[GRASS-SVN] r47854 -
grass/branches/releasebranch_6_4/scripts/i.in.spotvgt
svn_grass at osgeo.org
Tue Aug 23 10:35:47 EDT 2011
Author: mmetz
Date: 2011-08-23 07:35:47 -0700 (Tue, 23 Aug 2011)
New Revision: 47854
grass/branches/releasebranch_6_4/scripts/i.in.spotvgt/description.html
grass/branches/releasebranch_6_4/scripts/i.in.spotvgt/i.in.spotvgt
update link for Status Map FAQ
Modified: grass/branches/releasebranch_6_4/scripts/i.in.spotvgt/description.html
--- grass/branches/releasebranch_6_4/scripts/i.in.spotvgt/description.html 2011-08-23 14:34:30 UTC (rev 47853)
+++ grass/branches/releasebranch_6_4/scripts/i.in.spotvgt/description.html 2011-08-23 14:35:47 UTC (rev 47854)
@@ -42,7 +42,7 @@
<a href="http://free.vgt.vito.be/">SPOT Vegetation (1km, global) NDVI data set server</a><br>
<a href="http://www.vgt.vito.be/faq/faq.html">SPOT Vegetation FAQ</a><br>
-<a href="http://www.vgt.vito.be/faq/FAQS/faq15.html">SPOT Vegetation Status Map (SM)</a> - Quality map
+<a href="http://nieuw.vgt.vito.be/faq/FAQS/faq22.html">SPOT Vegetation Status Map (SM)</a> - Quality map
<h2>AUTHOR</h2>
Modified: grass/branches/releasebranch_6_4/scripts/i.in.spotvgt/i.in.spotvgt
--- grass/branches/releasebranch_6_4/scripts/i.in.spotvgt/i.in.spotvgt 2011-08-23 14:34:30 UTC (rev 47853)
+++ grass/branches/releasebranch_6_4/scripts/i.in.spotvgt/i.in.spotvgt 2011-08-23 14:35:47 UTC (rev 47854)
@@ -248,7 +248,7 @@
# second, optionally process the SM quality map:
#SM Status Map
-# http://www.vgt.vito.be/faq/FAQS/faq15.html
+# http://nieuw.vgt.vito.be/faq/FAQS/faq22.html
#Data about
# Bit NR 7: Radiometric quality for B0 coded as 0 if bad and 1 if good
# Bit NR 6: Radiometric quality for B2 coded as 0 if bad and 1 if good
