[GRASS-SVN] r47943 - in grass/trunk: include/vect lib/vector/Vlib
Mon Aug 29 12:29:13 EDT 2011
Author: martinl
Date: 2011-08-29 09:29:13 -0700 (Mon, 29 Aug 2011)
New Revision: 47943
   grass/trunk/include/vect/dig_structs.h
   grass/trunk/lib/vector/Vlib/close_ogr.c
   grass/trunk/lib/vector/Vlib/open_ogr.c
   grass/trunk/lib/vector/Vlib/write_ogr.c
vlib: optimize writing attributes for OGR output
Modified: grass/trunk/include/vect/dig_structs.h
--- grass/trunk/include/vect/dig_structs.h	2011-08-29 16:27:30 UTC (rev 47942)
+++ grass/trunk/include/vect/dig_structs.h	2011-08-29 16:29:13 UTC (rev 47943)
@@ -24,9 +24,10 @@
 #include <grass/shapefil.h>
 #include <grass/rbtree.h>
 #include <grass/rtree.h>
+#include <grass/dbmi.h>
 #ifdef HAVE_OGR
-#include "ogr_api.h"
+#include <ogr_api.h>
 #endif
@@ -429,6 +430,14 @@
 #endif
+      \brief Open DB driver when writing attributes
+      This driver is open by V2_open_new_ogr() and closed by
+      V1_close_ogr().
+    dbDriver *dbdriver;
       \brief Array of OGR DSN options
     char **dsn_options;
Modified: grass/trunk/lib/vector/Vlib/close_ogr.c
--- grass/trunk/lib/vector/Vlib/close_ogr.c	2011-08-29 16:27:30 UTC (rev 47942)
+++ grass/trunk/lib/vector/Vlib/close_ogr.c	2011-08-29 16:29:13 UTC (rev 47943)
@@ -33,29 +33,36 @@
     int i;
+    struct Format_info_ogr *fInfo;
     if (!VECT_OPEN(Map))
 	return -1;
+    fInfo = &(Map->fInfo.ogr);
     if (Map->format != GV_FORMAT_OGR_DIRECT &&
 	(Map->mode == GV_MODE_WRITE || Map->mode == GV_MODE_RW))
 	Vect__write_head(Map);
-    if (Map->fInfo.ogr.feature_cache)
-	OGR_F_Destroy(Map->fInfo.ogr.feature_cache);
+    if (fInfo->feature_cache)
+	OGR_F_Destroy(fInfo->feature_cache);
-    OGR_DS_Destroy(Map->fInfo.ogr.ds);
+    OGR_DS_Destroy(fInfo->ds);
-    for (i = 0; i < Map->fInfo.ogr.lines_alloc; i++) {
-	Vect_destroy_line_struct(Map->fInfo.ogr.lines[i]);
+    for (i = 0; i < fInfo->lines_alloc; i++) {
+	Vect_destroy_line_struct(fInfo->lines[i]);
-    G_free(Map->fInfo.ogr.lines);
-    G_free(Map->fInfo.ogr.lines_types);
+    if (fInfo->dbdriver) {
+	db_close_database_shutdown_driver(fInfo->dbdriver);
-    G_free(Map->fInfo.ogr.driver_name);
-    G_free(Map->fInfo.ogr.dsn);
-    G_free(Map->fInfo.ogr.layer_name);
+    G_free(fInfo->lines);
+    G_free(fInfo->lines_types);
+    G_free(fInfo->driver_name);
+    G_free(fInfo->dsn);
+    G_free(fInfo->layer_name);
     return 0;
Modified: grass/trunk/lib/vector/Vlib/open_ogr.c
--- grass/trunk/lib/vector/Vlib/open_ogr.c	2011-08-29 16:27:30 UTC (rev 47942)
+++ grass/trunk/lib/vector/Vlib/open_ogr.c	2011-08-29 16:29:13 UTC (rev 47943)
@@ -30,7 +30,7 @@
 #include <cpl_string.h>
 static int sqltype_to_ogrtype(int);
-static int create_table(OGRLayerH, const struct field_info *);
+static dbDriver *create_table(OGRLayerH, const struct field_info *);
    \brief Open existing OGR layer (level 1 - without feature index file)
@@ -314,7 +314,9 @@
     projinfo  = G_get_projinfo();
     projunits = G_get_projunits();
     Ogr_spatial_ref = GPJ_grass_to_osr(projinfo, projunits);
+    G_free_key_value(projinfo);
+    G_free_key_value(projunits);
     switch(type) {
     case GV_POINT:
 	Ogr_geom_type = wkbPoint;
@@ -359,7 +361,7 @@
 	    if (ndblinks > 1)
 		G_warning(_("More layers defined, using driver <%s> and "
 			    "database <%s>"), Fi->driver, Fi->database);
-	    create_table(Map->fInfo.ogr.layer, Fi);
+	    Map->fInfo.ogr.dbdriver = create_table(Map->fInfo.ogr.layer, Fi);
 	    G_free(Fi);
 	else
@@ -373,7 +375,7 @@
     return 0;
-int create_table(OGRLayerH hLayer, const struct field_info *Fi)
+dbDriver *create_table(OGRLayerH hLayer, const struct field_info *Fi)
     int col, ncols;
     int sqltype, ogrtype, length;
@@ -396,14 +398,14 @@
     driver = db_start_driver(Fi->driver);
     if (!driver) {
 	G_warning(_("Unable to start driver <%s>"), Fi->driver);
-	return -1;
+	return NULL;
     db_set_handle(&handle, Fi->database, NULL);
     if (db_open_database(driver, &handle) != DB_OK) {
 	G_warning(_("Unable to open database <%s> by driver <%s>"),
 		  Fi->database, Fi->driver);
 	db_close_database_shutdown_driver(driver);
-	return -1;
+	return NULL;
     /* to get no data */
@@ -416,7 +418,7 @@
 	G_warning(_("Unable to open select cursor: '%s'"),
 		  db_get_string(&sql));
-	return -1;
+	return NULL;
     table = db_get_cursor_table(&cursor);
@@ -444,15 +446,13 @@
 	if (OGR_L_CreateField(hLayer, hFieldDefn, TRUE) != OGRERR_NONE) {
 	    G_warning(_("Creating field <%s> failed"), colname);
-	    return -1;
+	    return NULL;
 	OGR_Fld_Destroy(hFieldDefn);
-    db_close_database_shutdown_driver(driver);
-    return 0;
+    return driver;
 int sqltype_to_ogrtype(int sqltype)
Modified: grass/trunk/lib/vector/Vlib/write_ogr.c
--- grass/trunk/lib/vector/Vlib/write_ogr.c	2011-08-29 16:27:30 UTC (rev 47942)
+++ grass/trunk/lib/vector/Vlib/write_ogr.c	2011-08-29 16:29:13 UTC (rev 47943)
@@ -28,7 +28,7 @@
-static int write_attributes(int, const struct field_info *,
+static int write_attributes(dbDriver *, int, const struct field_info *,
 			    OGRLayerH, OGRFeatureH);
 void V2__add_line_to_topo_ogr(struct Map_info *Map, int line,
@@ -73,9 +73,10 @@
     cat = -1; /* no attributes to be written */
     if (cats->n_cats > 0) {
 	/* check for attributes */
-	Fi = Vect_get_field(Map, cats->field[0]);
+	Fi = Vect_get_dblink(Map, 0);
 	if (Fi) {
-	    cat = cats->cat[0];
+	    if (!Vect_cat_get(cats, Fi->number, &cat))
+		G_warning(_("No category defined for layer %d"), Fi->number);
 	    if (cats->n_cats > 1) {
 		G_warning(_("Feature has more categories, using "
 			    "category %d (from layer %d)"),
@@ -165,9 +166,11 @@
     OGR_F_SetGeometry(Ogr_feature, Ogr_geometry);
     /* write attributes */
-    if (cat > -1)
-	write_attributes(cat, Fi, Map->fInfo.ogr.layer, Ogr_feature);
+    if (cat > -1 && Map->fInfo.ogr.dbdriver) {
+	write_attributes(Map->fInfo.ogr.dbdriver,
+			 cat, Fi, Map->fInfo.ogr.layer, Ogr_feature);
+	G_free(Fi);
     /* write feature into layer */
     ret = OGR_L_CreateFeature(Map->fInfo.ogr.layer, Ogr_feature);
@@ -385,17 +388,15 @@
     return ret;
-int write_attributes(int cat, const struct field_info *Fi,
+int write_attributes(dbDriver *driver, int cat, const struct field_info *Fi,
 		     OGRLayerH Ogr_layer, OGRFeatureH Ogr_feature)
     int j, ogrfieldnum;
     char buf[2000];
     int ncol, sqltype, ctype, ogrtype, more;
     const char *fidcol, *colname;
-    dbDriver *driver;
     dbTable *table;
     dbString dbstring;
-    dbHandle handle;
     dbColumn *column;
     dbCursor cursor;
     dbValue *value;
@@ -410,21 +411,7 @@
     db_init_string(&dbstring);
-    db_init_handle(&handle);
-    driver = db_start_driver(Fi->driver);
-    if (!driver) {
-	G_warning(_("Unable to start driver <%s>"), Fi->driver);
-	return -1;
-    db_set_handle(&handle, Fi->database, NULL);
-    if (db_open_database(driver, &handle) != DB_OK) {
-	G_warning(_("Unable to open database <%s> by driver <%s>"),
-		  Fi->database, Fi->driver);
-	return -1;
     /* read & set attributes */
     sprintf(buf, "SELECT * FROM %s WHERE %s = %d", Fi->table, Fi->key,
 	    cat);
@@ -509,7 +496,6 @@
     db_close_cursor (&cursor);
     db_free_string(&dbstring);
