[GRASS-SVN] r48004 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Aug 31 12:29:25 EDT 2011
Author: annakrat
Date: 2011-08-31 09:29:25 -0700 (Wed, 31 Aug 2011)
New Revision: 48004
grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
grass/trunk/gui/wxpython/gui_modules/toolbars.py
wxNviz: panning added (not true panning, just something similar)
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py 2011-08-31 16:14:30 UTC (rev 48003)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py 2011-08-31 16:29:25 UTC (rev 48004)
@@ -431,6 +431,10 @@
self.render['quick'] = True
self.Refresh(False)
+ if self.mouse['use'] == 'pan':
+ self.FocusPanning(event)
event.Skip()
def Pixel2Cell(self, (x, y)):
@@ -520,7 +524,11 @@
self.saveHistory = True
self.render['quick'] = False
self.Refresh(False)
+ elif self.mouse['use'] == 'pan':
+ self.saveHistory = True
+ self.render['quick'] = False
+ self.Refresh(False)
elif self.mouse['use'] == 'zoom':
self.DoZoom(zoomtype = self.zoomtype, pos = self.mouse['end'])
event.Skip()
@@ -538,7 +546,76 @@
self.parent.OnAddLegend(None)
elif self.dragid > 100:
self.parent.OnAddText(None)
+ def FocusPanning(self, event):
+ """!Simulation of panning using focus"""
+ size = self.GetClientSizeTuple()
+ id1, x1, y1, z1 = self._display.GetPointOnSurface(
+ self.mouse['tmp'][0], size[1] - self.mouse['tmp'][1])
+ id2, x2, y2, z2 = self._display.GetPointOnSurface(
+ event.GetX(), size[1] - event.GetY())
+ if id1 and id1 == id2:
+ dx, dy, dz = x2 - x1, y2 - y1, z2 - z1
+ focus = self.iview['focus']
+ focus['x'], focus['y'], focus['z'] = self._display.GetFocus()
+ focus['x'] -= dx
+ focus['y'] -= dy
+ focus['z'] -= dz
+ #update properties
+ evt = wxUpdateView(zExag = False)
+ wx.PostEvent(self, evt)
+ self.mouse['tmp'] = event.GetPositionTuple()
+ self.render['quick'] = True
+ def HorizontalPanning(self, event):
+ """!Move all layers in horizontal (x, y) direction.
+ Currently not used.
+ dx, dy = x2 - x1, y2 - y1
+ # find raster and volume
+ for item in self.layers:
+ mapLayer = self.tree.GetPyData(item)[0]['maplayer']
+ data = self.tree.GetPyData(item)[0]['nviz']
+ if mapLayer.GetType() == 'raster':
+ data['surface']['position']['x'] += dx
+ data['surface']['position']['y'] += dy
+ data['surface']['position']['update'] = None
+ evt = wxUpdateProperties(data = data)
+ if event.CmdDown() and id1 == data['surface']['object']['id']:
+ break
+ elif mapLayer.GetType() == '3d-raster':
+ if 'x' not in data['volume']['position']:
+ data['volume']['position']['x'] = 0
+ data['volume']['position']['y'] = 0
+ data['volume']['position']['z'] = 0
+ data['volume']['position']['x'] += dx
+ data['volume']['position']['y'] += dy
+ data['volume']['position']['update'] = None
def DragItem(self, id, event):
"""!Drag an overlay decoration item
@@ -1215,10 +1292,10 @@
errorMsg = _("Unable to unload 3d raster map")
successMsg = _("3d raster map")
- if 'object' not in data[nvizType]:
+ try:
+ id = data[nvizType]['object']['id']
+ except KeyError:
return
- else:
- id = data[nvizType]['object']['id']
if unloadFn(id) == 0:
self.log.WriteError("%s <%s>" % (errorMsg, layer.name))
@@ -1778,22 +1855,18 @@
- for datatype in ['surface', 'volume']:
- if 'object' not in data[datatype]:
- return -1
- for datatype in ['points', 'lines']:
- if 'object' not in data['vector'][datatype]:
- return -1
- if type == 'raster':
- return data['surface']['object']['id']
- elif type == 'vector':
- if vsubtyp == 'vpoint':
- return data['vector']['points']['object']['id']
- elif vsubtyp == 'vline':
- return data['vector']['lines']['object']['id']
- elif type == '3d-raster':
- return data['volume']['object']['id']
+ try:
+ if type == 'raster':
+ return data['surface']['object']['id']
+ elif type == 'vector':
+ if vsubtyp == 'vpoint':
+ return data['vector']['points']['object']['id']
+ elif vsubtyp == 'vline':
+ return data['vector']['lines']['object']['id']
+ elif type == '3d-raster':
+ return data['volume']['object']['id']
+ except KeyError:
+ return -1
return -1
def ReloadLayersData(self):
Modified: grass/trunk/gui/wxpython/gui_modules/toolbars.py
--- grass/trunk/gui/wxpython/gui_modules/toolbars.py 2011-08-31 16:14:30 UTC (rev 48003)
+++ grass/trunk/gui/wxpython/gui_modules/toolbars.py 2011-08-31 16:29:25 UTC (rev 48004)
@@ -375,8 +375,7 @@
def Enable2D(self, enabled):
"""!Enable/Disable 2D display mode specific tools"""
- for tool in (self.pan,
- self.zoommenu,
+ for tool in (self.zoommenu,
self.analyze,
self.printmap):
self.EnableTool(tool, enabled)
