[GRASS-SVN] r47993 - grass/branches/releasebranch_6_4/raster/r.sun2
svn_grass at osgeo.org
Wed Aug 31 05:37:13 EDT 2011
Author: hamish
Date: 2011-08-31 02:37:12 -0700 (Wed, 31 Aug 2011)
New Revision: 47993
grass/branches/releasebranch_6_4/raster/r.sun2/main.c
grass/branches/releasebranch_6_4/raster/r.sun2/rsunlib.c
complete backport from devbr6 of main.c and rsunlib.c. non-functional lat= option becomes a no-op. (#1431)
Modified: grass/branches/releasebranch_6_4/raster/r.sun2/main.c
--- grass/branches/releasebranch_6_4/raster/r.sun2/main.c 2011-08-31 08:12:23 UTC (rev 47992)
+++ grass/branches/releasebranch_6_4/raster/r.sun2/main.c 2011-08-31 09:37:12 UTC (rev 47993)
@@ -123,11 +123,11 @@
int varCount_global = 0;
int bitCount_global = 0;
int arrayNumInt = 1;
-float **z = NULL, **o = NULL, **s = NULL, **li = NULL, **a = NULL, **la =
- NULL, **longitArray, **cbhr = NULL, **cdhr = NULL;
+float **z = NULL, **o = NULL, **s = NULL, **li = NULL, **a = NULL,
+ **latitudeArray = NULL, **longitudeArray, **cbhr = NULL, **cdhr = NULL;
double op, dp;
double invstepx, invstepy;
-double sr_min = 24., sr_max = 0., ss_min = 24., ss_max = 0.;
+double sunrise_min = 24., sunrise_max = 0., sunset_min = 24., sunset_max = 0.;
float **lumcl, **beam, **insol, **diff, **refl, **globrad;
unsigned char *horizonarray = NULL;
@@ -138,10 +138,10 @@
double xmin, xmax, ymin, ymax;
double declin, step, dist;
-double li_max = 0., li_min = 100., al_max = 0., al_min = 1.0, la_max = -90.,
- la_min = 90.;
+double linke_max = 0., linke_min = 100., albedo_max = 0., albedo_min = 1.0,
+ lat_max = -90., lat_min = 90.;
double offsetx = 0.5, offsety = 0.5;
-char *tt, *lt;
+char *ttime;
* double slope;
@@ -163,7 +163,7 @@
double horizonStep;
double ltime, tim, timo;
-double declination; /* Contains the negative of the declination at the chosen day */
+double declination; /* Contains the negative of the declination at the chosen day */
* double lum_C31_l, lum_C33_l;
@@ -172,10 +172,10 @@
double cbh, cdh;
double TOLER;
+/* 1852m/nm * 60nm/degree = 111120 m/deg */
#define DEGREEINMETERS 111120.
-int ll_correction = 0;
+int ll_correction = FALSE;
double coslatsq;
/* why not use G_distance() here which switches to geodesic/great
@@ -325,26 +325,16 @@
parm.latin->required = NO;
parm.latin->gisprompt = "old,cell,raster";
parm.latin->description =
- _("Name of the latitudes input raster map [decimal degrees]");
+ _("Name of input raster map containing latitudes [decimal degrees]");
parm.latin->guisection = _("Input_options");
- if (parm.latin->answer == NULL) {
- parm.lat = G_define_option();
- parm.lat->key = "lat";
- parm.lat->type = TYPE_DOUBLE;
- parm.lat->required = NO;
- parm.lat->description =
- _("A single value of latitude [decimal degrees]");
- parm.lat->guisection = _("Input_options");
parm.longin = G_define_option();
parm.longin->key = "longin";
parm.longin->type = TYPE_STRING;
parm.longin->required = NO;
parm.longin->gisprompt = "old,cell,raster";
parm.longin->description =
- _("Name of the longitude input raster map [decimal degrees]");
+ _("Name of input raster map containing longitudes [decimal degrees]");
parm.longin->guisection = _("Input_options");
parm.coefbh = G_define_option();
@@ -435,7 +425,6 @@
_("Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/irradiation raster map [Wh.m-2.day-1] (mode 2)");
parm.glob_rad->guisection = _("Output_options");
parm.day = G_define_option();
parm.day->key = "day";
parm.day->type = TYPE_INTEGER;
@@ -504,7 +493,16 @@
parm.civilTime->description =
_("Civil time zone value, if none, the time will be local solar time");
+ /* remove for GRASS 7 */
+ parm.lat = G_define_option();
+ parm.lat->key = "lat";
+ parm.lat->type = TYPE_DOUBLE;
+ parm.lat->required = NO;
+ parm.lat->description =
+ _("This does nothing. It is retained for backwards compatibility");
+ parm.lat->guisection = _("Unused");
flag.shade = G_define_flag();
flag.shade->key = 's';
flag.shade->description =
@@ -544,42 +542,41 @@
saveMemory = flag.saveMemory->answer;
- civiltime = parm.civilTime->answer;
elevin = parm.elevin->answer;
aspin = parm.aspin->answer;
slopein = parm.slopein->answer;
linkein = parm.linkein->answer;
albedo = parm.albedo->answer;
latin = parm.latin->answer;
+ longin = parm.longin->answer;
+ civiltime = parm.civilTime->answer;
if (civiltime != NULL) {
- setUseCivilTime(1);
- longin = parm.longin->answer;
+ setUseCivilTime(TRUE);
- if (longin == NULL) {
- G_fatal_error(_("You must give the longitude raster if you use civil time"));
+ if (longin == NULL)
+ G_fatal_error(
+ _("You must give the longitude raster if you use civil time"));
- sscanf(parm.civilTime->answer, "%lf", &civilTime);
+ if (sscanf(parm.civilTime->answer, "%lf", &civilTime) != 1)
+ G_fatal_error(_("Error reading civil time zone value"));
+ if (civilTime < -24. || civilTime > 24.)
+ G_fatal_error(_("Invalid civil time zone value"));
/* Normalize if somebody should be weird enough to give more than +- 12
* hours offset. */
- civilTime -= 24 * ((int)(civilTime / 24.));
- if (civilTime < -12.) {
+ if (civilTime < -12.)
civilTime += 24.;
- else if (civilTime > 12.) {
+ else if (civilTime > 12.)
civilTime -= 24;
else {
- setUseCivilTime(0);
+ setUseCivilTime(FALSE);
coefbh = parm.coefbh->answer;
coefdh = parm.coefdh->answer;
incidout = parm.incidout->answer;
@@ -595,12 +592,12 @@
G_fatal_error(_("insol_time and incidout are incompatible options"));
sscanf(parm.day->answer, "%d", &day);
- sscanf(parm.step->answer, "%lf", &step);
- if (parm.step->answer != NULL) {
- if (sscanf(parm.step->answer, "%lf", &step) != 1)
- G_fatal_error(_("Error reading time step size"));
+ if (sscanf(parm.step->answer, "%lf", &step) != 1)
+ G_fatal_error(_("Error reading time step size"));
+ if (step <= 0.0 || step > 24.0)
+ G_fatal_error(_("Invalid time step size"));
if (parm.horizonstep->answer != NULL) {
if (sscanf(parm.horizonstep->answer, "%lf", &horizonStep) != 1)
G_fatal_error(_("Error reading horizon step size"));
@@ -613,17 +610,18 @@
G_fatal_error(_("If you use the horizon option you must also set the 'horizonstep' parameter."));
- tt = parm.ltime->answer;
+ ttime = parm.ltime->answer;
if (parm.ltime->answer != NULL) {
if (insol_time != NULL)
G_fatal_error(_("Time and insol_time are incompatible options"));
G_message(_("Mode 1: instantaneous solar incidence angle & irradiance using a set local time"));
sscanf(parm.ltime->answer, "%lf", &timo);
else {
if (incidout != NULL)
G_fatal_error(_("incidout requires time parameter to be set"));
G_message(_("Mode 2: integrated daily irradiation for a given day of the year"));
@@ -649,15 +647,6 @@
sscanf(parm.lin->answer, "%lf", &singleLinke);
if (parm.albedo->answer == NULL)
sscanf(parm.alb->answer, "%lf", &singleAlbedo);
- lt = parm.lat->answer;
- * if (parm.lat->answer != NULL)
- * sscanf(parm.lat->answer, "%lf", &latitude);
- /* HB 6/2008: why is the above commented out? instead of sscanf, maybe nicer to use:
- G_scan_lat(parm.lat->answer, &latitude);
- MN 2/2009: latitude doesn't exist! also G_scan_lat() does not exist in GRASS
if (parm.slopein->answer == NULL)
sscanf(parm.slope->answer, "%lf", &singleSlope);
@@ -700,12 +689,7 @@
declination = -declin;
- * if (lt != NULL)
- * latitude = -latitude * deg2rad;
- if (tt != 0) {
+ if (ttime != 0) {
/* Shadow for just one time during the day */
if (horizon == NULL) {
arrayNumInt = 1;
@@ -721,7 +705,7 @@
- if (tt != NULL) {
+ if (ttime != NULL) {
tim = (timo - 12) * 15;
/* converting to degrees */
@@ -732,20 +716,24 @@
/* conv. to radians */
- /* Set up parameters for projection to lat/long if necessary */
- if (latin == NULL && lt == NULL && (G_projection() != PROJECTION_LL)) {
+ /* Set up parameters for projection to lat/long if necessary */
+ /* we need to do this even if latin= and longin= were given because
+ rsunlib's com_par() needs iproj and oproj */
+ if ((G_projection() != PROJECTION_LL)) {
struct Key_Value *in_proj_info, *in_unit_info;
if ((in_proj_info = G_get_projinfo()) == NULL)
- G_fatal_error
- (_("Can't get projection info of current location: please set latitude via 'lat' or 'latin' option!"));
+ G_fatal_error(
+ _("Can't get projection info of current location"));
if ((in_unit_info = G_get_projunits()) == NULL)
- G_fatal_error(_("Can't get projection units of current location"));
+ G_fatal_error(
+ _("Can't get projection units of current location"));
if (pj_get_kv(&iproj, in_proj_info, in_unit_info) < 0)
- G_fatal_error(_("Can't get projection key values of current location"));
+ G_fatal_error(
+ _("Can't get projection key values of current location"));
G_free_key_value(in_proj_info);
G_free_key_value(in_unit_info);
@@ -758,15 +746,23 @@
G_fatal_error(_("Unable to set up lat/long projection parameters"));
+ if ((latin != NULL || longin != NULL) && (G_projection() == PROJECTION_LL))
+ G_warning(_("latin and longin raster maps have no effect when in a Lat/Lon location"));
+ /* true about longin= when civiltime is used? */
+ /* civiltime needs longin= but not latin= for non-LL projections -
+ better would be it just use pj_proj() if it needs those?? */
+ if (latin != NULL && longin == NULL)
+ G_fatal_error(_("Both latin and longin raster maps must be given, or neither"));
/**********end of parser - ******************************/
- if ((G_projection() == PROJECTION_LL)) {
- ll_correction = 1;
- G_debug(3, "calculate starts...");
+ if ((G_projection() == PROJECTION_LL))
+ ll_correction = TRUE;
+ G_debug(3, "calculate() starts...");
calculate(singleSlope, singleAspect, singleAlbedo, singleLinke, gridGeom);
- G_debug(3, "OUTGR starts...");
+ G_debug(3, "OUTGR() starts...");
OUTGR();
exit(EXIT_SUCCESS);
@@ -784,8 +780,8 @@
FCELL *rast1 = NULL, *rast2 = NULL;
static FCELL **horizonbuf;
unsigned char *horizonpointer;
- int fd1 = -1, fd2 = -1, fd3 = -1, fd4 = -1, fd5 = -1, fd6 = -1, fd7 =
- -1, row, row_rev;
+ int fd1 = -1, fd2 = -1, fd3 = -1, fd4 = -1, fd5 = -1, fd6 = -1,
+ fd7 = -1, row, row_rev;
static int *fd_shad;
int fr1 = -1, fr2 = -1;
int l, i, j;
@@ -876,10 +872,10 @@
if (latin != NULL) {
cell6 = G_allocate_f_raster_buf();
- if (la == NULL) {
- la = (float **)G_malloc(sizeof(float *) * (numRows));
+ if (latitudeArray == NULL) {
+ latitudeArray = (float **)G_malloc(sizeof(float *) * (numRows));
for (l = 0; l < numRows; l++)
- la[l] = (float *)G_malloc(sizeof(float) * (n));
+ latitudeArray[l] = (float *)G_malloc(sizeof(float) * (n));
if ((mapset = G_find_cell2(latin, "")) == NULL)
G_fatal_error(_("Raster map <%s> not found"), latin);
@@ -888,9 +884,9 @@
if (longin != NULL) {
cell7 = G_allocate_f_raster_buf();
- longitArray = (float **)G_malloc(sizeof(float *) * (numRows));
+ longitudeArray = (float **)G_malloc(sizeof(float *) * (numRows));
- longitArray[l] = (float *)G_malloc(sizeof(float) * (n));
+ longitudeArray[l] = (float *)G_malloc(sizeof(float) * (n));
if ((mapset = G_find_cell2(longin, "")) == NULL)
G_fatal_error(_("Raster map <%s> not found"), longin);
@@ -931,7 +927,7 @@
fd_shad = (int *)G_malloc(sizeof(int) * arrayNumInt);
- * if(tt != NULL)
+ * if(ttime != NULL)
* horizonbuf[0]=G_allocate_f_raster_buf();
@@ -1040,16 +1036,16 @@
if (!G_is_f_null_value(cell6 + j))
- la[rowrevoffset][j] = (float)cell6[j];
+ latitudeArray[rowrevoffset][j] = (float)cell6[j];
else
- la[rowrevoffset][j] = UNDEFZ;
+ latitudeArray[rowrevoffset][j] = UNDEFZ;
if (!G_is_f_null_value(cell7 + j))
- longitArray[rowrevoffset][j] = (float)cell7[j];
+ longitudeArray[rowrevoffset][j] = (float)cell7[j];
else
- longitArray[rowrevoffset][j] = UNDEFZ;
+ longitudeArray[rowrevoffset][j] = UNDEFZ;
if (coefbh != NULL) {
@@ -1140,7 +1136,7 @@
z[i][j] = UNDEFZ;
if (albedo != NULL && a[i][j] == UNDEFZ)
z[i][j] = UNDEFZ;
- if (latin != NULL && la[i][j] == UNDEFZ)
+ if (latin != NULL && latitudeArray[i][j] == UNDEFZ)
z[i][j] = UNDEFZ;
if (coefbh != NULL && cbhr[i][j] == UNDEFZ)
z[i][j] = UNDEFZ;
@@ -1334,7 +1330,7 @@
com_par(sunGeom, sunVarGeom, gridGeom, latitude, longitude);
- if (tt != NULL) { /*irradiance */
+ if (ttime != NULL) { /*irradiance */
s0 = lumcline2(sunGeom, sunVarGeom, sunSlopeGeom, gridGeom,
horizonpointer);
@@ -1809,7 +1805,8 @@
for (i = 0; i < n; i++) {
if (useCivilTime()) {
- longitTime = -longitArray[arrayOffset][i] / 15.;
+ /* sun travels 15deg per hour, so 1 TZ every 15 deg and 15 TZs * 24hrs = 360deg */
+ longitTime = -longitudeArray[arrayOffset][i] / 15.;
gridGeom.xg0 = gridGeom.xx0 = (double)i *gridGeom.stepx;
@@ -1840,42 +1837,49 @@
if (linkein != NULL) {
sunRadVar.linke = li[arrayOffset][i];
- li_max = AMAX1(li_max, sunRadVar.linke);
- li_min = AMIN1(li_min, sunRadVar.linke);
+ linke_max = AMAX1(linke_max, sunRadVar.linke);
+ linke_min = AMIN1(linke_min, sunRadVar.linke);
if (albedo != NULL) {
sunRadVar.alb = a[arrayOffset][i];
- al_max = AMAX1(al_max, sunRadVar.alb);
- al_min = AMIN1(al_min, sunRadVar.alb);
+ albedo_max = AMAX1(albedo_max, sunRadVar.alb);
+ albedo_min = AMIN1(albedo_min, sunRadVar.alb);
- latitude = la[arrayOffset][i];
- la_max = AMAX1(la_max, latitude);
- la_min = AMIN1(la_min, latitude);
+ latitude = latitudeArray[arrayOffset][i];
+ lat_max = AMAX1(lat_max, latitude);
+ lat_min = AMIN1(lat_min, latitude);
latitude *= deg2rad;
- /* MN 2/2009: should it be??
+ if (longin != NULL) {
+ longitude = longitudeArray[arrayOffset][i];
+ /* lon_max = AMAX1(lon_max, longitude); */
+ /* lon_min = AMIN1(lon_min, longitude); */
+ longitude *= deg2rad;
- longitude = gridGeom.xp;
- latitude = gridGeom.yp;
+ if (latin == NULL || longin == NULL) {
+ /* if either is missing we have to calc both from current projection */
+ longitude = gridGeom.xp;
+ latitude = gridGeom.yp;
- if (pj_do_proj(&longitude, &latitude, &iproj, &oproj) < 0) {
- G_fatal_error("Error in pj_do_proj");
+ if (pj_do_proj(&longitude, &latitude, &iproj, &oproj) < 0) {
+ G_fatal_error("Error in pj_do_proj");
- latitude *= deg2rad;
- longitude *= deg2rad;
+ latitude *= deg2rad;
else { /* ll projection */
@@ -1891,7 +1895,7 @@
cos_v = cos(M_PI / 2 + sunSlopeGeom.aspect);
sin_v = sin(M_PI / 2 + sunSlopeGeom.aspect);
- if (tt != NULL)
sunGeom.timeAngle = tim;
gridGeom.sinlat = sin(-latitude);
@@ -1911,10 +1915,10 @@
if ((incidout != NULL) || someRadiation) {
com_par_const(longitTime, &sunGeom, &gridGeom);
- sr_min = AMIN1(sr_min, sunGeom.sunrise_time);
- sr_max = AMAX1(sr_max, sunGeom.sunrise_time);
- ss_min = AMIN1(ss_min, sunGeom.sunset_time);
- ss_max = AMAX1(ss_max, sunGeom.sunset_time);
+ sunrise_min = AMIN1(sunrise_min, sunGeom.sunrise_time);
+ sunrise_max = AMAX1(sunrise_max, sunGeom.sunrise_time);
+ sunset_min = AMIN1(sunset_min, sunGeom.sunset_time);
+ sunset_max = AMAX1(sunset_max, sunGeom.sunset_time);
@@ -1984,7 +1988,7 @@
day);
hist.edlinecnt = 2;
- if (tt != NULL) {
sprintf(hist.edhist[hist.edlinecnt],
" Local (solar) time (decimal hr.): %.4f", timo);
hist.edlinecnt++;
@@ -1999,17 +2003,12 @@
" Declination (rad): %f", -declination);
hist.edlinecnt += 3;
- if (lt != NULL)
- sprintf(hist.edhist[hist.edlinecnt],
- " Latitude (deg): %.4f",
- -latitude * rad2deg);
- else
- " Latitude min-max(deg): %.4f - %.4f",
- la_min, la_max);
+ sprintf(hist.edhist[hist.edlinecnt],
+ " Latitude min-max(deg): %.4f - %.4f",
+ lat_min, lat_max);
hist.edlinecnt++;
- if (tt != NULL) {
" Sunrise time (hr.): %.2f",
@@ -2023,16 +2022,16 @@
else {
" Sunrise time min-max (hr.): %.2f - %.2f",
- sr_min, sr_max);
+ sunrise_min, sunrise_max);
sprintf(hist.edhist[hist.edlinecnt + 1],
" Sunset time min-max (hr.): %.2f - %.2f",
- ss_min, ss_max);
+ sunset_min, sunset_max);
sprintf(hist.edhist[hist.edlinecnt + 2],
" Time step (hr.): %.4f", step);
- if (incidout != NULL || tt != NULL) {
+ if (incidout != NULL || ttime != NULL) {
" Solar altitude (deg): %.4f",
sunVarGeom.solarAltitude * rad2deg);
@@ -2049,7 +2048,7 @@
else
" Linke turbidity factor min-max: %.1f-%.1f",
- li_min, li_max);
+ linke_min, linke_max);
hist.edlinecnt++;
if (albedo == NULL)
@@ -2059,7 +2058,7 @@
else
" Ground albedo min-max: %.3f-%.3f",
- al_min, al_max);
+ albedo_min, albedo_max);
hist.edlinecnt++;
Modified: grass/branches/releasebranch_6_4/raster/r.sun2/rsunlib.c
--- grass/branches/releasebranch_6_4/raster/r.sun2/rsunlib.c 2011-08-31 08:12:23 UTC (rev 47992)
+++ grass/branches/releasebranch_6_4/raster/r.sun2/rsunlib.c 2011-08-31 09:37:12 UTC (rev 47993)
@@ -385,18 +385,17 @@
(horizonHeight > sunVarGeom->solarAltitude);
if (!sunVarGeom->isShadow) {
- if (z_orig != UNDEFZ)
- s = sunSlopeGeom->lum_C31_l * cos(-sungeom->timeAngle - sunSlopeGeom->longit_l) + sunSlopeGeom->lum_C33_l;
+ /* if (z_orig != UNDEFZ) {
+ s = sunSlopeGeom->lum_C31_l
+ * cos(-sungeom->timeAngle - sunSlopeGeom->longit_l)
+ + sunSlopeGeom->lum_C33_l;
+ } else {
+ s = sunVarGeom->sinSolarAltitude;
- else
- s = sunVarGeom->sinSolarAltitude;
- s = sunSlopeGeom->lum_C31_l * cos(-sungeom->timeAngle - sunSlopeGeom->longit_l) + sunSlopeGeom->lum_C33_l; /* Jenco */
+ + sunSlopeGeom->lum_C33_l; /* Jenco */
} /* End if useHorizonData() */
@@ -412,35 +411,32 @@
else {
+ } else {
- else
else {
+ } else {
- else
/* if (s <= 0) return UNDEFZ; ?? */
