[GRASS-SVN] r47891 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Fri Aug 26 08:39:45 EDT 2011
Author: annakrat
Date: 2011-08-26 05:39:45 -0700 (Fri, 26 Aug 2011)
New Revision: 47891
grass/trunk/gui/wxpython/gui_modules/colorrules.py
grass/trunk/gui/wxpython/gui_modules/layertree.py
wxGUI: fix apply in vector color rules dialog when attribute column is used
Modified: grass/trunk/gui/wxpython/gui_modules/colorrules.py
--- grass/trunk/gui/wxpython/gui_modules/colorrules.py 2011-08-26 12:04:55 UTC (rev 47890)
+++ grass/trunk/gui/wxpython/gui_modules/colorrules.py 2011-08-26 12:39:45 UTC (rev 47891)
@@ -528,8 +528,10 @@
@return True on success otherwise False
ret = self.CreateColorTable()
- if not self.colorTable:
- self.UseAttrColumn()
+ if self.colorTable:
+ self.UseAttrColumn(False)
+ else:
+ self.UseAttrColumn(True)
if ret:
display = self.parent.GetLayerTree().GetMapDisplay()
if display and display.IsAutoRendered():
@@ -1529,27 +1531,29 @@
cmd = 'v.colors'
ColorTable.RunHelp(self, cmd = cmd)
- def UseAttrColumn(self, useAttrColumn = True):
- """!Use attribute column to render map"""
- # TODO switch back to table, not only selected map
- layer = self.parent.curr_page.maptree.layer_selected
- if layer and self.parent.curr_page.maptree.GetPyData(layer)[0]['maplayer'].GetName() == self.inmap:
-## cmd = self.parent.curr_page.maptree.GetPyData(layer)[0]['maplayer'].GetCmd()
-## if useAttrColumn:
-## cmd[1].update({'flags': 'a', })
- cmdlist = ['d.vect',
- '-a',
- 'map=%s' % self.inmap,
- 'type=point,line,boundary,area']
+ def UseAttrColumn(self, useAttrColumn):
+ """!Find layers and apply the changes in d.vect command"""
+ layers = self.parent.curr_page.maptree.FindItemByData(key = 'name', value = self.inmap)
+ if not layers:
+ return
+ for layer in layers:
+ if self.parent.curr_page.maptree.GetPyData(layer)[0]['type'] != 'vector':
+ continue
+ cmdlist = self.parent.curr_page.maptree.GetPyData(layer)[0]['maplayer'].GetCmd()
if self.attributeType == 'color':
- cmdlist.append('rgb_column=%s' % self.properties['storeColumn'])
+ if useAttrColumn:
+ cmdlist[1].update({'flags': 'a'})
+ cmdlist[1].update({'rgb_column': self.properties['storeColumn']})
+ else:
+ if 'flags' in cmdlist[1]:
+ cmdlist[1]['flags'] = cmdlist[1]['flags'].replace('a', '')
+ cmdlist[1].pop('rgb_column', None)
elif self.attributeType == 'size':
- cmdlist.append('size_column=%s' % self.properties['storeColumn'])
+ cmdlist[1].update({'size_column': self.properties['storeColumn']})
elif self.attributeType == 'width':
- cmdlist.append('width_column=%s' % self.properties['storeColumn'])
- self.parent.curr_page.maptree.GetPyData(layer)[0]['maplayer'].SetCmd(cmdlist)
+ cmdlist[1].update({'width_column' :self.properties['storeColumn']})
+ self.parent.curr_page.maptree.GetPyData(layer)[0]['cmd'] = cmdlist
def CreateColorTable(self, tmp = False):
"""!Create color rules (color table or color column)"""
Modified: grass/trunk/gui/wxpython/gui_modules/layertree.py
--- grass/trunk/gui/wxpython/gui_modules/layertree.py 2011-08-26 12:04:55 UTC (rev 47890)
+++ grass/trunk/gui/wxpython/gui_modules/layertree.py 2011-08-26 12:39:45 UTC (rev 47891)
@@ -1561,13 +1561,18 @@
# self.Map.Clean()
def FindItemByData(self, key, value):
- """!Find item based on key and value (see PyData[0])
+ """!Find item based on key and value (see PyData[0]).
+ If key is 'name', finds item(s) of given maplayer name.
@return item instance
@return None not found
item = self.GetFirstChild(self.root)[0]
- return self.__FindSubItemByData(item, key, value)
+ if key == 'name':
+ return self.__FindSubItemByName(item, value)
+ else:
+ return self.__FindSubItemByData(item, key, value)
def FindItemByIndex(self, index):
"""!Find item by index (starting at 0)
@@ -1597,7 +1602,7 @@
item = self.GetNextSibling(item)
def __FindSubItemByData(self, item, key, value):
- """!Support method for FindItemByValue"""
+ """!Support method for FindItemByData"""
while item and item.IsOk():
try:
itemValue = self.GetPyData(item)[0][key]
@@ -1615,3 +1620,24 @@
return None
+ def __FindSubItemByName(self, item, value):
+ """!Support method for FindItemByData for searching by name"""
+ items = []
+ while item and item.IsOk():
+ try:
+ itemLayer = self.GetPyData(item)[0]['maplayer']
+ except KeyError:
+ return None
+ if value == itemLayer.GetName():
+ items.append(item)
+ if self.GetPyData(item)[0]['type'] == 'group':
+ subItem = self.GetFirstChild(item)[0]
+ found = self.__FindSubItemByName(subItem, name)
+ if found:
+ items.extend(found)
+ item = self.GetNextSibling(item)
+ if items:
+ return items
+ return None
