[GRASS-SVN] r47811 - grass/trunk/lib/db/dbmi_base/test
svn_grass at osgeo.org
Mon Aug 22 04:05:32 EDT 2011
Author: huhabla
Date: 2011-08-22 01:05:32 -0700 (Mon, 22 Aug 2011)
New Revision: 47811
grass/trunk/lib/db/dbmi_base/test/test_main.c
Typo fix
Modified: grass/trunk/lib/db/dbmi_base/test/test_main.c
--- grass/trunk/lib/db/dbmi_base/test/test_main.c 2011-08-22 06:37:34 UTC (rev 47810)
+++ grass/trunk/lib/db/dbmi_base/test/test_main.c 2011-08-22 08:05:32 UTC (rev 47811)
@@ -80,7 +80,7 @@
module = G_define_module();
module->description
- = _("Performs benchmarks, unit and integration tests for the gmath library");
+ = _("Performs unit and integration tests for the dbmi base library");
/* Get parameters from user */
set_params();
