[GRASS-SVN] r47864 -
grass/branches/develbranch_6/raster3d/r3.out.vtk
svn_grass at osgeo.org
Tue Aug 23 18:12:17 EDT 2011
Author: neteler
Date: 2011-08-23 15:12:17 -0700 (Tue, 23 Aug 2011)
New Revision: 47864
grass/branches/develbranch_6/raster3d/r3.out.vtk/main.c
more msg cosmetics
Modified: grass/branches/develbranch_6/raster3d/r3.out.vtk/main.c
--- grass/branches/develbranch_6/raster3d/r3.out.vtk/main.c 2011-08-23 22:08:09 UTC (rev 47863)
+++ grass/branches/develbranch_6/raster3d/r3.out.vtk/main.c 2011-08-23 22:12:17 UTC (rev 47864)
@@ -115,7 +115,6 @@
if (param.structgrid->answer) {
if (!param.top->answer || !param.bottom->answer)
- G3d_fatalError(_("You have to specify top and bottom map"));
G3d_fatalError(_("Specify top and bottom map"));
mapset = NULL;
@@ -207,7 +206,7 @@
®ion, G3D_TILE_SAME_AS_FILE,
G3D_USE_CACHE_DEFAULT);
if (maprgb == NULL) {
- G_warning(_("Unable to open 3D raster map <%s>"),
+ G_warning(_("Unable to open 3D raster map <%s>"),
param.rgbmaps->answers[i]);
fatal_error(_("No RGB Data will be created"), in);
@@ -339,7 +338,7 @@
if (!G3d_closeCell(mapvect)) {
fatal_error(_("Unable to close 3D raster map"), in);
- /*Set the pointer to null so we noe later that these files are already closed */
+ /*Set the pointer to null so we know later that these files are already closed */
if (i == 0)
in->map_x = NULL;
if (i == 1)
@@ -376,7 +375,7 @@
module = G_define_module();
module->keywords = _("raster3d, voxel, export");
module->description =
- _("Converts 3D raster maps (G3D) into the VTK-Ascii format");
+ _("Converts 3D raster maps into the VTK-ASCII format.");
/* Get parameters from user */
set_params();
@@ -487,12 +486,12 @@
if (G_close_cell(in->top) < 0) {
- G_fatal_error(_("unable to close top raster map"));
+ G_fatal_error(_("Unable to close top raster map"));
in->top = -1;
if (G_close_cell(in->bottom) < 0) {
- G_fatal_error(_("unable to close bottom raster map"));
+ G_fatal_error(_("Unable to close bottom raster map"));
in->bottom = -1;
