[GRASS-SVN] r47918 - in grass/trunk: gui/wxpython/gui_modules
gui/wxpython/icons include lib/ogsf
svn_grass at osgeo.org
Sun Aug 28 09:09:05 EDT 2011
Author: annakrat
Date: 2011-08-28 06:09:05 -0700 (Sun, 28 Aug 2011)
New Revision: 47918
grass/trunk/gui/wxpython/gui_modules/mapdisp.py
grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
grass/trunk/gui/wxpython/gui_modules/preferences.py
grass/trunk/gui/wxpython/gui_modules/toolbars.py
grass/trunk/gui/wxpython/gui_modules/wxnviz.py
grass/trunk/gui/wxpython/icons/icon.py
grass/trunk/include/ogsf_proto.h
grass/trunk/lib/ogsf/GS2.c
wxNviz: view history
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2011-08-28 08:51:14 UTC (rev 47917)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2011-08-28 13:09:05 UTC (rev 47918)
@@ -368,7 +368,10 @@
if '3D' in self._layerManager.gm_cb.GetPage(page).maptree.mapdisplay.toolbars['map'].combo.GetString(1):
self._layerManager.gm_cb.GetPage(page).maptree.mapdisplay.toolbars['map'].combo.Delete(1)
self.toolbars['map'].Enable2D(False)
+ # add rotate tool to map toolbar
+ self.toolbars['map'].InsertTool((('rotate', Icons['nviz']['rotate'],
+ self.OnRotate, wx.ITEM_CHECK,7),)) # 7 is position
+ self.toolbars['map'].ChangeToolsDesc(mode2d = False)
# update status bar
self.statusbarWin['toggle'].Enable(False)
@@ -401,6 +404,7 @@
self.MapWindow3D.OnPaint(None) # -> LoadData
self.MapWindow3D.Show()
+ self.MapWindow3D.ResetViewHistory()
self.MapWindow3D.UpdateView(None)
else:
self.MapWindow = self.MapWindow3D
@@ -416,7 +420,7 @@
# add Nviz notebookpage
self._layerManager.AddNvizTools()
for page in ('view', 'light', 'fringe', 'constant', 'cplane'):
self._layerManager.nviz.UpdatePage(page)
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py 2011-08-28 08:51:14 UTC (rev 47917)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py 2011-08-28 13:09:05 UTC (rev 47918)
@@ -103,6 +103,9 @@
self.cplanes = list()
# list of query points
self.qpoints = list()
+ # list of past views
+ self.viewhistory = []
+ self.saveHistory = False
# overlays
self.overlays = {}
self.imagedict = {}
@@ -352,46 +355,24 @@
def OnMouseWheel(self, event):
"""!Change perspective"""
wheel = event.GetWheelRotation()
- current = event.GetPositionTuple()[:]
Debug.msg (5, "GLWindow.OnMouseMotion(): wheel = %d" % wheel)
- prev_value = self.view['persp']['value']
- if wheel > 0:
- value = -1 * self.view['persp']['step']
- else:
- value = self.view['persp']['step']
- self.view['persp']['value'] += value
- if self.view['persp']['value'] < 1:
- self.view['persp']['value'] = 1
- elif self.view['persp']['value'] > 180:
- self.view['persp']['value'] = 180
- if prev_value != self.view['persp']['value']:
- if hasattr(self.lmgr, "nviz"):
- self.lmgr.nviz.UpdateSettings()
- self._display.SetView(self.view['position']['x'], self.view['position']['y'],
- self.iview['height']['value'],
- self.view['persp']['value'],
- self.view['twist']['value'])
+ self.DoZoom(zoomtype = wheel, pos = event.GetPositionTuple())
- # redraw map
- self.DoPaint()
+ # update statusbar
+ ### self.parent.StatusbarUpdate()
- # update statusbar
- ### self.parent.StatusbarUpdate()
def OnLeftDown(self, event):
"""!On left mouse down"""
self.mouse['begin'] = event.GetPositionTuple()
self.mouse['tmp'] = event.GetPositionTuple()
if self.mouse['use'] == "lookHere":
- pos = event.GetPosition()
size = self.GetClientSize()
- self._display.LookHere(pos[0], size[1] - pos[1])
- self.Refresh(False)
+ self._display.LookHere(self.mouse['begin'][0], size[1] - self.mouse['begin'][1])
focus = self._display.GetFocus()
for i, coord in enumerate(('x', 'y', 'z')):
self.iview['focus'][coord] = focus[i]
+ self.saveHistory = True
+ self.Refresh(False)
toggle = self.lmgr.nviz.FindWindowByName('here')
toggle.SetValue(False)
self.mouse['use'] = 'pointer'
@@ -467,7 +448,40 @@
return (x, y)
+ def DoZoom(self, zoomtype, pos):
+ """!Change perspective and focus"""
+ prev_value = self.view['persp']['value']
+ if zoomtype > 0:
+ value = -1 * self.view['persp']['step']
+ else:
+ value = self.view['persp']['step']
+ self.view['persp']['value'] += value
+ if self.view['persp']['value'] < 1:
+ self.view['persp']['value'] = 1
+ elif self.view['persp']['value'] > 180:
+ self.view['persp']['value'] = 180
+ if prev_value != self.view['persp']['value']:
+ if hasattr(self.lmgr, "nviz"):
+ self.lmgr.nviz.UpdateSettings()
+ x, y = pos[0], self.GetClientSize()[1] - pos[1]
+ result = self._display.GetPointOnSurface(x, y)
+ if result[0]:
+ self._display.LookHere(x, y)
+ focus = self._display.GetFocus()
+ for i, coord in enumerate(('x', 'y', 'z')):
+ self.iview['focus'][coord] = focus[i]
+ self._display.SetView(self.view['position']['x'], self.view['position']['y'],
+ self.iview['height']['value'],
+ self.view['persp']['value'],
+ self.view['twist']['value'])
+ # redraw map
+ self.DoPaint()
def OnLeftUp(self, event):
+ self.mouse['end'] = event.GetPositionTuple()
if self.mouse["use"] == "query":
layers = self.GetSelectedLayer(multi = True)
@@ -500,9 +514,13 @@
elif self.mouse['use'] == 'rotate':
self._display.UnsetRotation()
+ self.iview['rotation'] = self._display.GetRotationMatrix()
self.render['quick'] = False
self.Refresh(False)
+ elif self.mouse['use'] == 'zoom':
+ self.DoZoom(zoomtype = self.zoomtype, pos = self.mouse['end'])
event.Skip()
def OnDClick(self, event):
@@ -547,7 +565,66 @@
self.pdc.DrawToDC(dc)
del odc
self.mouse['tmp'] = (event.GetX(), event.GetY())
+ def ZoomBack(self):
+ """!Set previous view in history list
+ view = {}
+ if len(self.viewhistory) > 1:
+ self.viewhistory.pop()
+ view = copy.deepcopy(self.viewhistory[-1])
+ # disable tool if stack is empty
+ if len(self.viewhistory) < 2: # disable tool
+ toolbar = self.parent.toolbars['map']
+ toolbar.Enable('zoomback', enable = False)
+ # set view and update nviz view page
+ self.lmgr.nviz.UpdateState(view = view[0], iview = view[1])
+ self.lmgr.nviz.UpdatePage('view')
+ # update map
+ def ViewHistory(self, view, iview):
+ """!Manages a list of last 10 views
+ @param view view dictionary
+ @param iview view dictionary (internal)
+ @return removed history item if exists (or None)
+ removed = None
+ hview = copy.deepcopy(view)
+ hiview = copy.deepcopy(iview)
+ if not (self.viewhistory and self.viewhistory[-1] == (hview, hiview)):
+ self.viewhistory.append((hview, hiview))
+ if len(self.viewhistory) > 10:
+ removed = self.viewhistory.pop(0)
+ if removed:
+ Debug.msg(4, "GLWindow.ViewHistory(): hist=%s, removed=%s" %
+ (self.viewhistory, removed))
+ else:
+ Debug.msg(4, "GLWindow.ViewHistory(): hist=%s" %
+ (self.viewhistory))
+ # update toolbar
+ enable = True
+ else:
+ enable = False
+ toolbar.Enable('zoomback', enable)
+ return removed
+ def ResetViewHistory(self):
+ """!Reset view history"""
+ self.viewhistory = list()
def OnQuerySurface(self, event):
"""!Query surface on given position"""
size = self.GetClientSizeTuple()
@@ -599,19 +676,27 @@
def UpdateView(self, event):
"""!Change view settings"""
data = self.view
+ ## multiple z-exag value from slider by original value computed in ogsf so it scales
+ ## correctly with maps of different height ranges
+ if event and event.zExag and 'value' in data['z-exag']:
+ self._display.SetZExag(self.iview['z-exag']['original'] * data['z-exag']['value'])
self._display.SetView(data['position']['x'], data['position']['y'],
data['persp']['value'],
data['twist']['value'])
- ## multiple z-exag value from slider by original value computed in ogsf so it scales
- ## correctly with maps of different height ranges
- if event and event.zExag and 'value' in data['z-exag']:
- self._display.SetZExag(self.iview['z-exag']['original'] * data['z-exag']['value'])
if self.iview['focus']['x'] != -1:
self._display.SetFocus(self.iview['focus']['x'], self.iview['focus']['y'],
self.iview['focus']['z'])
+ if 'rotation' in self.iview:
+ if self.iview['rotation']:
+ self._display.SetRotationMatrix(self.iview['rotation'])
+ else:
+ self._display.ResetRotation()
if event:
event.Skip()
@@ -644,6 +729,9 @@
if self.render['quick'] is False:
self.parent.statusbarWin['progress'].SetValue(1)
self._display.Draw(False, -1)
+ if self.saveHistory:
+ self.ViewHistory(view = self.view, iview = self.iview)
elif self.render['quick'] is True:
# quick
mode = wxnviz.DRAW_QUICK_SURFACE | wxnviz.DRAW_QUICK_VOLUME
@@ -1281,6 +1369,7 @@
self.view['twist']['value'] = UserSettings.Get(group = 'nviz', key = 'view',
subkey = ('twist', 'value'))
+ self.iview['rotation'] = None
self._display.LookAtCenter()
focus = self.iview['focus']
focus['x'], focus['y'], focus['z'] = self._display.GetFocus()
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_tools.py 2011-08-28 08:51:14 UTC (rev 47917)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_tools.py 2011-08-28 13:09:05 UTC (rev 47918)
@@ -2544,6 +2544,7 @@
focus = self.mapWindow.iview['focus']
+ self.mapWindow.saveHistory = True
self.mapWindow.Refresh(False)
elif name == 'top':
self.mapWindow.view['position']['x'] = 0.5
@@ -2559,7 +2560,7 @@
else:
self.mapWindow.mouse['use'] = 'default'
self.mapWindow.SetCursor(self.mapWindow.cursors['default'])
def OnResetView(self, event):
"""!Reset to default view (view page)"""
self.mapWindow.ResetView()
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py 2011-08-28 08:51:14 UTC (rev 47917)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py 2011-08-28 13:09:05 UTC (rev 47918)
@@ -707,6 +707,7 @@
self.internalSettings['nviz']['view']['height']['value'] = -1
self.internalSettings['nviz']['view']['z-exag'] = {}
self.internalSettings['nviz']['view']['z-exag']['original'] = 1
+ self.internalSettings['nviz']['view']['rotation'] = None
self.internalSettings['nviz']['view']['focus'] = {}
self.internalSettings['nviz']['view']['focus']['x'] = -1
self.internalSettings['nviz']['view']['focus']['y'] = -1
Modified: grass/trunk/gui/wxpython/gui_modules/toolbars.py
--- grass/trunk/gui/wxpython/gui_modules/toolbars.py 2011-08-28 08:51:14 UTC (rev 47917)
+++ grass/trunk/gui/wxpython/gui_modules/toolbars.py 2011-08-28 13:09:05 UTC (rev 47918)
@@ -333,6 +333,19 @@
self.parent._mgr.GetPane('mapToolbar').BestSize(self.GetBestSize())
self.parent._mgr.Update()
+ def ChangeToolsDesc(self, mode2d):
+ """!Change description of zoom tools for 2D/3D view"""
+ if mode2d:
+ set = 'displayWindow'
+ else:
+ set = 'nviz'
+ for i, data in enumerate(self._data):
+ for tool, toolname in (('zoomin', 'zoomIn'),('zoomout', 'zoomOut')):
+ if data[0] == tool:
+ tmp = list(data)
+ tmp[4] = Icons[set][toolname].GetDesc()
+ self._data[i] = tuple(tmp)
def OnSelectTool(self, event):
"""!Select / enable tool available in tools list
@@ -341,13 +354,10 @@
if tool == self.toolId['2d']:
self.ExitToolbars()
self.Enable2D(True)
+ self.ChangeToolsDesc(mode2d = True)
elif tool == self.toolId['3d'] and \
not (self.parent.MapWindow3D and self.parent.IsPaneShown('3d')):
- self.InsertTool((('rotate', Icons['nviz']['rotate'],
- self.parent.OnRotate,
- wx.ITEM_CHECK,7),)) # 7 is position
self.ExitToolbars()
self.parent.AddNviz()
@@ -367,9 +377,6 @@
def Enable2D(self, enabled):
"""!Enable/Disable 2D display mode specific tools"""
for tool in (self.pan,
- self.zoomin,
- self.zoomout,
- self.zoomback,
self.zoommenu,
self.analyze,
self.printmap):
Modified: grass/trunk/gui/wxpython/gui_modules/wxnviz.py
--- grass/trunk/gui/wxpython/gui_modules/wxnviz.py 2011-08-28 08:51:14 UTC (rev 47917)
+++ grass/trunk/gui/wxpython/gui_modules/wxnviz.py 2011-08-28 13:09:05 UTC (rev 47918)
@@ -1835,3 +1835,19 @@
def ResetRotation(self):
"""!Reset scene rotation"""
Nviz_init_rotation()
+ def GetRotationMatrix(self):
+ """!Get rotation matrix"""
+ matrix = (c_double * 16)()
+ GS_get_rotation_matrix(byref(matrix))
+ returnMatrix = []
+ for item in matrix:
+ returnMatrix.append(item)
+ return returnMatrix
+ def SetRotationMatrix(self, matrix):
+ """!Set rotation matrix"""
+ mtrx = (c_double * 16)()
+ for i in range(len(matrix)):
+ mtrx[i] = matrix[i]
+ GS_set_rotation_matrix(byref(mtrx))
Modified: grass/trunk/gui/wxpython/icons/icon.py
--- grass/trunk/gui/wxpython/icons/icon.py 2011-08-28 08:51:14 UTC (rev 47917)
+++ grass/trunk/gui/wxpython/icons/icon.py 2011-08-28 13:09:05 UTC (rev 47918)
@@ -333,9 +333,15 @@
desc = _('Settings dialog for georectification tool')),
'nviz' : {
- 'rotate': MetaIcon(img = iconSet.get('3d-rotate', wx.ART_ERROR),
+ 'rotate': MetaIcon(img = iconSet.get('3d-rotate', wx.ART_ERROR),
label = _('Rotate 3D scene'),
- desc = _('Drag with mouse to rotate 3D scene')),
+ desc = _('Drag with mouse to rotate 3D scene')),
+ 'zoomIn': MetaIcon(img = iconSet.get('zoom-in', wx.ART_ERROR),
+ label = _('Zoom in'),
+ desc = _('Click mouse to zoom')),
+ 'zoomOut': MetaIcon(img = iconSet.get('zoom-out', wx.ART_ERROR),
+ label = _('Zoom out'),
+ desc = _('Click mouse to unzoom')),
'nviz_cmd': MetaIcon(img = iconSet.get('script-save', wx.ART_ERROR),
label = _('Generate command for nviz_cmd'),
desc = _('Generate command for nviz_cmd based on current state')),
Modified: grass/trunk/include/ogsf_proto.h
--- grass/trunk/include/ogsf_proto.h 2011-08-28 08:51:14 UTC (rev 47917)
+++ grass/trunk/include/ogsf_proto.h 2011-08-28 13:09:05 UTC (rev 47918)
@@ -173,6 +173,8 @@
void GS_set_viewdir(float *);
void GS_set_fov(int);
void GS_set_rotation(double, double, double, double);
+void GS_get_rotation_matrix(double *);
+void GS_set_rotation_matrix(double *);
void GS_init_rotation(void);
void GS_unset_rotation(void);
int GS_get_fov(void);
Modified: grass/trunk/lib/ogsf/GS2.c
--- grass/trunk/lib/ogsf/GS2.c 2011-08-28 08:51:14 UTC (rev 47917)
+++ grass/trunk/lib/ogsf/GS2.c 2011-08-28 13:09:05 UTC (rev 47918)
@@ -2928,6 +2928,30 @@
+ * \brief Get rotation matrix
+void GS_get_rotation_matrix(double *matrix)
+ int i;
+ for (i = 0; i < 16; i++) {
+ matrix[i] = Gv.rotate.rotMatrix[i];
+ * \brief Set rotation matrix
+void GS_set_rotation_matrix(double *matrix)
+ int i;
+ Gv.rotate.rotMatrix[i] = matrix[i];
\brief Unset focus
void GS_set_nofocus(void)
