[GRASS-SVN] r47868 - grass/trunk/vector/v.colors.out
svn_grass at osgeo.org
Wed Aug 24 08:25:23 EDT 2011
Author: martinl
Date: 2011-08-24 05:25:23 -0700 (Wed, 24 Aug 2011)
New Revision: 47868
grass/trunk/vector/v.colors.out/main.c
v.colors.out: check if color table is defined
Modified: grass/trunk/vector/v.colors.out/main.c
--- grass/trunk/vector/v.colors.out/main.c 2011-08-24 11:00:24 UTC (rev 47867)
+++ grass/trunk/vector/v.colors.out/main.c 2011-08-24 12:25:23 UTC (rev 47868)
@@ -37,6 +37,7 @@
} flag;
struct Colors cat_colors, *colors;
+ int ret;
int min, max;
const char *file, *name, *layer, *column;
FILE *fp;
@@ -78,10 +79,16 @@
file = opt.file->answer;
column = opt.col->answer;
- if (Vect_read_colors(name, "", &cat_colors) < 0)
+ ret = Vect_read_colors(name, "", &cat_colors);
+ if (ret < 0)
G_fatal_error(_("Unable to read color table for vector map <%s>"),
opt.map->answer);
+ if (ret == 0) {
+ G_warning(_("No color table defined for vector map <%s>"),
+ opt.map->answer);
+ exit(EXIT_SUCCESS);
min = max = -1;
if (flag.p->answer) {
scan_cats(name, layer, &min, &max);
