[GRASS-SVN] r47828 - in grass-addons/grass7/raster/r.modis:
libmodis r.modis.import
svn_grass at osgeo.org
Mon Aug 22 12:20:32 EDT 2011
Author: neteler
Date: 2011-08-22 09:20:32 -0700 (Mon, 22 Aug 2011)
New Revision: 47828
grass-addons/grass7/raster/r.modis/libmodis/modis.py
grass-addons/grass7/raster/r.modis/libmodis/rmodislib.py
grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.html
fix resampling naming
Modified: grass-addons/grass7/raster/r.modis/libmodis/modis.py
--- grass-addons/grass7/raster/r.modis/libmodis/modis.py 2011-08-22 15:34:56 UTC (rev 47827)
+++ grass-addons/grass7/raster/r.modis/libmodis/modis.py 2011-08-22 16:20:32 UTC (rev 47828)
@@ -431,7 +431,7 @@
self.proj_list = ('GEO', 'HAM', 'IGH', 'ISIN', 'LA', 'LCC', 'MOL', 'PS',
'SIN','TM', 'UTM', 'MERCAT')
# resampling
- self.resam_list = ('NEAREST_NEIGHBOR', 'BICUBIC', 'CUBIC_CONVOLUTION', 'NONE')
+ self.resam_list = ('NEAREST_NEIGHBOR', 'BILINEAR', 'CUBIC_CONVOLUTION')
self.resam_list_swath = ('NN', 'BI', 'CC')
# datum
Modified: grass-addons/grass7/raster/r.modis/libmodis/rmodislib.py
--- grass-addons/grass7/raster/r.modis/libmodis/rmodislib.py 2011-08-22 15:34:56 UTC (rev 47827)
+++ grass-addons/grass7/raster/r.modis/libmodis/rmodislib.py 2011-08-22 16:20:32 UTC (rev 47828)
@@ -220,8 +220,8 @@
def __init__(self,value):
self.code = value
- self.resampling = {'NN': 'NEAREST_NEIGHBOR','BI' : 'BICUBIC',
- 'CC' : 'CUBIC CONVOLUTION','NONE' : 'NONE'}
+ self.resampling = {'nearest': 'NEAREST_NEIGHBOR', 'bilinear': 'BILINEAR',
+ 'cubic': 'CUBIC CONVOLUTION'}
def returned(self):
return self.resampling[self.code]
Modified: grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.html
--- grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.html 2011-08-22 15:34:56 UTC (rev 47827)
+++ grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.html 2011-08-22 16:20:32 UTC (rev 47828)
@@ -19,8 +19,9 @@
<b>Warning</b>:
<ul>
<li>The module has currently only been tested with Lat/Long locations, but also
- the follow projection systems are supported: Lambert Conformal Conic,
- Mercator, Polar Stereographic, Transverse Mercator, Universal Transverse Mercator</li>
+ the following projection systems are supported: Lambert Azimuthal Equal Area,
+ Lambert Conformal Conic, Mercator, Polar Stereographic, Transverse Mercator,
+ Universal Transverse Mercator</li>
</ul>
<h2>EXAMPLES</h2>
@@ -41,14 +42,14 @@
</pre></div>
Import a single file with the default subset without QA layer analysis and without
-rescaling the pixel:
+rescaling the pixel values:
<div class="code"><pre>
r.modis.import -r dsn=/path/to/file mrtpath=/path/to/mrt
</pre></div>
Import a single file with your own subset of layers (for power user):
-r.modis.import dsn=/path/to/file mrtpath=/path/to/mrt spectral="( 1 0 1 0)"
+r.modis.import dsn=/path/to/file mrtpath=/path/to/mrt spectral="( 1 0 1 0 )"
</pre></div>
Import more files with your own subset of layers and without QA layer analysis (for power users):
