[GRASS-SVN] r47956 - grass/branches/develbranch_6/lib/init
svn_grass at osgeo.org
Mon Aug 29 15:21:22 EDT 2011
Author: mmetz
Date: 2011-08-29 12:21:22 -0700 (Mon, 29 Aug 2011)
New Revision: 47956
grass/branches/develbranch_6/lib/init/init.bat
grass/branches/develbranch_6/lib/init/init.sh
lib/init: update location of GISRC file
Modified: grass/branches/develbranch_6/lib/init/init.bat
--- grass/branches/develbranch_6/lib/init/init.bat 2011-08-29 19:02:41 UTC (rev 47955)
+++ grass/branches/develbranch_6/lib/init/init.bat 2011-08-29 19:21:22 UTC (rev 47956)
@@ -31,7 +31,7 @@
set GIS_LOCK=1
set GRASS_VERSION=GRASS_VERSION_NUMBER
if "%HOME%"=="" set HOME=%USERPROFILE%
-set WINGISRC=%HOME%\.grassrc6
+set WINGISRC=%APPDATA%\grass6\rc
rem Make sure %GISRC% is set so g.dirseps will work
rem (not actually used)
set GISRC=junk
Modified: grass/branches/develbranch_6/lib/init/init.sh
--- grass/branches/develbranch_6/lib/init/init.sh 2011-08-29 19:02:41 UTC (rev 47955)
+++ grass/branches/develbranch_6/lib/init/init.sh 2011-08-29 19:21:22 UTC (rev 47956)
@@ -162,12 +162,21 @@
# Set the global grassrc file
if [ -n "$GRASS_BATCH_JOB" ] ; then
- GISRCRC="$HOME/.grassrc6.`uname -n`"
+ if [ "$MINGW" ] ; then
+ GISRCRC="$APPDATA/grassrc6/rc.`uname -n`"
+ else
+ GISRCRC="$HOME/.grass6/rc.`uname -n`"
if [ ! -f "$GISRCRC" ] ; then
- GISRCRC="$HOME/.grassrc6"
+ GISRCRC="$APPDATA/grass6/rc"
+ else
+ GISRCRC="$HOME/.grass6/rc"
fi
else
+ else
fi
# Set the session grassrc file
