[GRASS-SVN] r47806 -
grass-addons/grass7/raster/r.modis/r.modis.import
svn_grass at osgeo.org
Sun Aug 21 17:33:16 EDT 2011
Author: lucadelu
Date: 2011-08-21 14:33:16 -0700 (Sun, 21 Aug 2011)
New Revision: 47806
grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.html
grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py
update r.modis.import
Modified: grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.html
--- grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.html 2011-08-21 21:21:44 UTC (rev 47805)
+++ grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.html 2011-08-21 21:33:16 UTC (rev 47806)
@@ -25,31 +25,37 @@
<h2>EXAMPLES</h2>
-Import a single file with the default subset without QA layer:
+Import a single file with the default subset with QA layer analisys to remove bad pixels
<div class="code"><pre>
r.modis.import dsn=/path/to/file mrtpath=/path/to/mrt
</pre></div>
-Import a single file with your own subset of layers:
+Import more files with the default subset with QA layer
-r.modis.import dsn=/path/to/file mrtpath=/path/to/mrt spectral="( 1 0 1 0 )"
+r.modis.import filename=/path/to/listfile mrtpath=/path/to/mrt
</pre></div>
-Import more files with the default subset without QA layer:
+Import more files like daily mosaic with the default subset without QA layer
</pre></div>
-Import more files like a daily mosaics with the default subset with QA layer:
+Import a single file with the default subset without QA layer analisys and it doesn't
+rescale the pixel
-r.modis.import -qm filename=/path/to/listfile mrtpath=/path/to/mrt
+r.modis.import -r dsn=/path/to/file mrtpath=/path/to/mrt
</pre></div>
-Import more files with your own subset of layers:
+Import a single file with your own subset of layers (for power user)
-r.modis.import filename=/path/to/listfile mrtpath=/path/to/mrt spectral="( 1 )"
+r.modis.import dsn=/path/to/file mrtpath=/path/to/mrt spectral="( 1 0 1 0)"
</pre></div>
+Import more files with your own subset of layers and without QA layer analisys (for power user)
+<div class="code"><pre>
+r.modis.import -q filename=/path/to/listfile mrtpath=/path/to/mrt spectral="( 1 )"
+</pre></div>
<h2>SEE ALSO</h2>
<em>
Modified: grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py
--- grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py 2011-08-21 21:21:44 UTC (rev 47805)
+++ grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py 2011-08-21 21:33:16 UTC (rev 47806)
@@ -36,11 +36,11 @@
#%end
#%flag
#% key: q
-#% description: Doesn't use the QA map
+#% description: Doesn't use the QA map, don't use with "r" flag
#%end
#%flag
#% key: r
-#% description: Doesn't resampling the output map
+#% description: Doesn't resampling the output map
#%end
#%option
#% key: mrtpath
@@ -175,12 +175,15 @@
return pm.confResample(spectr, None, pref, dat, resampl, proj, zone, projpar)
def prefix(options, name = False):
+ """Return the prefix of output file if not set return None to use default
+ value
if options['output']:
return options['output']
else:
return None
-def import_tif(out, basedir, rem, target=None):
+def import_tif(out, basedir, rem, write, target=None):
"""Import TIF files"""
# list of tif files
tifiles = glob.glob1(basedir, out + "*.tif")
@@ -197,8 +200,8 @@
basename = os.path.splitext(t)[0]
name = os.path.join(basedir,t)
try:
- grass.run_command('r.in.gdal', input = name,
- output = basename, flags = f, overwrite = True, quiet = True)
+ grass.run_command('r.in.gdal', input = name, output = basename,
+ flags = f, overwrite = write, quiet = True)
outfile.append(basename)
except:
grass.fatal(_('Error during import'))
@@ -210,45 +213,55 @@
return outfile
def findfile(pref, suff):
+ """ Check if a file exists on mapset """
if grass.find_file(pref + suff)['file']:
return grass.find_file(pref + suff)
else:
- grass.fatal(_("Raster map <%s> not found") % pref + suff)
+ grass.warning(_("Raster map <%s> not found") % (pref + suff))
def metadata(pars, mapp, coll):
+ """ Set metadata to the imported files """
+ # metadata
meta = pars.metastring()
- grass.run_command('r.support', map=mapp, hist=meta)
+ grass.run_command('r.support', quiet = True, map=mapp, hist=meta)
+ # timestamp
rangetime = pars.retRangeTime()
data = rangetime['RangeBeginningDate'].split('-')
dataobj = date(int(data[0]),int(data[1]),int(data[2]))
- grass.run_command('r.timestamp', map=mapp, date=dataobj.strftime("%d %b %Y"))
- if coll:
- grass.run_command('r.colors', map=mapp, color = coll)
+ grass.run_command('r.timestamp', map=mapp, date=dataobj.strftime("%d %b %Y"),
+ quiet = True)
+ # color
+ if string.find(mapp, 'QA'):
+ grass.run_command('r.colors', quiet = True, map=mapp, color = coll)
+ elif string.find(mapp, 'NDVI'):
+ grass.run_command('r.colors', quiet = True, map=mapp, color = coll[0])
+ elif string.find(mapp, 'EVI'):
+ grass.run_command('r.colors', quiet = True, map=mapp, color = coll[1])
+ elif string.find(mapp, 'LST'):
+ elif string.find(mapp, 'Snow'):
-def analize(pref, an, cod, parse):
+def analize(pref, an, cod, parse, write):
+ """ Analiza the MODIS data using QA if present """
prod = product().fromcode(cod)
if not prod['spec_qa']:
grass.warning(_("There is not QA file, analysis will be skipped"))
- an = 'noqa'
+ an = 'noqa'
pat = prod['pattern']
suf = prod['suff']
col = prod['color']
val = []
qa = []
- for v,q in suf.iteritems():
- val.append(findfile(pref,v))
- qa.append(findfile(pref,q))
+ for v,q in suf.iteritems():
+ val.append(findfile(pref,v))
+ if q:
+ qa.append(findfile(pref,q))
grass.run_command('g.region', rast = val[0]['fullname'])
- if len(qa) != len(val):
- grass.fatal(_("The number of QA and value maps is different, something wrong"))
- for n in range(len(qa)):
+ for n in range(len(val)):
valname = val[n]['name']
valfull = val[n]['fullname']
- qaname = qa[n]['name']
- qafull = qa[n]['fullname']
grass.run_command('r.null', map = valfull)
if string.find(cod,'13Q1') or string.find(cod,'13A2'):
mapc = "%s.2 = %s / 10000" % (valname, valfull)
@@ -256,39 +269,47 @@
elif string.find(cod,'11A1') or string.find(cod,'11A2') or string.find(cod,'11B1'):
mapc = "%s.2 = (%s * 0.0200) - 273.15" % (valname, valfull)
grass.mapcalc(mapc)
- else:
- grass.run_command('g.copy', rast = (valfull,valname + '.2'))
if an == 'noqa':
- grass.run_command('g.remove', rast = valfull)
- grass.run_command('g.rename', rast= (valname + '.2', valfull))
+ #grass.run_command('g.remove', quiet = True, rast = valfull)
+ try:
+ grass.run_command('g.rename', quiet = True, overwrite = write,
+ rast= (valname + '.2', valname + '.check'))
+ except:
+ pass
#TODO check in modis.py to adjust the xml file of mosaic
- #metadata(parse, valfull, col)
+ #metadata(parse, valname, col)
+ #metadata(parse, valname + '.check', col)
#metadata(parse, qafull, 'byr')
if an == 'all':
+ if len(qa) != len(val):
+ grass.fatal(_("The number of QA and value maps is different, something wrong"))
+ qaname = qa[n]['name']
+ qafull = qa[n]['fullname']
finalmap = "%s.3=if(" % valname
for key,value in prod['pattern'].iteritems():
for v in value:
outpat = "%s.%i.%i" % (qaname, key, v)
- grass.run_command('r.bitpattern', quiet=True, input = qafull,
- output = outpat, pattern = key, patval= v)
+ grass.run_command('r.bitpattern', quiet = True, input = qafull,
+ output = outpat, pattern = key, patval= v)
finalmap += "%s == 0 && " % outpat
finalmap += "%s.2 <= 1.000" % valname
else:
finalmap.rstrip(' && ')
finalmap += ",%s.2, null() )" % valname
- import pdb; pdb.set_trace()
grass.mapcalc(finalmap)
- grass.run_command('g.remove', rast=(valname, valname + '.2'))
- grass.run_command('g.mremove', flag="f", quiet = True,
+ #grass.run_command('g.remove', quiet = True, rast=(valname, valname + '.2'))
+ grass.run_command('g.remove', quiet = True, rast=(valname + '.2'))
+ grass.run_command('g.mremove', flags="f", quiet = True,
rast = ("%s.*" % qaname))
- grass.run_command('g.rename', rast=(valname + '.3', valname))
+ rast=(valname + '.3', valname + '.check'))
-def single(options,remove,an):
+def single(options,remove,an,ow):
"""Convert the hdf file to tif and import it
listfile, basedir = list_files(options)
@@ -306,14 +327,14 @@
if not output:
output = os.path.split(hdf)[1].rstrip('.hdf')
# import tif files
- maps_import = import_tif(output,basedir,remove)
+ maps_import = import_tif(output,basedir,remove,ow)
if an:
cod = os.path.split(pm.hdfname)[1].split('.')[0]
- analize(output, an, cod, pm)
+ analize(output, an, cod, pm, ow)
os.remove(confname)
return grass.message(_('All files imported correctly'))
-def mosaic(options,remove,an):
+def mosaic(options,remove,an,ow):
"""Create a daily mosaic of hdf files convert to tif and import it
dictfile, targetdir = list_files(options,True)
@@ -331,7 +352,7 @@
spectr = spectral(options,listfiles[0].split('/')[-1].split('.')[0],an, True)
spectr = spectr.lstrip('( ').rstrip(' )')
# create mosaic
- cm = createMosaic(tempfile.name,outname,options['mrtpath'],spectr)
+ cm = createMosaic(tempfile.name, outname, options['mrtpath'], spectr)
cm.run()
# list of hdf files
hdfiles = glob.glob1(basedir, outname + "*.hdf")
@@ -342,24 +363,24 @@
pm = parseModis(hdf)
confname = confile(pm,options,an)
# create convertModis class and convert it in tif file
- execmodis = convertModis(hdf,confname,options['mrtpath'])
+ execmodis = convertModis(hdf, confname, options['mrtpath'])
execmodis.run()
# remove hdf
if remove:
# import tif files
- import_tif(outname,basedir,remove)
+ import_tif(outname, basedir, remove, ow)
if an:
- analize(outname, an, cod, pm)
+ analize(outname, an, cod, pm, ow)
os.remove(hdf)
os.remove(hdf + '.xml')
# or move the hdf and hdf.xml to the dir where are the original files
else:
# import tif files
- import_tif(outname,basedir,remove,targetdir)
+ import_tif(outname, basedir, remove, ow, targetdir)
if an:
try:
shutil.move(hdf,targetdir)
shutil.move(hdf + '.xml',targetdir)
@@ -368,6 +389,7 @@
# remove the conf file
os.remove(confname)
grass.try_remove(tempfile.name)
+ grass.try_remove(os.path.join(targetdir,'mosaic',str(os.getpid())))
def main():
@@ -377,9 +399,9 @@
grass.fatal(_('$GISBASE not defined'))
return 0
# return an error if q and spectral are set
- if flags['q'] and options['spectral'] != '':
- grass.fatal(_('It is not possible set flag "q" and "spectral" option'))
- return 0
+ if not flags['q'] and options['spectral'] != '':
+ grass.warning(_('If you have not choose QA layer in the "spectral" option'\
+ + 'the command would be report an error'))
# return an error if both dns and files option are set or not
if options['dns'] == '' and options['files'] == '':
grass.fatal(_('You have to choose one of "dns" or "files" options'))
@@ -398,10 +420,14 @@
remove = False
else:
remove = True
+ if grass.overwrite():
+ over = True
+ else:
+ over = False
# check if do check quality, resampling and setting of color
if flags['r']:
analize = None
- if flags['q']:
+ elif flags['q']:
analize = 'noqa'
else:
analize = 'all'
@@ -410,9 +436,9 @@
grass.fatal(_('It is not possible to create a mosaic with a single HDF file'))
return 0
elif flags['m']:
- mosaic(options,remove,analize)
+ mosaic(options,remove,analize,over)
else:
- single(options,remove,analize)
+ single(options,remove,analize,over)
if __name__ == "__main__":
options, flags = grass.parser()
