[GRASS-SVN] r47879 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Thu Aug 25 06:42:08 EDT 2011
Author: martinl
Date: 2011-08-25 03:42:08 -0700 (Thu, 25 Aug 2011)
New Revision: 47879
grass/trunk/lib/vector/Vlib/build_ogr.c
vlib: formatting issues in build_ogr.c
Modified: grass/trunk/lib/vector/Vlib/build_ogr.c
--- grass/trunk/lib/vector/Vlib/build_ogr.c 2011-08-25 10:41:19 UTC (rev 47878)
+++ grass/trunk/lib/vector/Vlib/build_ogr.c 2011-08-25 10:42:08 UTC (rev 47879)
@@ -52,8 +52,7 @@
- \brief
- Reset parts
+ \brief Reset parts
static void reset_parts(GEOM_PARTS * parts)
@@ -240,7 +239,7 @@
OGR_G_GetZ(hRing, i));
- /* register line */
+ /* register boundary */
add_part(parts, iPart);
line = add_line(Map, GV_BOUNDARY, Points[iPart], FID, parts);
del_part(parts);
@@ -275,10 +274,9 @@
/* create virtual centroid */
- ret =
- Vect_get_point_in_poly_isl((const struct line_pnts *) Points[0],
- (const struct line_pnts **) Points + 1, nRings - 1,
- &x, &y);
+ ret = Vect_get_point_in_poly_isl((const struct line_pnts *) Points[0],
+ (const struct line_pnts **) Points + 1,
+ nRings - 1, &x, &y);
if (ret < -1) {
G_warning(_("Unable to calculate centroid for area %d"),
outer_area);
