[GRASS-SVN] r47815 -
grass-addons/grass7/raster/r.modis/r.modis.import
svn_grass at osgeo.org
Mon Aug 22 07:49:37 EDT 2011
Author: neteler
Date: 2011-08-22 04:49:37 -0700 (Mon, 22 Aug 2011)
New Revision: 47815
grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py
english fixes
Modified: grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py
--- grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py 2011-08-22 10:30:11 UTC (rev 47814)
+++ grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py 2011-08-22 11:49:37 UTC (rev 47815)
@@ -22,7 +22,7 @@
#%module
-#% description: Import single or more tiles of MODIS products using pyModis/MRT
+#% description: Import single or multiple tiles of MODIS products using pyModis/MRT
#% keywords: raster
#% keywords: MODIS
#%end
@@ -36,17 +36,17 @@
#%end
#%flag
#% key: q
-#% description: Do not use the QA map, do not use with "r" flag
+#% description: Ignore the QA map layer, do not use with "r" flag
#%end
#%flag
#% key: r
-#% description: Do not resample the output map
+#% description: Do not rescale the output map values to destination units
#%end
#%option
#% key: mrtpath
#% type: string
#% key_desc: path
-#% description: The full path to MRT directory
+#% description: Full path to MRT directory
#% gisprompt: old,dir,input
#% required: yes
#%end
@@ -54,7 +54,7 @@
#% key: dns
#% type: string
#% key_desc: path
-#% description: Path to single HDF file
+#% description: Full path to single HDF file
#% gisprompt: old,file,input
#% required: no
#%end
@@ -62,7 +62,7 @@
#% key: files
#% type: string
#% key_desc: file
-#% description: Path to a file with a list of HDF files
+#% description: Full path to file with list of HDF files
#% required: no
#%end
@@ -74,7 +74,7 @@
#% key: resampl
#% type: string
#% key_desc: resampling
-#% description: Code of resampling type
+#% description: Code of spatial resampling method
#% options: NN, BI, CC, NONE
#% answer: NN
#% required: no
@@ -83,7 +83,7 @@
#% key: spectral
#% type: string
#% key_desc: spectral subset
-#% description: A string to choose the subset of HDF file to use
+#% description: String to choose subset of layers in HDF file for import
#% required: no
#%end
@@ -93,7 +93,7 @@
# add the folder containing libraries to python path
libmodis = os.path.join(os.getenv('GISBASE'), 'etc', 'r.modis')
sys.path.append(libmodis)
-# try to import pymodis (modis) and some class for r.modis.download
+# try to import pymodis (modis) and some classes for r.modis.download
try:
from rmodislib import resampling, product, get_proj, projection
from modis import parseModis, convertModis, createMosaic
@@ -101,8 +101,8 @@
pass
def list_files(opt, mosaik = False):
- """Return a list of hdf files from the filelist on function single
- Return a dictionary with a list o hdf file for each day on function mosaic
+ """If used in function single(): Return a list of HDF files from the file list
+ If used in function mosaic(): Return a dictionary with a list of HDF files for each day
# read the file with the list of HDF
if opt['files'] != '':
@@ -133,7 +133,7 @@
def spectral(opts, code, q, m = False):
"""Return spectral string"""
- # return the spectral set by the user
+ # return the spectral set selected by the user
if opts['spectral'] != '':
spectr = opts['spectral']
# return the spectral by default
@@ -243,10 +243,10 @@
grass.run_command('r.colors', quiet = True, map=mapp, color = coll[0])
def analize(pref, an, cod, parse, write):
- """ Analiza the MODIS data using QA if present """
+ """ Analyze the MODIS data using QA if present """
prod = product().fromcode(cod)
if not prod['spec_qa']:
- grass.warning(_("There is not QA file, analysis will be skipped"))
+ grass.warning(_("There is no QA layer, analysis and filtering will be skipped"))
an = 'noqa'
pat = prod['pattern']
suf = prod['suff']
@@ -282,7 +282,7 @@
#metadata(parse, qafull, 'byr')
if an == 'all':
if len(qa) != len(val):
- grass.fatal(_("The number of QA and value maps is different, something wrong"))
+ grass.fatal(_("The number of QA and value maps is different, something is wrong"))
qaname = qa[n]['name']
qafull = qa[n]['fullname']
finalmap = "%s.3=if(" % valname
@@ -310,7 +310,7 @@
def single(options,remove,an,ow):
- """Convert the hdf file to tif and import it
+ """Convert the HDF file to TIF and import it
listfile, basedir = list_files(options)
# for each file
@@ -335,7 +335,7 @@
return grass.message(_('All files imported correctly'))
def mosaic(options,remove,an,ow):
- """Create a daily mosaic of hdf files convert to tif and import it
+ """Create a daily mosaic of HDF files convert to TIF and import it
dictfile, targetdir = list_files(options,True)
# for each day
@@ -400,11 +400,11 @@
return 0
# return an error if q and spectral are set
if not flags['q'] and options['spectral'] != '':
- grass.warning(_('If you have not choose QA layer in the "spectral" option'\
- + 'the command would be report an error'))
+ grass.warning(_('If no QA layer chosen in the "spectral" option'\
+ + 'the command will report an error'))
# return an error if both dns and files option are set or not
if options['dns'] == '' and options['files'] == '':
- grass.fatal(_('You have to choose one of "dns" or "files" options'))
+ grass.fatal(_('Choose one of "dns" or "files" options'))
return 0
elif options['dns'] != '' and options['files'] != '':
grass.fatal(_('It is not possible set "dns" and "files" options together'))
@@ -413,7 +413,7 @@
version = grass.core.version()
# this is would be set automatically
if version['version'].find('7.') == -1:
- grass.fatal(_('You are not in GRASS GIS version 7'))
+ grass.fatal(_('GRASS GIS version 7 required'))
return 0
# check if remove the files or not
if flags['t']:
@@ -443,3 +443,4 @@
if __name__ == "__main__":
options, flags = grass.parser()
sys.exit(main())
