[GRASS-SVN] r47941 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Mon Aug 29 11:14:53 EDT 2011
Author: martinl
Date: 2011-08-29 08:14:53 -0700 (Mon, 29 Aug 2011)
New Revision: 47941
grass/trunk/lib/vector/Vlib/open_ogr.c
grass/trunk/lib/vector/Vlib/write_ogr.c
vlib/OGR: more create_table to V2_open_new_ogr()
Modified: grass/trunk/lib/vector/Vlib/open_ogr.c
--- grass/trunk/lib/vector/Vlib/open_ogr.c 2011-08-29 14:48:33 UTC (rev 47940)
+++ grass/trunk/lib/vector/Vlib/open_ogr.c 2011-08-29 15:14:53 UTC (rev 47941)
@@ -21,6 +21,7 @@
#include <sys/stat.h>
#include <grass/vector.h>
+#include <grass/dbmi.h>
#include <grass/gprojects.h>
#include <grass/glocale.h>
@@ -28,6 +29,9 @@
#include <ogr_api.h>
#include <cpl_string.h>
+static int sqltype_to_ogrtype(int);
+static int create_table(OGRLayerH, const struct field_info *);
\brief Open existing OGR layer (level 1 - without feature index file)
@@ -291,9 +295,11 @@
int V2_open_new_ogr(struct Map_info *Map, int type)
+ int ndblinks;
OGRLayerH Ogr_layer;
OGRSpatialReferenceH Ogr_spatial_ref;
+ struct field_info *Fi;
struct Key_Value *projinfo, *projunits;
OGRwkbGeometryType Ogr_geom_type;
@@ -345,9 +351,135 @@
Map->fInfo.ogr.layer = Ogr_layer;
+ ndblinks = Vect_get_num_dblinks(Map);
+ if (ndblinks > 0) {
+ /* write also attributes */
+ Fi = Vect_get_dblink(Map, 0);
+ if (Fi) {
+ if (ndblinks > 1)
+ G_warning(_("More layers defined, using driver <%s> and "
+ "database <%s>"), Fi->driver, Fi->database);
+ create_table(Map->fInfo.ogr.layer, Fi);
+ G_free(Fi);
+ else
+ G_warning(_("Database connection not defined. "
+ "Unable to write attributes."));
if (OGR_L_TestCapability(Map->fInfo.ogr.layer, OLCTransactions))
OGR_L_StartTransaction(Map->fInfo.ogr.layer);
return 0;
+int create_table(OGRLayerH hLayer, const struct field_info *Fi)
+ int col, ncols;
+ int sqltype, ogrtype, length;
+ const char *colname;
+ dbDriver *driver;
+ dbHandle handle;
+ dbCursor cursor;
+ dbTable *table;
+ dbColumn *column;
+ dbString sql;
+ OGRFieldDefnH hFieldDefn;
+ OGRFeatureDefnH hFeatureDefn;
+ db_init_string(&sql);
+ db_init_handle(&handle);
+ driver = db_start_driver(Fi->driver);
+ if (!driver) {
+ G_warning(_("Unable to start driver <%s>"), Fi->driver);
+ return -1;
+ db_set_handle(&handle, Fi->database, NULL);
+ if (db_open_database(driver, &handle) != DB_OK) {
+ G_warning(_("Unable to open database <%s> by driver <%s>"),
+ Fi->database, Fi->driver);
+ db_close_database_shutdown_driver(driver);
+ return -1;
+ /* to get no data */
+ db_set_string(&sql, "select * from ");
+ db_append_string(&sql, Fi->table);
+ db_append_string(&sql, " where 0 = 1");
+ if (db_open_select_cursor(driver, &sql, &cursor, DB_SEQUENTIAL) !=
+ DB_OK) {
+ G_warning(_("Unable to open select cursor: '%s'"),
+ db_get_string(&sql));
+ return -1;
+ table = db_get_cursor_table(&cursor);
+ ncols = db_get_table_number_of_columns(table);
+ hFeatureDefn = OGR_L_GetLayerDefn(hLayer);
+ for (col = 0; col < ncols; col++) {
+ column = db_get_table_column(table, col);
+ colname = db_get_column_name(column);
+ sqltype = db_get_column_sqltype(column);
+ ogrtype = sqltype_to_ogrtype(sqltype);
+ length = db_get_column_length(column);
+ if (strcmp(OGR_L_GetFIDColumn(hLayer), colname) == 0 ||
+ OGR_FD_GetFieldIndex(hFeatureDefn, colname) > -1) {
+ /* field already exists */
+ continue;
+ hFieldDefn = OGR_Fld_Create(colname, ogrtype);
+ /* GDAL 1.9.0 (r22968) uses VARCHAR instead of CHAR */
+ if (ogrtype == OFTString && length > 0)
+ OGR_Fld_SetWidth(hFieldDefn, length);
+ if (OGR_L_CreateField(hLayer, hFieldDefn, TRUE) != OGRERR_NONE) {
+ G_warning(_("Creating field <%s> failed"), colname);
+ return -1;
+ OGR_Fld_Destroy(hFieldDefn);
+ return 0;
+int sqltype_to_ogrtype(int sqltype)
+ int ctype, ogrtype;
+ ctype = db_sqltype_to_Ctype(sqltype);
+ switch(ctype) {
+ case DB_C_TYPE_INT:
+ ogrtype = OFTInteger;
+ break;
+ case DB_C_TYPE_DOUBLE:
+ ogrtype = OFTReal;
+ break;
+ case DB_C_TYPE_STRING:
+ ogrtype = OFTString;
+ break;
+ case DB_C_TYPE_DATETIME:
+ break;
+ default:
+ break;
+ return ogrtype;
#endif
Modified: grass/trunk/lib/vector/Vlib/write_ogr.c
--- grass/trunk/lib/vector/Vlib/write_ogr.c 2011-08-29 14:48:33 UTC (rev 47940)
+++ grass/trunk/lib/vector/Vlib/write_ogr.c 2011-08-29 15:14:53 UTC (rev 47941)
@@ -28,8 +28,7 @@
-static dbDriver *create_table(OGRLayerH, const struct field_info *);
-static int write_attributes(dbDriver *, int, const struct field_info *,
+static int write_attributes(int, const struct field_info *,
OGRLayerH, OGRFeatureH);
void V2__add_line_to_topo_ogr(struct Map_info *Map, int line,
@@ -61,8 +60,6 @@
- dbDriver *driver;
OGRGeometryH Ogr_geometry;
OGRFeatureH Ogr_feature;
OGRFeatureDefnH Ogr_featuredefn;
@@ -73,18 +70,18 @@
return -1;
- /* check for attributes */
- Fi = Vect_get_field(Map, cats->field[0]);
- driver = NULL;
- cat = -1; /* no attributes to be written */
- if (Fi && cats->n_cats > 0) {
- cat = cats->cat[0];
- if (cats->n_cats > 1) {
- G_warning(_("Feature has more categories, using "
- "category %d (from layer %d)"),
- cat, cats->field[0]);
+ cat = -1; /* no attributes to be written */
+ if (cats->n_cats > 0) {
+ /* check for attributes */
+ Fi = Vect_get_field(Map, cats->field[0]);
+ if (Fi) {
+ cat = cats->cat[0];
+ if (cats->n_cats > 1) {
+ G_warning(_("Feature has more categories, using "
+ "category %d (from layer %d)"),
+ cat, cats->field[0]);
- driver = create_table(Map->fInfo.ogr.layer, Fi);
Ogr_featuredefn = OGR_L_GetLayerDefn(Map->fInfo.ogr.layer);
@@ -168,10 +165,8 @@
OGR_F_SetGeometry(Ogr_feature, Ogr_geometry);
/* write attributes */
- if (driver && cat > -1) {
- write_attributes(driver, cat, Fi, Map->fInfo.ogr.layer, Ogr_feature);
- db_close_database_shutdown_driver(driver);
+ if (cat > -1)
+ write_attributes(cat, Fi, Map->fInfo.ogr.layer, Ogr_feature);
/* write feature into layer */
ret = OGR_L_CreateFeature(Map->fInfo.ogr.layer, Ogr_feature);
@@ -390,95 +385,17 @@
return ret;
-dbDriver *create_table(OGRLayerH hLayer, const struct field_info *Fi)
- int col, ncols;
- int sqltype, ogrtype, length;
- const char *colname;
- dbDriver *driver;
- dbHandle handle;
- dbCursor cursor;
- dbTable *table;
- dbColumn *column;
- dbString sql;
- OGRFieldDefnH hFieldDefn;
- OGRFeatureDefnH hFeatureDefn;
- db_init_string(&sql);
- db_init_handle(&handle);
- driver = db_start_driver(Fi->driver);
- if (!driver) {
- G_warning(_("Unable to start driver <%s>"), Fi->driver);
- return NULL;
- db_set_handle(&handle, Fi->database, NULL);
- if (db_open_database(driver, &handle) != DB_OK) {
- G_warning(_("Unable to open database <%s> by driver <%s>"),
- Fi->database, Fi->driver);
- return NULL;
- /* to get no data */
- db_set_string(&sql, "select * from ");
- db_append_string(&sql, Fi->table);
- db_append_string(&sql, " where 0 = 1");
- if (db_open_select_cursor(driver, &sql, &cursor, DB_SEQUENTIAL) !=
- DB_OK) {
- G_warning(_("Unable to open select cursor: '%s'"),
- db_get_string(&sql));
- return NULL;
- table = db_get_cursor_table(&cursor);
- ncols = db_get_table_number_of_columns(table);
- hFeatureDefn = OGR_L_GetLayerDefn(hLayer);
- for (col = 0; col < ncols; col++) {
- column = db_get_table_column(table, col);
- colname = db_get_column_name(column);
- sqltype = db_get_column_sqltype(column);
- ogrtype = sqltype_to_ogrtype(sqltype);
- length = db_get_column_length(column);
- if (strcmp(OGR_L_GetFIDColumn(hLayer), colname) == 0 ||
- OGR_FD_GetFieldIndex(hFeatureDefn, colname) > -1) {
- /* field already exists */
- continue;
- hFieldDefn = OGR_Fld_Create(colname, ogrtype);
- /* GDAL 1.9.0 (r22968) uses VARCHAR instead of CHAR */
- if (ogrtype == OFTString && length > 0)
- OGR_Fld_SetWidth(hFieldDefn, length);
- if (OGR_L_CreateField(hLayer, hFieldDefn, TRUE) != OGRERR_NONE) {
- G_warning(_("Creating field <%s> failed"), colname);
- return NULL;
- OGR_Fld_Destroy(hFieldDefn);
- return driver;
-int write_attributes(dbDriver *driver, int cat, const struct field_info *Fi,
+int write_attributes(int cat, const struct field_info *Fi,
OGRLayerH Ogr_layer, OGRFeatureH Ogr_feature)
int j, ogrfieldnum;
char buf[2000];
int ncol, sqltype, ctype, ogrtype, more;
const char *fidcol, *colname;
+ dbDriver *driver;
dbTable *table;
dbString dbstring;
+ dbHandle handle;
dbColumn *column;
dbCursor cursor;
dbValue *value;
@@ -488,12 +405,26 @@
G_debug(3, "write_attributes(): cat = %d", cat);
if (cat < 0) {
- G_warning ("Feature without category of layer %d", Fi->number);
+ G_warning(_("Feature without category of layer %d"), Fi->number);
return 0;
db_init_string(&dbstring);
+ if (!driver) {
+ return -1;
+ return -1;
/* read & set attributes */
sprintf(buf, "SELECT * FROM %s WHERE %s = %d", Fi->table, Fi->key,
cat);
@@ -578,6 +509,7 @@
db_close_cursor (&cursor);
db_free_string(&dbstring);
