[GRASS-SVN] r47846 -
grass/branches/releasebranch_6_4/scripts/i.in.spotvgt
svn_grass at osgeo.org
Tue Aug 23 09:41:02 EDT 2011
Author: mmetz
Date: 2011-08-23 06:41:02 -0700 (Tue, 23 Aug 2011)
New Revision: 47846
grass/branches/releasebranch_6_4/scripts/i.in.spotvgt/i.in.spotvgt
quote variables, do not modify path/to/quality.map, use bit patterns for filtering
Modified: grass/branches/releasebranch_6_4/scripts/i.in.spotvgt/i.in.spotvgt
--- grass/branches/releasebranch_6_4/scripts/i.in.spotvgt/i.in.spotvgt 2011-08-23 09:47:29 UTC (rev 47845)
+++ grass/branches/releasebranch_6_4/scripts/i.in.spotvgt/i.in.spotvgt 2011-08-23 13:41:02 UTC (rev 47846)
@@ -34,7 +34,7 @@
#%End
#%flag
#% key: a
-#% description: also import quality map (SM status map layer) and filter NDVI map
+#% description: Also import quality map (SM status map layer) and filter NDVI map
#%end
#%option
#% key: file
@@ -118,13 +118,13 @@
#### a function for writing VRT files
create_VRT_file(){
- WESTCENTER=`cat $PROJFILE | grep CARTO_UPPER_LEFT_X | tr -s ' ' ' ' | cut -d' ' -f2`
- NORTHCENTER=`cat $PROJFILE | grep CARTO_UPPER_LEFT_Y | tr -s ' ' ' ' | cut -d' ' -f2`
- EASTCENTER=`cat $PROJFILE | grep CARTO_UPPER_RIGHT_X | tr -s ' ' ' ' | cut -d' ' -f2`
- SOUTHCENTER=`cat $PROJFILE | grep CARTO_LOWER_LEFT_Y | tr -s ' ' ' ' | cut -d' ' -f2`
- MAP_PROJ_RESOLUTION=`cat $PROJFILE | grep MAP_PROJ_RESOLUTION | tr -s ' ' ' ' | cut -d' ' -f2`
- XSIZE=`cat $PROJFILE | grep IMAGE_UPPER_RIGHT_COL | tr -s ' ' ' ' | cut -d' ' -f2`
- YSIZE=`cat $PROJFILE | grep IMAGE_LOWER_RIGHT_ROW | tr -s ' ' ' ' | cut -d' ' -f2`
+ WESTCENTER=`cat "$PROJFILE" | grep CARTO_UPPER_LEFT_X | tr -s ' ' ' ' | cut -d' ' -f2`
+ NORTHCENTER=`cat "$PROJFILE" | grep CARTO_UPPER_LEFT_Y | tr -s ' ' ' ' | cut -d' ' -f2`
+ EASTCENTER=`cat "$PROJFILE" | grep CARTO_UPPER_RIGHT_X | tr -s ' ' ' ' | cut -d' ' -f2`
+ SOUTHCENTER=`cat "$PROJFILE" | grep CARTO_LOWER_LEFT_Y | tr -s ' ' ' ' | cut -d' ' -f2`
+ MAP_PROJ_RESOLUTION=`cat "$PROJFILE" | grep MAP_PROJ_RESOLUTION | tr -s ' ' ' ' | cut -d' ' -f2`
+ XSIZE=`cat "$PROJFILE" | grep IMAGE_UPPER_RIGHT_COL | tr -s ' ' ' ' | cut -d' ' -f2`
+ YSIZE=`cat "$PROJFILE" | grep IMAGE_LOWER_RIGHT_ROW | tr -s ' ' ' ' | cut -d' ' -f2`
# DEBUG (in terminal WEST is not printed?!?!?!)
#echo " $NORTHCENTER"
@@ -170,7 +170,7 @@
################### let's go
if [ -n "$GIS_OPT_FILE" ] ; then
- SPOTDIR="`dirname $GIS_OPT_FILE`"
+ SPOTDIR="`dirname \"$GIS_OPT_FILE\"`"
SPOTNAME=`basename "$GIS_OPT_FILE" .HDF`
fi
@@ -226,7 +226,6 @@
# Coefficient a = 0.004
# Coefficient b = -0.1
# clone current region
g.region save="spot_$PID"
@@ -236,6 +235,7 @@
g.region rast="$NAME" --quiet
g.message "Remapping digital numbers to NDVI..."
r.mapcalc "${NAME}_$PID = 0.004 * $NAME - 0.1"
g.remove rast="$NAME" --quiet
@@ -275,7 +275,8 @@
if [ $GIS_FLAG_A -eq 1 ] ; then
g.message "Importing SPOT VGT NDVI quality map..."
rm -f "$VRTFILE"
- create_VRT_file "$VRTFILE" `echo ${GIS_OPT_FILE} | sed 's+NDV+SM+g'`
+ SPOTSMNAME=`echo ${SPOTNAME} | sed 's+NDV+SM+g'`
+ create_VRT_file "$VRTFILE" "${SPOTDIR}/${SPOTSMNAME}.HDF"
## let's import the SM quality map...
r.in.gdal "$VRTFILE" output="$NAME.sm"
@@ -297,14 +298,15 @@
236 brown
248 orange
251 yellow
-252 green
+253 green
EOF
g.message message="Imported SPOT VEGETATION SM quality map <$NAME.sm>."
g.message message="Note: A snow map can be extracted by category 252 (d.rast $NAME.sm cat=252)"
g.message ""
g.message message="Filtering NDVI map by Status Map quality layer..."
- r.mapcalc "${NAME}_filt=if($NAME.sm >= 248, $NAME, null() )"
+ # r.mapcalc "${NAME}_filt=if($NAME.sm >= 248, $NAME, null() )"
+ r.mapcalc "${NAME}_filt=if($NAME.sm % 4 == 3 || ($NAME.sm / 16) % 16 == 0, null(), $NAME )"
r.colors "${NAME}_filt" color=ndvi --quiet
g.message message="Filtered SPOT VEGETATION NDVI map <${NAME}_filt>."
fi
