.out.vtk/main.c
grass/branches/develbranch_6/raster3d/r3.to.rast/main.c
i18n polishing
Modified: grass/branches/develbranch_6/raster3d/r3.out.ascii/description.html
--- grass/branches/develbranch_6/raster3d/r3.out.ascii/description.html 2011-08-21 21:05:58 UTC (rev 47802)
+++ grass/branches/develbranch_6/raster3d/r3.out.ascii/description.html 2011-08-21 21:06:15 UTC (rev 47803)
@@ -45,7 +45,7 @@
the header lines "top", "bottom" and "levels".
<h2>SEE ALSO</h2>
-<em><a href="r3.in.ascii.html">r3.in.ascii</a></em><br>
+<em><a href="r3.in.ascii.html">r3.in.ascii</a></em>,
<em><a href="g.region.html">g.region</a></em><br>
<h2>AUTHORS</h2>
Modified: grass/branches/develbranch_6/raster3d/r3.out.v5d/main.c
--- grass/branches/develbranch_6/raster3d/r3.out.v5d/main.c 2011-08-21 21:05:58 UTC (rev 47802)
+++ grass/branches/develbranch_6/raster3d/r3.out.v5d/main.c 2011-08-21 21:06:15 UTC (rev 47803)
@@ -261,7 +261,7 @@
/* Write the v5d file */
if (!v5dWrite(1, 1, g))
- G_fatal_error(_("Error writing V5D file"));
+ G_fatal_error(_("Failed writing V5D file"));
/* Close the v5d file */
v5dClose();
Modified: grass/branches/develbranch_6/raster3d/r3.out.vtk/errorHandling.c
--- grass/branches/develbranch_6/raster3d/r3.out.vtk/errorHandling.c 2011-08-21 21:05:58 UTC (rev 47802)
+++ grass/branches/develbranch_6/raster3d/r3.out.vtk/errorHandling.c 2011-08-21 21:06:15 UTC (rev 47803)
@@ -32,14 +32,14 @@
/* Error handling ********************************************************** */
-void fatal_error(char *errorMsg, input_maps * in)
+void fatal_error(char *errorMsg, input_maps *in)
- G_warning("%s\n", errorMsg);
+ G_warning("%s", errorMsg);
/*close all open maps and free memory */
release_input_maps_struct(in);
- G3d_fatalError("Break because of errors.");
+ G3d_fatalError("Break because of errors");
@@ -49,7 +49,7 @@
if (fd != -1)
if (G_close_cell(fd) < 0) {
- G_warning(_("unable to close input raster map"));
+ G_warning(_("Unable to close input raster map"));
return 1;
@@ -64,7 +64,7 @@
if (map != NULL) {
if (!G3d_closeCell(map)) {
- G_warning(_("unable to close input 3d raster map"));
+ G_warning(_("Unable to close 3D raster map <%s>"), map);
return 1;
@@ -104,7 +104,7 @@
free(in);
if (error > 0)
- G3d_fatalError("Error while closing the input maps");
+ G3d_fatalError(_("Unable to close input raster maps"));
return;
Modified: grass/branches/develbranch_6/raster3d/r3.out.vtk/main.c
--- grass/branches/develbranch_6/raster3d/r3.out.vtk/main.c 2011-08-21 21:05:58 UTC (rev 47802)
+++ grass/branches/develbranch_6/raster3d/r3.out.vtk/main.c 2011-08-21 21:06:15 UTC (rev 47803)
@@ -448,7 +448,8 @@
/*If not equal, set the 2D windows correct */
if (rows != region.rows || cols != region.cols) {
- G_message(_("The 2d and 3d region settings are different. The g3d settings are used to adjust the 2d region."));
+ G_message(_("The 2D and 3D region settings are different. "
+ "Using the 2D window settings to adjust the 2D part of the 3D region."));
G_get_set_window(&window2d);
window2d.ns_res = region.ns_res;
window2d.ew_res = region.ew_res;
Modified: grass/branches/develbranch_6/raster3d/r3.to.rast/main.c
--- grass/branches/develbranch_6/raster3d/r3.to.rast/main.c 2011-08-21 21:05:58 UTC (rev 47802)
+++ grass/branches/develbranch_6/raster3d/r3.to.rast/main.c 2011-08-21 21:06:15 UTC (rev 47803)
@@ -240,13 +240,13 @@
G3D_DEFAULT_WINDOW, G3D_TILE_SAME_AS_FILE,
G3D_USE_CACHE_DEFAULT);
if (map == NULL)
- G3d_fatalError(_("Error opening 3d raster map <%s>"),
+ G3d_fatalError(_("Error opening 3D raster map <%s>"),
param.input->answer);
/*Get the region of the map */
G3d_getRegionStructMap(map, ®ion);
- /*set this region as current 3d window for map */
+ /*set this region as current 3D window for map */
G3d_setWindowMap(map, ®ion);
/*Set the 2d region appropriate */
G3d_extract2dRegion(®ion, ®ion2d);
@@ -264,7 +264,7 @@
/*If not equal, set the 3D window correct */
- G_message(_("The 2d and 3d region settings are different. "
G_get_set_window(®ion2d);
region.ns_res = region2d.ns_res;
@@ -274,14 +274,14 @@
G3d_setWindow(®ion);
- /*Open the 3d raster map */
+ /*Open the 3D raster map */
map = G3d_openCellOld(param.input->answer,
G_find_grid3(param.input->answer, ""),
®ion, G3D_TILE_SAME_AS_FILE,
if (map == NULL)
@@ -387,7 +387,7 @@
/* Close files and exit */
- fatal_error(map, NULL, 0, _("Error closing 3d raster map"));
+ fatal_error(map, NULL, 0, _("Unable to close 3D raster map"));
map = NULL;
