[GRASS-SVN] r47973 - grass/branches/develbranch_6/lib/db/dbmi_client
Tue Aug 30 05:24:10 EDT 2011
Author: mmetz
Date: 2011-08-30 02:24:09 -0700 (Tue, 30 Aug 2011)
New Revision: 47973
   grass/branches/develbranch_6/lib/db/dbmi_client/shutdown.c
db_shutdown_driver(): clean up code, update documentation
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/shutdown.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/shutdown.c	2011-08-30 09:22:21 UTC (rev 47972)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/shutdown.c	2011-08-30 09:24:09 UTC (rev 47973)
@@ -14,12 +14,8 @@
 #include <stdlib.h>
-#ifdef __MINGW32__
-#include <process.h>
-#else
-#include <sys/wait.h>
-#endif
 #include <grass/dbmi.h>
+#include <grass/spawn.h>
 #include "macros.h"
@@ -28,19 +24,17 @@
   <b>Note:</b> the management of the memory for the driver structure
   probably should be handled differently.
-  db_start_driver() could take a pointer to driver structure as
-  an argument, instead of returning the pointer to allocated
-  then there would be no hidden free required
+  db_start_driver() could take a pointer to driver structure as an
+  argument, instead of returning the pointer to allocated then there
+  would be no hidden free required
-  \param driver db driver
+  \param driver pointer to dbDriver to be freed
-  \return status (?)
+  \return 0 on sucess
+  \return -1 on error
 int db_shutdown_driver(dbDriver * driver)
-#ifndef __MINGW32__
-    int pid;
-#endif
     int status;
 #ifdef __MINGW32__
