[GRASS-SVN] r47850 - grass/trunk/scripts/i.in.spotvgt
svn_grass at osgeo.org
Tue Aug 23 10:30:58 EDT 2011
Author: mmetz
Date: 2011-08-23 07:30:58 -0700 (Tue, 23 Aug 2011)
New Revision: 47850
grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py
do not modify path/to/quality.map, use bit patterns for filtering
Modified: grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py
--- grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py 2011-08-23 14:15:29 UTC (rev 47849)
+++ grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py 2011-08-23 14:30:58 UTC (rev 47850)
@@ -179,6 +179,9 @@
grass.run_command('g.remove', rast = name, quiet = True)
grass.run_command('g.rename', rast = (tmpname, name), quiet = True)
+ # write cmd history:
+ grass.raster_history(name)
#apply color table:
grass.run_command('r.colors', map = name, color = 'ndvi', quiet = True)
@@ -213,45 +216,45 @@
if also:
grass.message(_("Importing SPOT VGT NDVI quality map..."))
grass.try_remove(vrtfile)
- qfile = infile.replace('NDV','SM')
+ qname = spotname.replace('NDV','SM')
+ qfile = os.path.join(spotdir, qname)
create_VRT_file(projfile, vrtfile, qfile)
- ## let's import the SM quality map...
- smfile = name + '.sm'
- if grass.run_command('r.in.gdal', input = vrtfile, output = smfile) != 0:
- grass.fatal(_("An error occurred. Stop."))
+ ## let's import the SM quality map...
+ smfile = name + '.sm'
+ if grass.run_command('r.in.gdal', input = vrtfile, output = smfile) != 0:
+ grass.fatal(_("An error occurred. Stop."))
- # some of the possible values:
- rules = [r + '\n' for r in [
- '8 50 50 50',
- '11 70 70 70',
- '12 90 90 90',
- '60 grey',
- '155 blue',
- '232 violet',
- '235 red',
- '236 brown',
- '248 orange',
- '251 yellow',
- '252 green'
- grass.write_command('r.colors', map = smfile, rules = '-', stdin = rules)
+ # some of the possible values:
+ rules = [r + '\n' for r in [
+ '8 50 50 50',
+ '11 70 70 70',
+ '12 90 90 90',
+ '60 grey',
+ '155 blue',
+ '232 violet',
+ '235 red',
+ '236 brown',
+ '248 orange',
+ '251 yellow',
+ '252 green'
+ grass.write_command('r.colors', map = smfile, rules = '-', stdin = rules)
- grass.message(_("Imported SPOT VEGETATION SM quality map <%s>.") % smfile)
- grass.message(_("Note: A snow map can be extracted by category 252 (d.rast %s cat=252)") % smfile)
- grass.message("")
- grass.message(_("Filtering NDVI map by Status Map quality layer..."))
+ grass.message(_("Imported SPOT VEGETATION SM quality map <%s>.") % smfile)
+ grass.message(_("Note: A snow map can be extracted by category 252 (d.rast %s cat=252)") % smfile)
+ grass.message("")
+ grass.message(_("Filtering NDVI map by Status Map quality layer..."))
- filtfile = "%s_filt" % name
- grass.mapcalc("$filtfile = if($smfile >= 248, $name, null())",
- filtfile = filtfile, smfile = smfile, name = name)
- grass.run_command('r.colors', map = filtfile, color = 'ndvi', quiet = True)
- grass.message(_("Filtered SPOT VEGETATION NDVI map <%s>.") % filtfile)
+ filtfile = "%s_filt" % name
+ grass.mapcalc("$filtfile = if($smfile % 4 == 3 || ($smfile / 16) % 16 == 0, null(), $name)",
+ filtfile = filtfile, smfile = smfile, name = name)
+ grass.run_command('r.colors', map = filtfile, color = 'ndvi', quiet = True)
+ grass.message(_("Filtered SPOT VEGETATION NDVI map <%s>.") % filtfile)
- # write cmd history:
- grass.raster_history(name)
- grass.raster_history(smfile)
- grass.raster_history(filtfile)
+ grass.raster_history(smfile)
+ grass.raster_history(filtfile)
grass.message(_("Done."))
