[GRASS-SVN] r47821 - grass-addons/grass7/raster/r.modis/libmodis
svn_grass at osgeo.org
Mon Aug 22 10:13:45 EDT 2011
Author: lucadelu
Date: 2011-08-22 07:13:45 -0700 (Mon, 22 Aug 2011)
New Revision: 47821
grass-addons/grass7/raster/r.modis/libmodis/rmodislib.py
fix bugs in projection and datum
Modified: grass-addons/grass7/raster/r.modis/libmodis/rmodislib.py
--- grass-addons/grass7/raster/r.modis/libmodis/rmodislib.py 2011-08-22 14:00:06 UTC (rev 47820)
+++ grass-addons/grass7/raster/r.modis/libmodis/rmodislib.py 2011-08-22 14:13:45 UTC (rev 47821)
@@ -238,7 +238,7 @@
'polar':'POLAR STEREOGRAPHIC', 'utm':'UTM',
'tmerc':'TRANSVERSE MERCATOR'}
self.datumlist = {'none':'NONE', 'nad27':'NAD27', 'nad83':'NAD83',
- 'wgs66':'WGS66', 'wgs72':'WGS72', 'wgs84':'WGS84'}
+ 'wgs66':'WGS66', 'wgs72':'WGS72', 'wgs84':'WGS84', 'etrs89':'WGS84'}
self.datumlist_swath = {'Clarke 1866' : 0, 'Clarke 1880' : 1, 'bessel' : 2
, 'International 1967' : 3, 'International 1909': 4, 'wgs72' : 5,
'Everest' : 6, 'wgs66' : 7, 'wgs84' : 8, 'Airy' : 9,
@@ -249,7 +249,10 @@
def returned(self):
"""Return the projection in the MRT style"""
- return self.projections[self.val]
+ if self.val not in self.projections.keys():
+ grass.fatal(_("Projection <%s> is not supported") % self.val)
+ else:
+ return self.projections[self.val]
def _par(self,key):
"""Function use in return_params"""
@@ -306,6 +309,10 @@
def datum(self):
"""Return the datum in the MRT style"""
+ if self.dat is not in self.datumlist.keys():
+ grass.fatal(_("Datum <%s> is not supported") % self.dat)
+ elif self.dat == 'etrs89':
+ grass.warning(_("Changing etrs89 to wgs84"))
return self.datumlist[self.dat]
def datumswath(self):
