[GRASS-SVN] r47909 - grass/trunk/display/d.vect
Sat Aug 27 11:23:20 EDT 2011
Author: martinl
Date: 2011-08-27 08:23:20 -0700 (Sat, 27 Aug 2011)
New Revision: 47909
   grass/trunk/display/d.vect/label.c
   grass/trunk/display/d.vect/lines.c
d.vect: fix showing cats for OGR layers (centroids from topo)
Modified: grass/trunk/display/d.vect/label.c
--- grass/trunk/display/d.vect/label.c	2011-08-27 14:21:55 UTC (rev 47908)
+++ grass/trunk/display/d.vect/label.c	2011-08-27 15:23:20 UTC (rev 47909)
@@ -5,86 +5,133 @@
 #include "local_proto.h"
 #include "plot.h"
+static int process_line(int, const struct line_pnts *,
+			const struct line_cats *, LATTR *,
+			int, const struct cat_list *);
 int display_label(struct Map_info *Map, int type,
 		  struct cat_list *Clist, LATTR *lattr, int chcat)
-    int i, ltype;
+    int ltype;
     struct line_pnts *Points;
     struct line_cats *Cats;
-    int cat;
-    char text[100];
+    int ogr_centroids;
     Points = Vect_new_line_struct();
     Cats = Vect_new_cats_struct();
     Vect_rewind(Map);
-    while (1) {
+    ogr_centroids = FALSE;
+    if (Vect_maptype(Map) == GV_FORMAT_OGR) {
+	if (Vect_level(Map) < 2)
+	    G_warning(_("Topology level required for drawing centroids "
+			"for OGR layers"));
+	else if (Vect_get_num_primitives(Map, GV_CENTROID) > 0 &&
+		 type & GV_CENTROID)
+	    /* label centroids from topo, don't label boundaries */
+	    ogr_centroids = TRUE;
+    while (TRUE) {
 	ltype = Vect_read_next_line(Map, Points, Cats);
-	switch (ltype) {
-	case -1:
-	  G_fatal_error(_("Unable to read vector map"));
-	case -2:		/* EOF */
-	    return 0;
+	if (ltype == -1)
+	    G_fatal_error(_("Unable to read vector map"));
+	else if (ltype == -2) /* EOF */
+	    break;
 	if (!(type & ltype))
 	    continue;		/* used for both lines and labels */
+	if (ogr_centroids && ltype == GV_BOUNDARY)
+	    /* do not label boundaries */
+	    continue;
-	D_RGB_color(lattr->color.R, lattr->color.G, lattr->color.B);
-	D_text_size(lattr->size, lattr->size);
-	if (lattr->font)
-	    D_font(lattr->font);
-	if (lattr->enc)
-	    D_encoding(lattr->enc);
+	process_line(ltype, Points, Cats, lattr, chcat, Clist);
-	if (chcat) {
-	    int found = 0;
+    if (ogr_centroids) {
+	/* show label for centroids stored in topo (for OGR layers
+	   only) */
+	int line, nlines;
+	struct bound_box box;
+	struct boxlist *list;
+	list = Vect_new_boxlist(FALSE); /* bboxes not needed */
+	Vect_get_constraint_box(Map, &box);
+	nlines = Vect_select_lines_by_box(Map, &box, GV_CENTROID, list);
+	G_debug(0, "ncentroids (ogr) = %d", nlines);
+	for (line = 0; line < nlines; line++) {
+	    ltype = Vect_read_line(Map, Points, Cats, list->id[line]);
+	Vect_destroy_boxlist(list);
-	    for (i = 0; i < Cats->n_cats; i++) {
-		if (Cats->field[i] == Clist->field &&
-		    Vect_cat_in_cat_list(Cats->cat[i], Clist)) {
-		    found = 1;
-		    break;
+    Vect_destroy_line_struct(Points);
+    Vect_destroy_cats_struct(Cats);
+    return 0;
+int process_line(int ltype, const struct line_pnts *Points,
+		 const struct line_cats *Cats, LATTR *lattr,
+		 int chcat, const struct cat_list *Clist)
+    int i, cat;
+    char text[100];
+    D_RGB_color(lattr->color.R, lattr->color.G, lattr->color.B);
+    D_text_size(lattr->size, lattr->size);
+    if (lattr->font)
+	D_font(lattr->font);
+    if (lattr->enc)
+	D_encoding(lattr->enc);
+    if (chcat) {
+	int found = 0;
+	for (i = 0; i < Cats->n_cats; i++) {
+	    if (Cats->field[i] == Clist->field &&
+		Vect_cat_in_cat_list(Cats->cat[i], Clist)) {
+		found = 1;
+		break;
-	    if (!found)
-		continue;
-	else if (Clist->field > 0) {
-	    int found = 0;
-		if (Cats->field[i] == Clist->field) {
-		    found = 1;
-		    break;
+	if (!found)
+	    return 0;
+    else if (Clist->field > 0) {
+	int found = 0;
+	    if (Cats->field[i] == Clist->field) {
+		found = 1;
+		break;
-	    /* lines with no category will be displayed */
-	    if (Cats->n_cats > 0 && !found)
-		continue;
-	if (Vect_cat_get(Cats, lattr->field, &cat)) {
-	    text[0] = '\0';
-		G_debug(3, "cat lab: field = %d, cat = %d", Cats->field[i],
-			Cats->cat[i]);
-		if (Cats->field[i] == lattr->field) {	/* all cats of given lfield */
-		    if (*text != '\0')
-			sprintf(text, "%s/", text);
-		    sprintf(text, "%s%d", text, Cats->cat[i]);
+	/* lines with no category will be displayed */
+	if (Cats->n_cats > 0 && !found)
+	    return 0;
+    if (Vect_cat_get(Cats, lattr->field, &cat)) {
+	text[0] = '\0';
+	    G_debug(3, "cat lab: field = %d, cat = %d", Cats->field[i],
+		    Cats->cat[i]);
+	    if (Cats->field[i] == lattr->field) {	/* all cats of given lfield */
+		if (*text != '\0')
+		    sprintf(text, "%s/", text);
+		sprintf(text, "%s%d", text, Cats->cat[i]);
-	    show_label_line(Points, ltype, lattr, text);
+	show_label_line(Points, ltype, lattr, text);
-    Vect_destroy_line_struct(Points);
-    Vect_destroy_cats_struct(Cats);
-    return 0;
+    return 1;
 void show_label(double *px, double *py, LATTR *lattr, const char *text)
@@ -141,7 +188,8 @@
     D_text(text);
-void show_label_line(const struct line_pnts *Points, int ltype, LATTR *lattr, const char *text)
+void show_label_line(const struct line_pnts *Points, int ltype, LATTR *lattr,
+		     const char *text)
     double X, Y;
Modified: grass/trunk/display/d.vect/lines.c
--- grass/trunk/display/d.vect/lines.c	2011-08-27 14:21:55 UTC (rev 47908)
+++ grass/trunk/display/d.vect/lines.c	2011-08-27 15:23:20 UTC (rev 47909)
@@ -6,12 +6,13 @@
 #include <grass/raster.h>
 #include <grass/vector.h>
 #include <grass/display.h>
-#include "plot.h"
-#include "local_proto.h"
 #include <grass/symbol.h>
 #include <grass/glocale.h>
 #include <grass/dbmi.h>
+#include "plot.h"
+#include "local_proto.h"
 int palette_ncolors = 16;
 struct rgb_color palette[16] = {
@@ -157,13 +158,14 @@
 	/* centroids are stored in topology for OGR layers */
 	if (Vect_level(Map) >= 2) {
-	    if (Vect_get_num_primitives(Map, GV_CENTROID) > 0) {
+	    if (type & GV_CENTROID &&
+		Vect_get_num_primitives(Map, GV_CENTROID) > 0) {
 		int nlines;
-		Vect_get_map_box(Map, &box);
 		G_debug(3, "ncentroids (ogr) = %d", nlines);
