[GRASS-SVN] r47996 - grass/trunk/gui/wxpython/xml
Wed Aug 31 06:57:17 EDT 2011
Author: mmetz
Date: 2011-08-31 03:57:17 -0700 (Wed, 31 Aug 2011)
New Revision: 47996
   grass/trunk/gui/wxpython/xml/menudata.xml
update menudata.xml
Modified: grass/trunk/gui/wxpython/xml/menudata.xml
--- grass/trunk/gui/wxpython/xml/menudata.xml	2011-08-31 10:47:51 UTC (rev 47995)
+++ grass/trunk/gui/wxpython/xml/menudata.xml	2011-08-31 10:57:17 UTC (rev 47996)
@@ -2437,6 +2437,13 @@
 	  <command>v.rast.stats</command>
 	</menuitem>
 	<menuitem>
+	  <label>Update area attributes from vector</label>
+	  <help>Calculates points in polygons and univariate statistics from points based on vector polygon map and uploads statistics to new attribute columns.</help>
+	  <keywords>vector,statistics</keywords>
+	  <handler>OnMenuCmd</handler>
+	  <command>v.vect.stats</command>
+	</menuitem>
+	<menuitem>
 	  <label>Update point attributes from areas</label>
 	  <help>Uploads vector values at positions of vector points to the table.</help>
 	  <keywords>vector,database,attribute table</keywords>
