[GRASS-SVN] r47840 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Mon Aug 22 15:54:06 EDT 2011
Author: cmbarton
Date: 2011-08-22 12:54:06 -0700 (Mon, 22 Aug 2011)
New Revision: 47840
grass/branches/develbranch_6/gui/wxpython/gui_modules/colorrules.py
Fixing color table behavior and bugs. Backport from trunk r47801
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/colorrules.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/colorrules.py 2011-08-22 19:04:51 UTC (rev 47839)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/colorrules.py 2011-08-22 19:54:06 UTC (rev 47840)
@@ -269,28 +269,31 @@
def LoadRules(self):
- message = ""
+ message = ""
for item in range(len(self.ruleslines)):
- self.mainPanel.FindWindowById(item + 1000).SetValue(self.ruleslines[item]['value'])
- r, g, b = (0, 0, 0) # default
- if not self.ruleslines[item][self.attributeType]:
+ try:
+ self.mainPanel.FindWindowById(item + 1000).SetValue(self.ruleslines[item]['value'])
+ r, g, b = (0, 0, 0) # default
+ if not self.ruleslines[item][self.attributeType]:
+ if self.attributeType == 'color':
+ self.ruleslines[item][self.attributeType] = '%d:%d:%d' % (r, g, b)
+ elif self.attributeType == 'size':
+ self.ruleslines[item][self.attributeType] = 100
+ elif self.attributeType == 'width':
+ self.ruleslines[item][self.attributeType] = 2
- self.ruleslines[item][self.attributeType] = '%d:%d:%d' % (r, g, b)
- elif self.attributeType == 'size':
- self.ruleslines[item][self.attributeType] = 100
- elif self.attributeType == 'width':
- self.ruleslines[item][self.attributeType] = 2
+ try:
+ r, g, b = map(int, self.ruleslines[item][self.attributeType].split(':'))
+ except ValueError, e:
+ message = _("Bad color format. Use color format '0:0:0'")
+ self.mainPanel.FindWindowById(item + 2000).SetValue((r, g, b))
+ else:
+ value = float(self.ruleslines[item][self.attributeType])
+ self.mainPanel.FindWindowById(item + 2000).SetValue(value)
+ except:
+ continue
- if self.attributeType == 'color':
- try:
- r, g, b = map(int, self.ruleslines[item][self.attributeType].split(':'))
- except ValueError, e:
- message = _("Bad color format. Use color format '0:0:0'")
- self.mainPanel.FindWindowById(item + 2000).SetValue((r, g, b))
- else:
- value = float(self.ruleslines[item][self.attributeType])
- self.mainPanel.FindWindowById(item + 2000).SetValue(value)
if message:
gcmd.GMessage(parent = self.parent, message = message)
return False
@@ -300,7 +303,7 @@
def SQLConvert(self, vals):
"""!Prepare value for SQL query"""
if vals[0].isdigit():
- sqlrule = '%s>=%s' % (self.properties['sourceColumn'], vals[0])
+ sqlrule = '%s=%s' % (self.properties['sourceColumn'], vals[0])
if vals[1]:
sqlrule += ' AND %s<%s' % (self.properties['sourceColumn'], vals[1])
else:
@@ -553,7 +556,7 @@
rulestxt = ''
for rule in self.rulesPanel.ruleslines.itervalues():
- if not rule['value']:
+ if 'value' not in rule:
continue
rulestxt += rule['value'] + ' ' + rule['color'] + '\n'
if not rulestxt:
@@ -661,7 +664,7 @@
rulestxt = ''
- if not rule['value']: # skip empty rules
+ if 'value' not in rule: # skip empty rules
continue
if rule['value'] not in ('nv', 'default') and \
@@ -1366,6 +1369,10 @@
i = 0
minim = maxim = 0.0
limit = 1000
+ colvallist = []
+ readvals = False
while True:
# os.linesep doesn't work here (MSYS)
record = outFile.readline().replace('\n', '')
@@ -1383,28 +1390,32 @@
minim = float(col1)
if float(col1) > maxim:
maxim = float(col1)
- self.rulesPanel.ruleslines[i]['value'] = col1
- self.rulesPanel.ruleslines[i][self.attributeType] = col2
+ # color rules list should only have unique values of col1, not all records
+ if col1 not in colvallist:
+ self.rulesPanel.ruleslines[i]['value'] = col1
+ self.rulesPanel.ruleslines[i][self.attributeType] = col2
+ colvallist.append(col1)
+ i += 1
- i += 1
+ if i > limit and readvals == False:
+ dlg = wx.MessageDialog (parent = self, message = _(
+ "Number of loaded records reached %d, "
+ "displaying all the records will be time-consuming "
+ "and may lead to computer freezing, "
+ "do you still want to continue?") % i,
+ caption = _("Too many records"),
+ style = wx.YES_NO | wx.NO_DEFAULT | wx.ICON_QUESTION)
+ if dlg.ShowModal() == wx.ID_YES:
+ readvals = True
+ dlg.Destroy()
+ else:
+ busy.Destroy()
+ dlg.Destroy()
+ return
- if i > limit:
- dlg = wx.MessageDialog (parent = self, message = _(
- "Number of loaded records reached %d, "
- "displaying all the records will be time-consuming "
- "and may lead to computer freezing, "
- "do you still want to continue?") % i,
- caption = _("Too many records"),
- style = wx.YES_NO | wx.NO_DEFAULT | wx.ICON_QUESTION)
- if dlg.ShowModal() == wx.ID_YES:
- dlg.Destroy()
- else:
- busy.Destroy()
- dlg.Destroy()
- return
self.rulesPanel.AddRules(i, start = True)
ret = self.rulesPanel.LoadRules()
@@ -1558,8 +1569,9 @@
rulestxt = ''
- continue
+ break
if tmp:
rgb_col = self.properties['tmpColumn']
else:
